[petsc-users] Fieldsplit with LSC for constrained	elasticity/poroelasticity?
    Tabrez Ali
    stali at geology.wisc.edu
    Tue Oct 28 11:11:35 CDT 2014
Matt and Jed
But it does appear to work well in practice (as in I get the correct
solution). Based on what I have tried, LSC (with GAMG on 00) is the only
solver I am able to use on relatively large problems with non trivial
geometries (e.g., see my original email).
So why is that?
I will experiment with your other suggestions.
Tabrez
On 10/28/2014 09:55 AM, Matthew Knepley wrote:
> On Tue, Oct 28, 2014 at 9:49 AM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Matt
>     The system is certainly not singular (checked using -pc_type svd
>     -pc_svd_monitor). It also gives the correct solution (compared to
>     the analytical solution for a trivial problem).
> Something is very wrong with the preconditioner then. Move back to
> full Schur complement with a tight tolerance
> on the solver for S. This should converge in 1 iterate with a good
> true residual. Perhaps there is something wrong
> with LSC for your system. It is not guaranteed to work for all saddle
> points.
>   Matt
>     Tabrez
>     On 10/28/2014 08:44 AM, Matthew Knepley wrote:
>>     On Tue, Oct 28, 2014 at 8:00 AM, Tabrez Ali
>>     <stali at geology.wisc.edu <mailto:stali at geology.wisc.edu>> wrote:
>>         Matt
>>         With MUMPS it is indeed the same but not faster. E.g., see
>>         1.txt and 2.txt
>>     There is a big problem here. This system is never actually being
>>     solved. Look at 1.txt:
>>     0 KSP preconditioned resid norm 9.320055451716e+05 true resid
>>     norm 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
>>     380 KSP preconditioned resid norm 9.034871458425e-05 true resid
>>     norm 3.118451181896e+09 ||r(i)||/||b|| 1.775884728811e+07
>>     The preconditioned residual did drop 10 order of magnitude, but
>>     the true residual (b - Ax) is still very very large.
>>     This looks like the system is singular and the preconditioner is
>>     masking this. This needs to be figured out first.
>>     I would go back to a small serial problem, and make sure it is
>>     actually being solved.
>>        Matt
>>         With GAMG, cg takes forever (see 4.txt). For reference GAMG
>>         with preonly is attached again (3.txt)
>>         All logs include -fieldsplit_0_ksp_monitor.
>>         Also, the true residual shows small oscillations. Is that normal?
>>         Tabrez
>>         On 10/28/2014 07:08 AM, Matthew Knepley wrote:
>>>         On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali
>>>             Mark
>>>             When I replace "-fieldsplit_0_ksp_type preonly" with
>>>             "-fieldsplit_0_ksp_type cg" then it becomes very slow
>>>             (had to kill it).
>>>         That means something in the setup is wrong. It should be
>>>         about the same or faster. Run with -fieldsplit_0_ksp_monitor
>>>         so we can see what is happening.
>>>            Matt
>>>             With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
>>>             -fieldsplit_0_pc_factor_mat_solver_package mumps
>>>             -fieldsplit_0_ksp_type preonly' it works fine but takes
>>>             more time, and will be an issue for larger problems. The
>>>             output for this run is attached.
>>>             I will work on passing rigid body modes (as Matt
>>>             mentioned) but short of that what is the best set of
>>>             options for solving the following problem (i.e., linear
>>>             elasticity with constraints):
>>>             |K cG'| | u | = |F|
>>>             |G  0 | |l/c| |d|
>>>             where c is a scaling factor (so that cG' terms are more
>>>             or less of the same order as K)? The constraints are
>>>             used to impose slip between surfaces and so on.
>>>             Tabrez
>>>             On 10/27/2014 01:17 PM, Mark Adams wrote:
>>>>             The null space for GAMG is not critical but useful for
>>>>             elasticity.  If you in fact have an indefinite operator
>>>>             (eg, not "pinned)  the you need to use an iterative
>>>>             coarse grid solver.  You are
>>>>             using '-fieldsplit_0_pc_type gamg
>>>>             -fieldsplit_0_ksp_type preonly'.  And you have a hard
>>>>             elasticity problem.  You are going to want to start
>>>>             with a stronger solver. Use cg instead of preonly.  As
>>>>             Matt said start with MUMPS, then go to CG/GAMG, then
>>>>             you can see how far you can cut the _0_ solver down.
>>>>             Mark
>>>>             On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley
>>>>             <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>                 On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali
>>>>                     Matt
>>>>                     On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>>>                     On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali
>>>>>                         Matt
>>>>>                         Sorry about that (I always forget it). The
>>>>>                         output for the smallest problem is now
>>>>>                         attached (see log.txt). I am also
>>>>>                         attaching some results that compare
>>>>>                         results obtained using FS/LSC and the
>>>>>                         direct solver (MUMPS), again for the
>>>>>                         smallest problem. The difference, as you
>>>>>                         can see is insignificant O(1E-6).
