[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tabrez Ali stali at geology.wisc.edu
Tue Oct 28 08:00:38 CDT 2014
Matt
With MUMPS it is indeed the same but not faster. E.g., see 1.txt and 2.txt
With GAMG, cg takes forever (see 4.txt). For reference GAMG with preonly
is attached again (3.txt)
All logs include -fieldsplit_0_ksp_monitor.
Also, the true residual shows small oscillations. Is that normal?
Tabrez
On 10/28/2014 07:08 AM, Matthew Knepley wrote:
> On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Mark
>     When I replace "-fieldsplit_0_ksp_type preonly" with
>     "-fieldsplit_0_ksp_type cg" then it becomes very slow (had to kill
>     it).
> That means something in the setup is wrong. It should be about the
> same or faster. Run with -fieldsplit_0_ksp_monitor
> so we can see what is happening.
>    Matt
>     With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
>     -fieldsplit_0_pc_factor_mat_solver_package mumps
>     -fieldsplit_0_ksp_type preonly' it works fine but takes more time,
>     and will be an issue for larger problems. The output for this run
>     is attached.
>     I will work on passing rigid body modes (as Matt mentioned) but
>     short of that what is the best set of options for solving the
>     following problem (i.e., linear elasticity with constraints):
>     |K cG'| | u | = |F|
>     |G  0 | |l/c|   |d|
>     where c is a scaling factor (so that cG' terms are more or less of
>     the same order as K)? The constraints are used to impose slip
>     between surfaces and so on.
>     Tabrez
>     On 10/27/2014 01:17 PM, Mark Adams wrote:
>>     The null space for GAMG is not critical but useful for
>>     elasticity.  If you in fact have an indefinite operator (eg, not
>>     "pinned)  the you need to use an iterative coarse grid solver.
>>     You are using '-fieldsplit_0_pc_type gamg -fieldsplit_0_ksp_type
>>     preonly'.  And you have a hard elasticity problem.  You are going
>>     to want to start with a stronger solver. Use cg instead of
>>     preonly.  As Matt said start with MUMPS, then go to CG/GAMG, then
>>     you can see how far you can cut the _0_ solver down.
>>     Mark
>>     On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley
>>     <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>         On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali
>>         <stali at geology.wisc.edu <mailto:stali at geology.wisc.edu>> wrote:
>>             Matt
>>             On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>             On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali
>>>             wrote:
>>>                 Matt
>>>                 Sorry about that (I always forget it). The output
>>>                 for the smallest problem is now attached (see
>>>                 log.txt). I am also attaching some results that
>>>                 compare results obtained using FS/LSC and the direct
>>>                 solver (MUMPS), again for the smallest problem. The
>>>                 difference, as you can see is insignificant O(1E-6).
>>>             1) How do you use MUMPS if you have a saddle point
>>             I simply used -pc_type lu -pc_factor_mat_solver_package
>>             mumps.
>>>             2) You can see from the output that something is
>>>             seriously wrong with the preconditioner. It looks like
>>>             it has a null space.
>>>                 Did you add the elastic null modes to GAMG? Without
>>>             this, it is not going to work. We have helper functions
>>>             for this:
>>>             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>             you could just copy that code. And then use
>>>             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>             I don't see it in the output, so I think this is your
>>>             problem.
>>>             In order to test, I would first use MUMPS as the A00
>>>             solver and get the Schur stuff worked out. Then I would
>>>             replace MUMPS with GAMG and tune it until I get back my
>>>             original convergence.
>>             I will try this with MatNullSpaceCreateRigidBody. Btw
>>             does it matter if some nodes are pinned?
>>         No these are null modes of the operator, not of the
>>         particular problem.
>>           Matt
>>             Tabrez
>>>               Thanks,
>>>                 Matt
>>>                 Also, I did pass 'upper' and 'full' to
>>>                 '-pc_fieldsplit_schur_factorization_type' but the
>>>                 iteration count doesn't improve (in fact, it
>>>                 increases slightly). The attached log is with 'upper'.
>>>                 Regards,
>>>                 Tabrez
>>>                 On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>                 On Thu, Oct 23, 2014 at 7:20 AM, Tabrez Ali
>>>>                     Hello
>>>>                     I am using the following options (below) for
>>>>                     solving linear elasticity/poroelasticity
>>>>                     problems involving slip between two surfaces
>>>>                     involving non-trivial geometries, i.e.,
>>>>                     elements with high aspect ratios, large
>>>>                     contrasts in material properties etc. The
>>>>                     constraints are imposed using Lagrange
>>>>                     Multipliers.
>>>>                     A picture (shows displacement magnitude) is
>>>>                     attached. The boundary nodes, i.e., the base
>>>>                     and the four side are pinned.
>>>>                     The following options appear to work well for
>>>>                     the saddle point problem:
>>>>                     -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>                     -pc_fieldsplit_detect_saddle_point
>>>>                     -fieldsplit_1_pc_type lsc
>>>>                     -fieldsplit_1_ksp_type preonly
>>>>                     -pc_fieldsplit_schur_fact_type lower -ksp_monitor
>>>>                     However, the number of iterations keep on
>>>>                     increasing with the problems size (see attached
>>>>                     plot), e.g.,
>>>>                     120K Tets *507* Iterations (KSP Residual norm
>>>>                     8.827362494659e-05)in  17 secs on   3 cores
>>>>                     1 Million Tets *1374* Iterations (KSP Residual
>>>>                     norm 7.164704416296e-05)in 117 secs on  20 cores
>>>>                     8 Million Tets *2495* Iterations (KSP Residual
>>>>                     norm 9.101247550026e-05) in 225 secs on 160 cores
>>>>                     So what other options should I try to improve
>>>>                     solver performance? Any tips/insights would be
>>>>                     appreciated as preconditioning is black magic
>>>>                     to me.
>>>>                 For reports, always run with
>>>>                 -ksp_view -ksp_monitor_true_residual
>>>>                 -ksp_converged_reason
>>>>                 so that we can see exactly what you used.
>>>>                 I believe the default is a diagonal factorization.
>>>>                 Since your outer iterates are increasing, I would
>>>>                 strengthen this
>>>>                 to either upper or full
>>>>                 -pc_fieldsplit_schur_factorization_type <upper, full>
>>>>                   Thanks,
>>>>                 Matt
>>>>                     Thanks in advance.
>>>>                     Tabrez
>>>>                 What most experimenters take for granted before
>>>>                 they begin their experiments is infinitely more
>>>>                 interesting than any results to which their
>>>>                 experiments lead.
>>>>                 -- Norbert Wiener
>>>             What most experimenters take for granted before they
>>>             begin their experiments is infinitely more interesting
>>>             than any results to which their experiments lead.
>>>             -- Norbert Wiener
>>         What most experimenters take for granted before they begin
>>         their experiments is infinitely more interesting than any
>>         -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/14084d34/attachment-0001.html>
salloc: Granted job allocation 79010
 Reading input ...
 Partitioning mesh ...
 Reading mesh data ...
 Forming [K] ...
 Applying constraints ...
 Forming RHS ...
 Setting up solver ...
 Solving ...
  0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.127510702346e+05 true resid norm 1.362125072634e+14 ||r(i)||/||b|| 7.756982470220e+11
  2 KSP preconditioned resid norm 8.626930780275e+05 true resid norm 7.140706098955e+14 ||r(i)||/||b|| 4.066464464051e+12
  3 KSP preconditioned resid norm 6.917392651646e+05 true resid norm 2.788588220631e+15 ||r(i)||/||b|| 1.588035517346e+13
  4 KSP preconditioned resid norm 5.948180320596e+05 true resid norm 3.828406259238e+15 ||r(i)||/||b|| 2.180187476056e+13
  5 KSP preconditioned resid norm 5.365265868551e+05 true resid norm 4.509015181942e+15 ||r(i)||/||b|| 2.567778277265e+13
  6 KSP preconditioned resid norm 5.020807291688e+05 true resid norm 4.938429989057e+15 ||r(i)||/||b|| 2.812319927527e+13
  7 KSP preconditioned resid norm 4.691107247107e+05 true resid norm 5.504613096315e+15 ||r(i)||/||b|| 3.134747913486e+13
  8 KSP preconditioned resid norm 4.500805942145e+05 true resid norm 5.950219821547e+15 ||r(i)||/||b|| 3.388510480939e+13
  9 KSP preconditioned resid norm 4.250032501744e+05 true resid norm 6.670720166034e+15 ||r(i)||/||b|| 3.798818510228e+13
 10 KSP preconditioned resid norm 4.051645463810e+05 true resid norm 7.414211051141e+15 ||r(i)||/||b|| 4.222219112596e+13
 11 KSP preconditioned resid norm 3.880013874032e+05 true resid norm 8.151575238507e+15 ||r(i)||/||b|| 4.642130704452e+13
 12 KSP preconditioned resid norm 3.741408602796e+05 true resid norm 8.948407390773e+15 ||r(i)||/||b|| 5.095907906048e+13
 13 KSP preconditioned resid norm 3.532148969165e+05 true resid norm 1.028219119134e+16 ||r(i)||/||b|| 5.855466464062e+13
 14 KSP preconditioned resid norm 3.306246816868e+05 true resid norm 1.207912805635e+16 ||r(i)||/||b|| 6.878779817734e+13
 15 KSP preconditioned resid norm 3.077008490960e+05 true resid norm 1.412194821609e+16 ||r(i)||/||b|| 8.042117934569e+13
 16 KSP preconditioned resid norm 2.709436838755e+05 true resid norm 1.756809508461e+16 ||r(i)||/||b|| 1.000461766282e+14
 17 KSP preconditioned resid norm 2.491233804162e+05 true resid norm 1.976045004356e+16 ||r(i)||/||b|| 1.125311233683e+14
