[petsc-users] fieldsplit_0_ monitor in combination with selfp
Klaij, Christiaan C.Klaij at marin.nl
Fri Sep 5 07:31:29 CDT 2014
Thanks! I've spotted another difference: you are setting the
fieldsplit_0_ksp_type and I'm not, just relying on the default
instead. If I add -fieldsplit_0_ksp_type gmres then is also get
the correct answer. Probably, you will get my problem if you
remove -fieldsplit_velocity.
mpiexec -n 2 ./ex70 -nx 4 -ny 6 \
-ksp_type fgmres \
-pc_type fieldsplit \
-pc_fieldsplit_type schur \
-pc_fieldsplit_schur_fact_type lower \
-pc_fieldsplit_schur_precondition selfp \
-fieldsplit_1_inner_ksp_type preonly \
-fieldsplit_1_inner_pc_type jacobi \
-fieldsplit_0_ksp_monitor -fieldsplit_0_ksp_max_it 1 \
-fieldsplit_1_ksp_monitor -fieldsplit_1_ksp_max_it 1 \
-ksp_monitor -ksp_max_it 1 \
-fieldsplit_0_ksp_type gmres -ksp_view
KSP Object: 2 MPI processes
  type: fgmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=1, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 2 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization LOWER
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (the lumped) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       2 MPI processes
        type: gmres
MARIN news: Development of a Scaled-Down Floating Wind Turbine for Offshore Basin Testing<http://www.marin.nl/web/News/News-items/Development-of-a-ScaledDown-Floating-Wind-Turbine-for-Offshore-Basin-Testing-1.htm>
This e-mail may be confidential, privileged and/or protected by copyright. If you are not the intended recipient, you should return it to the sender immediately and delete your copy from your system.
Sent: Friday, September 05, 2014 2:10 PM
To: Klaij, Christiaan; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] fieldsplit_0_ monitor in combination with selfp
On Fri, Sep 5, 2014 at 1:34 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Matt,
I think the problem is somehow related to -pc_fieldsplit_schur_precondition selfp. In the example below your are not using that option.
Here is the selfp output. It retains the A00 solver.
ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi -snes_monitor_short -ksp_monitor_short -snes_converged_reason -ksp_converged_reason -snes_view -show_solution 0 -fieldsplit_pressure_inner_ksp_type preonly -fieldsplit_pressure_inner_pc_type jacobi -pc_fieldsplit_schur_precondition selfp
SNES Object: 1 MPI processes
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=20
  total number of function evaluations=2
  SNESLineSearch Object:   1 MPI processes
    type: bt
      interpolation: cubic
      alpha=1.000000e-04
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
    maximum iterations=40
  KSP Object:   1 MPI processes
    type: fgmres
      GMRES: restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
    has attached null space
  PC Object:   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization FULL
      Split info:
        KSP Object:        (fieldsplit_velocity_)         1 MPI processes
          type: gmres
          left preconditioning
          using PRECONDITIONED norm type for convergence test
        PC Object:        (fieldsplit_velocity_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 3.45047
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=962, cols=962
                  package used to perform factorization: petsc
                  total: nonzeros=68692, allocated nonzeros=68692
                  total number of mallocs used during MatSetValues calls =0
                    using I-node routines: found 456 nodes, limit used is 5
          linear system matrix = precond matrix:
          Mat Object:          (fieldsplit_velocity_)           1 MPI processes
            type: seqaij
            rows=962, cols=962
            total: nonzeros=19908, allocated nonzeros=19908
              using I-node routines: found 481 nodes, limit used is 5
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (fieldsplit_pressure_)         1 MPI processes
          type: gmres
          tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
        PC Object:        (fieldsplit_pressure_)         1 MPI processes
          type: jacobi
          linear system matrix followed by preconditioner matrix:
          Mat Object:          (fieldsplit_pressure_)           1 MPI processes
            type: schurcomplement
            rows=145, cols=145
              Schur complement A11 - A10 inv(A00) A01
              A11
                  type: seqaij
                  rows=145, cols=145
                  total: nonzeros=945, allocated nonzeros=945
                    not using I-node routines
              A10
                  type: seqaij
                  rows=145, cols=962
                  total: nonzeros=4466, allocated nonzeros=4466
              KSP of A00
                KSP Object:                (fieldsplit_pressure_inner_)                 1 MPI processes
                  type: preonly
                  using NONE norm type for convergence test
                PC Object:                (fieldsplit_pressure_inner_)                 1 MPI processes
                  type: jacobi
                    type: seqaij
                    rows=962, cols=962
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
            total: nonzeros=2601, allocated nonzeros=2601
      type: seqaij
      rows=1107, cols=1107
      total: nonzeros=29785, allocated nonzeros=29785
        using I-node routines: found 513 nodes, limit used is 5
    Matt
Chris
[cid:imagea7316f.JPG at f7909bee.44832f74][cid:image4a95d2.JPG at 67db08fd.4e9b7a1c]
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
MARIN
        2, Haagsteeg
E C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>     P.O. Box 28     T +31 317 49 39 11<tel:%2B31%20317%2049%2039%2011>
        6700 AA Wageningen      F +31 317 49 32 45<tel:%2B31%20317%2049%2032%2045>
T  +31 317 49 33 44<tel:%2B31%20317%2049%2033%2044>     The Netherlands I  www.marin.nl<http://www.marin.nl>
MARIN news: MARIN at SMM, Hamburg, September 9-12<http://www.marin.nl/web/News/News-items/MARIN-at-SMM-Hamburg-September-912.htm>
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Friday, September 05, 2014 12:36 AM
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Thu, Sep 4, 2014 at 7:26 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Sorry, here's the ksp_view. I'm expecting
to set the ksp(A00) in the Schur complement only, but it seems to set it in the inv(A00) of the diagonal as well.
