[petsc-users] Assembling Restriction and Prolongation Operators for Parallel Calculations
Mon Apr 6 16:12:44 CDT 2015
On Mon, Apr 6, 2015 at 3:59 PM, Eric Mittelstaedt <emittelstaedt at uidaho.edu>
wrote:
>  Hi Matt
> On 4/6/2015 6:49 AM, Matthew Knepley wrote:
>  On Mon, Apr 6, 2015 at 12:16 AM, Eric Mittelstaedt <
> emittelstaedt at uidaho.edu> wrote:
>> Hello all,
>>    We are working on implementing restriction and prolongation operators
>> for algebraic multigrid in our finite difference (staggered grid) code that
>> solves the incompressible Stokes problem.  So far, the restriction and
>> prolongation operators we have assembled in serial can successfully solve
>> on a simple 2D grid with multiple-level v-cycles.  However, we are running
>> into problems when we attempt to progress to parallel solves.  One of the
>> primary errors we run into is an incompatibility in matrix types for
>> MatMatMatMult and similar calls:
>> [0]PETSC ERROR: [1]PETSC ERROR: MatMatMatMult() line 9173 in
>> /opt/petsc/src/mat/interface/matrix.c MatMatMatMult requires A, seqaij, to
>> be compatible with B, mpiaij, C, seqaij
>> MatMatMatMult() line 9173 in /opt/petsc/src/mat/interface/matrix.c
>> MatMatMatMult requires A, seqaij, to be compatible with B, mpiaij, C, seqaij
>> The root cause of this is likely the matrix types we chose for
>> restriction and prolongation. To ease calculation of our restriction (R)
>> and prolongation (P) matrices, we have created them as sparse, sequential
>> matrices (SEQAIJ) that are identical on all procs.  Will this matrix type
>> actually work for R and P operators in parallel?
>  You need to create them as parallel matrices, MPIAIJ for example, that
> have the same layout as the system matrix.
> Okay, this is what I thought was the problem.  It is really a matter of
> making sure we have the correct information on each processor.
>> It seem that setting this matrix type correctly is the heart of our
>> problem.  Originally, we chose SEQAIJ because we want to let Petsc deal
>> with partitioning of the grid on multiple processors.  If we do this,
>> however, we don't know a priori whether Petsc will place a processor
>> boundary on an even or odd nodal point.  This makes determining the
>> processor bounds on the subsequent coarse levels difficult.  One method for
>> resolving this may be to handle the partitioning ourselves, but it would be
>> nice to avoid this if possible. Is there a better way to set up these
>> operators?
>  You use the same partitioning as the system matrices on the two levels.
> Does this makes sense?
>    It does, but I am unsure how to get the partitioning of the coarser
> grids since we don't deal with them directly.  Is it safe to assume that
> the partitioning on the coarser grid will always overlap with the same part
> of the domain as the fine level? In other words, the current processor will
> receive the coarse grid that is formed by the portion of the restriction
> matrix that it owns, right?
You can get the coarse grid by calling DMCoarsen(), just like the AMG will
do. Then you can ask the coverage questions
directly to the DMDA. I don't remember exactly what we guarantee with
regard to coverage of the fine grid by the coarse.
Maybe Jed does since he jsut rewrote this for the HPGMG benchmark.
     MAtt
> Thanks!
> Eric
>     Thanks,
>       Matt
>> Thank you,
>> Eric and Arthur
> experiments lead.
> -- Norbert Wiener
> Eric Mittelstaedt, Ph.D.
> Assistant Professor
> Dept. of Geological Sciences
> University of Idaho
> email: emittelstaedt at uidaho.edu
> phone: (208) 885 2045http://scholar.google.com/citations?user=DvRzEqkAAAAJ
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150406/5b192bba/attachment.html>
