[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Jed Brown jed at jedbrown.org
Tue Oct 28 11:18:08 CDT 2014
Tabrez Ali <stali at geology.wisc.edu> writes:
> Matt and Jed
> But it does appear to work well in practice (as in I get the correct
> solution).
Your "correct" solution has a residual seven orders of magnitude bigger
than the initial guess.  Does that not give you pause?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/fe6dec7b/attachment.pgp>
