[petsc-users] Floating point exception
Danyang Su danyang.su at gmail.com
Sat Apr 25 20:31:18 CDT 2015
On 15-04-25 06:26 PM, Matthew Knepley wrote:
> On Sat, Apr 25, 2015 at 8:23 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     On 15-04-25 06:03 PM, Barry Smith wrote:
>            If this is what you got in your last run
>                  at ../../gas_advection/velocity_g.F90:1344
>             1344                                        cinfrt =
>             cinfrt_dg(i1) * diff(ic,idim)             !diff is a very
>             small value, e.g., 1.0d-316
>            then it is still catching floating point underflow, which
>         we do not want. This means either the change I suggested you
>         make in the fp.c code didn't work or it actually uses a
>         different floating point trap than that one.  BTW: absurd
>         numbers like 1.0d-316 are often a symptom of uninitialized
>         data; could that be a problem that diff is not filled
>         correctly for all the ic, idim you are using?
>             This going round and round is very frustrating and a waste
>         of time. You need to be more proactive yourself and explore
>         the code and poke around to figure out how to solve the problem.
>            Please email
>         $PETSC_DIR/$PETSC_ARCH/include/petscvariables.h so I can see
>         what FP trap is being used on your machine.
>         Barry
>     Do you mean $PETSC_DIR/$PETSC_ARCH/conf/petscvariables? Otherwise
>     I cannot find this file.
> Its include/petscconf.h
>     Do I need to reconfigure PETSc after changing the code you mentioned?
> No, but you need to rebuild.
Yes, I have done 'gnumake'.
>    Matt
>     Danyang
>             On Apr 25, 2015, at 2:24 PM, Danyang Su
>             <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> wrote:
>             On 15-04-25 11:55 AM, Barry Smith wrote:
>                     On Apr 25, 2015, at 1:51 PM, Danyang Su
>                       wrote:
>                     On 15-04-25 11:32 AM, Barry Smith wrote:
>                            I told you this yesterday.
>                            It is probably stopping here on a harmless
>                         underflow. You need to edit the PETSc code to
>                         not worry about underflow.
>                         Edit the file
>                         /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>                         and locate
>                         #elif defined PETSC_HAVE_XMMINTRIN_H
>                             _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT);
>                         #else
>                         change it to
>                             _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT |
>                         _MM_MASK_UNDERFLOW);
>                         #else
>                           Then run make gnumake in the PETSc directory
>                         to compile the new version. Now link and run
>                         the program again with -fp_trap and see where
>                         it gets stuck this time.
>                            Did you do this?
>                           Barry
>                     Yes, I did change the code in fp.c and run 'make
>                     gnumake' in the PETSc directory. I just did a
>                     double check and ran make gnumake again and got
>                     the following information this time.
>                     dsu at nwmop:~/Soft/PETSc/petsc-3.5.2$
>                       make gnumake
>                     Building PETSc using GNU Make with 10 build threads
>                     make[1]: Entering directory
>                     `/home/dsu/Soft/PETSc/petsc-3.5.2'
>                     make[1]: Nothing to be done for `all'.
>                     make[1]: Leaving directory
>                     Then I recompiled the codes, ran with -fp_trap and
>                     still got the following error
>                     Backtrace for this error:
>                     Note: The EXACT line numbers in the stack are not
>                     available,
>                     [2]PETSC ERROR:       INSTEAD the line number of
>                     the start of the function
>                     [2]PETSC ERROR:       is given.
>                     [2]PETSC ERROR: [2] PetscDefaultFPTrap line 379
>                           INSTEAD the line number of the start of the
>                     function
>                     [3]PETSC ERROR:       is given.
>                     [3]PETSC ERROR: [3] PetscDefaultFPTrap line 379
>                     [2]PETSC ERROR: User provided function() line 0 in
>                     Unknown file trapped floating point error
>                     [3]PETSC ERROR: User provided function() line 0 in
>                     This is different then what you sent a few minutes
>                 ago where it crashed in hypre.
>                     Anyways you need to use the -start_in_debugger
>                 business I sent in the previous email to see the exact
>                 place the problem occurs.
>             Here is the information shown on gdb screen
>             Program received signal SIGFPE, Arithmetic exception.
