[petsc-users] Floating point exception
Danyang Su danyang.su at gmail.com
Sat Apr 25 20:23:33 CDT 2015
On 15-04-25 06:03 PM, Barry Smith wrote:
>    If this is what you got in your last run
>>      at ../../gas_advection/velocity_g.F90:1344
>> 1344                                        cinfrt = cinfrt_dg(i1) * diff(ic,idim)                                      !diff is a very small value, e.g., 1.0d-316
>    then it is still catching floating point underflow, which we do not want. This means either the change I suggested you make in the fp.c code didn't work or it actually uses a different floating point trap than that one.  BTW: absurd numbers like 1.0d-316 are often a symptom of uninitialized data; could that be a problem that diff is not filled correctly for all the ic, idim you are using?
>     This going round and round is very frustrating and a waste of time. You need to be more proactive yourself and explore the code and poke around to figure out how to solve the problem.
>    Please email $PETSC_DIR/$PETSC_ARCH/include/petscvariables.h so I can see what FP trap is being used on your machine.
> Barry
Do you mean $PETSC_DIR/$PETSC_ARCH/conf/petscvariables? Otherwise I
cannot find this file.
Do I need to reconfigure PETSc after changing the code you mentioned?
Danyang
>> On Apr 25, 2015, at 2:24 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> On 15-04-25 11:55 AM, Barry Smith wrote:
>>>> On Apr 25, 2015, at 1:51 PM, Danyang Su <danyang.su at gmail.com>
>>>>   wrote:
>>>> On 15-04-25 11:32 AM, Barry Smith wrote:
>>>>>    I told you this yesterday.
>>>>>    It is probably stopping here on a harmless underflow. You need to edit the PETSc code to not worry about underflow.
>>>>> Edit the file /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c and locate
>>>>> #elif defined PETSC_HAVE_XMMINTRIN_H
>>>>>     _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT);
>>>>> #else
>>>>> change it to
>>>>>     _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT | _MM_MASK_UNDERFLOW);
>>>>> #else
>>>>>   Then run make gnumake in the PETSc directory to compile the new version. Now link and run the program again with -fp_trap and see where it gets stuck this time.
>>>>>    Did you do this?
>>>>>   Barry
>>>> Yes, I did change the code in fp.c and run 'make gnumake' in the PETSc directory. I just did a double check and ran make gnumake again and got the following information this time.
>>>> dsu at nwmop:~/Soft/PETSc/petsc-3.5.2$
>>>>   make gnumake
>>>> Building PETSc using GNU Make with 10 build threads
>>>> make[1]: Entering directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>>> make[1]: Nothing to be done for `all'.
>>>> make[1]: Leaving directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>>> Then I recompiled the codes, ran with -fp_trap and still got the following error
>>>> Backtrace for this error:
>>>> Note: The EXACT line numbers in the stack are not available,
>>>> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>> [2]PETSC ERROR:       is given.
>>>> [2]PETSC ERROR: [2] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>>>> [3]PETSC ERROR:       is given.
>>>> [3]PETSC ERROR: [3] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>>>> [2]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
>>>> [3]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
>>>     This is different then what you sent a few minutes ago where it crashed in hypre.
>>>     Anyways you need to use the -start_in_debugger business I sent in the previous email to see the exact place the problem occurs.
>> Here is the information shown on gdb screen
>> Program received signal SIGFPE, Arithmetic exception.
>> 0x00000000006c2bef in velocity_g (l_sufx=1, suffix=..., nmax=12, njamxc=34,
>>      cinfradx=..., radial_coordx=.FALSE., _suffix=3)
>> (gdb)
>> After type cont on gdb screen, I got error information as below
>> [1]PETSC ERROR: *** unknown floating point error occurred ***
>> [1]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
>> [1]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
>> [1]PETSC ERROR: where the result is a bitwise OR of the following flags:
>> [1]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>> [1]PETSC ERROR: Try option -start_in_debugger
>> [1]PETSC ERROR: likely location of problem given in stack below
>> [1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
>> [1]PETSC ERROR:       is given.