 18 KSP preconditioned resid norm 2.169453185969e+05 true resid norm 2.315544602061e+16 ||r(i)||/||b|| 1.318648283338e+14
 19 KSP preconditioned resid norm 1.853345270881e+05 true resid norm 2.647069144540e+16 ||r(i)||/||b|| 1.507443726291e+14
 20 KSP preconditioned resid norm 1.684382143134e+05 true resid norm 2.847996525788e+16 ||r(i)||/||b|| 1.621867152263e+14
 21 KSP preconditioned resid norm 1.487793180709e+05 true resid norm 3.106944054176e+16 ||r(i)||/||b|| 1.769331689754e+14
 22 KSP preconditioned resid norm 1.324108267214e+05 true resid norm 3.364687707291e+16 ||r(i)||/||b|| 1.916110648544e+14
 23 KSP preconditioned resid norm 1.154783368236e+05 true resid norm 3.664744963424e+16 ||r(i)||/||b|| 2.086986210755e+14
 24 KSP preconditioned resid norm 9.690290840858e+04 true resid norm 4.059423491277e+16 ||r(i)||/||b|| 2.311746365563e+14
 25 KSP preconditioned resid norm 8.541667474357e+04 true resid norm 4.382080823727e+16 ||r(i)||/||b|| 2.495492140601e+14
 26 KSP preconditioned resid norm 6.738137388843e+04 true resid norm 4.935828200765e+16 ||r(i)||/||b|| 2.810838270183e+14
 27 KSP preconditioned resid norm 5.559761934719e+04 true resid norm 5.372591255721e+16 ||r(i)||/||b|| 3.059564575058e+14
 28 KSP preconditioned resid norm 4.606357788000e+04 true resid norm 5.783519870721e+16 ||r(i)||/||b|| 3.293578772954e+14
 29 KSP preconditioned resid norm 3.846753020759e+04 true resid norm 6.227329505443e+16 ||r(i)||/||b|| 3.546317939556e+14
 30 KSP preconditioned resid norm 3.331905232454e+04 true resid norm 6.606924388252e+16 ||r(i)||/||b|| 3.762488312665e+14
 31 KSP preconditioned resid norm 3.290201988589e+04 true resid norm 6.618297473864e+16 ||r(i)||/||b|| 3.768965017889e+14
 32 KSP preconditioned resid norm 3.162870028106e+04 true resid norm 6.654393352127e+16 ||r(i)||/||b|| 3.789520773051e+14
 33 KSP preconditioned resid norm 2.991966449137e+04 true resid norm 6.709255863637e+16 ||r(i)||/||b|| 3.820763685218e+14
 34 KSP preconditioned resid norm 2.922952746962e+04 true resid norm 6.743695964938e+16 ||r(i)||/||b|| 3.840376514277e+14
 35 KSP preconditioned resid norm 2.798614888132e+04 true resid norm 6.838110987678e+16 ||r(i)||/||b|| 3.894143652923e+14
 36 KSP preconditioned resid norm 2.701665220432e+04 true resid norm 6.929642686721e+16 ||r(i)||/||b|| 3.946268806420e+14
 37 KSP preconditioned resid norm 2.601811428041e+04 true resid norm 7.044504608605e+16 ||r(i)||/||b|| 4.011679974047e+14
 38 KSP preconditioned resid norm 2.531056406740e+04 true resid norm 7.153872989162e+16 ||r(i)||/||b|| 4.073962698874e+14
 39 KSP preconditioned resid norm 2.332617529628e+04 true resid norm 7.497512777369e+16 ||r(i)||/||b|| 4.269657489810e+14
 40 KSP preconditioned resid norm 2.254584604071e+04 true resid norm 7.640212636547e+16 ||r(i)||/||b|| 4.350921709109e+14
 41 KSP preconditioned resid norm 2.082879229582e+04 true resid norm 7.986664049456e+16 ||r(i)||/||b|| 4.548217654299e+14
 42 KSP preconditioned resid norm 1.914379086213e+04 true resid norm 8.367676210833e+16 ||r(i)||/||b|| 4.765195134276e+14
 43 KSP preconditioned resid norm 1.815822267408e+04 true resid norm 8.615765209333e+16 ||r(i)||/||b|| 4.906475993948e+14
 44 KSP preconditioned resid norm 1.677428596734e+04 true resid norm 8.993611308867e+16 ||r(i)||/||b|| 5.121650476043e+14
 45 KSP preconditioned resid norm 1.534247135245e+04 true resid norm 9.414497409112e+16 ||r(i)||/||b|| 5.361335227990e+14
 46 KSP preconditioned resid norm 1.412608783355e+04 true resid norm 9.852630241878e+16 ||r(i)||/||b|| 5.610841589166e+14
 47 KSP preconditioned resid norm 1.177668977489e+04 true resid norm 1.077880272896e+17 ||r(i)||/||b|| 6.138275074610e+14
 48 KSP preconditioned resid norm 1.065678918035e+04 true resid norm 1.124882415442e+17 ||r(i)||/||b|| 6.405941240601e+14
 49 KSP preconditioned resid norm 9.962410637891e+03 true resid norm 1.158017305203e+17 ||r(i)||/||b|| 6.594636657927e+14
 50 KSP preconditioned resid norm 9.371192463165e+03 true resid norm 1.195573007678e+17 ||r(i)||/||b|| 6.808507565679e+14
 51 KSP preconditioned resid norm 8.608163058609e+03 true resid norm 1.259685427075e+17 ||r(i)||/||b|| 7.173612740950e+14
 52 KSP preconditioned resid norm 7.720924960100e+03 true resid norm 1.350861356595e+17 ||r(i)||/||b|| 7.692838252031e+14
 53 KSP preconditioned resid norm 6.628413884735e+03 true resid norm 1.478135305618e+17 ||r(i)||/||b|| 8.417633508586e+14
 54 KSP preconditioned resid norm 5.583298607076e+03 true resid norm 1.607393601792e+17 ||r(i)||/||b|| 9.153729156262e+14
 55 KSP preconditioned resid norm 4.854896331522e+03 true resid norm 1.721936891597e+17 ||r(i)||/||b|| 9.806026297653e+14
 56 KSP preconditioned resid norm 4.262399411032e+03 true resid norm 1.837125351753e+17 ||r(i)||/||b|| 1.046199753271e+15
 57 KSP preconditioned resid norm 3.584024669343e+03 true resid norm 2.026508285280e+17 ||r(i)||/||b|| 1.154048887322e+15
 58 KSP preconditioned resid norm 3.302611897192e+03 true resid norm 2.155979885016e+17 ||r(i)||/||b|| 1.227779923460e+15
 59 KSP preconditioned resid norm 3.106452236261e+03 true resid norm 2.294151324033e+17 ||r(i)||/||b|| 1.306465313802e+15
 60 KSP preconditioned resid norm 2.894632302136e+03 true resid norm 2.500169544012e+17 ||r(i)||/||b|| 1.423787852901e+15
 61 KSP preconditioned resid norm 2.892427608155e+03 true resid norm 2.503572781296e+17 ||r(i)||/||b|| 1.425725916628e+15
 62 KSP preconditioned resid norm 2.881855812247e+03 true resid norm 2.520690203791e+17 ||r(i)||/||b|| 1.435473886833e+15
 63 KSP preconditioned resid norm 2.872986380440e+03 true resid norm 2.536302493377e+17 ||r(i)||/||b|| 1.444364719185e+15
 64 KSP preconditioned resid norm 2.865635949494e+03 true resid norm 2.551732099897e+17 ||r(i)||/||b|| 1.453151517821e+15
 65 KSP preconditioned resid norm 2.860836435780e+03 true resid norm 2.565769302251e+17 ||r(i)||/||b|| 1.461145374977e+15
 66 KSP preconditioned resid norm 2.860026342231e+03 true resid norm 2.574294644220e+17 ||r(i)||/||b|| 1.466000357059e+15
 67 KSP preconditioned resid norm 2.860026336216e+03 true resid norm 2.574330960398e+17 ||r(i)||/||b|| 1.466021038269e+15
 68 KSP preconditioned resid norm 2.859446352241e+03 true resid norm 2.564102967024e+17 ||r(i)||/||b|| 1.460196436189e+15
 69 KSP preconditioned resid norm 2.855291192203e+03 true resid norm 2.530743143999e+17 ||r(i)||/||b|| 1.441198800245e+15
 70 KSP preconditioned resid norm 2.843683581066e+03 true resid norm 2.467887076608e+17 ||r(i)||/||b|| 1.405403745686e+15
 71 KSP preconditioned resid norm 2.825924372442e+03 true resid norm 2.382078643151e+17 ||r(i)||/||b|| 1.356537857561e+15
 72 KSP preconditioned resid norm 2.803340022966e+03 true resid norm 2.288941643308e+17 ||r(i)||/||b|| 1.303498522949e+15
 73 KSP preconditioned resid norm 2.768188650268e+03 true resid norm 2.170599056138e+17 ||r(i)||/||b|| 1.236105198165e+15
 74 KSP preconditioned resid norm 2.728040723494e+03 true resid norm 2.050447447185e+17 ||r(i)||/||b|| 1.167681677951e+15
 75 KSP preconditioned resid norm 2.663723516353e+03 true resid norm 1.886813386912e+17 ||r(i)||/||b|| 1.074495922651e+15
 76 KSP preconditioned resid norm 2.580490699661e+03 true resid norm 1.697855415282e+17 ||r(i)||/||b|| 9.668887944221e+14
 77 KSP preconditioned resid norm 2.507785655285e+03 true resid norm 1.549544648438e+17 ||r(i)||/||b|| 8.824292949480e+14
 78 KSP preconditioned resid norm 2.381407885412e+03 true resid norm 1.327524813262e+17 ||r(i)||/||b|| 7.559942117023e+14
 79 KSP preconditioned resid norm 2.275211715418e+03 true resid norm 1.165811443906e+17 ||r(i)||/||b|| 6.639022447827e+14
 80 KSP preconditioned resid norm 2.161471491933e+03 true resid norm 1.015723095329e+17 ||r(i)||/||b|| 5.784304542479e+14
 81 KSP preconditioned resid norm 1.982790704653e+03 true resid norm 8.141089228178e+16 ||r(i)||/||b|| 4.636159167775e+14
 82 KSP preconditioned resid norm 1.740676429272e+03 true resid norm 5.840122411450e+16 ||r(i)||/||b|| 3.325812590907e+14
 83 KSP preconditioned resid norm 1.587150103736e+03 true resid norm 4.629492757460e+16 ||r(i)||/||b|| 2.636387427785e+14
 84 KSP preconditioned resid norm 1.322911470027e+03 true resid norm 2.928137570587e+16 ||r(i)||/||b|| 1.667505595614e+14
 85 KSP preconditioned resid norm 1.181708293679e+03 true resid norm 2.197349341693e+16 ||r(i)||/||b|| 1.251338857709e+14
 86 KSP preconditioned resid norm 9.902319658992e+02 true resid norm 1.423216419310e+16 ||r(i)||/||b|| 8.104883345673e+13
 87 KSP preconditioned resid norm 8.359003989923e+02 true resid norm 9.303072097139e+15 ||r(i)||/||b|| 5.297881129018e+13
 88 KSP preconditioned resid norm 6.981353832080e+02 true resid norm 5.935654408160e+15 ||r(i)||/||b|| 3.380215820001e+13
 89 KSP preconditioned resid norm 5.800715473848e+02 true resid norm 3.708718754357e+15 ||r(i)||/||b|| 2.112028252214e+13
 90 KSP preconditioned resid norm 4.883814959546e+02 true resid norm 2.388206782439e+15 ||r(i)||/||b|| 1.360027689001e+13
 91 KSP preconditioned resid norm 4.789803948167e+02 true resid norm 2.397467672188e+15 ||r(i)||/||b|| 1.365301548272e+13
 92 KSP preconditioned resid norm 4.571508437042e+02 true resid norm 2.421108269234e+15 ||r(i)||/||b|| 1.378764313224e+13
 93 KSP preconditioned resid norm 4.504410856546e+02 true resid norm 2.430412620122e+15 ||r(i)||/||b|| 1.384062922594e+13
 94 KSP preconditioned resid norm 4.405021402898e+02 true resid norm 2.456969922842e+15 ||r(i)||/||b|| 1.399186682945e+13
 95 KSP preconditioned resid norm 4.293421489705e+02 true resid norm 2.491683261285e+15 ||r(i)||/||b|| 1.418955114141e+13
 96 KSP preconditioned resid norm 4.173639470445e+02 true resid norm 2.540093934790e+15 ||r(i)||/||b|| 1.446523856049e+13
 97 KSP preconditioned resid norm 4.071406469759e+02 true resid norm 2.585692419976e+15 ||r(i)||/||b|| 1.472491122739e+13
 98 KSP preconditioned resid norm 3.923770532776e+02 true resid norm 2.664480924262e+15 ||r(i)||/||b|| 1.517359326025e+13
 99 KSP preconditioned resid norm 3.696685915067e+02 true resid norm 2.790356275911e+15 ||r(i)||/||b|| 1.589042383315e+13
100 KSP preconditioned resid norm 3.522302502819e+02 true resid norm 2.891433713993e+15 ||r(i)||/||b|| 1.646603611067e+13
101 KSP preconditioned resid norm 3.289451342229e+02 true resid norm 3.043740140594e+15 ||r(i)||/||b|| 1.733338544958e+13
102 KSP preconditioned resid norm 3.041026415553e+02 true resid norm 3.223224053568e+15 ||r(i)||/||b|| 1.835550419226e+13
103 KSP preconditioned resid norm 2.721797724150e+02 true resid norm 3.434699181372e+15 ||r(i)||/||b|| 1.955980539207e+13
104 KSP preconditioned resid norm 2.495064983369e+02 true resid norm 3.595571452999e+15 ||r(i)||/||b|| 2.047593520719e+13
