[petsc-users] fieldsplit doesn't pass prefix to inner ksp
anton popov at uni-mainz.de
Fri Sep 26 10:17:34 CDT 2014
This is what I get for 3.5.0:
anton at anton ~/LIB/petsc-3.5.0-deb/src/snes/examples/tutorials $ ./ex19
-bf_pc_type fieldsplit -bf_snes_view
lid velocity = 0.0625, prandtl # = 1, grashof # = 1
Number of SNES iterations = 2
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-bf_pc_type value: fieldsplit
Option left: name:-bf_snes_view (no value)
It seems like it was already corrected  between 3.5.0 & 3.5.2
On 09/26/2014 04:26 PM, Matthew Knepley wrote:
> Here is the result for 3.5.2, which looks right to me:
> (v3.5.2)
> *:/PETSc3/petsc/release-petsc-3.5.1/src/snes/examples/tutorials$
> ./ex19 -bf_pc_type fieldsplit -bf_snes_view -bf_pc_fieldsplit_type
> schur -bf_pc_fieldsplit_0_fields 0,1,2 -bf_pc_fieldsplit_1_fields 3
> -bf_pc_fieldsplit_schur_factorization_type upper
> SNES Object:(bf_) 1 MPI processes
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=4
>   total number of function evaluations=3
>   SNESLineSearch Object:  (bf_)   1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object:  (bf_)   1 MPI processes
>     type: gmres
>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>     left preconditioning
>     using PRECONDITIONED norm type for convergence test
>   PC Object:  (bf_)   1 MPI processes
>     type: fieldsplit
>       FieldSplit with Schur preconditioner, factorization UPPER
>       Preconditioner for the Schur complement formed from A11
>       Split info:
>       Split number 0 Defined by IS
>       Split number 1 Defined by IS
>       KSP solver for A00 block
>         KSP Object:        (bf_fieldsplit_0_)         1 MPI processes
>           type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
>         PC Object:        (bf_fieldsplit_0_)         1 MPI processes
>           type: ilu
>             ILU: out-of-place factorization
>             0 levels of fill
>             tolerance for zero pivot 2.22045e-14
>             using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
>             matrix ordering: natural
>             factor fill ratio given 1, needed 1
>               Factored matrix follows:
>                 Mat Object:                 1 MPI processes
>                   type: seqaij
>                   rows=48, cols=48
>                   package used to perform factorization: petsc
>                   total: nonzeros=576, allocated nonzeros=576
>                   total number of mallocs used during MatSetValues
> calls =0
>                     using I-node routines: found 16 nodes, limit used is 5
>           linear system matrix = precond matrix:
>           Mat Object:          (bf_fieldsplit_0_)   1 MPI processes
>             type: seqaij
>             rows=48, cols=48
>             total number of mallocs used during MatSetValues calls =0
>       KSP solver for S = A11 - A10 inv(A00) A01
>         KSP Object:        (bf_fieldsplit_temperature_)       1 MPI
> processes
>           type: gmres
>         PC Object:        (bf_fieldsplit_temperature_)       1 MPI
> processes
>           type: ilu
>             0 levels of fill
> [INBLOCKS]
>                   type: seqaij
>                   rows=16, cols=16
>                   total: nonzeros=64, allocated nonzeros=64
> calls =0
>                     not using I-node routines
>           linear system matrix followed by preconditioner matrix:
>           Mat Object:  (bf_fieldsplit_temperature_)           1 MPI
> processes
>             type: schurcomplement
>             rows=16, cols=16
>               Schur complement A11 - A10 inv(A00) A01
>               A11
>     1 MPI processes
>                   type: seqaij
>                   rows=16, cols=16
> calls =0
>               A10
>                   type: seqaij
>                   rows=16, cols=48
>                   total: nonzeros=192, allocated nonzeros=192
> calls =0
>               KSP of A00
> processes
>                   type: gmres
> divergence=10000
> processes
>                   type: ilu
>                     0 levels of fill
> pivot [INBLOCKS]
>                           type: seqaij
>                           rows=48, cols=48
> limit used is 5
> MPI processes
>                     type: seqaij
>                     rows=48, cols=48
> calls =0
> used is 5
>               A01
>                   type: seqaij
>                   rows=48, cols=16
> calls =0
> processes
>             type: seqaij
>             rows=16, cols=16
>       type: seqaij
>       rows=64, cols=64, bs=4
>       total: nonzeros=1024, allocated nonzeros=1024
>   Thanks,
>      Matt
> On Fri, Sep 26, 2014 at 8:52 AM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>     On Fri, Sep 26, 2014 at 7:29 AM, anton <popov at uni-mainz.de
>     <mailto:popov at uni-mainz.de>> wrote:
>         Create preconditioner:
>         PCCreate(PETSC_COMM_WORLD, &pc);
>         PCSetOptionsPrefix(pc, "bf_");
>         PCSetFromOptions(pc);
>         Define fieldsplit options:
>         -bf_pc_fieldsplit_type SCHUR
>         -bf_pc_fieldsplit_schur_factorization_type UPPER
>         Works OK.
