[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tabrez Ali stali at geology.wisc.edu
Tue Oct 28 09:49:21 CDT 2014
Matt
The system is certainly not singular (checked using -pc_type svd
-pc_svd_monitor). It also gives the correct solution (compared to the
analytical solution for a trivial problem).
Tabrez
On 10/28/2014 08:44 AM, Matthew Knepley wrote:
> On Tue, Oct 28, 2014 at 8:00 AM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Matt
>     With MUMPS it is indeed the same but not faster. E.g., see 1.txt
>     and 2.txt
> There is a big problem here. This system is never actually being
> solved. Look at 1.txt:
> 0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm
> 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
> 380 KSP preconditioned resid norm 9.034871458425e-05 true resid norm
> 3.118451181896e+09 ||r(i)||/||b|| 1.775884728811e+07
> The preconditioned residual did drop 10 order of magnitude, but the
> true residual (b - Ax) is still very very large.
> This looks like the system is singular and the preconditioner is
> masking this. This needs to be figured out first.
> I would go back to a small serial problem, and make sure it is
> actually being solved.
>    Matt
>     With GAMG, cg takes forever (see 4.txt). For reference GAMG with
>     preonly is attached again (3.txt)
>     All logs include -fieldsplit_0_ksp_monitor.
>     Also, the true residual shows small oscillations. Is that normal?
>     Tabrez
>     On 10/28/2014 07:08 AM, Matthew Knepley wrote:
>>     On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali
>>     <stali at geology.wisc.edu <mailto:stali at geology.wisc.edu>> wrote:
>>         Mark
>>         When I replace "-fieldsplit_0_ksp_type preonly" with
>>         "-fieldsplit_0_ksp_type cg" then it becomes very slow (had to
>>         kill it).
>>     That means something in the setup is wrong. It should be about
>>     the same or faster. Run with -fieldsplit_0_ksp_monitor
>>     so we can see what is happening.
>>        Matt
>>         With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
>>         -fieldsplit_0_pc_factor_mat_solver_package mumps
>>         -fieldsplit_0_ksp_type preonly' it works fine but takes more
>>         time, and will be an issue for larger problems. The output
>>         for this run is attached.
>>         I will work on passing rigid body modes (as Matt mentioned)
>>         but short of that what is the best set of options for solving
>>         the following problem (i.e., linear elasticity with constraints):
>>         |K cG'| | u | = |F|
>>         |G  0 | |l/c|   |d|
>>         where c is a scaling factor (so that cG' terms are more or
>>         less of the same order as K)? The constraints are used to
>>         impose slip between surfaces and so on.
>>         Tabrez
>>         On 10/27/2014 01:17 PM, Mark Adams wrote:
>>>         The null space for GAMG is not critical but useful for
>>>         elasticity. If you in fact have an indefinite operator (eg,
>>>         not "pinned)  the you need to use an iterative coarse grid
>>>         solver. You are using '-fieldsplit_0_pc_type gamg
>>>         -fieldsplit_0_ksp_type preonly'. And you have a hard
>>>         elasticity problem. You are going to want to start with a
>>>         stronger solver. Use cg instead of preonly.  As Matt said
>>>         start with MUMPS, then go to CG/GAMG, then you can see how
>>>         far you can cut the _0_ solver down.
>>>         Mark
>>>         On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley
>>>         <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>             On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali
>>>             wrote:
>>>                 Matt
>>>                 On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>>                 On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali
>>>>                     Matt
>>>>                     Sorry about that (I always forget it). The
>>>>                     output for the smallest problem is now attached
>>>>                     (see log.txt). I am also attaching some results
>>>>                     that compare results obtained using FS/LSC and
>>>>                     the direct solver (MUMPS), again for the
>>>>                     smallest problem. The difference, as you can
>>>>                     see is insignificant O(1E-6).
>>>>                 1) How do you use MUMPS if you have a saddle point
>>>                 I simply used -pc_type lu
>>>                 -pc_factor_mat_solver_package mumps.
>>>>                 2) You can see from the output that something is
>>>>                 seriously wrong with the preconditioner. It looks
>>>>                 like it has a null space.
>>>>                     Did you add the elastic null modes to GAMG?
