[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Jed Brown jed at jedbrown.org
Tue Oct 28 12:20:56 CDT 2014
Tabrez Ali <stali at geology.wisc.edu> writes:
> Jed
> You're right and it is precisely what I am trying to understand as well.
> I am attaching the comparison to the analytical solution. As you can see
> the agreement is almost perfect, except at the discontinuity (y=0 in the
> analytical solution).
> So why am I getting the correct solution when according to true
> residuals I should not?
Assuming (I'm not convinced) that the solution is "correct", your system
is sufficiently ill-conditioned that the residual is huge.  Take any
system A and add a single row and column that are all zero except an
entry on the diagonal.  Augment the right-hand side with a corresponding
0.  The solution is obviously the solution of A x = b with an extra 0
regardless of what the diagonal entry is.
If the diagonal entry is 1e20, then [x; 1e-10] has a huge residual even
though it is pretty accurate.  If the diagonal entry is 1e-20, then [x;
1e10] is a nonsensical solution with a tiny residual.  This is
ill-conditioning.  You should nondimensionalize your problem to avoid
this spurious ill-conditioning, otherwise you should assume your results
are nonsense any any case where you don't already know the answer.
Sorry.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/85acc897/attachment.pgp>
