[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tue Oct 28 09:55:56 CDT 2014
On Tue, Oct 28, 2014 at 9:49 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Matt
> The system is certainly not singular (checked using -pc_type svd
> -pc_svd_monitor). It also gives the correct solution (compared to the
> analytical solution for a trivial problem).
Something is very wrong with the preconditioner then. Move back to full
Schur complement with a tight tolerance
on the solver for S. This should converge in 1 iterate with a good true
residual. Perhaps there is something wrong
with LSC for your system. It is not guaranteed to work for all saddle
points.
  Matt
> Tabrez
> On 10/28/2014 08:44 AM, Matthew Knepley wrote:
>  On Tue, Oct 28, 2014 at 8:00 AM, Tabrez Ali <stali at geology.wisc.edu>
> wrote:
>>  Matt
>> With MUMPS it is indeed the same but not faster. E.g., see 1.txt and 2.txt
>  There is a big problem here. This system is never actually being solved.
> Look at 1.txt:
>  0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm
> 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
> 380 KSP preconditioned resid norm 9.034871458425e-05 true resid norm
> 3.118451181896e+09 ||r(i)||/||b|| 1.775884728811e+07
>  The preconditioned residual did drop 10 order of magnitude, but the true
> residual (b - Ax) is still very very large.
> This looks like the system is singular and the preconditioner is masking
> this. This needs to be figured out first.
> I would go back to a small serial problem, and make sure it is actually
> being solved.
>     Matt
>>  With GAMG, cg takes forever (see 4.txt). For reference GAMG with
>> preonly is attached again (3.txt)
>> All logs include -fieldsplit_0_ksp_monitor.
>> Also, the true residual shows small oscillations. Is that normal?
>> Tabrez
>> On 10/28/2014 07:08 AM, Matthew Knepley wrote:
>>  On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali <stali at geology.wisc.edu>
>> wrote:
>>>  Mark
>>> When I replace "-fieldsplit_0_ksp_type preonly" with
>>> "-fieldsplit_0_ksp_type cg" then it becomes very slow (had to kill it).
>>  That means something in the setup is wrong. It should be about the same
>> or faster. Run with -fieldsplit_0_ksp_monitor
>> so we can see what is happening.
>>     Matt
>>>  With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
>>> -fieldsplit_0_pc_factor_mat_solver_package mumps -fieldsplit_0_ksp_type
>>> preonly' it works fine but takes more time, and will be an issue for larger
>>> problems. The output for this run is attached.
>>> I will work on passing rigid body modes (as Matt mentioned) but short of
>>> that what is the best set of options for solving the following problem
>>> (i.e., linear elasticity with constraints):
>>> |K cG'| | u | = |F|
>>> |G  0 | |l/c|   |d|
>>> where c is a scaling factor (so that cG' terms are more or less of the
>>> same order as K)? The constraints are used to impose slip between surfaces
>>> and so on.
>>> Tabrez
>>> On 10/27/2014 01:17 PM, Mark Adams wrote:
>>> The null space for GAMG is not critical but useful for elasticity.  If
>>> you in fact have an indefinite operator (eg, not "pinned)  the you need to
>>> use an iterative coarse grid solver.  You are using '-fieldsplit_0_pc_type
>>> gamg -fieldsplit_0_ksp_type preonly'.  And you have a hard elasticity
>>> problem.  You are going to want to start with a stronger solver. Use cg
>>> instead of preonly.  As Matt said start with MUMPS, then go to CG/GAMG,
>>> then you can see how far you can cut the _0_ solver down.
>>> Mark
>>> On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>>  On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>> wrote:
>>>>>  Matt
>>>>> On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>>>  On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>>> wrote:
>>>>>>  Matt
>>>>>> Sorry about that (I always forget it). The output for the smallest
>>>>>> problem is now attached (see log.txt). I am also attaching some results
>>>>>> that compare results obtained using FS/LSC and the direct solver (MUMPS),
>>>>>> again for the smallest problem. The difference, as you can see is
>>>>>> insignificant O(1E-6).
>>>>>  1) How do you use MUMPS if you have a saddle point
>>>>> I simply used -pc_type lu -pc_factor_mat_solver_package mumps.
>>>>>  2) You can see from the output that something is seriously wrong
>>>>> with the preconditioner. It looks like it has a null space.
>>>>>     Did you add the elastic null modes to GAMG? Without this, it is
>>>>> not going to work. We have helper functions for this:
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>>>  you could just copy that code. And then use
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>>>  I don't see it in the output, so I think this is your problem.
>>>>>  In order to test, I would first use MUMPS as the A00 solver and get
>>>>> the Schur stuff worked out. Then I would
>>>>> replace MUMPS with GAMG and tune it until I get back my original
>>>>> convergence.
>>>>> I will try this with MatNullSpaceCreateRigidBody. Btw does it matter
>>>>> if some nodes are pinned?
>>>>  No these are null modes of the operator, not of the particular
>>>> problem.
>>>>    Matt
>>>>>  Tabrez
>>>>>    Thanks,
>>>>>      Matt
>>>>>>  Also, I did pass 'upper' and 'full' to
>>>>>> '-pc_fieldsplit_schur_factorization_type' but the iteration count doesn't
>>>>>> improve (in fact, it increases slightly). The attached log is with 'upper'.
>>>>>> Regards,
>>>>>> Tabrez
>>>>>> On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>>>  On Thu, Oct 23, 2014 at 7:20 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>>>> wrote:
>>>>>>>  Hello
>>>>>>> I am using the following options (below) for solving linear
>>>>>>> elasticity/poroelasticity problems involving slip between two surfaces
>>>>>>> involving non-trivial geometries, i.e., elements with high aspect ratios,
>>>>>>> large contrasts in material properties etc. The constraints are imposed
>>>>>>> using Lagrange Multipliers.
>>>>>>> A picture (shows displacement magnitude) is attached. The boundary
>>>>>>> nodes, i.e., the base and the four side are pinned.
>>>>>>> The following options appear to work well for the saddle point
>>>>>>> problem:
>>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>>> -pc_fieldsplit_detect_saddle_point -fieldsplit_0_pc_type gamg
>>>>>>> -fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type lsc
>>>>>>> -fieldsplit_1_ksp_type preonly -pc_fieldsplit_schur_fact_type lower
>>>>>>> -ksp_monitor
>>>>>>> However, the number of iterations keep on increasing with the
>>>>>>> problems size (see attached plot), e.g.,
>>>>>>> 120K Tets        *507* Iterations (KSP Residual norm
>>>>>>> 8.827362494659e-05) in  17 secs on   3 cores
>>>>>>> 1 Million Tets  *1374* Iterations (KSP Residual norm
>>>>>>> 7.164704416296e-05) in 117 secs on  20 cores
>>>>>>> 8 Million Tets  *2495* Iterations (KSP Residual norm
>>>>>>> 9.101247550026e-05) in 225 secs on 160 cores
>>>>>>> So what other options should I try to improve solver performance?
>>>>>>> Any tips/insights would be appreciated as preconditioning is black magic to
>>>>>>> me.
>>>>>>  For reports, always run with
>>>>>>    -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>>>>  so that we can see exactly what you used.
>>>>>>  I believe the default is a diagonal factorization. Since your outer
>>>>>> iterates are increasing, I would strengthen this
>>>>>> to either upper or full
>>>>>>    -pc_fieldsplit_schur_factorization_type <upper, full>
>>>>>>    Thanks,
>>>>>>        Matt
>>>>>>>  Thanks in advance.
>>>>>>> Tabrez
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/7772a716/attachment-0001.html>