>> [1]PETSC ERROR: [1] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>> [1]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
>> [0]PETSC ERROR: *** unknown floating point error occurred ***
>> [0]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
>> [0]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
>> [0]PETSC ERROR: where the result is a bitwise OR of the following flags:
>> [0]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>> [0]PETSC ERROR: Try option -start_in_debugger
>> [0]PETSC ERROR: likely location of problem given in stack below
>> Thanks,
>> Danyang
>>>> Thanks,
>>>> Danyang
>>>>>> On Apr 25, 2015, at 1:05 AM, Danyang Su <danyang.su at gmail.com>
>>>>>>   wrote:
>>>>>> Hi Barry and Satish,
>>>>>> How can I get rid of unknown floating point error when a very small value is multiplied.
>>>>>> e.g.,
>>>>>> cinfrt_dg(i1) and diff(ic,idim) are  1.0250235986806329E-008 8.6178408169776945E-317 respectively,
>>>>>> I get the following error when run with "-fp_trap -start_in_debugger".
>>>>>> [2]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
>>>>>> [2]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
>>>>>> [2]PETSC ERROR:  cinfrt_dg(i1),diff(ic,idim) 1.0250235986806329E-008   8.6178408169776945E-317
>>>>>> [2]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>>>>>> [2]PETSC ERROR: Try option -start_in_debugger
>>>>>> [2]PETSC ERROR: likely location of problem given in stack below
>>>>>> Thanks,
>>>>>> Danyang
>>>>>> On 15-04-24 01:54 PM, Danyang Su wrote:
>>>>>>> On 15-04-24 01:23 PM, Satish Balay wrote:
>>>>>>>>   c           4   1.0976214263087059E-067
>>>>>>>> I don't think this number can be stored in a real*4.
>>>>>>>> Satish
>>>>>>> Thanks, Satish. It is caused by this number.
>>>>>>>> On Fri, 24 Apr 2015, Danyang Su wrote:
>>>>>>>>> On 15-04-24 11:12 AM, Barry Smith wrote:
>>>>>>>>>>> On Apr 24, 2015, at 1:05 PM, Danyang Su <danyang.su at gmail.com>
>>>>>>>>>>>   wrote:
>>>>>>>>>>> Hi All,
>>>>>>>>>>> One of my case crashes because of floating point exception when using 4
>>>>>>>>>>> processors, as shown below. But if I run this case with 1 processor, it
>>>>>>>>>>> works fine. I have tested the codes with around 100 cases up to 768
>>>>>>>>>>> processors, all other cases work fine. I just wonder if this kind of error
>>>>>>>>>>> is caused because of NaN in jacobi matrix, RHS or preconditioner?
>>>>>>>>>>      Yes, almost for sure it is one of these places.
>>>>>>>>>>      First run the bad case with -fp_trap  if all goes well you'll see the
>>>>>>>>>> function where the FPE is generated. Then run also with -start_in_debugger
>>>>>>>>>> and
>>>>>>>>>> type cont in all four debugger windows. When the FPE happens the debugger
>>>>>>>>>> should stop showing exactly where the FPE happens.
>>>>>>>>>>     Barry
>>>>>>>>> Hi Barry,
>>>>>>>>> If run with -fp_trap -start_in_debugger, I got the following error
>>>>>>>>> debugger.  When the
>>>>>>>>> fetestexcept(0x3d)
>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>> [0]PETSC ERROR: [0] PetscDefaultFPTrap line 379
>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in Unknown file trapped
>>>>>>>>> Program received signal SIGABRT: Process abort signal.
