[petsc-users] fieldsplit_0_ monitor in combination with selfp
Fri Sep 5 10:38:37 CDT 2014
On Fri, Sep 5, 2014 at 7:31 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>   Thanks! I've spotted another difference: you are setting the
> fieldsplit_0_ksp_type and I'm not, just relying on the default
> instead. If I add -fieldsplit_0_ksp_type gmres then is also get
> the correct answer. Probably, you will get my problem if you
> remove -fieldsplit_velocity.
This is not a bug. The default solver for A00 is preonly, unless it is used
as the inner
solver as well, in which case it defaults to GMRES so as not to give an
inexact
Schur complement by default.
ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
-interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type
fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
-pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full
-fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_pressure_pc_type jacobi
-snes_monitor_short -ksp_monitor_short -snes_converged_reason -snes_view
-show_solution 0 -fieldsplit_pressure_inner_ksp_type gmres
-fieldsplit_pressure_inner_ksp_max_it 1 -fieldsplit_pressure_inner_pc_type
jacobi -pc_fieldsplit_schur_precondition selfp
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=77
  total number of function evaluations=2
  SNESLineSearch Object:   1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object:   1 MPI processes
    type: fgmres
      GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
    right preconditioning
    has attached null space
    using UNPRECONDITIONED norm type for convergence test
  PC Object:   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization FULL
      Preconditioner for the Schur complement formed from Sp, an assembled
approximation to S, which uses (the lumped) A00's diagonal's inverse
      Split info:
      Split number 0 Defined by IS
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object:        (fieldsplit_velocity_)         1 MPI processes
          type: preonly
          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
          left preconditioning
          using NONE norm type for convergence test
        PC Object:        (fieldsplit_velocity_)         1 MPI processes
          type: ilu
            ILU: out-of-place factorization
            0 levels of fill
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: natural
            factor fill ratio given 1, needed 1
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=962, cols=962
                  package used to perform factorization: petsc
                  total: nonzeros=19908, allocated nonzeros=19908
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 481 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object:          (fieldsplit_velocity_)           1 MPI
processes
            type: seqaij
            rows=962, cols=962
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (fieldsplit_pressure_)         1 MPI processes
          type: gmres
            GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
          tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
          using PRECONDITIONED norm type for convergence test
        PC Object:        (fieldsplit_pressure_)         1 MPI processes
          type: jacobi
          linear system matrix followed by preconditioner matrix:
          Mat Object:          (fieldsplit_pressure_)           1 MPI
processes
            type: schurcomplement
            rows=145, cols=145
              Schur complement A11 - A10 inv(A00) A01
              A11
      1 MPI processes
                  type: seqaij
                  rows=145, cols=145
                  total: nonzeros=945, allocated nonzeros=945
                    not using I-node routines
              A10
                  type: seqaij
                  rows=145, cols=962
                  total: nonzeros=4466, allocated nonzeros=4466
              KSP of A00
                KSP Object:                (fieldsplit_pressure_inner_)
            1 MPI processes
                  type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
                  maximum iterations=1, initial guess is zero
divergence=10000
                PC Object:                (fieldsplit_pressure_inner_)
            1 MPI processes
                  type: jacobi
            1 MPI processes
                    type: seqaij
                    rows=962, cols=962
=0
5
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
            total: nonzeros=2601, allocated nonzeros=2601
      type: seqaij
      rows=1107, cols=1107
      total: nonzeros=29785, allocated nonzeros=29785
        using I-node routines: found 513 nodes, limit used is 5
   Matt
> mpiexec -n 2 ./ex70 -nx 4 -ny 6 \
> -ksp_type fgmres \
> -pc_type fieldsplit \
> -pc_fieldsplit_type schur \
> -pc_fieldsplit_schur_fact_type lower \
> -pc_fieldsplit_schur_precondition selfp \
> -fieldsplit_1_inner_ksp_type preonly \
> -fieldsplit_1_inner_pc_type jacobi \
> -fieldsplit_0_ksp_monitor -fieldsplit_0_ksp_max_it 1 \
> -fieldsplit_1_ksp_monitor -fieldsplit_1_ksp_max_it 1 \
> -ksp_monitor -ksp_max_it 1 \
> -fieldsplit_0_ksp_type gmres -ksp_view
> KSP Object: 2 MPI processes
>   type: fgmres
> PC Object: 2 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization LOWER
>     Split info:
>       KSP Object:      (fieldsplit_0_)       2 MPI processes
>         type: gmres
> MARIN news: Development of a Scaled-Down Floating Wind Turbine for
> Offshore Basin Testing
> <http://www.marin.nl/web/News/News-items/Development-of-a-ScaledDown-Floating-Wind-Turbine-for-Offshore-Basin-Testing-1.htm>
> This e-mail may be confidential, privileged and/or protected by copyright.
