[petsc-users] Floating point exception
Sat Apr 25 20:26:19 CDT 2015
On Sat, Apr 25, 2015 at 8:23 PM, Danyang Su <danyang.su at gmail.com> wrote:
> On 15-04-25 06:03 PM, Barry Smith wrote:
>>    If this is what you got in your last run
>>       at ../../gas_advection/velocity_g.F90:1344
>>> 1344                                        cinfrt = cinfrt_dg(i1) *
>>> diff(ic,idim)                                      !diff is a very small
>>> value, e.g., 1.0d-316
>>    then it is still catching floating point underflow, which we do not
>> want. This means either the change I suggested you make in the fp.c code
>> didn't work or it actually uses a different floating point trap than that
>> one.  BTW: absurd numbers like 1.0d-316 are often a symptom of
>> uninitialized data; could that be a problem that diff is not filled
>> correctly for all the ic, idim you are using?
>>     This going round and round is very frustrating and a waste of time.
>> You need to be more proactive yourself and explore the code and poke around
>> to figure out how to solve the problem.
>>    Please email $PETSC_DIR/$PETSC_ARCH/include/petscvariables.h so I can
>> see what FP trap is being used on your machine.
>> Barry
> Do you mean $PETSC_DIR/$PETSC_ARCH/conf/petscvariables? Otherwise I cannot
> find this file.
Its include/petscconf.h
> Do I need to reconfigure PETSc after changing the code you mentioned?
No, but you need to rebuild.
   Matt
> Danyang
>>  On Apr 25, 2015, at 2:24 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> On 15-04-25 11:55 AM, Barry Smith wrote:
>>>> On Apr 25, 2015, at 1:51 PM, Danyang Su <danyang.su at gmail.com>
>>>>>   wrote:
>>>>> On 15-04-25 11:32 AM, Barry Smith wrote:
>>>>>     I told you this yesterday.
>>>>>>    It is probably stopping here on a harmless underflow. You need to
>>>>>> edit the PETSc code to not worry about underflow.
>>>>>> Edit the file /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c and
>>>>>> locate
>>>>>> #elif defined PETSC_HAVE_XMMINTRIN_H
>>>>>>     _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT);
>>>>>> #else
>>>>>> change it to
>>>>>>     _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT | _MM_MASK_UNDERFLOW);
>>>>>> #else
>>>>>>   Then run make gnumake in the PETSc directory to compile the new
>>>>>> version. Now link and run the program again with -fp_trap and see where it
>>>>>> gets stuck this time.
>>>>>>    Did you do this?
>>>>>>   Barry
>>>>>>  Yes, I did change the code in fp.c and run 'make gnumake' in the
>>>>> PETSc directory. I just did a double check and ran make gnumake again and
>>>>> got the following information this time.
>>>>> dsu at nwmop:~/Soft/PETSc/petsc-3.5.2$
>>>>>   make gnumake
>>>>> Building PETSc using GNU Make with 10 build threads
>>>>> make[1]: Entering directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>>>> make[1]: Nothing to be done for `all'.
>>>>> make[1]: Leaving directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>>>> Then I recompiled the codes, ran with -fp_trap and still got the
>>>>> following error
>>>>> Backtrace for this error:
>>>>> Note: The EXACT line numbers in the stack are not available,
>>>>> [2]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>> function
>>>>> [2]PETSC ERROR:       is given.
>>>>> [2]PETSC ERROR: [2] PetscDefaultFPTrap line 379
>>>>>       INSTEAD the line number of the start of the function
>>>>> [3]PETSC ERROR:       is given.
>>>>> [3]PETSC ERROR: [3] PetscDefaultFPTrap line 379
>>>>> [2]PETSC ERROR: User provided function() line 0 in Unknown file
>>>>> trapped floating point error
>>>>> [3]PETSC ERROR: User provided function() line 0 in Unknown file
>>>>>      This is different then what you sent a few minutes ago where it
>>>> crashed in hypre.
>>>>     Anyways you need to use the -start_in_debugger business I sent in
>>>> the previous email to see the exact place the problem occurs.
>>>>  Here is the information shown on gdb screen
>>> Program received signal SIGFPE, Arithmetic exception.