105 KSP preconditioned resid norm 2.226326062999e+02 true resid norm 3.801867767252e+15 ||r(i)||/||b|| 2.165074427978e+13
106 KSP preconditioned resid norm 2.073865351924e+02 true resid norm 3.926005822571e+15 ||r(i)||/||b|| 2.235768135798e+13
107 KSP preconditioned resid norm 1.889509603881e+02 true resid norm 4.115951898164e+15 ||r(i)||/||b|| 2.343937966033e+13
108 KSP preconditioned resid norm 1.749949839579e+02 true resid norm 4.278800041159e+15 ||r(i)||/||b|| 2.436676159897e+13
109 KSP preconditioned resid norm 1.618193207581e+02 true resid norm 4.465831426392e+15 ||r(i)||/||b|| 2.543186142407e+13
110 KSP preconditioned resid norm 1.465181110970e+02 true resid norm 4.714655861628e+15 ||r(i)||/||b|| 2.684885816033e+13
111 KSP preconditioned resid norm 1.318107852393e+02 true resid norm 5.037611722496e+15 ||r(i)||/||b|| 2.868801595995e+13
112 KSP preconditioned resid norm 1.242084503143e+02 true resid norm 5.234477191653e+15 ||r(i)||/||b|| 2.980911858403e+13
113 KSP preconditioned resid norm 1.155780621405e+02 true resid norm 5.582223035717e+15 ||r(i)||/||b|| 3.178944951743e+13
114 KSP preconditioned resid norm 1.021440269876e+02 true resid norm 6.169174742477e+15 ||r(i)||/||b|| 3.513200167484e+13
115 KSP preconditioned resid norm 9.495516434823e+01 true resid norm 6.557142244926e+15 ||r(i)||/||b|| 3.734138550895e+13
116 KSP preconditioned resid norm 8.974660093572e+01 true resid norm 6.966234194713e+15 ||r(i)||/||b|| 3.967106811076e+13
117 KSP preconditioned resid norm 8.668620724647e+01 true resid norm 7.370496290054e+15 ||r(i)||/||b|| 4.197324582552e+13
118 KSP preconditioned resid norm 8.544499517816e+01 true resid norm 7.721073757102e+15 ||r(i)||/||b|| 4.396970218697e+13
119 KSP preconditioned resid norm 8.540356800271e+01 true resid norm 7.783986645065e+15 ||r(i)||/||b|| 4.432797631237e+13
120 KSP preconditioned resid norm 8.509182595205e+01 true resid norm 7.567149827193e+15 ||r(i)||/||b|| 4.309314154651e+13
121 KSP preconditioned resid norm 8.501310458315e+01 true resid norm 7.594939989774e+15 ||r(i)||/||b|| 4.325139999746e+13
122 KSP preconditioned resid norm 8.493474592259e+01 true resid norm 7.626607729139e+15 ||r(i)||/||b|| 4.343174033775e+13
123 KSP preconditioned resid norm 8.488333505978e+01 true resid norm 7.656182047437e+15 ||r(i)||/||b|| 4.360015913659e+13
124 KSP preconditioned resid norm 8.487226334182e+01 true resid norm 7.669732176286e+15 ||r(i)||/||b|| 4.367732393890e+13
125 KSP preconditioned resid norm 8.487223132681e+01 true resid norm 7.668341686089e+15 ||r(i)||/||b|| 4.366940542371e+13
126 KSP preconditioned resid norm 8.485866275463e+01 true resid norm 7.639207136251e+15 ||r(i)||/||b|| 4.350349100299e+13
127 KSP preconditioned resid norm 8.480918903522e+01 true resid norm 7.584336028944e+15 ||r(i)||/||b|| 4.319101293027e+13
128 KSP preconditioned resid norm 8.461824044155e+01 true resid norm 7.465571292783e+15 ||r(i)||/||b|| 4.251467564305e+13
129 KSP preconditioned resid norm 8.425430254488e+01 true resid norm 7.263958636771e+15 ||r(i)||/||b|| 4.136653890445e+13
130 KSP preconditioned resid norm 8.380956078491e+01 true resid norm 7.064381616384e+15 ||r(i)||/||b|| 4.022999463278e+13
131 KSP preconditioned resid norm 8.314252078293e+01 true resid norm 6.808447695490e+15 ||r(i)||/||b|| 3.877251104497e+13
132 KSP preconditioned resid norm 8.226839163275e+01 true resid norm 6.516418948240e+15 ||r(i)||/||b|| 3.710947589590e+13
133 KSP preconditioned resid norm 8.078979388845e+01 true resid norm 6.095155817867e+15 ||r(i)||/||b|| 3.471048127837e+13
134 KSP preconditioned resid norm 7.933264183989e+01 true resid norm 5.736990178593e+15 ||r(i)||/||b|| 3.267081205775e+13
135 KSP preconditioned resid norm 7.629870771673e+01 true resid norm 5.098475075145e+15 ||r(i)||/||b|| 2.903461846295e+13
136 KSP preconditioned resid norm 7.384550440347e+01 true resid norm 4.620263540645e+15 ||r(i)||/||b|| 2.631131605505e+13
137 KSP preconditioned resid norm 7.019186089415e+01 true resid norm 3.995768085741e+15 ||r(i)||/||b|| 2.275496106699e+13
138 KSP preconditioned resid norm 6.549021211843e+01 true resid norm 3.271622423957e+15 ||r(i)||/||b|| 1.863112154799e+13
139 KSP preconditioned resid norm 6.216358320616e+01 true resid norm 2.825089716686e+15 ||r(i)||/||b|| 1.608822262317e+13
140 KSP preconditioned resid norm 5.819590212463e+01 true resid norm 2.365235629981e+15 ||r(i)||/||b|| 1.346946157024e+13
141 KSP preconditioned resid norm 5.322146455266e+01 true resid norm 1.862541523452e+15 ||r(i)||/||b|| 1.060673666298e+13
142 KSP preconditioned resid norm 4.838864075967e+01 true resid norm 1.460907869921e+15 ||r(i)||/||b|| 8.319527307186e+12
143 KSP preconditioned resid norm 4.288901894843e+01 true resid norm 1.075225948117e+15 ||r(i)||/||b|| 6.123159318213e+12
144 KSP preconditioned resid norm 3.774714223463e+01 true resid norm 7.813012561145e+14 ||r(i)||/||b|| 4.449327208934e+12
145 KSP preconditioned resid norm 3.210844047850e+01 true resid norm 5.182912787837e+14 ||r(i)||/||b|| 2.951547141129e+12
146 KSP preconditioned resid norm 2.633903242416e+01 true resid norm 3.154831961047e+14 ||r(i)||/||b|| 1.796602728339e+12
147 KSP preconditioned resid norm 2.195326889592e+01 true resid norm 1.974702121211e+14 ||r(i)||/||b|| 1.124546493262e+12
148 KSP preconditioned resid norm 1.932058732465e+01 true resid norm 1.401754968147e+14 ||r(i)||/||b|| 7.982665420318e+11
149 KSP preconditioned resid norm 1.720408947068e+01 true resid norm 1.028932390640e+14 ||r(i)||/||b|| 5.859528377818e+11
150 KSP preconditioned resid norm 1.559613054012e+01 true resid norm 8.129962713198e+13 ||r(i)||/||b|| 4.629822878737e+11
151 KSP preconditioned resid norm 1.528043547944e+01 true resid norm 8.168491802735e+13 ||r(i)||/||b|| 4.651764290589e+11
152 KSP preconditioned resid norm 1.473379333578e+01 true resid norm 8.241475904895e+13 ||r(i)||/||b|| 4.693327023149e+11
153 KSP preconditioned resid norm 1.446555352901e+01 true resid norm 8.283310540263e+13 ||r(i)||/||b|| 4.717150865739e+11
154 KSP preconditioned resid norm 1.433069800411e+01 true resid norm 8.320637495219e+13 ||r(i)||/||b|| 4.738407690174e+11
155 KSP preconditioned resid norm 1.398451209809e+01 true resid norm 8.447596474853e+13 ||r(i)||/||b|| 4.810707848158e+11
156 KSP preconditioned resid norm 1.338238396578e+01 true resid norm 8.694940793013e+13 ||r(i)||/||b|| 4.951564629860e+11
157 KSP preconditioned resid norm 1.285596711425e+01 true resid norm 8.942604823864e+13 ||r(i)||/||b|| 5.092603480434e+11
158 KSP preconditioned resid norm 1.259640711755e+01 true resid norm 9.096288627685e+13 ||r(i)||/||b|| 5.180122798311e+11
159 KSP preconditioned resid norm 1.150402739583e+01 true resid norm 9.770720834982e+13 ||r(i)||/||b|| 5.564196105120e+11
160 KSP preconditioned resid norm 1.091254034929e+01 true resid norm 1.013341675049e+14 ||r(i)||/||b|| 5.770742913128e+11
161 KSP preconditioned resid norm 1.005189915540e+01 true resid norm 1.071270712788e+14 ||r(i)||/||b|| 6.100635181677e+11
162 KSP preconditioned resid norm 9.249803512226e+00 true resid norm 1.126348443433e+14 ||r(i)||/||b|| 6.414289925795e+11
163 KSP preconditioned resid norm 8.498257694031e+00 true resid norm 1.184210190463e+14 ||r(i)||/||b|| 6.743798989555e+11
164 KSP preconditioned resid norm 7.683744736255e+00 true resid norm 1.250524243614e+14 ||r(i)||/||b|| 7.121441952129e+11
165 KSP preconditioned resid norm 7.203608048105e+00 true resid norm 1.292064833777e+14 ||r(i)||/||b|| 7.358005859637e+11
166 KSP preconditioned resid norm 6.554687010295e+00 true resid norm 1.355011219866e+14 ||r(i)||/||b|| 7.716470748995e+11
167 KSP preconditioned resid norm 6.040625671715e+00 true resid norm 1.410686541010e+14 ||r(i)||/||b|| 8.033528630691e+11
168 KSP preconditioned resid norm 5.602777727500e+00 true resid norm 1.472338492425e+14 ||r(i)||/||b|| 8.384622018512e+11
169 KSP preconditioned resid norm 5.137313560334e+00 true resid norm 1.546289114528e+14 ||r(i)||/||b|| 8.805753448241e+11
170 KSP preconditioned resid norm 4.772073752601e+00 true resid norm 1.617511854452e+14 ||r(i)||/||b|| 9.211350229458e+11
171 KSP preconditioned resid norm 4.429552108805e+00 true resid norm 1.699874815352e+14 ||r(i)||/||b|| 9.680387953478e+11
172 KSP preconditioned resid norm 4.058042066487e+00 true resid norm 1.807916301249e+14 ||r(i)||/||b|| 1.029565884819e+12
173 KSP preconditioned resid norm 3.659352883143e+00 true resid norm 1.979586476733e+14 ||r(i)||/||b|| 1.127328019050e+12
174 KSP preconditioned resid norm 3.345836787538e+00 true resid norm 2.142618164480e+14 ||r(i)||/||b|| 1.220170737340e+12
175 KSP preconditioned resid norm 3.144285119620e+00 true resid norm 2.281978037714e+14 ||r(i)||/||b|| 1.299532913064e+12
176 KSP preconditioned resid norm 3.022396672033e+00 true resid norm 2.394375521335e+14 ||r(i)||/||b|| 1.363540640964e+12
177 KSP preconditioned resid norm 2.937051784737e+00 true resid norm 2.511984768128e+14 ||r(i)||/||b|| 1.430516345621e+12
178 KSP preconditioned resid norm 2.894844006212e+00 true resid norm 2.630994673035e+14 ||r(i)||/||b|| 1.498289692188e+12
179 KSP preconditioned resid norm 2.891859803054e+00 true resid norm 2.664328909271e+14 ||r(i)||/||b|| 1.517272757057e+12
180 KSP preconditioned resid norm 2.881379220023e+00 true resid norm 2.599861276412e+14 ||r(i)||/||b|| 1.480559953803e+12
181 KSP preconditioned resid norm 2.879542844584e+00 true resid norm 2.605906188316e+14 ||r(i)||/||b|| 1.484002389202e+12
182 KSP preconditioned resid norm 2.877332104952e+00 true resid norm 2.614134991883e+14 ||r(i)||/||b|| 1.488688499626e+12
183 KSP preconditioned resid norm 2.874457453304e+00 true resid norm 2.627920384570e+14 ||r(i)||/||b|| 1.496538957089e+12
184 KSP preconditioned resid norm 2.874350178426e+00 true resid norm 2.629889841321e+14 ||r(i)||/||b|| 1.497660516467e+12
185 KSP preconditioned resid norm 2.874316759497e+00 true resid norm 2.632240907437e+14 ||r(i)||/||b|| 1.498999393418e+12
186 KSP preconditioned resid norm 2.873427310817e+00 true resid norm 2.616631062224e+14 ||r(i)||/||b|| 1.490109953079e+12
187 KSP preconditioned resid norm 2.871829724110e+00 true resid norm 2.600479248375e+14 ||r(i)||/||b|| 1.480911874327e+12
188 KSP preconditioned resid norm 2.866312069964e+00 true resid norm 2.569200516311e+14 ||r(i)||/||b|| 1.463099370821e+12
189 KSP preconditioned resid norm 2.846491732666e+00 true resid norm 2.470738838019e+14 ||r(i)||/||b|| 1.407027756852e+12
190 KSP preconditioned resid norm 2.819731886872e+00 true resid norm 2.362847839597e+14 ||r(i)||/||b|| 1.345586366464e+12
191 KSP preconditioned resid norm 2.792936766447e+00 true resid norm 2.273872960182e+14 ||r(i)||/||b|| 1.294917261711e+12
192 KSP preconditioned resid norm 2.756926455345e+00 true resid norm 2.167291058783e+14 ||r(i)||/||b|| 1.234221371341e+12
