[petsc-users] Error: Symbol 'petsc_default_real' at (1) has no IMPLICIT type
TAY wee-beng zonexo at gmail.com
Wed Oct 29 22:27:21 CDT 2014
On 30/10/2014 10:02 AM, Barry Smith wrote:
>    Hmm, could you send us a (simple) code that reproduces the problem; I don’t think we have a petsc_default_real anywhere.
>    Barry
Hi Barry,
I realised that it's because I was using ver 3.4.4. There's no problem
after using ver 3.5.2.
Thanks!
Regards.
>> On Oct 29, 2014, at 8:52 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> When compiling using gnu gfortran, I got the following error msg:
>> My code is :
>> module PETSc_solvers
>> use set_matrix
>> use ibm
>> implicit none
>> contains
>> subroutine semi_momentum_simple_xyz(du,dv,dw)
>> !discretise momentum eqn using semi-implicit mtd
>> !simple except east,west
>> #include "finclude/petsc.h90"
>> call KSPSetTolerances(ksp_semi_xyz,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr) -> error
>> There's no problem when using ifort though.
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