I think something is wrong in your example (we strongly advise against using MatNest directly). I cannot reproduce this using SNES ex62:
  ./config/builder2.py check src/snes/examples/tutorials/ex62.c --testnum=36 --args="-fieldsplit_pressure_inner_ksp_type preonly -fieldsplit_pressure_inner_pc_type jacobi"
which translates to
gives
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
  type: newtonls
    type: bt
      alpha=1.000000e-04
    type: fgmres
    type: fieldsplit
      Preconditioner for the Schur complement formed from A11
      Split info:
          type: gmres
          type: lu
            matrix ordering: nd
                  type: seqaij
                  rows=962, cols=962
            type: seqaij
            rows=962, cols=962
          type: gmres
          type: jacobi
            rows=145, cols=145
              A11
                  type: seqaij
                  rows=145, cols=145
              A10
                  type: seqaij
                  rows=145, cols=962
              KSP of A00
                  type: preonly
                  type: jacobi
                    type: seqaij
                    rows=962, cols=962
              A01
                  type: seqaij
                  rows=962, cols=145
            type: seqaij
            rows=145, cols=145
      type: seqaij
   Matt
Chris
  0 KSP Residual norm 1.229687498638e+00
    Residual norms for fieldsplit_1_ solve.
    0 KSP Residual norm 7.185799114488e+01
    1 KSP Residual norm 3.873274154012e+01
  1 KSP Residual norm 1.107969383366e+00
  type: fgmres
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: preonly
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 1
          Local solve is same for all blocks, in the following KSP and PC objects:
          KSP Object:          (fieldsplit_0_sub_)           1 MPI processes
            type: preonly
          PC Object:          (fieldsplit_0_sub_)           1 MPI processes
            type: ilu
              ILU: out-of-place factorization
              0 levels of fill
              using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
              matrix ordering: natural
              factor fill ratio given 1, needed 1
                    type: seqaij
                    rows=48, cols=48
                    total: nonzeros=200, allocated nonzeros=200
            Mat Object:            (fieldsplit_0_)             1 MPI processes
              type: seqaij
              rows=48, cols=48
              total: nonzeros=200, allocated nonzeros=240
          type: mpiaij
          rows=48, cols=48
          total: nonzeros=200, allocated nonzeros=480
            not using I-node (on process 0) routines
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: bjacobi
          KSP Object:          (fieldsplit_1_sub_)           1 MPI processes
            type: preonly
          PC Object:          (fieldsplit_1_sub_)           1 MPI processes
            type: bjacobi
              KSP Object:              (fieldsplit_1_sub_sub_)               1 MPI processes
                type: preonly
              PC Object:              (fieldsplit_1_sub_sub_)               1 MPI processes
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=24, cols=24
                        total: nonzeros=120, allocated nonzeros=120
                  type: seqaij
                  rows=24, cols=24
              type: mpiaij
              rows=24, cols=24
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          rows=24, cols=24
            A11
                type: mpiaij
                rows=24, cols=24
                total: nonzeros=0, allocated nonzeros=0
                  using I-node (on process 0) routines: found 5 nodes, limit used is 5
            A10
              Mat Object:              (a10_)               1 MPI processes
                type: mpiaij
                rows=24, cols=48
                total: nonzeros=96, allocated nonzeros=96
            KSP of A00
              KSP Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: preonly
              PC Object:              (fieldsplit_1_inner_)               1 MPI processes
                type: jacobi
                  type: mpiaij
                  rows=48, cols=48
            A01
              Mat Object:              (a01_)               1 MPI processes
                type: mpiaij
                rows=48, cols=24
                total: nonzeros=96, allocated nonzeros=480
          type: mpiaij
          rows=24, cols=24
    type: nest
    rows=72, cols=72
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=48, cols=48
        (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
        (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
        (1,1) : prefix="fieldsplit_1_", type=mpiaij, rows=24, cols=24
Sent: Thursday, September 04, 2014 2:20 PM
On Thu, Sep 4, 2014 at 7:06 AM, Klaij, Christiaan  <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
 I'm playing with the selfp option in fieldsplit using
snes/examples/tutorials/ex70.c. For example:
-ksp_type fgmres \
gives the following output
    0 KSP Residual norm 2.330138480101e+01
    1 KSP Residual norm 1.609000846751e+01
  1 KSP Residual norm 1.180287268335e+00
To my suprise I don't see anything for the fieldsplit_0_ solve,
why?
Always run with -ksp_view for any solver question.
    Matt
   Furthermore, if I understand correctly the above should be
exactly equivalent with
-ksp_type fgmres \
-user_ksp \
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 5.486639587672e-01
    1 KSP Residual norm 6.348354253703e-02
    0 KSP Residual norm 2.321938107977e+01
    1 KSP Residual norm 1.605484031258e+01
  1 KSP Residual norm 1.183225251166e+00
because -user_ksp replaces the Schur complement by the simple
approximation A11 - A10 inv(diag(A00)) A01. Beside the missing
fielsplit_0_ part, the numbers are pretty close but not exactly
the same. Any explanation?
Chris
CFD Researcher
E mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11<tel:%2B31%20317%2049%2039%2011>, F +31 317 49 32 45<tel:%2B31%20317%2049%2032%2045>, I www.marin.nl<http://www.marin.nl>
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/39085013/attachment-0001.html>
Type: image/jpeg
Desc: image4a95d2.JPG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/39085013/attachment-0002.jpe>
Type: image/jpeg
Desc: imagea7316f.JPG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140905/39085013/attachment-0003.jpe>
