[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tue Oct 28 12:08:02 CDT 2014
On Tue, Oct 28, 2014 at 12:05 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Matt
> The analytical (Okada) solution is wrong at the fault. PETSc is right. It
> is a strike slip fault and constraints are being enforced correctly.
If the solution is right and the residual is large, then the function
calculating the residual is wrong, since
the residual is supposed to define the solution.
   Matt
> Tabrez
> On 10/28/2014 11:57 AM, Matthew Knepley wrote:
>  On Tue, Oct 28, 2014 at 11:56 AM, Tabrez Ali <stali at geology.wisc.edu>
> wrote:
>> Jed
>> You're right and it is precisely what I am trying to understand as well.
>> I am attaching the comparison to the analytical solution. As you can see
>> the agreement is almost perfect, except at the discontinuity (y=0 in the
>> analytical solution).
>> So why am I getting the correct solution when according to true residuals
>> I should not?
>  The discontinuty is generating the large residuals. Your saddle is not
> actually enforcing
> the discontinuty, so you get the bulk mostly right by solving the (1,1)
> block, but not
> the slip. At least it looks that way to me.
>     Matt
>> Tabrez
>> On 10/28/2014 11:18 AM, Jed Brown wrote:
>>> Tabrez Ali <stali at geology.wisc.edu> writes:
>>>  Matt and Jed
>>>> But it does appear to work well in practice (as in I get the correct
>>>> solution).
>>> Your "correct" solution has a residual seven orders of magnitude bigger
>>> than the initial guess.  Does that not give you pause?
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/624f5766/attachment.html>
