[petsc-users] Curiosity about MatSetOptionsPrefix on a_11 in PCSetUp_FieldSplit
Jed Brown jed at jedbrown.org
Thu Sep 11 20:17:28 CDT 2014
Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> writes:
> On 09/11/2014 12:52 PM, Matthew Knepley wrote:
>> On Thu, Sep 11, 2014 at 11:47 AM, Eric Chamberland
>> MatNest is absolutely the worst thing in the PETSc interface. You should
> Sounds so strange to me... :-)
MatNest is really supposed to be a backend optimization, not a public
interface.  Perhaps irresponsibly, we expose a few MatNest*() functions
because those interfaces are convenient for a few legacy applications
that made poor design/workflow decisions.  There are a few other
functions in PETSc with similar status, e.g.,
MatCreateMPIAIJWithSplitArrays(), but surely Matt would rate MatNest as
the most popular and harmful such interface.
> ... because we decided to use MatNest to create sub-matrices for linear
> vs quadratic parts of a velocity field
> (http://onlinelibrary.wiley.com/doi/10.1002/nla.757/abstract).  We
> choosed MatNest to minimize the memory used, and "overloaded" the
> MatSetValues calls to be able to do the assembly of u-u blocks in all 4
> sub-matrices (doing global to local conversions with strides only).
Better to work with local indices all along.  The result is cleaner and
faster.  I understand that this option may not be available due to prior
design choices.
> This prevent us to do 4 different loops over all the elements (in other
> words, it allows the assembly part of our code to not be aware that we
> are doing the assembly into a matnest)!  We just have to do the
> numbering of the dofs correctly before everything.
>> never ever ever ever
>> be calling MatNest directly. You should be assembling into one matrix
>> from views. Then MatNest
>> can be used for optimization in the background.
> By "views" you mean doing MatGetLocalSubMatrix and
> MatRestoreLocalSubMatrix like in
> http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex28.c.html
> but... If I do a velocity(u)-pressure(p) field problem, how do I fix a
> block size of 3 for the u-u part and 1 for other parts without using a
> MatNest (with sub-matrices with good options)?
The isrow and iscol arguments should have a block size of 3.  Then the
Mat returned by MatGetLocalSubMatrix will inherit this block size such
that MatSetValuesBlockedLocal behaves as desired.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140911/d78c7f8e/attachment.pgp>