> If you are not the intended recipient, you should return it to the sender
> immediately and delete your copy from your system.
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Friday, September 05, 2014 2:10 PM
> *To:* Klaij, Christiaan; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] fieldsplit_0_ monitor in combination with
> selfp
>   On Fri, Sep 5, 2014 at 1:34 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
>>   Matt,
>> I think the problem is somehow related to
>> -pc_fieldsplit_schur_precondition selfp. In the example below your are not
>> using that option.
>  Here is the selfp output. It retains the A00 solver.
> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
> -ksp_converged_reason -snes_view -show_solution 0
> -fieldsplit_pressure_inner_ksp_type preonly
> -fieldsplit_pressure_inner_pc_type jacobi -pc_fieldsplit_schur_precondition
> selfp
>   type: newtonls
>   total number of linear solver iterations=20
>     type: bt
>       alpha=1.000000e-04
> lambda=1.000000e-08
>     type: fgmres
>     type: fieldsplit
>       Split info:
>           type: gmres
>           type: lu
>             matrix ordering: nd
>             factor fill ratio given 5, needed 3.45047
>                   type: seqaij
>                   rows=962, cols=962
>                   total: nonzeros=68692, allocated nonzeros=68692
>                     using I-node routines: found 456 nodes, limit used is 5
> processes
>             type: seqaij
>             rows=962, cols=962
>           type: gmres
>           type: jacobi
> processes
>             rows=145, cols=145
>               A11
>         1 MPI processes
>                   type: seqaij
>                   rows=145, cols=145
>               A10
>                   type: seqaij
>                   rows=145, cols=962
>               KSP of A00
>               1 MPI processes
>                   type: preonly
> divergence=10000
>             1 MPI processes
>                   type: jacobi
>               1 MPI processes
>                     type: seqaij
>                     rows=962, cols=962
> =0
> is 5
>               A01
>                   type: seqaij
>                   rows=962, cols=145
>             type: seqaij
>             rows=145, cols=145
>       type: seqaij
>    Thanks,
>      Matt
>>  Chris
>>     dr. ir. Christiaan Klaij
>> CFD Researcher
>>   Research & Development
>> *MARIN*
>>   2, Haagsteeg  E C.Klaij at marin.nl P.O. Box 28 T +31 317 49 39 11  6700
>> AA Wageningen F +31 317 49 32 45  T  +31 317 49 33 44 The Netherlands I
>> www.marin.nl
>> MARIN news: MARIN at SMM, Hamburg, September 9-12
>> <http://www.marin.nl/web/News/News-items/MARIN-at-SMM-Hamburg-September-912.htm>
>> copyright. If you are not the intended recipient, you should return it to
>> the sender immediately and delete your copy from your system.
>> *Sent:* Friday, September 05, 2014 12:36 AM
>> *Cc:* petsc-users at mcs.anl.gov
>> selfp
>>   On Thu, Sep 4, 2014 at 7:26 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>>> Sorry, here's the ksp_view. I'm expecting
>>> to set the ksp(A00) in the Schur complement only, but it seems to set it
>>> in the inv(A00) of the diagonal as well.
