[petsc-users] Release canditate?
Fri Dec 11 22:40:45 CST 2015
> On Dec 11, 2015, at 10:35 PM, Éric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Le 2015-12-11 23:22, Barry Smith a écrit :
>>   Eric,
>>    Would it be possible for the release candidates to be a git repository branch or does it have to be a tarball? Generating and regenerating the
> for sure, if you want a maximum of RC testers, I think it should be a tarball...  In my book, a RC is eventually the final release so everything must be the same...
>> tarball is a time consuming process which is why we don't use release candidates, but if you are able to test off the git repository we could
> ok, but hmmm, why isn't it possible to automate the making of the tarball?
>> certainly "pre announce" releases and allow testing before the actual release.
> If tarballs are impossible, I would certainly take the time to test a pre-announce release.
  Ok, we'll try to make rc tarballs and announce them on petsc-announce before the real release.
   Thanks for the suggestion.
> btw, the petsc-announce mailing list is somewhat silent...
   We try to use it only for releases.
  Barry
> Thanks anyway to have evaluated the idea! :)
> Eric
>>   Barry
>>> On Dec 11, 2015, at 10:18 PM, Éric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
>>> Hi,
>>> we just waited since petsc 3.5.4 until 3.6.3 to retrieve a working petsc for our usages (got bugs with 3.6.1, 3.6.2)
>>> Now, just discovered 3.6.3 have a bug with mkl_pardiso... :/
>>> We will have to wait until 3.6.4 (or patch the source with 3f7bb31...
>>> I was thinking that it could have been otherwise if release candidate packages would have been made available for anyone to test...
>>> and to give you feedback... and then a better official release...
>>> We can easily install it here and use the RC with our non-regression tests.
>>> Maybe other users would be interested, like me, to test the release candidates?
>>> Does that sounds interesting to you?
>>> Thanks,
>>> Eric
