[petsc-users] FETI-DP implementation and call sequence
Karin&NiKo niko.karin at gmail.com
Wed Sep 3 06:23:27 CDT 2014
You could perhaps have a look at the PCBDDC :
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCBDDC.html
contributed by Stefano Zampini.
Best,
Nicolas
2014-09-03 13:09 GMT+02:00 Matthew Knepley <knepley at gmail.com>:
> On Wed, Sep 3, 2014 at 3:10 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
>> Hi,
>> I need to investigate the performance of FETI-DP on a heteregenous
>> problem with a proposed preconditioner/scaling and different parameters. I
>> do not want to reinvent the known. I need to investigate the outcomes of my
>> research on top of FETI-DP.
>> I have seen several papers in literature discuss about the FETI-DP
>> implementations in PetSc. However, seems none of them is provided in
>> public. I have come across several functions in PetSc with *FETIDP* names.
>> But, since this algorithm is quite different then the ksp algorithms, I
>> could not figure out how to use them.
>> I have two concrete questions;
>> 1- Is it possible to complete a FETI-DP solution with the provided
>> functions in current PetSc release?
> There is no FETI-DP in PETSc. However, I recommend mailing Oliver
> Rheinbach to see about collaboration (http://www.uni-koeln.de/~orheinba/)
>   Thanks,
>       Matt
>> 2- If so, what  is the calling sequence for these functions?
>> Thanks in advance,
>> Alp
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/943a491e/attachment.html>
