[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tabrez Ali stali at geology.wisc.edu
Tue Oct 28 12:05:42 CDT 2014
Matt
The analytical (Okada) solution is wrong at the fault. PETSc is right.
It is a strike slip fault and constraints are being enforced correctly.
Tabrez
On 10/28/2014 11:57 AM, Matthew Knepley wrote:
> On Tue, Oct 28, 2014 at 11:56 AM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Jed
>     You're right and it is precisely what I am trying to understand as
>     well. I am attaching the comparison to the analytical solution. As
>     you can see the agreement is almost perfect, except at the
>     discontinuity (y=0 in the analytical solution).
>     So why am I getting the correct solution when according to true
>     residuals I should not?
> The discontinuty is generating the large residuals. Your saddle is not
> actually enforcing
> the discontinuty, so you get the bulk mostly right by solving the
> (1,1) block, but not
> the slip. At least it looks that way to me.
>    Matt
>     Tabrez
>         <mailto:stali at geology.wisc.edu>> writes:
>             Matt and Jed
>             But it does appear to work well in practice (as in I get
>             the correct
>             solution).
>         Your "correct" solution has a residual seven orders of
>         magnitude bigger
>         than the initial guess.  Does that not give you pause?
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/e0b605d8/attachment.html>