>>>>>                     1) How do you use MUMPS if you have a saddle point
>>>>                     I simply used -pc_type lu
>>>>                     -pc_factor_mat_solver_package mumps.
>>>>>                     2) You can see from the output that something
>>>>>                     is seriously wrong with the preconditioner. It
>>>>>                     looks like it has a null space.
>>>>>                         Did you add the elastic null modes to
>>>>>                     GAMG? Without this, it is not going to work.
>>>>>                     We have helper functions for this:
>>>>>                     http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>>>                     you could just copy that code. And then use
>>>>>                     http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>>>                     I don't see it in the output, so I think this
>>>>>                     is your problem.
>>>>>                     In order to test, I would first use MUMPS as
>>>>>                     the A00 solver and get the Schur stuff worked
>>>>>                     out. Then I would
>>>>>                     replace MUMPS with GAMG and tune it until I
>>>>>                     get back my original convergence.
>>>>                     I will try this with
>>>>                     MatNullSpaceCreateRigidBody. Btw does it matter
>>>>                     if some nodes are pinned?
>>>>                 No these are null modes of the operator, not of the
>>>>                 particular problem.
>>>>                   Matt
>>>>                     Tabrez
>>>>>                       Thanks,
>>>>>                         Matt
>>>>>                         Also, I did pass 'upper' and 'full' to
>>>>>                         '-pc_fieldsplit_schur_factorization_type'
>>>>>                         but the iteration count doesn't improve
>>>>>                         (in fact, it increases slightly). The
>>>>>                         attached log is with 'upper'.
>>>>>                         Regards,
>>>>>                         Tabrez
>>>>>                         On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>>>                         On Thu, Oct 23, 2014 at 7:20 AM, Tabrez
>>>>>>                             Hello
>>>>>>                             I am using the following options
>>>>>>                             (below) for solving linear
>>>>>>                             elasticity/poroelasticity problems
>>>>>>                             involving slip between two surfaces
>>>>>>                             involving non-trivial geometries,
>>>>>>                             i.e., elements with high aspect
>>>>>>                             ratios, large contrasts in material
>>>>>>                             properties etc. The constraints are
>>>>>>                             imposed using Lagrange Multipliers.
>>>>>>                             A picture (shows displacement
>>>>>>                             magnitude) is attached. The boundary
>>>>>>                             nodes, i.e., the base and the four
>>>>>>                             side are pinned.
>>>>>>                             The following options appear to work
>>>>>>                             well for the saddle point problem:
>>>>>>                             -pc_type fieldsplit
>>>>>>                             -pc_fieldsplit_type schur
>>>>>>                             -pc_fieldsplit_detect_saddle_point
>>>>>>                             -fieldsplit_1_pc_type lsc
>>>>>>                             -fieldsplit_1_ksp_type preonly
>>>>>>                             -pc_fieldsplit_schur_fact_type lower
>>>>>>                             -ksp_monitor
>>>>>>                             However, the number of iterations
>>>>>>                             keep on increasing with the problems
>>>>>>                             size (see attached plot), e.g.,
>>>>>>                             120K Tets *507* Iterations (KSP
>>>>>>                             Residual norm 8.827362494659e-05)in
>>>>>>                             17 secs on   3 cores
>>>>>>                             1 Million Tets *1374* Iterations (KSP
>>>>>>                             Residual norm 7.164704416296e-05)in
>>>>>>                             117 secs on  20 cores
>>>>>>                             8 Million Tets *2495* Iterations (KSP
>>>>>>                             Residual norm 9.101247550026e-05) in
>>>>>>                             225 secs on 160 cores
>>>>>>                             So what other options should I try to
>>>>>>                             improve solver performance? Any
>>>>>>                             tips/insights would be appreciated as
>>>>>>                             preconditioning is black magic to me.
>>>>>>                         For reports, always run with
>>>>>>                         -ksp_view -ksp_monitor_true_residual
>>>>>>                         -ksp_converged_reason
>>>>>>                         so that we can see exactly what you used.
>>>>>>                         I believe the default is a diagonal
>>>>>>                         factorization. Since your outer iterates
>>>>>>                         are increasing, I would strengthen this
>>>>>>                         to either upper or full
>>>>>>                         <upper, full>
>>>>>>                           Thanks,
>>>>>>                         Matt
>>>>>>                             Thanks in advance.
>>>>>>                             Tabrez
>>>>>>                         What most experimenters take for granted
>>>>>>                         before they begin their experiments is
>>>>>>                         infinitely more interesting than any
>>>>>>                         results to which their experiments lead.
>>>>>>                         -- Norbert Wiener
>>>>>                     infinitely more interesting than any results
>>>>>                     -- Norbert Wiener
>>>>                 What most experimenters take for granted before
>>>>                 they begin their experiments is infinitely more
>>>>                 interesting than any results to which their
>>>>                 experiments lead.
>>>>                 -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/bc37e35b/attachment-0001.html>
