[petsc-users] fieldsplit_0_ monitor in combination with selfp
Klaij, Christiaan C.Klaij at marin.nl
Mon Sep 8 02:45:29 CDT 2014
Matt,
Thanks for clarifying this issue (default preonly for A00 seems
rather strange to me). Anyway, in summary:
1) Nothing wrong with ex70.c, one just needs to explicitly
specifiy "-fieldsplit_0_ksp_type gmres" to avoid the default
preonly for A00 in the diagonal.
2) I've verified using petsc-3.5.1 that "out-of-the-box" SIMPLE
mpiexec -n 2 ./ex70 -nx 4 -ny 6 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -pc_fieldsplit_schur_precondition selfp -fieldsplit_1_inner_ksp_type preonly -fieldsplit_1_inner_pc_type jacobi -fieldsplit_0_ksp_monitor -fieldsplit_1_ksp_monitor -ksp_monitor -fieldsplit_0_ksp_type gmres > out1
gives almost the same as "user" SIMPLE
mpiexec -n 2 ./ex70 -nx 4 -ny 6 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -user_ksp -fieldsplit_0_ksp_monitor -fieldsplit_1_ksp_monitor -ksp_monitor > out2
as it should. See attachments for out1 and out2.
3) "out-of-the-box" SIMPLE is easier because the user doesn't
need to make the Schur approximation, thanks for adding this to
PETSc!
Chris
MARIN news: Development of a Scaled-Down Floating Wind Turbine for Offshore Basin Testing<http://www.marin.nl/web/News/News-items/Development-of-a-ScaledDown-Floating-Wind-Turbine-for-Offshore-Basin-Testing-1.htm>
This e-mail may be confidential, privileged and/or protected by copyright. If you are not the intended recipient, you should return it to the sender immediately and delete your copy from your system.
Sent: Friday, September 05, 2014 5:38 PM
To: Klaij, Christiaan
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] fieldsplit_0_ monitor in combination with selfp
On Fri, Sep 5, 2014 at 7:31 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Thanks! I've spotted another difference: you are setting the
fieldsplit_0_ksp_type and I'm not, just relying on the default
instead. If I add -fieldsplit_0_ksp_type gmres then is also get
the correct answer. Probably, you will get my problem if you
remove -fieldsplit_velocity.
This is not a bug. The default solver for A00 is preonly, unless it is used as the inner
solver as well, in which case it defaults to GMRES so as not to give an inexact
Schur complement by default.
ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_pressure_pc_type jacobi -snes_monitor_short -ksp_monitor_short -snes_converged_reason -snes_view -show_solution 0 -fieldsplit_pressure_inner_ksp_type gmres -fieldsplit_pressure_inner_ksp_max_it 1 -fieldsplit_pressure_inner_pc_type jacobi -pc_fieldsplit_schur_precondition selfp
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=77
  total number of function evaluations=2
  SNESLineSearch Object:   1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
    maximum iterations=40
  KSP Object:   1 MPI processes
    type: fgmres
      GMRES: restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
    right preconditioning
    has attached null space
    using UNPRECONDITIONED norm type for convergence test
  PC Object:   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization FULL
      Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (the lumped) A00's diagonal's inverse
      Split info:
      Split number 0 Defined by IS
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object:        (fieldsplit_velocity_)         1 MPI processes
          type: preonly
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          left preconditioning
          using NONE norm type for convergence test
        PC Object:        (fieldsplit_velocity_)         1 MPI processes
          type: ilu
            ILU: out-of-place factorization
            0 levels of fill
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: natural
            factor fill ratio given 1, needed 1
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=962, cols=962
                  package used to perform factorization: petsc
                  total: nonzeros=19908, allocated nonzeros=19908
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 481 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object:          (fieldsplit_velocity_)           1 MPI processes
            type: seqaij
            rows=962, cols=962
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (fieldsplit_pressure_)         1 MPI processes
          type: gmres
            GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
          tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
          using PRECONDITIONED norm type for convergence test
        PC Object:        (fieldsplit_pressure_)         1 MPI processes
          type: jacobi
          linear system matrix followed by preconditioner matrix:
          Mat Object:          (fieldsplit_pressure_)           1 MPI processes
            type: schurcomplement
            rows=145, cols=145
              Schur complement A11 - A10 inv(A00) A01
              A11
                  type: seqaij
                  rows=145, cols=145
                  total: nonzeros=945, allocated nonzeros=945
                    not using I-node routines
              A10
                  type: seqaij
                  rows=145, cols=962
                  total: nonzeros=4466, allocated nonzeros=4466
              KSP of A00