>>> 0x00000000006c2bef in velocity_g (l_sufx=1, suffix=..., nmax=12,
>>> njamxc=34,
>>>      cinfradx=..., radial_coordx=.FALSE., _suffix=3)
>>> (gdb)
>>> After type cont on gdb screen, I got error information as below
>>> [1]PETSC ERROR: *** unknown floating point error occurred ***
>>> [1]PETSC ERROR: The specific exception can be determined by running in a
>>> debugger.  When the
>>> [1]PETSC ERROR: debugger traps the signal, the exception can be found
>>> with fetestexcept(0x3d)
>>> [1]PETSC ERROR: where the result is a bitwise OR of the following flags:
>>> [1]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8
>>> FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>>> [1]PETSC ERROR: Try option -start_in_debugger
>>> [1]PETSC ERROR: likely location of problem given in stack below
>>> [1]PETSC ERROR: ---------------------  Stack Frames
>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [1]PETSC ERROR:       INSTEAD the line number of the start of the
>>> function
>>> [1]PETSC ERROR:       is given.
>>> [1]PETSC ERROR: [1] PetscDefaultFPTrap line 379
>>> [1]PETSC ERROR: User provided function() line 0 in Unknown file trapped
>>> [0]PETSC ERROR: *** unknown floating point error occurred ***
>>> [0]PETSC ERROR: The specific exception can be determined by running in a
>>> debugger.  When the
>>> [0]PETSC ERROR: debugger traps the signal, the exception can be found
>>> [0]PETSC ERROR: where the result is a bitwise OR of the following flags:
>>> [0]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8
>>> [0]PETSC ERROR: Try option -start_in_debugger
>>> [0]PETSC ERROR: likely location of problem given in stack below
>>> Thanks,
>>> Danyang
>>>> Thanks,
>>>>> Danyang
>>>>>  On Apr 25, 2015, at 1:05 AM, Danyang Su <danyang.su at gmail.com>
>>>>>>>   wrote:
>>>>>>> Hi Barry and Satish,
>>>>>>> How can I get rid of unknown floating point error when a very small
>>>>>>> value is multiplied.
>>>>>>> e.g.,
>>>>>>> cinfrt_dg(i1) and diff(ic,idim) are  1.0250235986806329E-008
>>>>>>> 8.6178408169776945E-317 respectively,
>>>>>>> cinfrt = cinfrt_dg(i1) * diff(ic,idim)
>>>>>>> I get the following error when run with "-fp_trap
>>>>>>> -start_in_debugger".
>>>>>>> [2]PETSC ERROR: The specific exception can be determined by running
>>>>>>> in a debugger.  When the
>>>>>>> [2]PETSC ERROR: debugger traps the signal, the exception can be
>>>>>>> found with fetestexcept(0x3d)
>>>>>>> [2]PETSC ERROR:  cinfrt_dg(i1),diff(ic,idim)
>>>>>>> 1.0250235986806329E-008   8.6178408169776945E-317
>>>>>>> [2]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8
>>>>>>> [2]PETSC ERROR: Try option -start_in_debugger
>>>>>>> [2]PETSC ERROR: likely location of problem given in stack below
>>>>>>> Thanks,
>>>>>>> Danyang
>>>>>>> On 15-04-24 01:54 PM, Danyang Su wrote:
>>>>>>>  On 15-04-24 01:23 PM, Satish Balay wrote:
>>>>>>>>    c           4   1.0976214263087059E-067
>>>>>>>>> I don't think this number can be stored in a real*4.
>>>>>>>>> Satish
>>>>>>>>>  Thanks, Satish. It is caused by this number.
>>>>>>>>  On Fri, 24 Apr 2015, Danyang Su wrote:
>>>>>>>>>  On 15-04-24 11:12 AM, Barry Smith wrote:
>>>>>>>>>>  On Apr 24, 2015, at 1:05 PM, Danyang Su <danyang.su at gmail.com>
>>>>>>>>>>>>   wrote:
>>>>>>>>>>>> Hi All,
>>>>>>>>>>>> One of my case crashes because of floating point exception when
>>>>>>>>>>>> using 4
>>>>>>>>>>>> processors, as shown below. But if I run this case with 1
>>>>>>>>>>>> processor, it
>>>>>>>>>>>> works fine. I have tested the codes with around 100 cases up to
>>>>>>>>>>>> 768
>>>>>>>>>>>> processors, all other cases work fine. I just wonder if this
>>>>>>>>>>>> kind of error
>>>>>>>>>>>> is caused because of NaN in jacobi matrix, RHS or
>>>>>>>>>>>> preconditioner?
