[petsc-users] MUMPS with symmetric matrices
Gianluca Meneghello gianmail at gmail.com
Wed Nov 4 17:37:47 CST 2015
It is a discretization of the differential operator, of which I would need
the inverse (or LU decomposition). My goal is frequency response
(resolvant) analysis of the linearized Navier-Stokes operator.
There was a reason I was not using MatTransposeMatMult, that is the matrix
is complex and I would need MatTransposeHemitianMatMult (or something like
that). It seems to me that is not available (or does MatTransposeMatMult
compute the Hermitian transpose?)
Any suggestion is of course welcome!
Thanks
Gianluca
On Wed, Nov 4, 2015 at 1:16 PM, Jed Brown <jed at jedbrown.org> wrote:
> Gianluca Meneghello <gianmail at gmail.com> writes:
> > That is correct... I will try with -pc_type cholesky and use
> > MatTransposeMatMult.
> > Using cholesky I do not need to specify mumps as a solver, am I right?
> Of course you do.
> > A is a linearization of the Navier Stokes equation.
> Of the differential operator, its inverse, or a map from some parameters
> to observations?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151104/e110269d/attachment.html>