193 KSP preconditioned resid norm 2.712360422860e+00 true resid norm 2.044302781008e+14 ||r(i)||/||b|| 1.164182434836e+12
194 KSP preconditioned resid norm 2.634448843059e+00 true resid norm 1.861635296282e+14 ||r(i)||/||b|| 1.060157591203e+12
195 KSP preconditioned resid norm 2.554394059240e+00 true resid norm 1.695438918584e+14 ||r(i)||/||b|| 9.655126562901e+11
196 KSP preconditioned resid norm 2.423825539214e+00 true resid norm 1.453837282179e+14 ||r(i)||/||b|| 8.279261970125e+11
197 KSP preconditioned resid norm 2.301147456622e+00 true resid norm 1.254692423355e+14 ||r(i)||/||b|| 7.145178757091e+11
198 KSP preconditioned resid norm 2.127717296192e+00 true resid norm 1.001850107010e+14 ||r(i)||/||b|| 5.705301131295e+11
199 KSP preconditioned resid norm 2.009570889375e+00 true resid norm 8.505087899865e+13 ||r(i)||/||b|| 4.843447864840e+11
200 KSP preconditioned resid norm 1.877929467118e+00 true resid norm 7.067975283976e+13 ||r(i)||/||b|| 4.025045972594e+11
201 KSP preconditioned resid norm 1.742306645778e+00 true resid norm 5.778295583468e+13 ||r(i)||/||b|| 3.290603664026e+11
202 KSP preconditioned resid norm 1.552694773463e+00 true resid norm 4.295283799072e+13 ||r(i)||/||b|| 2.446063273000e+11
203 KSP preconditioned resid norm 1.405131270730e+00 true resid norm 3.341312001580e+13 ||r(i)||/||b|| 1.902798732988e+11
204 KSP preconditioned resid norm 1.207664193636e+00 true resid norm 2.297635104050e+13 ||r(i)||/||b|| 1.308449244724e+11
205 KSP preconditioned resid norm 1.053318237111e+00 true resid norm 1.622815103212e+13 ||r(i)||/||b|| 9.241550985974e+10
206 KSP preconditioned resid norm 8.888845765981e-01 true resid norm 1.056122171702e+13 ||r(i)||/||b|| 6.014367796979e+10
207 KSP preconditioned resid norm 7.509568465149e-01 true resid norm 6.806276967032e+12 ||r(i)||/||b|| 3.876014925607e+10
208 KSP preconditioned resid norm 6.625686251463e-01 true resid norm 4.847396589685e+12 ||r(i)||/||b|| 2.760478543991e+10
209 KSP preconditioned resid norm 5.988642618667e-01 true resid norm 3.692436407290e+12 ||r(i)||/||b|| 2.102755837859e+10
210 KSP preconditioned resid norm 5.549023555358e-01 true resid norm 3.047380948800e+12 ||r(i)||/||b|| 1.735411899747e+10
211 KSP preconditioned resid norm 5.455066689212e-01 true resid norm 3.068915702741e+12 ||r(i)||/||b|| 1.747675436493e+10
212 KSP preconditioned resid norm 5.256037924156e-01 true resid norm 3.117149021671e+12 ||r(i)||/||b|| 1.775143179136e+10
213 KSP preconditioned resid norm 5.188512405250e-01 true resid norm 3.135845749577e+12 ||r(i)||/||b|| 1.785790526691e+10
214 KSP preconditioned resid norm 5.064661544592e-01 true resid norm 3.177032622850e+12 ||r(i)||/||b|| 1.809245483978e+10
215 KSP preconditioned resid norm 4.942966107592e-01 true resid norm 3.227527663801e+12 ||r(i)||/||b|| 1.838001224208e+10
216 KSP preconditioned resid norm 4.748832777350e-01 true resid norm 3.319202455933e+12 ||r(i)||/||b|| 1.890207865861e+10
217 KSP preconditioned resid norm 4.515766007515e-01 true resid norm 3.439082377839e+12 ||r(i)||/||b|| 1.958476666681e+10
218 KSP preconditioned resid norm 4.373636013530e-01 true resid norm 3.528935103695e+12 ||r(i)||/||b|| 2.009645684370e+10
219 KSP preconditioned resid norm 4.009409058224e-01 true resid norm 3.761071581232e+12 ||r(i)||/||b|| 2.141841957908e+10
220 KSP preconditioned resid norm 3.740642218035e-01 true resid norm 3.936786773390e+12 ||r(i)||/||b|| 2.241907634160e+10
221 KSP preconditioned resid norm 3.517621550751e-01 true resid norm 4.097034865102e+12 ||r(i)||/||b|| 2.333165159865e+10
222 KSP preconditioned resid norm 3.229172571887e-01 true resid norm 4.313515792451e+12 ||r(i)||/||b|| 2.456445965153e+10
223 KSP preconditioned resid norm 2.994652885566e-01 true resid norm 4.502575429318e+12 ||r(i)||/||b|| 2.564110989347e+10
224 KSP preconditioned resid norm 2.773847957709e-01 true resid norm 4.710010351261e+12 ||r(i)||/||b|| 2.682240306952e+10
225 KSP preconditioned resid norm 2.501295155918e-01 true resid norm 4.969594294575e+12 ||r(i)||/||b|| 2.830067267801e+10
226 KSP preconditioned resid norm 2.304712314567e-01 true resid norm 5.185438809988e+12 ||r(i)||/||b|| 2.952985651435e+10
227 KSP preconditioned resid norm 2.100779846797e-01 true resid norm 5.450176316298e+12 ||r(i)||/||b|| 3.103747445408e+10
228 KSP preconditioned resid norm 1.902335220167e-01 true resid norm 5.764165785042e+12 ||r(i)||/||b|| 3.282557075581e+10
229 KSP preconditioned resid norm 1.696094706888e-01 true resid norm 6.179726816553e+12 ||r(i)||/||b|| 3.519209325915e+10
230 KSP preconditioned resid norm 1.581599504430e-01 true resid norm 6.486811193342e+12 ||r(i)||/||b|| 3.694086668347e+10
231 KSP preconditioned resid norm 1.508622285730e-01 true resid norm 6.725920163898e+12 ||r(i)||/||b|| 3.830253612950e+10
232 KSP preconditioned resid norm 1.423061981474e-01 true resid norm 7.059553066573e+12 ||r(i)||/||b|| 4.020249717532e+10
233 KSP preconditioned resid norm 1.315343744406e-01 true resid norm 7.576207381506e+12 ||r(i)||/||b|| 4.314472219166e+10
234 KSP preconditioned resid norm 1.237631119715e-01 true resid norm 8.062833402738e+12 ||r(i)||/||b|| 4.591594312584e+10
235 KSP preconditioned resid norm 1.167455701157e-01 true resid norm 8.626377159952e+12 ||r(i)||/||b|| 4.912519250663e+10
236 KSP preconditioned resid norm 1.118150542335e-01 true resid norm 9.193240713930e+12 ||r(i)||/||b|| 5.235334735053e+10
237 KSP preconditioned resid norm 1.093203112720e-01 true resid norm 9.616801357038e+12 ||r(i)||/||b|| 5.476542576364e+10
238 KSP preconditioned resid norm 1.083571577732e-01 true resid norm 9.931584526963e+12 ||r(i)||/||b|| 5.655804200725e+10
239 KSP preconditioned resid norm 1.082844361418e-01 true resid norm 1.003794171129e+13 ||r(i)||/||b|| 5.716372119998e+10
240 KSP preconditioned resid norm 1.078315530435e-01 true resid norm 9.849635902358e+12 ||r(i)||/||b|| 5.609136383115e+10
241 KSP preconditioned resid norm 1.077293716089e-01 true resid norm 9.870905184873e+12 ||r(i)||/||b|| 5.621248740118e+10
242 KSP preconditioned resid norm 1.075375538902e-01 true resid norm 9.914548970249e+12 ||r(i)||/||b|| 5.646102851161e+10
243 KSP preconditioned resid norm 1.074753898786e-01 true resid norm 9.944199906958e+12 ||r(i)||/||b|| 5.662988363431e+10
244 KSP preconditioned resid norm 1.074753897188e-01 true resid norm 9.944120931810e+12 ||r(i)||/||b|| 5.662943388939e+10
245 KSP preconditioned resid norm 1.074692455282e-01 true resid norm 9.924468762730e+12 ||r(i)||/||b|| 5.651751940068e+10
246 KSP preconditioned resid norm 1.073634021511e-01 true resid norm 9.811991743004e+12 ||r(i)||/||b|| 5.587698918224e+10
247 KSP preconditioned resid norm 1.072871763676e-01 true resid norm 9.751064980653e+12 ||r(i)||/||b|| 5.553002557588e+10
248 KSP preconditioned resid norm 1.067011749299e-01 true resid norm 9.474130637214e+12 ||r(i)||/||b|| 5.395294951244e+10
249 KSP preconditioned resid norm 1.055795514542e-01 true resid norm 9.010869435560e+12 ||r(i)||/||b|| 5.131478573984e+10
250 KSP preconditioned resid norm 1.047264906315e-01 true resid norm 8.722590914578e+12 ||r(i)||/||b|| 4.967310724884e+10
251 KSP preconditioned resid norm 1.029468452861e-01 true resid norm 8.186051408096e+12 ||r(i)||/||b|| 4.661764073554e+10
252 KSP preconditioned resid norm 1.004306739339e-01 true resid norm 7.495653525966e+12 ||r(i)||/||b|| 4.268598689791e+10
253 KSP preconditioned resid norm 9.795465882615e-02 true resid norm 6.920294332192e+12 ||r(i)||/||b|| 3.940945138009e+10
254 KSP preconditioned resid norm 9.555297895830e-02 true resid norm 6.409331737743e+12 ||r(i)||/||b|| 3.649963937552e+10
255 KSP preconditioned resid norm 9.212236801156e-02 true resid norm 5.754520651725e+12 ||r(i)||/||b|| 3.277064398619e+10
256 KSP preconditioned resid norm 8.758716129780e-02 true resid norm 4.960284730854e+12 ||r(i)||/||b|| 2.824765689845e+10
257 KSP preconditioned resid norm 8.129614388311e-02 true resid norm 4.021897523341e+12 ||r(i)||/||b|| 2.290376207910e+10
258 KSP preconditioned resid norm 7.531167948772e-02 true resid norm 3.231798425642e+12 ||r(i)||/||b|| 1.840433322801e+10
259 KSP preconditioned resid norm 7.147274373805e-02 true resid norm 2.780272287343e+12 ||r(i)||/||b|| 1.583299788591e+10
260 KSP preconditioned resid norm 6.629497651684e-02 true resid norm 2.268106077708e+12 ||r(i)||/||b|| 1.291633157545e+10
261 KSP preconditioned resid norm 6.208848335548e-02 true resid norm 1.905343450029e+12 ||r(i)||/||b|| 1.085048358521e+10
262 KSP preconditioned resid norm 5.627463420064e-02 true resid norm 1.483147396155e+12 ||r(i)||/||b|| 8.446176187388e+09
263 KSP preconditioned resid norm 4.990060996976e-02 true resid norm 1.096560027659e+12 ||r(i)||/||b|| 6.244651892097e+09
264 KSP preconditioned resid norm 4.497149523606e-02 true resid norm 8.467973504088e+11 ||r(i)||/||b|| 4.822312087867e+09
265 KSP preconditioned resid norm 3.747771448386e-02 true resid norm 5.348773301719e+11 ||r(i)||/||b|| 3.046000809484e+09
266 KSP preconditioned resid norm 3.272493579045e-02 true resid norm 3.761018286666e+11 ||r(i)||/||b|| 2.141811607904e+09
267 KSP preconditioned resid norm 2.833957133035e-02 true resid norm 2.584003424653e+11 ||r(i)||/||b|| 1.471529279559e+09
268 KSP preconditioned resid norm 2.427356932428e-02 true resid norm 1.695160658437e+11 ||r(i)||/||b|| 9.653541936699e+08
269 KSP preconditioned resid norm 2.223266993764e-02 true resid norm 1.346276265138e+11 ||r(i)||/||b|| 7.666727232729e+08
270 KSP preconditioned resid norm 2.051295333624e-02 true resid norm 1.110746629442e+11 ||r(i)||/||b|| 6.325441258323e+08
271 KSP preconditioned resid norm 2.015855323507e-02 true resid norm 1.116965466597e+11 ||r(i)||/||b|| 6.360856075776e+08
272 KSP preconditioned resid norm 1.928852034379e-02 true resid norm 1.133139863240e+11 ||r(i)||/||b|| 6.452965467012e+08
273 KSP preconditioned resid norm 1.901631826643e-02 true resid norm 1.139199965486e+11 ||r(i)||/||b|| 6.487476326432e+08
274 KSP preconditioned resid norm 1.867363596983e-02 true resid norm 1.148727414952e+11 ||r(i)||/||b|| 6.541732914152e+08
275 KSP preconditioned resid norm 1.820280164400e-02 true resid norm 1.164715762055e+11 ||r(i)||/||b|| 6.632782796940e+08
276 KSP preconditioned resid norm 1.749874598398e-02 true resid norm 1.194548458241e+11 ||r(i)||/||b|| 6.802672997192e+08
277 KSP preconditioned resid norm 1.687372343702e-02 true resid norm 1.224937051098e+11 ||r(i)||/||b|| 6.975728898463e+08
278 KSP preconditioned resid norm 1.639581534582e-02 true resid norm 1.252604851014e+11 ||r(i)||/||b|| 7.133290522755e+08
279 KSP preconditioned resid norm 1.496517609431e-02 true resid norm 1.337999448784e+11 ||r(i)||/||b|| 7.619592706937e+08