>>>>>>>>>>>>       Yes, almost for sure it is one of these places.
>>>>>>>>>>>      First run the bad case with -fp_trap  if all goes well
>>>>>>>>>>> you'll see the
>>>>>>>>>>> function where the FPE is generated. Then run also with
>>>>>>>>>>> -start_in_debugger
>>>>>>>>>>> and
>>>>>>>>>>> type cont in all four debugger windows. When the FPE happens the
>>>>>>>>>>> debugger
>>>>>>>>>>> should stop showing exactly where the FPE happens.
>>>>>>>>>>>     Barry
>>>>>>>>>>>  Hi Barry,
>>>>>>>>>> If run with -fp_trap -start_in_debugger, I got the following error
>>>>>>>>>> running in a
>>>>>>>>>> debugger.  When the
>>>>>>>>>> found with
>>>>>>>>>> fetestexcept(0x3d)
>>>>>>>>>> flags:
>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>>>>> available,
>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>>>>> function
>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>> [0]PETSC ERROR: [0] PetscDefaultFPTrap line 379
>>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in Unknown file
>>>>>>>>>> trapped
>>>>>>>>>> Program received signal SIGABRT: Process abort signal.
>>>>>>>>>> #0  0x7F4FEAB1C7D7
>>>>>>>>>> #1  0x7F4FEAB1CDDE
>>>>>>>>>> #2  0x7F4FE9E1AD3F
>>>>>>>>>> #3  0x7F4FE9E1ACC9
>>>>>>>>>> #4  0x7F4FE9E1E0D7
>>>>>>>>>> #5  0x7F4FEB0B6DCB
>>>>>>>>>> #6  0x7F4FEB0B1825
>>>>>>>>>> #7  0x7F4FEB0B817F
>>>>>>>>>> #8  0x7F4FE9E1AD3F
>>>>>>>>>> #9  0x6972C8 in tprfrtlc_ at tprfrtlc.F90:2393 (discriminator 3)
>>>>>>>>>> #10  0x4C6C87 in gcreact_ at gcreact.F90:678
>>>>>>>>>> #11  0x707E19 in initicrt_ at initicrt.F90:589
>>>>>>>>>> #12  0x4F42D0 in initprob_ at initprob.F90:430
>>>>>>>>>> #13  0x5AAF72 in driver_pc at driver_pc.F90:438
>>>>>>>>>> I checked the code at  tprfrtlc.F90:2393,
>>>>>>>>>>          realbuffer_gb(1:nvars) = (/time,(c(ic),ic=1,nc-1),     &
>>>>>>>>>>                                     (cx(ix),ix=1,nxout)/)
>>>>>>>>>> All the values (time, c, cx) are reasonable, as shown below. The
>>>>>>>>>> only
>>>>>>>>>> possibility is that realbuffer_gb is in declared as real*4 if
>>>>>>>>>> using sing
>>>>>>>>>> precision output while time, c, cx are declared in real*8. I have
>>>>>>>>>> a lot of
>>>>>>>>>> similar data conversion from real*8 to real*4 output, other code
>>>>>>>>>> does not
>>>>>>>>>> return error.
>>>>>>>>>>   time   0.0000000000000000
>>>>>>>>>>   c           1   9.9999999999999995E-008
>>>>>>>>>>   c           2   3.1555251077549618E-003
>>>>>>>>>>   c           3   7.1657814842179362E-008
>>>>>>>>>>   c           5   5.2879822292305797E-004
>>>>>>>>>>   c           6   9.9999999999999964E-005
>>>>>>>>>>   c           7   6.4055731968811337E-005
>>>>>>>>>>   c           8   3.4607572892578404E-020
>>>>>>>>>>   cx           1   3.4376650636008101E-005
>>>>>>>>>>   cx           2   7.3989678854017763E-012
>>>>>>>>>>   cx           3   9.5317170613607207E-012
>>>>>>>>>>   cx           4   2.2344525794718353E-015
>>>>>>>>>>   cx           5   3.0624685689695889E-008
>>>>>>>>>>   cx           6   1.0046157902783967E-007
>>>>>>>>>>   cx           7   1.5320169154914984E-004
>>>>>>>>>>   cx           8   8.6930292776346176E-014
>>>>>>>>>>   cx           9   3.5944267559348721E-005
>>>>>>>>>>   cx          10   3.0072645866951157E-018
>>>>>>>>>>   cx          11   2.3592486321095017E-013
>>>>>>>>>> Thanks,
>>>>>>>>>> Danyang
>>>>>>>>>>  I can check all the entries of jacobi matrix to see if the value
>>>>>>>>>>>> is valid,
>>>>>>>>>>>> but this seems not a good idea as it takes a long time to reach
>>>>>>>>>>>> this
>>>>>>>>>>>> point. If I restart the simulation from a specified time (e.g.,
>>>>>>>>>>>> 7.685 in
>>>>>>>>>>>> this case), then the error does not occur.
