[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Christophe Ortiz christophe.ortiz at ciemat.es
Mon Sep 1 03:56:46 CDT 2014
Hi all,
Thanks a lot for your answers.
I followed Satish's advice and downloaded pets-dev. Then I tried to
configure it with CUDA 6.0. It complained because I did not have flex
installed, no big deal. Then it complained because it prefers GNU compilers
than Intel ones, no big deal.
This being fixed, I was able to configure and compile pets-dev with CUDA
6.0. There was no problem due to deprecated arch or thrust directory.
I configured it with the following options:
--with-x=1 --with-mpi=0 --with-cc=gcc --with-cxx=g++ --with-clanguage=cxx
--with-fc=gfortran --with-cuda=1 --with-cuda-dir=/usr/local/cuda-6.0
--with-cuda-arch=sm_35 --with-thrust=1
--with-thrust-dir=/usr/local/cuda-6.0/include/thrust --with-cusp=1
--with-cusp-dir=/usr/local/cuda-6.0/include/cusp --with-debugging=1
--with-scalar-type=real --with-precision=double --download-fblaslapack
Now this is done, how should I port my code to use it with CUDA ? Should I
change something and include some CUDA directives in the code ? Is there
some examples of makefile with nvcc that I could use ?
Thanks in advance.
Christophe
On Fri, Aug 29, 2014 at 6:29 PM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > On Fri, 29 Aug 2014, Dominic Meiser wrote:
> >> On 08/29/2014 08:31 AM, Matthew Knepley wrote:
> >> > On Fri, Aug 29, 2014 at 9:35 AM, Dominic Meiser <dmeiser at txcorp.com
> >> > <mailto:dmeiser at txcorp.com>> wrote:
> >> > >     Dominic, I think that thrust.py should depend on cuda.py. Do you
> >> > >     know why it does not?
> >> >     In principle you are right, thrust.py should depend on cuda.py.
> >> >     However, in my opinion, thrust.py should go away as a separate
> >> >     package altogether. Thrust is shipped as part of any recent
> >> >     version of the cuda toolkit (I forget since which version, Paul
> >> >     might know) and it's always installed in
> >> >     $CUDA_TOOLKIT_ROOT/include/thrust. Thus we can automatically
> >> >     deduct the thrust location from the cuda location. Thrust should
> >> >     be considered part of cuda.
> > I also think it should be removed.
> Agreed.  If it was correct to consolidate umfpack, cholmod, etc., into
> suitesparse, then there is no question that thrust should be
> consolidated into cuda.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140901/8699a397/attachment.html>