280 KSP preconditioned resid norm 1.418035417318e-02 true resid norm 1.386300317614e+11 ||r(i)||/||b|| 7.894654814188e+08
281 KSP preconditioned resid norm 1.331745056385e-02 true resid norm 1.444341207454e+11 ||r(i)||/||b|| 8.225184054188e+08
282 KSP preconditioned resid norm 1.222655360483e-02 true resid norm 1.521352895752e+11 ||r(i)||/||b|| 8.663747537182e+08
283 KSP preconditioned resid norm 1.131430015656e-02 true resid norm 1.595358392621e+11 ||r(i)||/||b|| 9.085191465823e+08
284 KSP preconditioned resid norm 1.037045062652e-02 true resid norm 1.680266580128e+11 ||r(i)||/||b|| 9.568723657767e+08
285 KSP preconditioned resid norm 9.688191710241e-03 true resid norm 1.743229906865e+11 ||r(i)||/||b|| 9.927285020137e+08
286 KSP preconditioned resid norm 9.052121728457e-03 true resid norm 1.811489298466e+11 ||r(i)||/||b|| 1.031600622843e+09
287 KSP preconditioned resid norm 8.110693591993e-03 true resid norm 1.926557318145e+11 ||r(i)||/||b|| 1.097129158325e+09
288 KSP preconditioned resid norm 7.508148910847e-03 true resid norm 2.010760971618e+11 ||r(i)||/||b|| 1.145081161929e+09
289 KSP preconditioned resid norm 6.917244373311e-03 true resid norm 2.109959323352e+11 ||r(i)||/||b|| 1.201572294126e+09
290 KSP preconditioned resid norm 6.270817241633e-03 true resid norm 2.235532624417e+11 ||r(i)||/||b|| 1.273083340701e+09
291 KSP preconditioned resid norm 5.723459551474e-03 true resid norm 2.366863981842e+11 ||r(i)||/||b|| 1.347873465176e+09
292 KSP preconditioned resid norm 5.384076682559e-03 true resid norm 2.476826665094e+11 ||r(i)||/||b|| 1.410494631433e+09
293 KSP preconditioned resid norm 5.001871189708e-03 true resid norm 2.646732099310e+11 ||r(i)||/||b|| 1.507251786946e+09
294 KSP preconditioned resid norm 4.705091159541e-03 true resid norm 2.809592007224e+11 ||r(i)||/||b|| 1.599996680654e+09
295 KSP preconditioned resid norm 4.424608317205e-03 true resid norm 3.023640626614e+11 ||r(i)||/||b|| 1.721892343670e+09
296 KSP preconditioned resid norm 4.204818967276e-03 true resid norm 3.239124009068e+11 ||r(i)||/||b|| 1.844605070563e+09
297 KSP preconditioned resid norm 4.020995274001e-03 true resid norm 3.491082273440e+11 ||r(i)||/||b|| 1.988089386300e+09
298 KSP preconditioned resid norm 3.962926420244e-03 true resid norm 3.653307295648e+11 ||r(i)||/||b|| 2.080472727506e+09
299 KSP preconditioned resid norm 3.957390293488e-03 true resid norm 3.700702150773e+11 ||r(i)||/||b|| 2.107462984698e+09
300 KSP preconditioned resid norm 3.939107198479e-03 true resid norm 3.622470106797e+11 ||r(i)||/||b|| 2.062911672493e+09
301 KSP preconditioned resid norm 3.936151280373e-03 true resid norm 3.628693131542e+11 ||r(i)||/||b|| 2.066455538973e+09
302 KSP preconditioned resid norm 3.931466595581e-03 true resid norm 3.639592089146e+11 ||r(i)||/||b|| 2.072662239428e+09
303 KSP preconditioned resid norm 3.926435182664e-03 true resid norm 3.655828398113e+11 ||r(i)||/||b|| 2.081908436166e+09
304 KSP preconditioned resid norm 3.926021426467e-03 true resid norm 3.661260862992e+11 ||r(i)||/||b|| 2.085002097364e+09
305 KSP preconditioned resid norm 3.925349557399e-03 true resid norm 3.649007689721e+11 ||r(i)||/||b|| 2.078024202882e+09
306 KSP preconditioned resid norm 3.923358477472e-03 true resid norm 3.626439026392e+11 ||r(i)||/||b|| 2.065171879014e+09
307 KSP preconditioned resid norm 3.917022083572e-03 true resid norm 3.580385367023e+11 ||r(i)||/||b|| 2.038945401315e+09
308 KSP preconditioned resid norm 3.903315312325e-03 true resid norm 3.514826655816e+11 ||r(i)||/||b|| 2.001611254560e+09
309 KSP preconditioned resid norm 3.868431844102e-03 true resid norm 3.361181687167e+11 ||r(i)||/||b|| 1.914114052402e+09
310 KSP preconditioned resid norm 3.830529010142e-03 true resid norm 3.221666140909e+11 ||r(i)||/||b|| 1.834663224546e+09
311 KSP preconditioned resid norm 3.796432004576e-03 true resid norm 3.115935002888e+11 ||r(i)||/||b|| 1.774451823943e+09
312 KSP preconditioned resid norm 3.690322145629e-03 true resid norm 2.821316991888e+11 ||r(i)||/||b|| 1.606673784125e+09
313 KSP preconditioned resid norm 3.593417830510e-03 true resid norm 2.581298804645e+11 ||r(i)||/||b|| 1.469989061967e+09
314 KSP preconditioned resid norm 3.480230295411e-03 true resid norm 2.333539117608e+11 ||r(i)||/||b|| 1.328895737442e+09
315 KSP preconditioned resid norm 3.353622106193e-03 true resid norm 2.081556998192e+11 ||r(i)||/||b|| 1.185397836817e+09
316 KSP preconditioned resid norm 3.194404159008e-03 true resid norm 1.800136692851e+11 ||r(i)||/||b|| 1.025135580497e+09
317 KSP preconditioned resid norm 3.071654543561e-03 true resid norm 1.608397945341e+11 ||r(i)||/||b|| 9.159448656958e+08
318 KSP preconditioned resid norm 2.839856706992e-03 true resid norm 1.286448140701e+11 ||r(i)||/||b|| 7.326020111329e+08
319 KSP preconditioned resid norm 2.631456530872e-03 true resid norm 1.035759604459e+11 ||r(i)||/||b|| 5.898407757529e+08
320 KSP preconditioned resid norm 2.421742413444e-03 true resid norm 8.242488267052e+10 ||r(i)||/||b|| 4.693903539628e+08
321 KSP preconditioned resid norm 2.249880781719e-03 true resid norm 6.797555823014e+10 ||r(i)||/||b|| 3.871048438856e+08
322 KSP preconditioned resid norm 2.051711845259e-03 true resid norm 5.362248662101e+10 ||r(i)||/||b|| 3.053674710829e+08
323 KSP preconditioned resid norm 1.852622242819e-03 true resid norm 4.140287521870e+10 ||r(i)||/||b|| 2.357796532349e+08
324 KSP preconditioned resid norm 1.586793121641e-03 true resid norm 2.820883331841e+10 ||r(i)||/||b|| 1.606426824911e+08
325 KSP preconditioned resid norm 1.397002344352e-03 true resid norm 2.041497331206e+10 ||r(i)||/||b|| 1.162584797044e+08
326 KSP preconditioned resid norm 1.221037138397e-03 true resid norm 1.446611906140e+10 ||r(i)||/||b|| 8.238115150056e+07
327 KSP preconditioned resid norm 1.033473918443e-03 true resid norm 9.359998416615e+09 ||r(i)||/||b|| 5.330299331365e+07
328 KSP preconditioned resid norm 9.116864046740e-04 true resid norm 6.661822582821e+09 ||r(i)||/||b|| 3.793751545497e+07
329 KSP preconditioned resid norm 8.282517125284e-04 true resid norm 5.144655662558e+09 ||r(i)||/||b|| 2.929760606536e+07
330 KSP preconditioned resid norm 7.530584930796e-04 true resid norm 4.075336468774e+09 ||r(i)||/||b|| 2.320808432621e+07
331 KSP preconditioned resid norm 7.379013029880e-04 true resid norm 4.106224221999e+09 ||r(i)||/||b|| 2.338398282857e+07
332 KSP preconditioned resid norm 7.208253294439e-04 true resid norm 4.143001104326e+09 ||r(i)||/||b|| 2.359341853844e+07
333 KSP preconditioned resid norm 7.065478031531e-04 true resid norm 4.177342705301e+09 ||r(i)||/||b|| 2.378898589280e+07
334 KSP preconditioned resid norm 6.922256661224e-04 true resid norm 4.218395844337e+09 ||r(i)||/||b|| 2.402277388059e+07
335 KSP preconditioned resid norm 6.743886958324e-04 true resid norm 4.282558054647e+09 ||r(i)||/||b|| 2.438816260342e+07
336 KSP preconditioned resid norm 6.468482934965e-04 true resid norm 4.403654061697e+09 ||r(i)||/||b|| 2.507777593099e+07
337 KSP preconditioned resid norm 6.112298327485e-04 true resid norm 4.572827652221e+09 ||r(i)||/||b|| 2.604117980812e+07
338 KSP preconditioned resid norm 5.788752885710e-04 true resid norm 4.751394641190e+09 ||r(i)||/||b|| 2.705807688389e+07
339 KSP preconditioned resid norm 5.410834722063e-04 true resid norm 4.973481545718e+09 ||r(i)||/||b|| 2.832280966057e+07
340 KSP preconditioned resid norm 5.010118139868e-04 true resid norm 5.234602366049e+09 ||r(i)||/||b|| 2.980983142282e+07
341 KSP preconditioned resid norm 4.660413373564e-04 true resid norm 5.472737511902e+09 ||r(i)||/||b|| 3.116595516582e+07
342 KSP preconditioned resid norm 4.188717184922e-04 true resid norm 5.804580276171e+09 ||r(i)||/||b|| 3.305572179372e+07
343 KSP preconditioned resid norm 3.873339125732e-04 true resid norm 6.068604268666e+09 ||r(i)||/||b|| 3.455927643981e+07
344 KSP preconditioned resid norm 3.623884936388e-04 true resid norm 6.323395887446e+09 ||r(i)||/||b|| 3.601025488528e+07
345 KSP preconditioned resid norm 3.275102770812e-04 true resid norm 6.705624685656e+09 ||r(i)||/||b|| 3.818695814616e+07
346 KSP preconditioned resid norm 3.059476371251e-04 true resid norm 6.975976972838e+09 ||r(i)||/||b|| 3.972655094464e+07
347 KSP preconditioned resid norm 2.842430817112e-04 true resid norm 7.278309985054e+09 ||r(i)||/||b|| 4.144826646332e+07
348 KSP preconditioned resid norm 2.701042874873e-04 true resid norm 7.506173036350e+09 ||r(i)||/||b|| 4.274589303963e+07
349 KSP preconditioned resid norm 2.489935977407e-04 true resid norm 7.858370531617e+09 ||r(i)||/||b|| 4.475157508141e+07
350 KSP preconditioned resid norm 2.261790623467e-04 true resid norm 8.300057569323e+09 ||r(i)||/||b|| 4.726687905580e+07
351 KSP preconditioned resid norm 2.108197466213e-04 true resid norm 8.660561620706e+09 ||r(i)||/||b|| 4.931986498433e+07
352 KSP preconditioned resid norm 1.952751185189e-04 true resid norm 9.171201474632e+09 ||r(i)||/||b|| 5.222783905740e+07
353 KSP preconditioned resid norm 1.857517778822e-04 true resid norm 9.612041070020e+09 ||r(i)||/||b|| 5.473831704676e+07
354 KSP preconditioned resid norm 1.755607178806e-04 true resid norm 1.022779610633e+10 ||r(i)||/||b|| 5.824489740313e+07
355 KSP preconditioned resid norm 1.629796228709e-04 true resid norm 1.128529235952e+10 ||r(i)||/||b|| 6.426709027154e+07
356 KSP preconditioned resid norm 1.523670690967e-04 true resid norm 1.237182813014e+10 ||r(i)||/||b|| 7.045465637343e+07
357 KSP preconditioned resid norm 1.479074333582e-04 true resid norm 1.303729898576e+10 ||r(i)||/||b|| 7.424435664783e+07
358 KSP preconditioned resid norm 1.460074843662e-04 true resid norm 1.352434774547e+10 ||r(i)||/||b|| 7.701798497833e+07
359 KSP preconditioned resid norm 1.458829647533e-04 true resid norm 1.366121581535e+10 ||r(i)||/||b|| 7.779741650057e+07
360 KSP preconditioned resid norm 1.455003008377e-04 true resid norm 1.345493890124e+10 ||r(i)||/||b|| 7.662271790721e+07
361 KSP preconditioned resid norm 1.453612812516e-04 true resid norm 1.349985427846e+10 ||r(i)||/||b|| 7.687850043463e+07
362 KSP preconditioned resid norm 1.452896929232e-04 true resid norm 1.352954023042e+10 ||r(i)||/||b|| 7.704755496096e+07
363 KSP preconditioned resid norm 1.452045529904e-04 true resid norm 1.358035370495e+10 ||r(i)||/||b|| 7.733692576772e+07
364 KSP preconditioned resid norm 1.452037661685e-04 true resid norm 1.358635691883e+10 ||r(i)||/||b|| 7.737111266129e+07
365 KSP preconditioned resid norm 1.451947097272e-04 true resid norm 1.356254561296e+10 ||r(i)||/||b|| 7.723551286509e+07
366 KSP preconditioned resid norm 1.450283003291e-04 true resid norm 1.341859300371e+10 ||r(i)||/||b|| 7.641573655459e+07