>>>>>>>>> #0  0x7F4FEAB1C7D7
>>>>>>>>> #1  0x7F4FEAB1CDDE
>>>>>>>>> #2  0x7F4FE9E1AD3F
>>>>>>>>> #3  0x7F4FE9E1ACC9
>>>>>>>>> #4  0x7F4FE9E1E0D7
>>>>>>>>> #5  0x7F4FEB0B6DCB
>>>>>>>>> #6  0x7F4FEB0B1825
>>>>>>>>> #7  0x7F4FEB0B817F
>>>>>>>>> #8  0x7F4FE9E1AD3F
>>>>>>>>> #9  0x6972C8 in tprfrtlc_ at tprfrtlc.F90:2393 (discriminator 3)
>>>>>>>>> #10  0x4C6C87 in gcreact_ at gcreact.F90:678
>>>>>>>>> #11  0x707E19 in initicrt_ at initicrt.F90:589
>>>>>>>>> #12  0x4F42D0 in initprob_ at initprob.F90:430
>>>>>>>>> #13  0x5AAF72 in driver_pc at driver_pc.F90:438
>>>>>>>>> I checked the code at  tprfrtlc.F90:2393,
>>>>>>>>>          realbuffer_gb(1:nvars) = (/time,(c(ic),ic=1,nc-1),     &
>>>>>>>>>                                     (cx(ix),ix=1,nxout)/)
>>>>>>>>> All the values (time, c, cx) are reasonable, as shown below. The only
>>>>>>>>> possibility is that realbuffer_gb is in declared as real*4 if using sing
>>>>>>>>> precision output while time, c, cx are declared in real*8. I have a lot of
>>>>>>>>> similar data conversion from real*8 to real*4 output, other code does not
>>>>>>>>> return error.
>>>>>>>>>   time   0.0000000000000000
>>>>>>>>>   c           1   9.9999999999999995E-008
>>>>>>>>>   c           2   3.1555251077549618E-003
>>>>>>>>>   c           3   7.1657814842179362E-008
>>>>>>>>>   c           5   5.2879822292305797E-004
>>>>>>>>>   c           6   9.9999999999999964E-005
>>>>>>>>>   c           7   6.4055731968811337E-005
>>>>>>>>>   c           8   3.4607572892578404E-020
>>>>>>>>>   cx           1   3.4376650636008101E-005
>>>>>>>>>   cx           2   7.3989678854017763E-012
>>>>>>>>>   cx           3   9.5317170613607207E-012
>>>>>>>>>   cx           4   2.2344525794718353E-015
>>>>>>>>>   cx           5   3.0624685689695889E-008
>>>>>>>>>   cx           6   1.0046157902783967E-007
>>>>>>>>>   cx           7   1.5320169154914984E-004
>>>>>>>>>   cx           8   8.6930292776346176E-014
>>>>>>>>>   cx           9   3.5944267559348721E-005
>>>>>>>>>   cx          10   3.0072645866951157E-018
>>>>>>>>>   cx          11   2.3592486321095017E-013
>>>>>>>>> Thanks,
>>>>>>>>> Danyang
>>>>>>>>>>> I can check all the entries of jacobi matrix to see if the value is valid,
>>>>>>>>>>> but this seems not a good idea as it takes a long time to reach this
>>>>>>>>>>> point. If I restart the simulation from a specified time (e.g., 7.685 in
>>>>>>>>>>> this case), then the error does not occur.
>>>>>>>>>>> Would you please give me any suggestion on debugging this case?
>>>>>>>>>>> Thanks and Regards,
>>>>>>>>>>> Danyang
>>>>>>>>>>> timestep:    2730 time: 7.665E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>>> timestep:    max.sia: 0.000E+00 tol.sia: 0.000E+00
>>>>>>>>>>> timestep:    2731 time: 7.675E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>>> timestep:    2732 time: 7.685E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>>> timestep:    2733 time: 7.695E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>>> timestep:    2734 time: 7.705E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>>> Reduce time step for reactive transport
>>>>>>>>>>> timestep:    2734 time: 7.700E+00 years   delt: 5.000E-03 years iter:  1
>>>>>>>>>>> timestep:    2734 time: 7.697E+00 years   delt: 2.500E-03 years iter:  1
>>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> [1]PETSC ERROR: Floating point exception
>>>>>>>>>>> [2]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> [2]PETSC ERROR: Floating point exception
>>>>>>>>>>> [2]PETSC ERROR: Vec entry at local location 0 is not-a-number or infinite
>>>>>>>>>>> at end of function: Parameter number 3
>>>>>>>>>>> [2]PETSC ERROR: See
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>>>>>> for trouble shooting.