                KSP Object:                (fieldsplit_pressure_inner_)                 1 MPI processes
                  type: gmres
                  maximum iterations=1, initial guess is zero
                PC Object:                (fieldsplit_pressure_inner_)                 1 MPI processes
                  type: jacobi
                    type: seqaij
                    rows=962, cols=962
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
            total: nonzeros=2601, allocated nonzeros=2601
      type: seqaij
      rows=1107, cols=1107
      total: nonzeros=29785, allocated nonzeros=29785
        using I-node routines: found 513 nodes, limit used is 5
   Matt
mpiexec -n 2 ./ex70 -nx 4 -ny 6 \
-ksp_type fgmres \
-pc_type fieldsplit \
-pc_fieldsplit_type schur \
-pc_fieldsplit_schur_fact_type lower \
-pc_fieldsplit_schur_precondition selfp \
-fieldsplit_1_inner_ksp_type preonly \
-fieldsplit_1_inner_pc_type jacobi \
-fieldsplit_0_ksp_monitor -fieldsplit_0_ksp_max_it 1 \
-fieldsplit_1_ksp_monitor -fieldsplit_1_ksp_max_it 1 \
-ksp_monitor -ksp_max_it 1 \
-fieldsplit_0_ksp_type gmres -ksp_view
KSP Object: 2 MPI processes
  type: fgmres
PC Object: 2 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization LOWER
    Split info:
      KSP Object:      (fieldsplit_0_)       2 MPI processes
        type: gmres
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Friday, September 05, 2014 2:10 PM
To: Klaij, Christiaan; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Fri, Sep 5, 2014 at 1:34 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Matt,
I think the problem is somehow related to -pc_fieldsplit_schur_precondition selfp. In the example below your are not using that option.
Here is the selfp output. It retains the A00 solver.
ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi -snes_monitor_short -ksp_monitor_short -snes_converged_reason -ksp_converged_reason -snes_view -show_solution 0 -fieldsplit_pressure_inner_ksp_type preonly -fieldsplit_pressure_inner_pc_type jacobi -pc_fieldsplit_schur_precondition selfp
  type: newtonls
  total number of linear solver iterations=20
    type: bt
      alpha=1.000000e-04
    type: fgmres
    type: fieldsplit
      Split info:
          type: gmres
          type: lu
            matrix ordering: nd
            factor fill ratio given 5, needed 3.45047
                  type: seqaij
                  rows=962, cols=962
                  total: nonzeros=68692, allocated nonzeros=68692
                    using I-node routines: found 456 nodes, limit used is 5
            type: seqaij
            rows=962, cols=962
          type: gmres
          type: jacobi
            rows=145, cols=145
              A11
                  type: seqaij
                  rows=145, cols=145
              A10
                  type: seqaij
                  rows=145, cols=962
              KSP of A00
                  type: preonly
                  type: jacobi
                    type: seqaij
                    rows=962, cols=962
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
      type: seqaij
    Matt
Chris
[cid:imagea7316f.JPG at f7909bee.44832f74][cid:image4a95d2.JPG at 67db08fd.4e9b7a1c]
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
MARIN
        2, Haagsteeg
E C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>     P.O. Box 28     T +31 317 49 39 11<tel:%2B31%20317%2049%2039%2011>
        6700 AA Wageningen      F +31 317 49 32 45<tel:%2B31%20317%2049%2032%2045>
T  +31 317 49 33 44<tel:%2B31%20317%2049%2033%2044>     The Netherlands I  www.marin.nl<http://www.marin.nl>
MARIN news: MARIN at SMM, Hamburg, September 9-12<http://www.marin.nl/web/News/News-items/MARIN-at-SMM-Hamburg-September-912.htm>
Sent: Friday, September 05, 2014 12:36 AM
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Thu, Sep 4, 2014 at 7:26 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Sorry, here's the ksp_view. I'm expecting
to set the ksp(A00) in the Schur complement only, but it seems to set it in the inv(A00) of the diagonal as well.
I think something is wrong in your example (we strongly advise against using MatNest directly). I cannot reproduce this using SNES ex62:
  ./config/builder2.py check src/snes/examples/tutorials/ex62.c --testnum=36 --args="-fieldsplit_pressure_inner_ksp_type preonly -fieldsplit_pressure_inner_pc_type jacobi"
which translates to
gives
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
  type: newtonls
    type: bt
      alpha=1.000000e-04
    type: fgmres
    type: fieldsplit
      Preconditioner for the Schur complement formed from A11
      Split info:
          type: gmres
          type: lu
            matrix ordering: nd
                  type: seqaij
                  rows=962, cols=962
            type: seqaij
            rows=962, cols=962
          type: gmres
          type: jacobi
            rows=145, cols=145
              A11
                  type: seqaij
                  rows=145, cols=145
              A10
                  type: seqaij
                  rows=145, cols=962
              KSP of A00
                  type: preonly
                  type: jacobi
                    type: seqaij
                    rows=962, cols=962
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
      type: seqaij
   Matt
Chris
  0 KSP Residual norm 1.229687498638e+00
    Residual norms for fieldsplit_1_ solve.
