[petsc-users] Error: Symbol 'petsc_default_real' at (1) has no IMPLICIT type
TAY wee-beng zonexo at gmail.com
Wed Oct 29 20:52:38 CDT 2014
When compiling using gnu gfortran, I got the following error msg:
My code is :
/module PETSc_solvers//
//use set_matrix//
//use ibm//
//implicit none//
//contains//
//subroutine semi_momentum_simple_xyz(du,dv,dw)//
//!discretise momentum eqn using semi-implicit mtd//
//!simple except east,west//
//#include "finclude/petsc.h90"//
//call
KSPSetTolerances(ksp_semi_xyz,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
-> error/
There's no problem when using ifort though.
Thank you
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141030/d060ef5b/attachment.html>
