[petsc-users] Error: Symbol 'petsc_default_real' at (1) has no IMPLICIT type
Wed Oct 29 21:02:40 CDT 2014
  Hmm, could you send us a (simple) code that reproduces the problem; I don’t think we have a petsc_default_real anywhere.
  Barry
> On Oct 29, 2014, at 8:52 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> When compiling using gnu gfortran, I got the following error msg:
> My code is :
> module PETSc_solvers
> use set_matrix
> use ibm
> implicit none
> contains
> subroutine semi_momentum_simple_xyz(du,dv,dw)
> !discretise momentum eqn using semi-implicit mtd
> !simple except east,west
> #include "finclude/petsc.h90"
> call KSPSetTolerances(ksp_semi_xyz,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr) -> error
> There's no problem when using ifort though.
> Thank you
> Yours sincerely,
> TAY wee-beng