>>>>>>>>>>> [2]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: Vec entry at local location 0 is
>>>>>>>>>>> not-a-number or infinite at end of function: Parameter number 3
>>>>>>>>>>> [1]PETSC ERROR: See
>>>>>>>>>>> [1]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>>> [1]PETSC ERROR: ../min3p_thcm_petsc_dbg on a linux-gnu-dbg named nwmop by
>>>>>>>>>>> dsu Thu Apr 23 15:38:52 2015
>>>>>>>>>>> [1]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg --with-cc=gcc
>>>>>>>>>>> --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich
>>>>>>>>>>> --download-mumps --download-hypre --download-superlu_dist --download-metis
>>>>>>>>>>> --download-parmetis --download-scalapack
>>>>>>>>>>> [1]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/vec/vec/interface/rvector.c
>>>>>>>>>>> ../min3p_thcm_petsc_dbg on a linux-gnu-dbg named nwmop by dsu Thu Apr 23
>>>>>>>>>>> 15:38:52 2015
>>>>>>>>>>> [2]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg --with-cc=gcc
>>>>>>>>>>> [2]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: #2 PCApply() line 442 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/pc/interface/precon.c
>>>>>>>>>>> [2]PETSC ERROR: #3 KSP_PCApply() line 230 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/include/petsc-private/kspimpl.h
>>>>>>>>>>> [1]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itres.c
>>>>>>>>>>> [2]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>>> [1]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/impls/gmres/gmres.c
>>>>>>>>>>> [2]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>>> [2]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>> [1]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>>> ^C[mpiexec at nwmop] Sending Ctrl-C to processes as requested
>>>>>>>>>>> [mpiexec at nwmop] Press Ctrl-C again to force abort
MPICXX_SHOW = g++ -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0 -fPIC -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpichcxx -Wl,-rpath -Wl,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpich -lopa -lmpl -lrt -lpthread
C_DEPFLAGS = -MMD -MP
FC_DEFINE_FLAG = -D
MPICC_SHOW = gcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -Wl,-rpath -Wl,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpich -lopa -lmpl -lrt -lpthread
AR_FLAGS = cr
CXX_DEPFLAGS = -MMD -MP
FC_DEPFLAGS = -MMD -MP
MPIFC_SHOW = gfortran -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpichf90 -Wl,-rpath -Wl,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpich -lopa -lmpl -lrt -lpthread
FAST_AR_FLAGS = Scq
FC_MODULE_OUTPUT_FLAG = -J
PETSC_LANGUAGE = CONLY
FC_LINKER_FLAGS =    -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
LIBNAME = ${INSTALL_LIB_DIR}/libpetsc.${AR_LIB_SUFFIX}
SL_LINKER = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc
PETSC_BUILD_USING_CMAKE = 1
CC_FLAGS =  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
PETSC_PRECISION = double
PETSC_LIB_BASIC = -lpetsc
SUPERLU_DIST_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lsuperlu_dist_3.3
FC_FLAGS =  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
BLASLAPACK_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lflapack -lfblas
PETSC_MAT_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PCC = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc
SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
VALGRIND_INCLUDE =
MPI_LIB =
PETSC_SNES_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
SSL_LIB = -lssl -lcrypto
PETSC_EXTERNAL_LIB_BASIC = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lHYPRE -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpichcxx -lstdc++ -lsuperlu_dist_3.3 -lflapack -lfblas -lparmetis -lmetis -lpthread -lssl -lcrypto -lm -lmpichf90 -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpichcxx -lstdc++ -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
PETSC_TS_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
SL_LINKER_FLAGS = ${PCC_LINKER_FLAGS}
PARMETIS_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lparmetis
SUPERLU_DIST_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
CC_SUFFIX = o