>>  I think something is wrong in your example (we strongly advise against
>> using MatNest directly). I cannot reproduce this using SNES ex62:
>>    ./config/builder2.py check src/snes/examples/tutorials/ex62.c
>> --testnum=36 --args="-fieldsplit_pressure_inner_ksp_type preonly
>> -fieldsplit_pressure_inner_pc_type jacobi"
>>  which translates to
>>  gives
>>    Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
>>   type: newtonls
>>     type: bt
>>       alpha=1.000000e-04
>> lambda=1.000000e-08
>>     type: fgmres
>>     type: fieldsplit
>>       Preconditioner for the Schur complement formed from A11
>>       Split info:
>>           type: gmres
>>           type: lu
>>             matrix ordering: nd
>>                   type: seqaij
>>                   rows=962, cols=962
>> =0
>> 5
>> processes
>>             type: seqaij
>>             rows=962, cols=962
>>           type: gmres
>>           type: jacobi
>> processes
>>             rows=145, cols=145
>>               A11
>>         1 MPI processes
>>                   type: seqaij
>>                   rows=145, cols=145
>> =0
>>               A10
>>                   type: seqaij
>>                   rows=145, cols=962
>> =0
>>               KSP of A00
>>               1 MPI processes
>>                   type: preonly
>> divergence=10000
>>               1 MPI processes
>>                   type: jacobi
>>               1 MPI processes
>>                     type: seqaij
>>                     rows=962, cols=962
>> calls =0
>> is 5
>>               A01
>>                   type: seqaij
>>                   rows=962, cols=145
>> =0
>> 5
>> processes
>>             type: seqaij
>>             rows=145, cols=145
>>       type: seqaij
>>     Matt
>>> Chris
>>>   0 KSP Residual norm 1.229687498638e+00
>>>     Residual norms for fieldsplit_1_ solve.
>>>     0 KSP Residual norm 7.185799114488e+01
>>>     1 KSP Residual norm 3.873274154012e+01
>>>   1 KSP Residual norm 1.107969383366e+00
>>>   type: fgmres
>>>   type: fieldsplit
>>>     Split info:
>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: preonly
>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: bjacobi
>>>           block Jacobi: number of blocks = 1
>>>           Local solve is same for all blocks, in the following KSP and
>>> PC objects:
>>>           KSP Object:          (fieldsplit_0_sub_)           1 MPI
>>> processes
>>>             type: preonly
>>>           PC Object:          (fieldsplit_0_sub_)           1 MPI
>>> processes
>>>             type: ilu
>>>               0 levels of fill
>>> [INBLOCKS]
>>>                     type: seqaij
>>>                     rows=48, cols=48
>>>                     total: nonzeros=200, allocated nonzeros=200
>>> calls =0
>>>             Mat Object:            (fieldsplit_0_)             1 MPI
>>> processes
>>>               type: seqaij
>>>               rows=48, cols=48
>>>               total: nonzeros=200, allocated nonzeros=240
>>>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>>>           type: mpiaij
>>>           rows=48, cols=48
>>>           total: nonzeros=200, allocated nonzeros=480
>>>             not using I-node (on process 0) routines
>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: gmres
>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: bjacobi
>>> PC objects:
>>>           KSP Object:          (fieldsplit_1_sub_)           1 MPI
>>> processes
>>>             type: preonly
>>>           PC Object:          (fieldsplit_1_sub_)           1 MPI
>>> processes
>>>             type: bjacobi
>>> and PC objects:
>>>               KSP Object:
>>> (fieldsplit_1_sub_sub_)               1 MPI processes
>>>                 type: preonly
>>> divergence=10000
>>>               PC Object:
>>>                 type: ilu