367 KSP preconditioned resid norm 1.448630740135e-04 true resid norm 1.330853779826e+10 ||r(i)||/||b|| 7.578899799982e+07
368 KSP preconditioned resid norm 1.440567965769e-04 true resid norm 1.296196745350e+10 ||r(i)||/||b|| 7.381536125899e+07
369 KSP preconditioned resid norm 1.424149319794e-04 true resid norm 1.234303836654e+10 ||r(i)||/||b|| 7.029070542941e+07
370 KSP preconditioned resid norm 1.405170637750e-04 true resid norm 1.171613546588e+10 ||r(i)||/||b|| 6.672064060300e+07
371 KSP preconditioned resid norm 1.384124482954e-04 true resid norm 1.109270199634e+10 ||r(i)||/||b|| 6.317033337224e+07
372 KSP preconditioned resid norm 1.349411971564e-04 true resid norm 1.017892860063e+10 ||r(i)||/||b|| 5.796660843193e+07
373 KSP preconditioned resid norm 1.298701178596e-04 true resid norm 9.002393037879e+09 ||r(i)||/||b|| 5.126651464526e+07
374 KSP preconditioned resid norm 1.243592082079e-04 true resid norm 7.854364119834e+09 ||r(i)||/||b|| 4.472875950699e+07
375 KSP preconditioned resid norm 1.196434867064e-04 true resid norm 6.952300103787e+09 ||r(i)||/||b|| 3.959171673458e+07
376 KSP preconditioned resid norm 1.150026535868e-04 true resid norm 6.147028883649e+09 ||r(i)||/||b|| 3.500588620853e+07
377 KSP preconditioned resid norm 1.078820003518e-04 true resid norm 5.101678614659e+09 ||r(i)||/||b|| 2.905286186832e+07
378 KSP preconditioned resid norm 1.020452351121e-04 true resid norm 4.355966470087e+09 ||r(i)||/||b|| 2.480620629352e+07
379 KSP preconditioned resid norm 9.619060714772e-05 true resid norm 3.698072276069e+09 ||r(i)||/||b|| 2.105965332802e+07
380 KSP preconditioned resid norm 9.034871458425e-05 true resid norm 3.118451181896e+09 ||r(i)||/||b|| 1.775884728811e+07
KSP Object: 4 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 1, factorization LOWER
    Preconditioner for the Schur complement formed from S itself
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       4 MPI processes
        type: preonly
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_0_)       4 MPI processes
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 0, needed 0
            Factored matrix follows:
              Mat Object:               4 MPI processes
                type: mpiaij
                rows=71946, cols=71946
                package used to perform factorization: mumps
                total: nonzeros=6.47715e+07, allocated nonzeros=6.47715e+07
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   0
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):                         1
                    ICNTL(13) (efficiency control):                         0
                    ICNTL(14) (percentage of estimated workspace increase): 20
                    ICNTL(18) (input mat struct):                           3
                    ICNTL(19) (Shur complement info):                       0
                    ICNTL(20) (rhs sparse pattern):                         0
                    ICNTL(21) (somumpstion struct):                            1
                    ICNTL(22) (in-core/out-of-core facility):               0
                    ICNTL(23) (max size of memory can be allocated locally):0
                    ICNTL(24) (detection of null pivot rows):               0
                    ICNTL(25) (computation of a null space basis):          0
                    ICNTL(26) (Schur options for rhs or solution):          0
                    ICNTL(27) (experimental parameter):                     -8
                    ICNTL(28) (use parallel or sequential ordering):        1
                    ICNTL(29) (parallel ordering):                          0
                    ICNTL(30) (user-specified set of entries in inv(A)):    0
                    ICNTL(31) (factors is discarded in the solve phase):    0
                    ICNTL(33) (compute determinant):                        0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absomumpste pivoting threshold):      0
                    CNTL(4) (vamumpse of static pivoting):         -1
                    CNTL(5) (fixation for null pivots):         0
                    RINFO(1) (local estimated flops for the elimination after analysis):
                      [0] 1.6957e+10
                      [1] 1.67964e+10
                      [2] 1.70959e+10
                      [3] 1.7073e+10
                    RINFO(2) (local estimated flops for the assembly after factorization):
                      [0]  3.99956e+07
                      [1]  3.71513e+07
                      [2]  4.43658e+07
                      [3]  2.95262e+07
                    RINFO(3) (local estimated flops for the elimination after factorization):
                      [0]  1.732e+10
                      [1]  1.7234e+10
                      [2]  1.70959e+10
                      [3]  1.62723e+10
                    INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                    [0] 243
                    [1] 237
                    [2] 256
                    [3] 212
                    INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                      [0] 243
                      [1] 237
                      [2] 256
                      [3] 212
                    INFO(23) (num of pivots eliminated on this processor after factorization):
                      [0] 23748
                      [1] 15630
                      [2] 20355
                      [3] 12213
                    RINFOG(1) (global estimated flops for the elimination after analysis): 6.79222e+10
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1.51039e+08
                    RINFOG(3) (global estimated flops for the elimination after factorization): 6.79222e+10
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0,0)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 64771542
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 1209207
                    INFOG(5) (estimated maximum front size in the complete tree): 2562
                    INFOG(6) (number of nodes in the complete tree): 3832
                    INFOG(7) (ordering option effectively use after analysis): 5
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 64771542
                    INFOG(10) (total integer space store the matrix factors after factorization): 1208659
                    INFOG(11) (order of largest frontal matrix after factorization): 2562
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 256
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 948
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 256
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 948
                    INFOG(20) (estimated number of entries in the factors): 64771542
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 212
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 789
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 58207698
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 229, 844
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): 7
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         4 MPI processes
          type: mpiaij
          total: nonzeros=2.96023e+06, allocated nonzeros=2.96023e+06
            using I-node (on process 0) routines: found 6259 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       4 MPI processes
        type: preonly
      PC Object:      (fieldsplit_1_)       4 MPI processes
        type: lsc
          KSP Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: preonly
          PC Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: bjacobi
              block Jacobi: number of blocks = 4
              Local solve is same for all blocks, in the following KSP and PC objects:
            KSP Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: preonly
            PC Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: ilu
                ILU: out-of-place factorization
                0 levels of fill
                using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                factor fill ratio given 1, needed 1
                    Mat Object:                     1 MPI processes
                      type: seqaij
                      rows=0, cols=0
                      package used to perform factorization: petsc
                      total: nonzeros=0, allocated nonzeros=0
                        not using I-node routines
                type: seqaij
                rows=0, cols=0
              type: mpiaij
              rows=3183, cols=3183
              total: nonzeros=9549, allocated nonzeros=9549
                not using I-node (on process 0) routines
        Mat Object:        (fieldsplit_1_)         4 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
                total: nonzeros=3183, allocated nonzeros=3183
            A10
                type: mpiaij
                rows=3183, cols=71946
                total: nonzeros=19098, allocated nonzeros=19098
            KSP of A00
                type: preonly
                type: lu
                        type: mpiaij
                              [0] 1.6957e+10
                              [1] 1.67964e+10
                              [2] 1.70959e+10
                              [3] 1.7073e+10
                              [0]  3.99956e+07
                              [1]  3.71513e+07
                              [2]  4.43658e+07
                              [3]  2.95262e+07
                              [0]  1.732e+10
                              [1]  1.7234e+10
                              [2]  1.70959e+10
                              [3]  1.62723e+10
                            [0] 243
                            [1] 237
                            [2] 256
                            [3] 212
                              [0] 243
                              [1] 237
                              [2] 256
                              [3] 212
                              [0] 23748
                              [1] 15630
                              [2] 20355
                              [3] 12213
                  type: mpiaij
            A01
                type: mpiaij
                rows=71946, cols=3183
                  using I-node (on process 0) routines: found 3757 nodes, limit used is 5
    type: mpiaij
    rows=75129, cols=75129
    total: nonzeros=3.0016e+06, allocated nonzeros=1.26217e+07
 Recovering stress ...
 Cleaning up ...
 Finished
0.00user 0.02system 0:26.34elapsed 0%CPU (0avgtext+0avgdata 17072maxresident)k
904inputs+0outputs (3major+1798minor)pagefaults 0swaps
salloc: Relinquishing job allocation 79010
salloc: Granted job allocation 79009
 Reading input ...