>>>>                 Without this, it is not going to work. We have
>>>>                 helper functions for this:
>>>>                 http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>>                 you could just copy that code. And then use
>>>>                 http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>>                 I don't see it in the output, so I think this is
>>>>                 your problem.
>>>>                 In order to test, I would first use MUMPS as the
>>>>                 A00 solver and get the Schur stuff worked out. Then
>>>>                 I would
>>>>                 replace MUMPS with GAMG and tune it until I get
>>>>                 back my original convergence.
>>>                 I will try this with MatNullSpaceCreateRigidBody.
>>>                 Btw does it matter if some nodes are pinned?
>>>             No these are null modes of the operator, not of the
>>>             particular problem.
>>>               Matt
>>>                 Tabrez
>>>>                   Thanks,
>>>>                     Matt
>>>>                     Also, I did pass 'upper' and 'full' to
>>>>                     '-pc_fieldsplit_schur_factorization_type' but
>>>>                     the iteration count doesn't improve (in fact,
>>>>                     it increases slightly). The attached log is
>>>>                     with 'upper'.
>>>>                     Regards,
>>>>                     Tabrez
>>>>                     On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>>                     On Thu, Oct 23, 2014 at 7:20 AM, Tabrez Ali
>>>>>                         Hello
>>>>>                         I am using the following options (below)
>>>>>                         for solving linear
>>>>>                         elasticity/poroelasticity problems
>>>>>                         involving slip between two surfaces
>>>>>                         involving non-trivial geometries, i.e.,
>>>>>                         elements with high aspect ratios, large
>>>>>                         contrasts in material properties etc. The
>>>>>                         constraints are imposed using Lagrange
>>>>>                         Multipliers.
>>>>>                         A picture (shows displacement magnitude)
>>>>>                         is attached. The boundary nodes, i.e., the
>>>>>                         base and the four side are pinned.
>>>>>                         The following options appear to work well
>>>>>                         for the saddle point problem:
>>>>>                         -pc_type fieldsplit -pc_fieldsplit_type
>>>>>                         schur -pc_fieldsplit_detect_saddle_point
>>>>>                         -fieldsplit_1_pc_type lsc
>>>>>                         -fieldsplit_1_ksp_type preonly
>>>>>                         -pc_fieldsplit_schur_fact_type lower
>>>>>                         -ksp_monitor
>>>>>                         However, the number of iterations keep on
>>>>>                         increasing with the problems size (see
>>>>>                         attached plot), e.g.,
>>>>>                         120K Tets *507* Iterations (KSP Residual
>>>>>                         norm 8.827362494659e-05)in  17 secs on   3
>>>>>                         cores
>>>>>                         1 Million Tets *1374* Iterations (KSP
>>>>>                         Residual norm 7.164704416296e-05)in 117
>>>>>                         secs on  20 cores
>>>>>                         8 Million Tets *2495* Iterations (KSP
>>>>>                         Residual norm 9.101247550026e-05) in 225
>>>>>                         secs on 160 cores
>>>>>                         So what other options should I try to
>>>>>                         improve solver performance? Any
>>>>>                         tips/insights would be appreciated as
>>>>>                         preconditioning is black magic to me.
>>>>>                     For reports, always run with
>>>>>                     -ksp_view -ksp_monitor_true_residual
>>>>>                     -ksp_converged_reason
>>>>>                     so that we can see exactly what you used.
>>>>>                     I believe the default is a diagonal
>>>>>                     factorization. Since your outer iterates are
>>>>>                     increasing, I would strengthen this
>>>>>                     to either upper or full
>>>>>                     <upper, full>
>>>>>                       Thanks,
>>>>>                     Matt
>>>>>                         Thanks in advance.
>>>>>                         Tabrez
>>>>>                     What most experimenters take for granted
>>>>>                     before they begin their experiments is
>>>>>                     infinitely more interesting than any results
>>>>>                     to which their experiments lead.
>>>>>                     -- Norbert Wiener
>>>>                 What most experimenters take for granted before
>>>>                 they begin their experiments is infinitely more
>>>>                 interesting than any results to which their
>>>>                 experiments lead.
>>>>                 -- Norbert Wiener
>>>             What most experimenters take for granted before they
>>>             begin their experiments is infinitely more interesting
>>>             than any results to which their experiments lead.
>>>             -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/46ce4305/attachment-0001.html>