>             0x00000000006c2bef in velocity_g (l_sufx=1, suffix=...,
>             nmax=12, njamxc=34,
>                  cinfradx=..., radial_coordx=.FALSE., _suffix=3)
>             1344                                        cinfrt =
>             (gdb)
>             After type cont on gdb screen, I got error information as
>             below
>             [1]PETSC ERROR: *** unknown floating point error occurred ***
>             [1]PETSC ERROR: The specific exception can be determined
>             by running in a debugger.  When the
>             [1]PETSC ERROR: debugger traps the signal, the exception
>             can be found with fetestexcept(0x3d)
>             [1]PETSC ERROR: where the result is a bitwise OR of the
>             following flags:
>             [1]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4
>             FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>             [1]PETSC ERROR: Try option -start_in_debugger
>             [1]PETSC ERROR: likely location of problem given in stack
>             below
>             [1]PETSC ERROR: ---------------------  Stack Frames
>             [1]PETSC ERROR: Note: The EXACT line numbers in the stack
>             are not available,
>             [1]PETSC ERROR:       INSTEAD the line number of the start
>             of the function
>             [1]PETSC ERROR:       is given.
>             [1]PETSC ERROR: [1] PetscDefaultFPTrap line 379
>             [1]PETSC ERROR: User provided function() line 0 in Unknown
>             [0]PETSC ERROR: *** unknown floating point error occurred ***
>             [0]PETSC ERROR: The specific exception can be determined
>             [0]PETSC ERROR: debugger traps the signal, the exception
>             [0]PETSC ERROR: where the result is a bitwise OR of the
>             following flags:
>             [0]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4
>             [0]PETSC ERROR: Try option -start_in_debugger
>             [0]PETSC ERROR: likely location of problem given in stack
>             below
>             Thanks,
>             Danyang
>                     Thanks,
>                     Danyang
>                             On Apr 25, 2015, at 1:05 AM, Danyang Su
>                               wrote:
>                             Hi Barry and Satish,
>                             How can I get rid of unknown floating
>                             point error when a very small value is
>                             multiplied.
>                             e.g.,
>                             cinfrt_dg(i1) and diff(ic,idim) are
>                             1.0250235986806329E-008
>                             8.6178408169776945E-317 respectively,
>                             cinfrt = cinfrt_dg(i1) * diff(ic,idim)
>                             I get the following error when run with
>                             "-fp_trap -start_in_debugger".
>                             [2]PETSC ERROR: The specific exception can
>                             be determined by running in a debugger.
>                             When the
>                             [2]PETSC ERROR: debugger traps the signal,
>                             the exception can be found with
>                             fetestexcept(0x3d)
>                             [2]PETSC ERROR:
>                             cinfrt_dg(i1),diff(ic,idim)
>                             following flags:
>                             [2]PETSC ERROR: FE_INVALID=0x1
>                             FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8
>                             [2]PETSC ERROR: Try option -start_in_debugger
>                             [2]PETSC ERROR: likely location of problem
>                             given in stack below
>                             Thanks,
>                             Danyang
>                             On 15-04-24 01:54 PM, Danyang Su wrote:
>                                 On 15-04-24 01:23 PM, Satish Balay wrote:
>                                       c           4
>                                      1.0976214263087059E-067
>                                     I don't think this number can be
>                                     stored in a real*4.
>                                     Satish
>                                 Thanks, Satish. It is caused by this
>                                 number.
>                                     On Fri, 24 Apr 2015, Danyang Su wrote:
>                                         On 15-04-24 11:12 AM, Barry
>                                         Smith wrote:
>                                                 On Apr 24, 2015, at
>                                                 1:05 PM, Danyang Su
>                                                   wrote:
>                                                 Hi All,
>                                                 One of my case crashes
>                                                 because of floating
>                                                 point exception when
>                                                 using 4
>                                                 processors, as shown
>                                                 below. But if I run
>                                                 this case with 1
>                                                 processor, it
>                                                 works fine. I have
>                                                 tested the codes with
>                                                 around 100 cases up to 768
>                                                 processors, all other
>                                                 cases work fine. I
>                                                 just wonder if this
>                                                 kind of error
>                                                 is caused because of
>                                                 NaN in jacobi matrix,
>                                                 RHS or preconditioner?
>                                                  Yes, almost for sure
>                                             it is one of these places.
>                                                  First run the bad
>                                             case with -fp_trap  if all
>                                             goes well you'll see the
>                                             function where the FPE is
>                                             generated. Then run also
>                                             with -start_in_debugger
>                                             and
>                                             type cont in all four
>                                             debugger windows. When the
>                                             FPE happens the debugger
>                                             should stop showing
>                                             exactly where the FPE happens.