 Forming [K] ...
 Forming RHS ...
 Solving ...
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 0.000000000000e+00
    0 KSP Residual norm 1.432612442706e-02
    1 KSP Residual norm 3.137946166373e-15
    0 KSP Residual norm 1.663988751024e-01
    1 KSP Residual norm 2.456064991848e-14
    0 KSP Residual norm 1.451385401868e-01
    1 KSP Residual norm 2.569197214229e-14
  3 KSP preconditioned resid norm 6.917392651646e+05 true resid norm 2.788588220631e+15 ||r(i)||/||b|| 1.588035517345e+13
    0 KSP Residual norm 9.081370774413e-02
    1 KSP Residual norm 1.573306002072e-14
    0 KSP Residual norm 1.380360375235e-01
    1 KSP Residual norm 2.643171503486e-14
    0 KSP Residual norm 1.277633702520e-01
    1 KSP Residual norm 2.000627015696e-14
  6 KSP preconditioned resid norm 5.020807291688e+05 true resid norm 4.938429989056e+15 ||r(i)||/||b|| 2.812319927527e+13
    0 KSP Residual norm 1.250134450112e-01
    1 KSP Residual norm 3.007637391635e-14
    0 KSP Residual norm 7.969378496446e-02
    1 KSP Residual norm 2.097049353738e-14
    0 KSP Residual norm 4.908705156881e-02
    1 KSP Residual norm 1.517652960611e-14
  9 KSP preconditioned resid norm 4.250032501743e+05 true resid norm 6.670720166035e+15 ||r(i)||/||b|| 3.798818510228e+13
    0 KSP Residual norm 5.051056574003e-02
    1 KSP Residual norm 1.611299744434e-14
 10 KSP preconditioned resid norm 4.051645463809e+05 true resid norm 7.414211051143e+15 ||r(i)||/||b|| 4.222219112597e+13
    0 KSP Residual norm 8.908456136614e-02
    1 KSP Residual norm 6.643673163588e-15
 11 KSP preconditioned resid norm 3.880013874030e+05 true resid norm 8.151575238509e+15 ||r(i)||/||b|| 4.642130704453e+13
    0 KSP Residual norm 6.302530902167e-02
    1 KSP Residual norm 1.118497427955e-14
 12 KSP preconditioned resid norm 3.741408602795e+05 true resid norm 8.948407390774e+15 ||r(i)||/||b|| 5.095907906048e+13
    0 KSP Residual norm 6.220040527806e-02
    1 KSP Residual norm 2.195172558135e-14
 13 KSP preconditioned resid norm 3.532148969164e+05 true resid norm 1.028219119134e+16 ||r(i)||/||b|| 5.855466464062e+13
    0 KSP Residual norm 3.664221635474e-02
    1 KSP Residual norm 1.095313151883e-14
 14 KSP preconditioned resid norm 3.306246816868e+05 true resid norm 1.207912805635e+16 ||r(i)||/||b|| 6.878779817733e+13
    0 KSP Residual norm 3.908823169273e-02
    1 KSP Residual norm 4.567677409800e-15
 15 KSP preconditioned resid norm 3.077008490958e+05 true resid norm 1.412194821609e+16 ||r(i)||/||b|| 8.042117934570e+13
    0 KSP Residual norm 3.464400632944e-02
    1 KSP Residual norm 1.248385796725e-14
 16 KSP preconditioned resid norm 2.709436838753e+05 true resid norm 1.756809508461e+16 ||r(i)||/||b|| 1.000461766282e+14
    0 KSP Residual norm 3.730924456396e-02
    1 KSP Residual norm 8.833952331029e-15
 17 KSP preconditioned resid norm 2.491233804160e+05 true resid norm 1.976045004357e+16 ||r(i)||/||b|| 1.125311233683e+14
    0 KSP Residual norm 3.360294528433e-02
    1 KSP Residual norm 8.866990379709e-15
 18 KSP preconditioned resid norm 2.169453185967e+05 true resid norm 2.315544602061e+16 ||r(i)||/||b|| 1.318648283338e+14
    0 KSP Residual norm 2.672923469416e-02
    1 KSP Residual norm 6.628932206411e-15
 19 KSP preconditioned resid norm 1.853345270878e+05 true resid norm 2.647069144539e+16 ||r(i)||/||b|| 1.507443726291e+14
    0 KSP Residual norm 4.439173838058e-02
    1 KSP Residual norm 8.710300289138e-15
 20 KSP preconditioned resid norm 1.684382143130e+05 true resid norm 2.847996525787e+16 ||r(i)||/||b|| 1.621867152262e+14
    0 KSP Residual norm 3.126040666118e-02
    1 KSP Residual norm 2.157718718490e-15
 21 KSP preconditioned resid norm 1.487793180702e+05 true resid norm 3.106944054176e+16 ||r(i)||/||b|| 1.769331689754e+14
    0 KSP Residual norm 2.982119365260e-02
    1 KSP Residual norm 6.500808717418e-15
 22 KSP preconditioned resid norm 1.324108267210e+05 true resid norm 3.364687707286e+16 ||r(i)||/||b|| 1.916110648541e+14
    0 KSP Residual norm 2.423850086514e-02
    1 KSP Residual norm 8.994789776599e-15
 23 KSP preconditioned resid norm 1.154783368229e+05 true resid norm 3.664744963422e+16 ||r(i)||/||b|| 2.086986210754e+14
    0 KSP Residual norm 2.393990608456e-02
    1 KSP Residual norm 2.406129385825e-15
 24 KSP preconditioned resid norm 9.690290840659e+04 true resid norm 4.059423491285e+16 ||r(i)||/||b|| 2.311746365567e+14
    0 KSP Residual norm 1.622348172052e-02
    1 KSP Residual norm 3.428873840323e-15
 25 KSP preconditioned resid norm 8.541667474243e+04 true resid norm 4.382080823706e+16 ||r(i)||/||b|| 2.495492140589e+14
    0 KSP Residual norm 2.075620151853e-02
    1 KSP Residual norm 5.698030139326e-15
 26 KSP preconditioned resid norm 6.738137389098e+04 true resid norm 4.935828200691e+16 ||r(i)||/||b|| 2.810838270141e+14
    0 KSP Residual norm 2.010803475004e-02
    1 KSP Residual norm 2.156132132236e-15
 27 KSP preconditioned resid norm 5.559761934926e+04 true resid norm 5.372591255703e+16 ||r(i)||/||b|| 3.059564575047e+14
    0 KSP Residual norm 1.826237158796e-02
    1 KSP Residual norm 1.017098814718e-15
 28 KSP preconditioned resid norm 4.606357788249e+04 true resid norm 5.783519870719e+16 ||r(i)||/||b|| 3.293578772953e+14
    0 KSP Residual norm 1.651629400227e-02
    1 KSP Residual norm 2.722822698494e-15
 29 KSP preconditioned resid norm 3.846753020935e+04 true resid norm 6.227329505519e+16 ||r(i)||/||b|| 3.546317939599e+14
    0 KSP Residual norm 2.027548486581e-02
    1 KSP Residual norm 3.494353474393e-15
    0 KSP Residual norm 6.263440621161e+02
    1 KSP Residual norm 2.976783624382e-11
 30 KSP preconditioned resid norm 3.331905232453e+04 true resid norm 6.606924388293e+16 ||r(i)||/||b|| 3.762488312689e+14
    0 KSP Residual norm 2.258485129873e-02
    1 KSP Residual norm 1.640294240474e-15
 31 KSP preconditioned resid norm 3.290201988669e+04 true resid norm 6.618297473877e+16 ||r(i)||/||b|| 3.768965017896e+14
    0 KSP Residual norm 1.873187189707e-01
    1 KSP Residual norm 3.007064345094e-14
 32 KSP preconditioned resid norm 3.162870028135e+04 true resid norm 6.654393352155e+16 ||r(i)||/||b|| 3.789520773067e+14
    0 KSP Residual norm 1.581656246293e-01
    1 KSP Residual norm 2.053212713329e-14
 33 KSP preconditioned resid norm 2.991966449596e+04 true resid norm 6.709255863545e+16 ||r(i)||/||b|| 3.820763685166e+14
    0 KSP Residual norm 6.232182407060e-02
    1 KSP Residual norm 9.699695737156e-15
 34 KSP preconditioned resid norm 2.922952747341e+04 true resid norm 6.743695964733e+16 ||r(i)||/||b|| 3.840376514161e+14
    0 KSP Residual norm 1.224840558679e-01
    1 KSP Residual norm 2.098402045938e-14
 35 KSP preconditioned resid norm 2.798614888072e+04 true resid norm 6.838110987781e+16 ||r(i)||/||b|| 3.894143652981e+14
    0 KSP Residual norm 1.112708896553e-01
    1 KSP Residual norm 2.324449816880e-14
 36 KSP preconditioned resid norm 2.701665220391e+04 true resid norm 6.929642686803e+16 ||r(i)||/||b|| 3.946268806467e+14
    0 KSP Residual norm 1.287500625843e-01
    1 KSP Residual norm 2.070816800358e-14
 37 KSP preconditioned resid norm 2.601811427966e+04 true resid norm 7.044504608715e+16 ||r(i)||/||b|| 4.011679974110e+14
    0 KSP Residual norm 6.310462940439e-02
    1 KSP Residual norm 1.033991542240e-14
 38 KSP preconditioned resid norm 2.531056406749e+04 true resid norm 7.153872989067e+16 ||r(i)||/||b|| 4.073962698820e+14
    0 KSP Residual norm 7.049341398055e-02
    1 KSP Residual norm 4.340873415037e-15
 39 KSP preconditioned resid norm 2.332617529409e+04 true resid norm 7.497512777546e+16 ||r(i)||/||b|| 4.269657489911e+14
    0 KSP Residual norm 4.919505340201e-02
    1 KSP Residual norm 4.836385484814e-15
 40 KSP preconditioned resid norm 2.254584603894e+04 true resid norm 7.640212636613e+16 ||r(i)||/||b|| 4.350921709147e+14
    0 KSP Residual norm 7.385283041415e-02
    1 KSP Residual norm 1.246243453282e-14
 41 KSP preconditioned resid norm 2.082879229166e+04 true resid norm 7.986664049992e+16 ||r(i)||/||b|| 4.548217654604e+14
    0 KSP Residual norm 3.962557904950e-02
    1 KSP Residual norm 1.180258599058e-14
 42 KSP preconditioned resid norm 1.914379086052e+04 true resid norm 8.367676211170e+16 ||r(i)||/||b|| 4.765195134468e+14
    0 KSP Residual norm 4.016394666901e-02
    1 KSP Residual norm 9.028629004183e-15
 43 KSP preconditioned resid norm 1.815822266994e+04 true resid norm 8.615765210331e+16 ||r(i)||/||b|| 4.906475994516e+14
    0 KSP Residual norm 5.203801613990e-02
    1 KSP Residual norm 6.332115504097e-15
 44 KSP preconditioned resid norm 1.677428595429e+04 true resid norm 8.993611312333e+16 ||r(i)||/||b|| 5.121650478016e+14
    0 KSP Residual norm 3.522972725508e-02
    1 KSP Residual norm 6.698886160069e-15
 45 KSP preconditioned resid norm 1.534247135186e+04 true resid norm 9.414497409761e+16 ||r(i)||/||b|| 5.361335228360e+14
    0 KSP Residual norm 3.458547496485e-02
    1 KSP Residual norm 4.892131084318e-15
 46 KSP preconditioned resid norm 1.412608783199e+04 true resid norm 9.852630241846e+16 ||r(i)||/||b|| 5.610841589148e+14
    0 KSP Residual norm 3.620925013348e-02
    1 KSP Residual norm 6.700211558332e-15
 47 KSP preconditioned resid norm 1.177668960206e+04 true resid norm 1.077880279666e+17 ||r(i)||/||b|| 6.138275113166e+14
    0 KSP Residual norm 6.177239640098e-02
    1 KSP Residual norm 9.278074637413e-15
 48 KSP preconditioned resid norm 1.065678908965e+04 true resid norm 1.124882419582e+17 ||r(i)||/||b|| 6.405941264176e+14