    0 KSP Residual norm 7.185799114488e+01
    1 KSP Residual norm 3.873274154012e+01
  1 KSP Residual norm 1.107969383366e+00
  type: fgmres
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: preonly
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 1
          Local solve is same for all blocks, in the following KSP and PC objects:
          KSP Object:          (fieldsplit_0_sub_)           1 MPI processes
            type: preonly
          PC Object:          (fieldsplit_0_sub_)           1 MPI processes
            type: ilu
              0 levels of fill
                    type: seqaij
                    rows=48, cols=48
                    total: nonzeros=200, allocated nonzeros=200
            Mat Object:            (fieldsplit_0_)             1 MPI processes
              type: seqaij
              rows=48, cols=48
              total: nonzeros=200, allocated nonzeros=240
          type: mpiaij
          rows=48, cols=48
          total: nonzeros=200, allocated nonzeros=480
            not using I-node (on process 0) routines
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: bjacobi
          KSP Object:          (fieldsplit_1_sub_)           1 MPI processes
            type: preonly
          PC Object:          (fieldsplit_1_sub_)           1 MPI processes
            type: bjacobi
              KSP Object:              (fieldsplit_1_sub_sub_)               1 MPI processes
                type: preonly
              PC Object:              (fieldsplit_1_sub_sub_)               1 MPI processes
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=24, cols=24
                        total: nonzeros=120, allocated nonzeros=120
                  type: seqaij
                  rows=24, cols=24
              type: mpiaij
              rows=24, cols=24
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          rows=24, cols=24
            A11
                type: mpiaij
                rows=24, cols=24
                total: nonzeros=0, allocated nonzeros=0
                  using I-node (on process 0) routines: found 5 nodes, limit used is 5
            A10
              Mat Object:              (a10_)               1 MPI processes
                type: mpiaij
                rows=24, cols=48
                total: nonzeros=96, allocated nonzeros=96
            KSP of A00
              KSP Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: preonly
              PC Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: jacobi
                  type: mpiaij
                  rows=48, cols=48
            A01
              Mat Object:              (a01_)               1 MPI processes
                type: mpiaij
                rows=48, cols=24
                total: nonzeros=96, allocated nonzeros=480
          type: mpiaij
          rows=24, cols=24
    type: nest
    rows=72, cols=72
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=48, cols=48
        (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
        (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
        (1,1) : prefix="fieldsplit_1_", type=mpiaij, rows=24, cols=24
Sent: Thursday, September 04, 2014 2:20 PM
On Thu, Sep 4, 2014 at 7:06 AM, Klaij, Christiaan  <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
 I'm playing with the selfp option in fieldsplit using
snes/examples/tutorials/ex70.c. For example:
-ksp_type fgmres \
gives the following output
    0 KSP Residual norm 2.330138480101e+01
    1 KSP Residual norm 1.609000846751e+01
  1 KSP Residual norm 1.180287268335e+00
To my suprise I don't see anything for the fieldsplit_0_ solve,
why?
Always run with -ksp_view for any solver question.
    Matt
   Furthermore, if I understand correctly the above should be
exactly equivalent with
-ksp_type fgmres \
-user_ksp \
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 5.486639587672e-01
    1 KSP Residual norm 6.348354253703e-02
    0 KSP Residual norm 2.321938107977e+01
    1 KSP Residual norm 1.605484031258e+01
  1 KSP Residual norm 1.183225251166e+00
because -user_ksp replaces the Schur complement by the simple
approximation A11 - A10 inv(diag(A00)) A01. Beside the missing
fielsplit_0_ part, the numbers are pretty close but not exactly
the same. Any explanation?
Chris
CFD Researcher
E mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11<tel:%2B31%20317%2049%2039%2011>, F +31 317 49 32 45<tel:%2B31%20317%2049%2032%2045>, I www.marin.nl<http://www.marin.nl>
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140908/706d8d98/attachment-0001.html>
Type: image/jpeg
Desc: image4a95d2.JPG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140908/706d8d98/attachment-0002.jpe>
Type: image/jpeg
Desc: imagea7316f.JPG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140908/706d8d98/attachment-0003.jpe>
Desc: out1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140908/706d8d98/attachment-0002.obj>
Desc: out2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140908/706d8d98/attachment-0003.obj>
