[petsc-users] Generating xdmf from h5 file.
Wed Sep 24 17:36:52 CDT 2014
On Wed, Sep 24, 2014 at 5:29 PM, subramanya sadasiva <potaman at outlook.com>
wrote:
> Hi Matt,
> That did not help.
That's not enough description to fix anything, and fixing it will require
programming.
> Is there any other way to output the mesh to something that paraview can
> view?  I tried outputting the file to a vtk file using
> ex12 -dm_view vtk:my.vtk:ascii_vtk
> which, I saw in another post on the forums, but that did not give me any
> output.
This is mixing two different things. PETSc has a diagnostic ASCII vtk
output, so the type would be ascii, not vtk,
and format ascii_vtk . It also has a production VTU output, which is type
vtk with format vtk_vtu.
     Matt
> Subramanya
> Date: Wed, 24 Sep 2014 17:19:51 -0500
> Subject: Re: [petsc-users] Generating xdmf from h5 file.
> From: knepley at gmail.com
> To: potaman at outlook.com
> CC: petsc-users at mcs.anl.gov
> On Wed, Sep 24, 2014 at 5:08 PM, subramanya sadasiva <potaman at outlook.com>
> wrote:
> Hi,
> i was trying to use petsc_gen_xdmf.py to convert a h5 file to a xdmf file.
> The h5 file was generated by snes/ex12 which was run as,
> ex12 -dm_view hdf5:my.h5
> When I do,
> petsc_gen_xdmf.py my.h5
> I get the following error,
>  File "/home/ssadasiv/software/petsc/bin/pythonscripts/petsc_gen_xdmf.py",
> line 220, in <module>
>     generateXdmf(sys.argv[1])
>   File
> "/home/ssadasiv/software/petsc/bin/pythonscripts/petsc_gen_xdmf.py", line
> 208, in generateXdmf
>     time        = np.array(h5['time']).flatten()
>   File "/usr/lib/python2.7/dist-packages/h5py/_hl/group.py", line 153, in
> __getitem__
>     oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
>   File "h5o.pyx", line 173, in h5py.h5o.open (h5py/h5o.c:3403)
> KeyError: "unable to open object (Symbol table: Can't open object)"
> I am not sure if the error is on my end. This is on Ubuntu 14.04 with the
> serial version of hdf5. I built petsc with --download-hdf5, is it necessary
> to use the same version of hdf5 to generate the xdmf file?
> That code is alpha, and mainly built for me to experiment with an
> application here, so it is not user-friendly. In your
> HDF5 file, there is no 'time' since you are not running a TS. This access
> to h5['time'] should just be protected, and
> an empty array should be put in if its not there.
>   Matt
> Thanks
> Subramanya
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140924/6dc6d674/attachment.html>