>                                                 Barry
>                                         Hi Barry,
>                                         If run with -fp_trap
>                                         -start_in_debugger, I got the
>                                         following error
>                                         exception can be determined by
>                                         running in a
>                                         debugger.  When the
>                                         the signal, the exception can
>                                         be found with
>                                         fetestexcept(0x3d)
>                                         following flags:
>                                         -start_in_debugger
>                                         stack below
>                                         [0]PETSC ERROR:
>                                         [0]PETSC ERROR: Note: The
>                                         stack are not available,
>                                         [0]PETSC ERROR:       INSTEAD
>                                         of the function
>                                         [0]PETSC ERROR:       is given.
>                                         [0]PETSC ERROR: [0]
>                                         [0]PETSC ERROR: User provided
>                                         file trapped
>                                         SIGABRT: Process abort signal.
>                                         #0  0x7F4FEAB1C7D7
>                                         #1  0x7F4FEAB1CDDE
>                                         #2  0x7F4FE9E1AD3F
>                                         #3  0x7F4FE9E1ACC9
>                                         #4  0x7F4FE9E1E0D7
>                                         #5  0x7F4FEB0B6DCB
>                                         #6  0x7F4FEB0B1825
>                                         #7  0x7F4FEB0B817F
>                                         #8  0x7F4FE9E1AD3F
>                                         #9  0x6972C8 in tprfrtlc_ at
>                                         tprfrtlc.F90:2393
>                                         (discriminator 3)
>                                         #10  0x4C6C87 in gcreact_ at
>                                         gcreact.F90:678
>                                         #11  0x707E19 in initicrt_ at
>                                         initicrt.F90:589
>                                         #12  0x4F42D0 in initprob_ at
>                                         initprob.F90:430
>                                         #13  0x5AAF72 in driver_pc at
>                                         driver_pc.F90:438
>                                         I checked the code at
>                                         tprfrtlc.F90:2393,
>                                          realbuffer_gb(1:nvars) =
>                                         (/time,(c(ic),ic=1,nc-1),     &
>                                         (cx(ix),ix=1,nxout)/)
>                                         All the values (time, c, cx)
>                                         are reasonable, as shown
>                                         below. The only
>                                         possibility is that
>                                         realbuffer_gb is in declared
>                                         as real*4 if using sing
>                                         precision output while time,
>                                         c, cx are declared in real*8.
>                                         I have a lot of
>                                         similar data conversion from
>                                         real*8 to real*4 output, other
>                                         code does not
>                                         return error.
>                                           time   0.0000000000000000
>                                           c           1
>                                          9.9999999999999995E-008
>                                           c           2
>                                          3.1555251077549618E-003
>                                           c           3
>                                          7.1657814842179362E-008
>                                           c           4
>                                           c           5
>                                          5.2879822292305797E-004
>                                           c           6
>                                          9.9999999999999964E-005
>                                           c           7
>                                          6.4055731968811337E-005
>                                           c           8
>                                          3.4607572892578404E-020
>                                           cx           1
>                                          3.4376650636008101E-005
>                                           cx           2
>                                          7.3989678854017763E-012
>                                           cx           3
>                                          9.5317170613607207E-012
>                                           cx           4
>                                          2.2344525794718353E-015
>                                           cx           5
>                                          3.0624685689695889E-008
>                                           cx           6
>                                          1.0046157902783967E-007
>                                           cx           7
>                                          1.5320169154914984E-004
>                                           cx           8
>                                          8.6930292776346176E-014
>                                           cx           9
>                                          3.5944267559348721E-005
>                                           cx          10
>                                          3.0072645866951157E-018
>                                           cx          11
>                                          2.3592486321095017E-013
>                                         Thanks,
>                                         Danyang
>                                                 I can check all the
>                                                 entries of jacobi
>                                                 matrix to see if the
>                                                 value is valid,
>                                                 but this seems not a
>                                                 good idea as it takes
>                                                 a long time to reach this
>                                                 point. If I restart
>                                                 the simulation from a
>                                                 specified time (e.g.,
>                                                 7.685 in
>                                                 this case), then the
>                                                 error does not occur.
>                                                 Would you please give
>                                                 me any suggestion on
>                                                 debugging this case?