>>>>>>>>>>>> Would you please give me any suggestion on debugging this case?
>>>>>>>>>>>> Thanks and Regards,
>>>>>>>>>>>> Danyang
>>>>>>>>>>>> timestep:    2730 time: 7.665E+00 years   delt: 1.000E-02 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> timestep:    max.sia: 0.000E+00 tol.sia: 0.000E+00
>>>>>>>>>>>> timestep:    2731 time: 7.675E+00 years   delt: 1.000E-02 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> timestep:    2732 time: 7.685E+00 years   delt: 1.000E-02 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> timestep:    2733 time: 7.695E+00 years   delt: 1.000E-02 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> timestep:    2734 time: 7.705E+00 years   delt: 1.000E-02 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> Reduce time step for reactive transport
>>>>>>>>>>>> timestep:    2734 time: 7.700E+00 years   delt: 5.000E-03 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> timestep:    2734 time: 7.697E+00 years   delt: 2.500E-03 years
>>>>>>>>>>>> iter:  1
>>>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> [1]PETSC ERROR: Floating point exception
>>>>>>>>>>>> [2]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> [2]PETSC ERROR: Floating point exception
>>>>>>>>>>>> [2]PETSC ERROR: Vec entry at local location 0 is not-a-number
>>>>>>>>>>>> or infinite
>>>>>>>>>>>> at end of function: Parameter number 3
>>>>>>>>>>>> [2]PETSC ERROR: See
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>>>>>>> for trouble shooting.
>>>>>>>>>>>> [2]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: Vec entry at local location 0 is
>>>>>>>>>>>> not-a-number or infinite at end of function: Parameter number 3
>>>>>>>>>>>> [1]PETSC ERROR: See
>>>>>>>>>>>> [1]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>>>> [1]PETSC ERROR: ../min3p_thcm_petsc_dbg on a linux-gnu-dbg
>>>>>>>>>>>> named nwmop by
>>>>>>>>>>>> dsu Thu Apr 23 15:38:52 2015
>>>>>>>>>>>> [1]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg
>>>>>>>>>>>> --with-cc=gcc
>>>>>>>>>>>> --with-cxx=g++ --with-fc=gfortran --download-fblaslapack
>>>>>>>>>>>> --download-mpich
>>>>>>>>>>>> --download-mumps --download-hypre --download-superlu_dist
>>>>>>>>>>>> --download-metis
>>>>>>>>>>>> --download-parmetis --download-scalapack
>>>>>>>>>>>> [1]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/vec/vec/interface/rvector.c
>>>>>>>>>>>> ../min3p_thcm_petsc_dbg on a linux-gnu-dbg named nwmop by dsu
>>>>>>>>>>>> Thu Apr 23
>>>>>>>>>>>> 15:38:52 2015
>>>>>>>>>>>> [2]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg
>>>>>>>>>>>> --with-cc=gcc
>>>>>>>>>>>> --download-mpich
>>>>>>>>>>>> --download-metis
>>>>>>>>>>>> [2]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: #2 PCApply() line 442 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>>> [2]PETSC ERROR: #3 KSP_PCApply() line 230 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/include/petsc-private/kspimpl.h
>>>>>>>>>>>> [1]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itres.c
>>>>>>>>>>>> [2]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>>>> [1]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/impls/gmres/gmres.c
>>>>>>>>>>>> [2]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>>>> [2]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>> [1]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>>>> ^C[mpiexec at nwmop] Sending Ctrl-C to processes as requested
>>>>>>>>>>>> [mpiexec at nwmop] Press Ctrl-C again to force abort
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150425/32e6e582/attachment-0001.html>
