[petsc-users] Floating point exception
Sat Apr 25 20:03:25 CDT 2015
  If this is what you got in your last run
>     at ../../gas_advection/velocity_g.F90:1344
> 1344                                        cinfrt = cinfrt_dg(i1) * diff(ic,idim)                                      !diff is a very small value, e.g., 1.0d-316
  then it is still catching floating point underflow, which we do not want. This means either the change I suggested you make in the fp.c code didn't work or it actually uses a different floating point trap than that one.  BTW: absurd numbers like 1.0d-316 are often a symptom of uninitialized data; could that be a problem that diff is not filled correctly for all the ic, idim you are using?
   This going round and round is very frustrating and a waste of time. You need to be more proactive yourself and explore the code and poke around to figure out how to solve the problem.
  Please email $PETSC_DIR/$PETSC_ARCH/include/petscvariables.h so I can see what FP trap is being used on your machine.
Barry
> On Apr 25, 2015, at 2:24 PM, Danyang Su <danyang.su at gmail.com> wrote:
> On 15-04-25 11:55 AM, Barry Smith wrote:
>>> On Apr 25, 2015, at 1:51 PM, Danyang Su <danyang.su at gmail.com>
>>>  wrote:
>>> On 15-04-25 11:32 AM, Barry Smith wrote:
>>>>   I told you this yesterday.
>>>>   It is probably stopping here on a harmless underflow. You need to edit the PETSc code to not worry about underflow.
>>>> Edit the file /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c and locate
>>>> #elif defined PETSC_HAVE_XMMINTRIN_H
>>>>    _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT);
>>>> #else
>>>> change it to
>>>>    _MM_SET_EXCEPTION_MASK(_MM_MASK_INEXACT | _MM_MASK_UNDERFLOW);
>>>> #else
>>>>  Then run make gnumake in the PETSc directory to compile the new version. Now link and run the program again with -fp_trap and see where it gets stuck this time.
>>>>   Did you do this?
>>>>  Barry
>>> Yes, I did change the code in fp.c and run 'make gnumake' in the PETSc directory. I just did a double check and ran make gnumake again and got the following information this time.
>>> dsu at nwmop:~/Soft/PETSc/petsc-3.5.2$
>>>  make gnumake
>>> Building PETSc using GNU Make with 10 build threads
>>> make[1]: Entering directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>> make[1]: Nothing to be done for `all'.
>>> make[1]: Leaving directory `/home/dsu/Soft/PETSc/petsc-3.5.2'
>>> Then I recompiled the codes, ran with -fp_trap and still got the following error
>>> Backtrace for this error:
>>> Note: The EXACT line numbers in the stack are not available,
>>> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> [2]PETSC ERROR:       is given.
>>> [2]PETSC ERROR: [2] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>>> [3]PETSC ERROR:       is given.
>>> [3]PETSC ERROR: [3] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
>>> [2]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
>>> [3]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
>>    This is different then what you sent a few minutes ago where it crashed in hypre.
>>    Anyways you need to use the -start_in_debugger business I sent in the previous email to see the exact place the problem occurs.
> Here is the information shown on gdb screen
> Program received signal SIGFPE, Arithmetic exception.
> 0x00000000006c2bef in velocity_g (l_sufx=1, suffix=..., nmax=12, njamxc=34,
>     cinfradx=..., radial_coordx=.FALSE., _suffix=3)
> (gdb)
> After type cont on gdb screen, I got error information as below
> [1]PETSC ERROR: *** unknown floating point error occurred ***
> [1]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
> [1]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
> [1]PETSC ERROR: where the result is a bitwise OR of the following flags:
> [1]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
> [1]PETSC ERROR: Try option -start_in_debugger
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> [1]PETSC ERROR:       is given.
> [1]PETSC ERROR: [1] PetscDefaultFPTrap line 379 /home/dsu/Soft/PETSc/petsc-3.5.2/src/sys/error/fp.c
> [1]PETSC ERROR: User provided function() line 0 in Unknown file trapped floating point error
> [0]PETSC ERROR: *** unknown floating point error occurred ***
> [0]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
> [0]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
> [0]PETSC ERROR: where the result is a bitwise OR of the following flags:
> [0]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
> [0]PETSC ERROR: Try option -start_in_debugger
> [0]PETSC ERROR: likely location of problem given in stack below
> Thanks,
> Danyang
>>> Thanks,
>>> Danyang
>>>>> On Apr 25, 2015, at 1:05 AM, Danyang Su <danyang.su at gmail.com>
>>>>>  wrote:
>>>>> Hi Barry and Satish,
>>>>> How can I get rid of unknown floating point error when a very small value is multiplied.
>>>>> e.g.,
>>>>> cinfrt_dg(i1) and diff(ic,idim) are  1.0250235986806329E-008 8.6178408169776945E-317 respectively,
>>>>> I get the following error when run with "-fp_trap -start_in_debugger".
