[petsc-users] fieldsplit doesn't pass prefix to inner ksp
Fri Sep 26 09:26:57 CDT 2014
Here is the result for 3.5.2, which looks right to me:
(v3.5.2) *:/PETSc3/petsc/release-petsc-3.5.1/src/snes/examples/tutorials$
./ex19 -bf_pc_type fieldsplit -bf_snes_view -bf_pc_fieldsplit_type schur
-bf_pc_fieldsplit_0_fields 0,1,2 -bf_pc_fieldsplit_1_fields 3
-bf_pc_fieldsplit_schur_factorization_type upper
lid velocity = 0.0625, prandtl # = 1, grashof # = 1
SNES Object:(bf_) 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=4
  total number of function evaluations=3
  SNESLineSearch Object:  (bf_)   1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object:  (bf_)   1 MPI processes
    type: gmres
      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object:  (bf_)   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization UPPER
      Preconditioner for the Schur complement formed from A11
      Split info:
      Split number 0 Defined by IS
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object:        (bf_fieldsplit_0_)         1 MPI processes
          type: gmres
        PC Object:        (bf_fieldsplit_0_)         1 MPI processes
          type: ilu
            ILU: out-of-place factorization
            0 levels of fill
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: natural
            factor fill ratio given 1, needed 1
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=48, cols=48
                  package used to perform factorization: petsc
                  total: nonzeros=576, allocated nonzeros=576
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 16 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object:          (bf_fieldsplit_0_)           1 MPI processes
            type: seqaij
            rows=48, cols=48
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (bf_fieldsplit_temperature_)         1 MPI
processes
          type: gmres
        PC Object:        (bf_fieldsplit_temperature_)         1 MPI
processes
          type: ilu
            0 levels of fill
                  type: seqaij
                  rows=16, cols=16
                  total: nonzeros=64, allocated nonzeros=64
                    not using I-node routines
          linear system matrix followed by preconditioner matrix:
          Mat Object:          (bf_fieldsplit_temperature_)           1 MPI
processes
            type: schurcomplement
            rows=16, cols=16
              Schur complement A11 - A10 inv(A00) A01
              A11
            1 MPI processes
                  type: seqaij
                  rows=16, cols=16
              A10
                  type: seqaij
                  rows=16, cols=48
                  total: nonzeros=192, allocated nonzeros=192
              KSP of A00
  1 MPI processes
                  type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
divergence=10000
  1 MPI processes
                  type: ilu
                    0 levels of fill
[INBLOCKS]
                          type: seqaij
                          rows=48, cols=48
calls =0
used is 5
        1 MPI processes
                    type: seqaij
                    rows=48, cols=48
=0
              A01
                  type: seqaij
                  rows=48, cols=16
processes
            type: seqaij
            rows=16, cols=16
      type: seqaij
      rows=64, cols=64, bs=4
      total: nonzeros=1024, allocated nonzeros=1024
Number of SNES iterations = 2
     Matt
On Fri, Sep 26, 2014 at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 26, 2014 at 7:29 AM, anton <popov at uni-mainz.de> wrote:
>> Create preconditioner:
>> PCCreate(PETSC_COMM_WORLD, &pc);
>> PCSetOptionsPrefix(pc, "bf_");
>> PCSetFromOptions(pc);
>> Define fieldsplit options:
>> -bf_pc_fieldsplit_type SCHUR
>> -bf_pc_fieldsplit_schur_factorization_type UPPER
>> Works OK.
>> Set options for the first field solver:
>> -bf_fieldsplit_0_ksp_type preonly
>> -bf_fieldsplit_0_pc_type lu
>> Doesn't work (ignored), because "bf_" prefix isn't pass to inner solver
>> ksp (checked in the debugger).
>> Indeed, the following works:
>> -fieldsplit_0_ksp_type preonly
>> -fieldsplit_0_pc_type lu
>> Observed with 3.5 but not with 3.4
> I just tried this with master on SNES ex19, and got the correct result:
> knepley/feature-parallel-partition
> *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex19 -bf_pc_type
>   type: newtonls
>   total number of linear solver iterations=13
>     type: bt
>       alpha=1.000000e-04
> lambda=1.000000e-08
>     type: gmres
>     type: fieldsplit
>       FieldSplit with MULTIPLICATIVE composition: total splits = 4
>       Solver info for each split is in the following KSP objects:
>       KSP Object:      (bf_fieldsplit_x_velocity_)       1 MPI processes
>         type: preonly
>         using NONE norm type for convergence test
>       PC Object:      (bf_fieldsplit_x_velocity_)       1 MPI processes
>         type: ilu
>           0 levels of fill
>                 type: seqaij
>                 rows=16, cols=16
>         Mat Object:        (bf_fieldsplit_x_velocity_)         1 MPI
> processes
>           type: seqaij
>           rows=16, cols=16
>       KSP Object:      (bf_fieldsplit_y_velocity_)       1 MPI processes
>         type: preonly
>       PC Object:      (bf_fieldsplit_y_velocity_)       1 MPI processes
>         type: ilu
>           0 levels of fill
>                 type: seqaij
>                 rows=16, cols=16
>         Mat Object:        (bf_fieldsplit_y_velocity_)         1 MPI
> processes
>           type: seqaij
>           rows=16, cols=16
>       Split number 2 Defined by IS
>       KSP Object:      (bf_fieldsplit_Omega_)       1 MPI processes
>         type: preonly
>       PC Object:      (bf_fieldsplit_Omega_)       1 MPI processes
>         type: ilu
>           0 levels of fill
>                 type: seqaij
>                 rows=16, cols=16
>         Mat Object:        (bf_fieldsplit_Omega_)         1 MPI processes
>           type: seqaij
>           rows=16, cols=16
>       Split number 3 Defined by IS
>       KSP Object:      (bf_fieldsplit_temperature_)       1 MPI processes
>         type: preonly
>       PC Object:      (bf_fieldsplit_temperature_)       1 MPI processes
>         type: ilu
>           0 levels of fill
>                 type: seqaij
>                 rows=16, cols=16
> processes
>           type: seqaij
>           rows=16, cols=16
>       type: seqaij
> I will try with 3.5.2.
>   Thanks,
>     Matt
>> Thanks.
>> Anton
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140926/919fa0b6/attachment-0001.html>
