[petsc-users] FETI-DP implementation and call sequence
Wed Sep 3 06:09:03 CDT 2014
On Wed, Sep 3, 2014 at 3:10 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
> Hi,
> I need to investigate the performance of FETI-DP on a heteregenous problem
> with a proposed preconditioner/scaling and different parameters. I do not
> want to reinvent the known. I need to investigate the outcomes of my
> research on top of FETI-DP.
> I have seen several papers in literature discuss about the FETI-DP
> implementations in PetSc. However, seems none of them is provided in
> public. I have come across several functions in PetSc with *FETIDP* names.
> But, since this algorithm is quite different then the ksp algorithms, I
> could not figure out how to use them.
> I have two concrete questions;
> 1- Is it possible to complete a FETI-DP solution with the provided
> functions in current PetSc release?
There is no FETI-DP in PETSc. However, I recommend mailing Oliver Rheinbach
to see about collaboration (http://www.uni-koeln.de/~orheinba/)
      Matt
> 2- If so, what  is the calling sequence for these functions?
> Thanks in advance,
> Alp
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/8f718c79/attachment.html>