>>>                   0 levels of fill
>>> [INBLOCKS]
>>>                         type: seqaij
>>>                         rows=24, cols=24
>>>                         total: nonzeros=120, allocated nonzeros=120
>>> calls =0
>>>                   type: seqaij
>>>                   rows=24, cols=24
>>> =0
>>>               type: mpiaij
>>>               rows=24, cols=24
>>>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>>>           rows=24, cols=24
>>>             A11
>>> MPI processes
>>>                 type: mpiaij
>>>                 rows=24, cols=24
>>>                 total: nonzeros=0, allocated nonzeros=0
>>>                   using I-node (on process 0) routines: found 5 nodes,
>>> limit used is 5
>>>             A10
>>>               Mat Object:              (a10_)               1 MPI
>>> processes
>>>                 type: mpiaij
>>>                 rows=24, cols=48
>>>                 total: nonzeros=96, allocated nonzeros=96
>>>             KSP of A00
>>>               KSP Object:
>>> (fieldsplit_1_inner_)               1 MPI processes
>>>                 type: preonly
>>> divergence=10000
>>>               PC Object:
>>>                 type: jacobi
>>>                 Mat Object:
>>>                   type: mpiaij
>>>                   rows=48, cols=48
>>> =0
>>>             A01
>>>               Mat Object:              (a01_)               1 MPI
>>> processes
>>>                 type: mpiaij
>>>                 rows=48, cols=24
>>>                 total: nonzeros=96, allocated nonzeros=480
>>>           type: mpiaij
>>>           rows=24, cols=24
>>>     type: nest
>>>     rows=72, cols=72
>>>       Matrix object:
>>>         type=nest, rows=2, cols=2
>>>         MatNest structure:
>>>         (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=48, cols=48
>>>         (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
>>>         (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
>>>         (1,1) : prefix="fieldsplit_1_", type=mpiaij, rows=24, cols=24
>>> From: Matthew Knepley <knepley at gmail.com>
>>> Sent: Thursday, September 04, 2014 2:20 PM
>>> To: Klaij, Christiaan
>>> Cc: petsc-users at mcs.anl.gov
>>> Subject: Re: [petsc-users] fieldsplit_0_ monitor in combination with
>>> selfp
>>> On Thu, Sep 4, 2014 at 7:06 AM, Klaij, Christiaan  <C.Klaij at marin.nl>
>>> wrote:
>>>  I'm playing with the selfp option in fieldsplit using
>>> snes/examples/tutorials/ex70.c. For example:
>>> -ksp_type fgmres \
>>> gives the following output
>>>     0 KSP Residual norm 2.330138480101e+01
>>>     1 KSP Residual norm 1.609000846751e+01
>>>   1 KSP Residual norm 1.180287268335e+00
>>> To my suprise I don't see anything for the fieldsplit_0_ solve,
>>> why?
>>> Always run with -ksp_view for any solver question.
>>>   Thanks,
>>>     Matt
>>>    Furthermore, if I understand correctly the above should be
>>> exactly equivalent with
>>> -ksp_type fgmres \
>>> -user_ksp \
>>>     Residual norms for fieldsplit_0_ solve.
>>>     0 KSP Residual norm 5.486639587672e-01
>>>     1 KSP Residual norm 6.348354253703e-02
>>>     0 KSP Residual norm 2.321938107977e+01
>>>     1 KSP Residual norm 1.605484031258e+01
>>>   1 KSP Residual norm 1.183225251166e+00
>>> because -user_ksp replaces the Schur complement by the simple
>>> approximation A11 - A10 inv(diag(A00)) A01. Beside the missing
>>> fielsplit_0_ part, the numbers are pretty close but not exactly
>>> the same. Any explanation?
>>> Chris
>>> CFD Researcher
>>> E mailto:C.Klaij at marin.nl
>>> T +31 317 49 33 44
>>> MARIN
>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/1693045a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/1693045a/attachment-0002.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/1693045a/attachment-0003.jpe>