>>>>> [2]PETSC ERROR: The specific exception can be determined by running in a debugger.  When the
>>>>> [2]PETSC ERROR: debugger traps the signal, the exception can be found with fetestexcept(0x3d)
>>>>> [2]PETSC ERROR:  cinfrt_dg(i1),diff(ic,idim) 1.0250235986806329E-008   8.6178408169776945E-317
>>>>> [2]PETSC ERROR: FE_INVALID=0x1 FE_DIVBYZERO=0x4 FE_OVERFLOW=0x8 FE_UNDERFLOW=0x10 FE_INEXACT=0x20
>>>>> [2]PETSC ERROR: Try option -start_in_debugger
>>>>> [2]PETSC ERROR: likely location of problem given in stack below
>>>>> Thanks,
>>>>> Danyang
>>>>> On 15-04-24 01:54 PM, Danyang Su wrote:
>>>>>> On 15-04-24 01:23 PM, Satish Balay wrote:
>>>>>>>  c           4   1.0976214263087059E-067
>>>>>>> I don't think this number can be stored in a real*4.
>>>>>>> Satish
>>>>>> Thanks, Satish. It is caused by this number.
>>>>>>> On Fri, 24 Apr 2015, Danyang Su wrote:
>>>>>>>> On 15-04-24 11:12 AM, Barry Smith wrote:
>>>>>>>>>> On Apr 24, 2015, at 1:05 PM, Danyang Su <danyang.su at gmail.com>
>>>>>>>>>>  wrote:
>>>>>>>>>> Hi All,
>>>>>>>>>> One of my case crashes because of floating point exception when using 4
>>>>>>>>>> processors, as shown below. But if I run this case with 1 processor, it
>>>>>>>>>> works fine. I have tested the codes with around 100 cases up to 768
>>>>>>>>>> processors, all other cases work fine. I just wonder if this kind of error
>>>>>>>>>> is caused because of NaN in jacobi matrix, RHS or preconditioner?
>>>>>>>>>     Yes, almost for sure it is one of these places.
>>>>>>>>>     First run the bad case with -fp_trap  if all goes well you'll see the
>>>>>>>>> function where the FPE is generated. Then run also with -start_in_debugger
>>>>>>>>> and
>>>>>>>>> type cont in all four debugger windows. When the FPE happens the debugger
>>>>>>>>> should stop showing exactly where the FPE happens.
>>>>>>>>>    Barry
>>>>>>>> Hi Barry,
>>>>>>>> If run with -fp_trap -start_in_debugger, I got the following error
>>>>>>>> debugger.  When the
>>>>>>>> fetestexcept(0x3d)
>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>> [0]PETSC ERROR: [0] PetscDefaultFPTrap line 379
>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in Unknown file trapped
>>>>>>>> Program received signal SIGABRT: Process abort signal.
>>>>>>>> #0  0x7F4FEAB1C7D7
>>>>>>>> #1  0x7F4FEAB1CDDE
>>>>>>>> #2  0x7F4FE9E1AD3F
>>>>>>>> #3  0x7F4FE9E1ACC9
>>>>>>>> #4  0x7F4FE9E1E0D7
>>>>>>>> #5  0x7F4FEB0B6DCB
>>>>>>>> #6  0x7F4FEB0B1825
>>>>>>>> #7  0x7F4FEB0B817F
>>>>>>>> #8  0x7F4FE9E1AD3F
>>>>>>>> #9  0x6972C8 in tprfrtlc_ at tprfrtlc.F90:2393 (discriminator 3)
>>>>>>>> #10  0x4C6C87 in gcreact_ at gcreact.F90:678
>>>>>>>> #11  0x707E19 in initicrt_ at initicrt.F90:589
>>>>>>>> #12  0x4F42D0 in initprob_ at initprob.F90:430
>>>>>>>> #13  0x5AAF72 in driver_pc at driver_pc.F90:438
>>>>>>>> I checked the code at  tprfrtlc.F90:2393,
>>>>>>>>         realbuffer_gb(1:nvars) = (/time,(c(ic),ic=1,nc-1),     &
>>>>>>>>                                    (cx(ix),ix=1,nxout)/)
>>>>>>>> All the values (time, c, cx) are reasonable, as shown below. The only
>>>>>>>> possibility is that realbuffer_gb is in declared as real*4 if using sing
>>>>>>>> precision output while time, c, cx are declared in real*8. I have a lot of
>>>>>>>> similar data conversion from real*8 to real*4 output, other code does not
>>>>>>>> return error.