>                                                 Thanks and Regards,
>                                                 Danyang
>                                                 timestep:    2730
>                                                 time: 7.665E+00 years
>                                                  delt: 1.000E-02 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 timestep:    2731
>                                                 time: 7.675E+00 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 timestep:    2732
>                                                 time: 7.685E+00 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 timestep:    2733
>                                                 time: 7.695E+00 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 timestep:    2734
>                                                 time: 7.705E+00 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 Reduce time step for
>                                                 reactive transport
>                                                 timestep:    2734
>                                                 time: 7.700E+00 years
>                                                  delt: 5.000E-03 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 reactive transport
>                                                 timestep:    2734
>                                                 time: 7.697E+00 years
>                                                  delt: 2.500E-03 years
>                                                 iter: 1
>                                                 timestep:    max.sia:
>                                                 0.000E+00 tol.sia:
>                                                 0.000E+00
>                                                 [1]PETSC ERROR:
>                                                 Error Message
>                                                 [1]PETSC ERROR:
>                                                 [2]PETSC ERROR:
>                                                 Error Message
>                                                 [2]PETSC ERROR:
>                                                 [2]PETSC ERROR: Vec
>                                                 entry at local
>                                                 location 0 is
>                                                 not-a-number or infinite
>                                                 at end of function:
>                                                 Parameter number 3
>                                                 [2]PETSC ERROR: See
>                                                 http://www.mcs.anl.gov/petsc/documentation/faq.html
>                                                 for trouble shooting.
>                                                 [2]PETSC ERROR: Petsc
>                                                 Release Version 3.5.2,
>                                                 Sep, 08, 2014
>                                                 [2]PETSC ERROR:
>                                                 [1]PETSC ERROR: Vec
>                                                 entry at local
>                                                 location 0 is
>                                                 not-a-number or
>                                                 infinite at end of
>                                                 function: Parameter
>                                                 number 3
>                                                 [1]PETSC ERROR: See
>                                                 [1]PETSC ERROR: Petsc
>                                                 Sep, 08, 2014
>                                                 [1]PETSC ERROR:
>                                                 ../min3p_thcm_petsc_dbg on
>                                                 a linux-gnu-dbg named
>                                                 nwmop by
>                                                 dsu Thu Apr 23
>                                                 15:38:52 2015
>                                                 [1]PETSC ERROR:
>                                                 Configure options
>                                                 PETSC_ARCH=linux-gnu-dbg
>                                                 --with-cc=gcc
>                                                 --with-cxx=g++
>                                                 --with-fc=gfortran
>                                                 --download-fblaslapack
>                                                 --download-mpich
>                                                 --download-mumps
>                                                 --download-hypre
>                                                 --download-superlu_dist --download-metis
>                                                 --download-parmetis
>                                                 --download-scalapack
>                                                 [1]PETSC ERROR: #1
>                                                 VecValidValues() line
>                                                 34 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/src/vec/vec/interface/rvector.c
>                                                 nwmop by dsu Thu Apr 23
>                                                 15:38:52 2015
>                                                 [2]PETSC ERROR:
>                                                 Configure options
>                                                 --with-cc=gcc
>                                                 --with-cxx=g++
>                                                 --with-fc=gfortran
>                                                 --download-mpich
>                                                 --download-mumps
>                                                 --download-hypre
>                                                 --download-parmetis
>                                                 [2]PETSC ERROR: #1
>                                                 34 in
>                                                 [2]PETSC ERROR:
>                                                 [1]PETSC ERROR: #2
>                                                 PCApply() line 442 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/pc/interface/precon.c
>                                                 [1]PETSC ERROR: #2
>                                                 [2]PETSC ERROR: #3
>                                                 KSP_PCApply() line 230 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/include/petsc-private/kspimpl.h
>                                                 #3 KSP_PCApply() line
>                                                 230 in
>                                                 [1]PETSC ERROR: #4
>                                                 KSPInitialResidual()
>                                                 line 63 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itres.c
>                                                 [2]PETSC ERROR: #4
>                                                 line 63 in
>                                                 [1]PETSC ERROR: #5
>                                                 KSPSolve_GMRES() line
>                                                 234 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/impls/gmres/gmres.c
>                                                 [2]PETSC ERROR: #5
>                                                 234 in
>                                                 [2]PETSC ERROR: #6
>                                                 KSPSolve() line 459 in
>                                                 /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
>                                                 [1]PETSC ERROR: #6
>                                                 ^C[mpiexec at nwmop]
>                                                 Sending Ctrl-C to
>                                                 processes as requested
>                                                 [mpiexec at nwmop] Press
>                                                 Ctrl-C again to force
>                                                 abort
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150425/ebaec750/attachment-0001.html>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150425/ebaec750/attachment-0001.h>
