[petsc-users] MUMPS with symmetric matrices
Gianluca Meneghello gianmail at gmail.com
Wed Nov 4 15:06:15 CST 2015
That is correct... I will try with -pc_type cholesky and use
MatTransposeMatMult.
Using cholesky I do not need to specify mumps as a solver, am I right?
A is a linearization of the Navier Stokes equation.
Thanks!
Gianluca
On Wed, Nov 4, 2015 at 12:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> Gianluca Meneghello <gianmail at gmail.com> writes:
> > Dear all,
> > I am trying to solve a linear system for a symmetric matrix with MUMPS.
> > Is there a way to tell MUMPS that the matrix is indeed symmetric?
> > The way I build the matrix is
> > Mat A,AT,ATA
> > MatHermitianTranspose(A,MAT_INITIAL_MATRIX,&AT);
> > MatMatMult(AT,A,MAT_INITIAL_MATRIX,7,&ATA);
> > MatSetOption(ATA,MAT_SYMMETRY_ETERNAL,PETSC_TRUE);
> > but MUMPS returns
> > L U Solver for unsymmetric matrices
> You're probably using -pc_type lu rather than -pc_type cholesky.
> > Of course, any suggestion of a better/more efficient way to build ATA or
> > store only half of it, that is more than welcome.
> Where does A come from?
> There is MatTransposeMatMult()
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151104/cf42e9a8/attachment.html>