>>>>>>>>  time   0.0000000000000000
>>>>>>>>  c           1   9.9999999999999995E-008
>>>>>>>>  c           2   3.1555251077549618E-003
>>>>>>>>  c           3   7.1657814842179362E-008
>>>>>>>>  c           5   5.2879822292305797E-004
>>>>>>>>  c           6   9.9999999999999964E-005
>>>>>>>>  c           7   6.4055731968811337E-005
>>>>>>>>  c           8   3.4607572892578404E-020
>>>>>>>>  cx           1   3.4376650636008101E-005
>>>>>>>>  cx           2   7.3989678854017763E-012
>>>>>>>>  cx           3   9.5317170613607207E-012
>>>>>>>>  cx           4   2.2344525794718353E-015
>>>>>>>>  cx           5   3.0624685689695889E-008
>>>>>>>>  cx           6   1.0046157902783967E-007
>>>>>>>>  cx           7   1.5320169154914984E-004
>>>>>>>>  cx           8   8.6930292776346176E-014
>>>>>>>>  cx           9   3.5944267559348721E-005
>>>>>>>>  cx          10   3.0072645866951157E-018
>>>>>>>>  cx          11   2.3592486321095017E-013
>>>>>>>> Thanks,
>>>>>>>> Danyang
>>>>>>>>>> I can check all the entries of jacobi matrix to see if the value is valid,
>>>>>>>>>> but this seems not a good idea as it takes a long time to reach this
>>>>>>>>>> point. If I restart the simulation from a specified time (e.g., 7.685 in
>>>>>>>>>> this case), then the error does not occur.
>>>>>>>>>> Would you please give me any suggestion on debugging this case?
>>>>>>>>>> Thanks and Regards,
>>>>>>>>>> Danyang
>>>>>>>>>> timestep:    2730 time: 7.665E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>> timestep:    max.sia: 0.000E+00 tol.sia: 0.000E+00
>>>>>>>>>> timestep:    2731 time: 7.675E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>> timestep:    2732 time: 7.685E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>> timestep:    2733 time: 7.695E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>> timestep:    2734 time: 7.705E+00 years   delt: 1.000E-02 years iter:  1
>>>>>>>>>> Reduce time step for reactive transport
>>>>>>>>>> timestep:    2734 time: 7.700E+00 years   delt: 5.000E-03 years iter:  1
>>>>>>>>>> timestep:    2734 time: 7.697E+00 years   delt: 2.500E-03 years iter:  1
>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>> [1]PETSC ERROR: Floating point exception
>>>>>>>>>> [2]PETSC ERROR: --------------------- Error Message
>>>>>>>>>> [2]PETSC ERROR: Floating point exception
>>>>>>>>>> [2]PETSC ERROR: Vec entry at local location 0 is not-a-number or infinite
>>>>>>>>>> at end of function: Parameter number 3
>>>>>>>>>> [2]PETSC ERROR: See
>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>>>>> for trouble shooting.
>>>>>>>>>> [2]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: Vec entry at local location 0 is
>>>>>>>>>> not-a-number or infinite at end of function: Parameter number 3
>>>>>>>>>> [1]PETSC ERROR: See
>>>>>>>>>> [1]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>>>>>>>> [1]PETSC ERROR: ../min3p_thcm_petsc_dbg on a linux-gnu-dbg named nwmop by
>>>>>>>>>> dsu Thu Apr 23 15:38:52 2015
>>>>>>>>>> [1]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg --with-cc=gcc
>>>>>>>>>> --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich
>>>>>>>>>> --download-mumps --download-hypre --download-superlu_dist --download-metis
>>>>>>>>>> --download-parmetis --download-scalapack
>>>>>>>>>> [1]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/vec/vec/interface/rvector.c
>>>>>>>>>> ../min3p_thcm_petsc_dbg on a linux-gnu-dbg named nwmop by dsu Thu Apr 23
>>>>>>>>>> 15:38:52 2015
>>>>>>>>>> [2]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-dbg --with-cc=gcc
>>>>>>>>>> [2]PETSC ERROR: #1 VecValidValues() line 34 in
>>>>>>>>>> [2]PETSC ERROR: [1]PETSC ERROR: #2 PCApply() line 442 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/pc/interface/precon.c
>>>>>>>>>> [2]PETSC ERROR: #3 KSP_PCApply() line 230 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/include/petsc-private/kspimpl.h
>>>>>>>>>> [1]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itres.c
>>>>>>>>>> [2]PETSC ERROR: #4 KSPInitialResidual() line 63 in
>>>>>>>>>> [1]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/impls/gmres/gmres.c
>>>>>>>>>> [2]PETSC ERROR: #5 KSPSolve_GMRES() line 234 in
>>>>>>>>>> [2]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>> /home/dsu/Soft/PETSc/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>> [1]PETSC ERROR: #6 KSPSolve() line 459 in
>>>>>>>>>> ^C[mpiexec at nwmop] Sending Ctrl-C to processes as requested
>>>>>>>>>> [mpiexec at nwmop] Press Ctrl-C again to force abort