PETSC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
SCALAPACK_INCLUDE =
SHLIBS = libpetsc
METIS_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
PETSC_CHARACTERISTIC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PTHREAD_LIB = -lpthread
PETSC_SCALAR = real
PETSC_FC_INCLUDES = -I/home/dsu/Soft/PETSc/petsc-3.5.2/include -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
CPP_FLAGS =
PETSC_TAO_LIB_BASIC = -lpetsc
PETSC_KSP_LIB_BASIC = -lpetsc
FPP_FLAGS =
HYPRE_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
FC_LINKER = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpif90
HYPRE_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lHYPRE -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpichcxx -lstdc++
PETSC_KSP_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
CXX_FLAGS =   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC
PCC_LINKER_FLAGS =    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
SSL_INCLUDE =
PETSC_CONTRIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PETSC_CC_INCLUDES = -I/home/dsu/Soft/PETSc/petsc-3.5.2/include -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
PCC_LINKER = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc
PETSC_SYS_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
PCC_FLAGS =  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
VALGRIND_LIB =
PTHREAD_INCLUDE =
METIS_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmetis
FBLASLAPACK_INCLUDE =
PETSC_TS_LIB_BASIC = -lpetsc
PETSC_VEC_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
CC_LINKER_SUFFIX =
FBLASLAPACK_LIB =
SL_LINKER_SUFFIX = so
PARMETIS_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
PETSC_DM_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
DESTDIR = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg
FC_MODULE_FLAG = -I
SCALAPACK_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lscalapack
PETSC_WITH_EXTERNAL_LIB = -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib  -lpetsc -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lHYPRE -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpichcxx -lstdc++ -lsuperlu_dist_3.3 -lflapack -lfblas -lparmetis -lmetis -lpthread -lssl -lcrypto -lm -lmpichf90 -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpichcxx -lstdc++ -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
CONFIGURE_OPTIONS = PETSC_ARCH=linux-gnu-dbg --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich --download-mumps --download-hypre --download-superlu_dist --download-metis --download-parmetis --download-scalapack
MUMPS_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
PETSC_TAO_LIB = ${C_SH_LIB_PATH} ${PETSC_WITH_EXTERNAL_LIB}
MPI_INCLUDE = -I/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/include
FC_SUFFIX = o
MUMPS_LIB = -Wl,-rpath,/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -L/home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
SHELL = /bin/sh
GREP = /bin/grep
MV = /bin/mv
PYTHON = /usr/bin/python
MKDIR = /bin/mkdir -p
SEDINPLACE = /bin/sed -i
SED = /bin/sed
DIFF = /usr/bin/diff -w
GZIP = /bin/gzip
RM = /bin/rm -f
CP = /bin/cp
CC_LINKER_SLFLAG = -Wl,-rpath,
RANLIB = /usr/bin/ranlib
DYNAMICLINKER = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc
CXX = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicxx
FC = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpif90
CXXCPP = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicxx -E
FC_LINKER_SLFLAG = -Wl,-rpath,
CPP = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc -E
AR_LIB_SUFFIX = a
LD_SHARED = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpicc
AR = /usr/bin/ar
OMAKE = /usr/bin/make  --no-print-directory
MAKE_IS_GNUMAKE = 1
MAKE_NP = 10
OMAKE_PRINTDIR  = /usr/bin/make  --print-directory
MPIEXEC = /home/dsu/Soft/PETSc/petsc-3.5.2/linux-gnu-dbg/bin/mpiexec
GDB = /usr/bin/gdb
DSYMUTIL = true
SL_LINKER_FUNCTION = -shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))
SONAME_FUNCTION = $(1).so.$(2)
BUILDSHAREDLIB = yes
TEST_RUNS = C Fortran SSL METIS PARMETIS SUPERLU_DIST HYPRE MUMPS Cxx F90 F90_NoComplex F2003 Fortran_NoComplex C_NoComplex
CMAKE = /usr/bin/cmake