>         Set options for the first field solver:
>         -bf_fieldsplit_0_ksp_type preonly
>         -bf_fieldsplit_0_pc_type lu
>         Doesn't work (ignored), because "bf_" prefix isn't pass to
>         inner solver ksp (checked in the debugger).
>         Indeed, the following works:
>         -fieldsplit_0_ksp_type preonly
>         -fieldsplit_0_pc_type lu
>         Observed with 3.5 but not with 3.4
>     I just tried this with master on SNES ex19, and got the correct
>     result:
>     knepley/feature-parallel-partition
>     *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex19
>       type: newtonls
>       total number of linear solver iterations=13
>         type: bt
>           alpha=1.000000e-04
>     lambda=1.000000e-08
>         type: gmres
>         type: fieldsplit
>           FieldSplit with MULTIPLICATIVE composition: total splits = 4
>           Solver info for each split is in the following KSP objects:
>           KSP Object:  (bf_fieldsplit_x_velocity_)       1 MPI processes
>             type: preonly
>             using NONE norm type for convergence test
>           PC Object:  (bf_fieldsplit_x_velocity_)       1 MPI processes
>             type: ilu
>               0 levels of fill
>     [INBLOCKS]
>                     type: seqaij
>                     rows=16, cols=16
>     calls =0
>             Mat Object:  (bf_fieldsplit_x_velocity_)         1 MPI
>     processes
>               type: seqaij
>               rows=16, cols=16
>           KSP Object:  (bf_fieldsplit_y_velocity_)       1 MPI processes
>             type: preonly
>           PC Object:  (bf_fieldsplit_y_velocity_)       1 MPI processes
>             type: ilu
>               0 levels of fill
>     [INBLOCKS]
>                     type: seqaij
>                     rows=16, cols=16
>     calls =0
>             Mat Object:  (bf_fieldsplit_y_velocity_)         1 MPI
>     processes
>               type: seqaij
>               rows=16, cols=16
>           Split number 2 Defined by IS
>           KSP Object:      (bf_fieldsplit_Omega_)     1 MPI processes
>             type: preonly
>           PC Object:      (bf_fieldsplit_Omega_)     1 MPI processes
>             type: ilu
>               0 levels of fill
>     [INBLOCKS]
>                     type: seqaij
>                     rows=16, cols=16
>     calls =0
>             Mat Object:  (bf_fieldsplit_Omega_)         1 MPI processes
>               type: seqaij
>               rows=16, cols=16
>           Split number 3 Defined by IS
>           KSP Object:  (bf_fieldsplit_temperature_)       1 MPI processes
>             type: preonly
>           PC Object:  (bf_fieldsplit_temperature_)       1 MPI processes
>             type: ilu
>               0 levels of fill
>     [INBLOCKS]
>                     type: seqaij
>                     rows=16, cols=16
>     calls =0
>     processes
>               type: seqaij
>               rows=16, cols=16
>           type: seqaij
>     I will try with 3.5.2.
>       Thanks,
>         Matt
>         Thanks.
>         Anton
>     What most experimenters take for granted before they begin their
>     experiments is infinitely more interesting than any results to
>     which their experiments lead.
>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140926/29f10a8c/attachment-0001.html>