    0 KSP Residual norm 6.503343368650e-02
    1 KSP Residual norm 1.422030224668e-14
 49 KSP preconditioned resid norm 9.962410632557e+03 true resid norm 1.158017305506e+17 ||r(i)||/||b|| 6.594636659650e+14
    0 KSP Residual norm 5.674003101964e-02
    1 KSP Residual norm 8.935395883314e-15
 50 KSP preconditioned resid norm 9.371192454299e+03 true resid norm 1.195573008344e+17 ||r(i)||/||b|| 6.808507569471e+14
    0 KSP Residual norm 5.760463738960e-02
    1 KSP Residual norm 8.072963700989e-15
 51 KSP preconditioned resid norm 8.608163058302e+03 true resid norm 1.259685427142e+17 ||r(i)||/||b|| 7.173612741331e+14
    0 KSP Residual norm 7.252122536889e-02
    1 KSP Residual norm 4.505661163138e-15
 52 KSP preconditioned resid norm 7.720924960576e+03 true resid norm 1.350861356563e+17 ||r(i)||/||b|| 7.692838251844e+14
    0 KSP Residual norm 9.552699268498e-02
    1 KSP Residual norm 3.880587833025e-15
 53 KSP preconditioned resid norm 6.628413883383e+03 true resid norm 1.478135305786e+17 ||r(i)||/||b|| 8.417633509545e+14
    0 KSP Residual norm 1.354164979975e-01
    1 KSP Residual norm 1.073467575675e-14
 54 KSP preconditioned resid norm 5.583298607651e+03 true resid norm 1.607393601737e+17 ||r(i)||/||b|| 9.153729155947e+14
    0 KSP Residual norm 1.768247575683e-01
    1 KSP Residual norm 7.925034358398e-15
 55 KSP preconditioned resid norm 4.854896331648e+03 true resid norm 1.721936891633e+17 ||r(i)||/||b|| 9.806026297857e+14
    0 KSP Residual norm 2.050327743689e-01
    1 KSP Residual norm 1.458510169247e-14
 56 KSP preconditioned resid norm 4.262399410809e+03 true resid norm 1.837125351848e+17 ||r(i)||/||b|| 1.046199753325e+15
    0 KSP Residual norm 2.402303362087e-01
    1 KSP Residual norm 1.021937235406e-14
 57 KSP preconditioned resid norm 3.584024669708e+03 true resid norm 2.026508285120e+17 ||r(i)||/||b|| 1.154048887232e+15
    0 KSP Residual norm 3.547784188892e-01
    1 KSP Residual norm 2.095367572283e-14
 58 KSP preconditioned resid norm 3.302611897269e+03 true resid norm 2.155979884936e+17 ||r(i)||/||b|| 1.227779923415e+15
    0 KSP Residual norm 3.240632014175e-01
    1 KSP Residual norm 1.749305570860e-14
 59 KSP preconditioned resid norm 3.106452236462e+03 true resid norm 2.294151323914e+17 ||r(i)||/||b|| 1.306465313734e+15
    0 KSP Residual norm 3.529538123727e-01
    1 KSP Residual norm 1.780729312291e-14
    0 KSP Residual norm 2.362276533049e+03
    1 KSP Residual norm 9.408788105556e-11
 60 KSP preconditioned resid norm 2.894632302157e+03 true resid norm 2.500169544004e+17 ||r(i)||/||b|| 1.423787852896e+15
    0 KSP Residual norm 8.165306005194e-01
    1 KSP Residual norm 4.440352683747e-14
 61 KSP preconditioned resid norm 2.892427608173e+03 true resid norm 2.503572781299e+17 ||r(i)||/||b|| 1.425725916630e+15
    0 KSP Residual norm 1.944839539559e-01
    1 KSP Residual norm 2.299886915476e-14
 62 KSP preconditioned resid norm 2.881855812195e+03 true resid norm 2.520690203889e+17 ||r(i)||/||b|| 1.435473886889e+15
    0 KSP Residual norm 2.198280520481e-01
    1 KSP Residual norm 4.423326697447e-14
 63 KSP preconditioned resid norm 2.872986380420e+03 true resid norm 2.536302493423e+17 ||r(i)||/||b|| 1.444364719211e+15
    0 KSP Residual norm 2.089918279476e-01
    1 KSP Residual norm 1.800237076950e-14
 64 KSP preconditioned resid norm 2.865635949476e+03 true resid norm 2.551732099922e+17 ||r(i)||/||b|| 1.453151517835e+15
    0 KSP Residual norm 1.719087534002e-01
    1 KSP Residual norm 1.837140972890e-14
 65 KSP preconditioned resid norm 2.860836435778e+03 true resid norm 2.565769302236e+17 ||r(i)||/||b|| 1.461145374968e+15
    0 KSP Residual norm 1.481116351416e-01
    1 KSP Residual norm 2.007161710282e-14
 66 KSP preconditioned resid norm 2.860026342229e+03 true resid norm 2.574294644210e+17 ||r(i)||/||b|| 1.466000357053e+15
    0 KSP Residual norm 1.525429042937e-01
    1 KSP Residual norm 2.156117826644e-14
 67 KSP preconditioned resid norm 2.860026336213e+03 true resid norm 2.574330960350e+17 ||r(i)||/||b|| 1.466021038242e+15
    0 KSP Residual norm 1.882198589149e-01
    1 KSP Residual norm 7.689815713863e-15
 68 KSP preconditioned resid norm 2.859446352239e+03 true resid norm 2.564102966971e+17 ||r(i)||/||b|| 1.460196436160e+15
    0 KSP Residual norm 1.626191755428e-01
    1 KSP Residual norm 1.723112875186e-14
 69 KSP preconditioned resid norm 2.855291192202e+03 true resid norm 2.530743143937e+17 ||r(i)||/||b|| 1.441198800209e+15
    0 KSP Residual norm 1.657349055826e-01
    1 KSP Residual norm 1.239710116466e-14
 70 KSP preconditioned resid norm 2.843683581024e+03 true resid norm 2.467887076324e+17 ||r(i)||/||b|| 1.405403745525e+15
    0 KSP Residual norm 1.701637412937e-01
    1 KSP Residual norm 1.019116797445e-14
 71 KSP preconditioned resid norm 2.825924372468e+03 true resid norm 2.382078643186e+17 ||r(i)||/||b|| 1.356537857581e+15
    0 KSP Residual norm 1.796494252151e-01
    1 KSP Residual norm 1.629015568887e-14
 72 KSP preconditioned resid norm 2.803340023027e+03 true resid norm 2.288941643475e+17 ||r(i)||/||b|| 1.303498523044e+15
    0 KSP Residual norm 1.509030408957e-01
    1 KSP Residual norm 7.503202555850e-15
 73 KSP preconditioned resid norm 2.768188650420e+03 true resid norm 2.170599056557e+17 ||r(i)||/||b|| 1.236105198404e+15
    0 KSP Residual norm 1.403279864061e-01
    1 KSP Residual norm 7.083414306415e-15
 74 KSP preconditioned resid norm 2.728040723726e+03 true resid norm 2.050447447767e+17 ||r(i)||/||b|| 1.167681678282e+15
    0 KSP Residual norm 1.235758010958e-01
    1 KSP Residual norm 6.082600419538e-15
 75 KSP preconditioned resid norm 2.663723516783e+03 true resid norm 1.886813387898e+17 ||r(i)||/||b|| 1.074495923212e+15
    0 KSP Residual norm 1.194778522578e-01
    1 KSP Residual norm 1.644080208873e-14
 76 KSP preconditioned resid norm 2.580490699769e+03 true resid norm 1.697855415479e+17 ||r(i)||/||b|| 9.668887945342e+14
    0 KSP Residual norm 1.162122535052e-01
    1 KSP Residual norm 4.736563840197e-15
 77 KSP preconditioned resid norm 2.507785655569e+03 true resid norm 1.549544648976e+17 ||r(i)||/||b|| 8.824292952547e+14
    0 KSP Residual norm 9.292215567615e-02
    1 KSP Residual norm 5.820466774404e-15
 78 KSP preconditioned resid norm 2.381407885104e+03 true resid norm 1.327524812787e+17 ||r(i)||/||b|| 7.559942114318e+14
    0 KSP Residual norm 9.878020432997e-02
    1 KSP Residual norm 9.375574109779e-15
 79 KSP preconditioned resid norm 2.275211715198e+03 true resid norm 1.165811443595e+17 ||r(i)||/||b|| 6.639022446051e+14
    0 KSP Residual norm 7.317922828486e-02
    1 KSP Residual norm 6.709439480018e-15
 80 KSP preconditioned resid norm 2.161471491914e+03 true resid norm 1.015723095291e+17 ||r(i)||/||b|| 5.784304542263e+14
    0 KSP Residual norm 6.004691390359e-02
    1 KSP Residual norm 5.059825151652e-15
 81 KSP preconditioned resid norm 1.982790704180e+03 true resid norm 8.141089223231e+16 ||r(i)||/||b|| 4.636159164957e+14
    0 KSP Residual norm 6.658868321392e-02
    1 KSP Residual norm 5.284454678312e-15
 82 KSP preconditioned resid norm 1.740676428371e+03 true resid norm 5.840122403494e+16 ||r(i)||/||b|| 3.325812586376e+14
    0 KSP Residual norm 5.546598555059e-02
    1 KSP Residual norm 5.389178370759e-15
 83 KSP preconditioned resid norm 1.587150103801e+03 true resid norm 4.629492757889e+16 ||r(i)||/||b|| 2.636387428029e+14
    0 KSP Residual norm 4.579942189825e-02
    1 KSP Residual norm 2.925284718872e-15
 84 KSP preconditioned resid norm 1.322911467320e+03 true resid norm 2.928137554973e+16 ||r(i)||/||b|| 1.667505586723e+14
    0 KSP Residual norm 4.844872261644e-02
    1 KSP Residual norm 2.358375413277e-15
 85 KSP preconditioned resid norm 1.181708293490e+03 true resid norm 2.197349340824e+16 ||r(i)||/||b|| 1.251338857214e+14
    0 KSP Residual norm 4.306304458857e-02
    1 KSP Residual norm 5.376181300056e-15
 86 KSP preconditioned resid norm 9.902319641871e+02 true resid norm 1.423216413086e+16 ||r(i)||/||b|| 8.104883310228e+13
    0 KSP Residual norm 3.279208851959e-02
    1 KSP Residual norm 3.873435620041e-15
 87 KSP preconditioned resid norm 8.359003981497e+02 true resid norm 9.303072073000e+15 ||r(i)||/||b|| 5.297881115271e+13
    0 KSP Residual norm 2.411795608184e-02
    1 KSP Residual norm 2.149885048897e-15
 88 KSP preconditioned resid norm 6.981353816351e+02 true resid norm 5.935654373576e+15 ||r(i)||/||b|| 3.380215800307e+13
    0 KSP Residual norm 2.806354454189e-02
    1 KSP Residual norm 4.211558319536e-15
 89 KSP preconditioned resid norm 5.800715464910e+02 true resid norm 3.708718738882e+15 ||r(i)||/||b|| 2.112028243402e+13
    0 KSP Residual norm 2.378367843596e-02
    1 KSP Residual norm 4.841752762035e-15
    0 KSP Residual norm 2.262347348058e+01
    1 KSP Residual norm 1.008816625874e-12
 90 KSP preconditioned resid norm 4.883814974933e+02 true resid norm 2.388206801554e+15 ||r(i)||/||b|| 1.360027699886e+13
    0 KSP Residual norm 4.704733431426e-02
    1 KSP Residual norm 2.819647156081e-15
 91 KSP preconditioned resid norm 4.789803955726e+02 true resid norm 2.397467691582e+15 ||r(i)||/||b|| 1.365301559317e+13
    0 KSP Residual norm 7.389489186629e-02
    1 KSP Residual norm 1.387938523458e-14
 92 KSP preconditioned resid norm 4.571508435040e+02 true resid norm 2.421108288771e+15 ||r(i)||/||b|| 1.378764324350e+13
    0 KSP Residual norm 8.462628653018e-02
    1 KSP Residual norm 2.052394328917e-14
 93 KSP preconditioned resid norm 4.504410874594e+02 true resid norm 2.430412637471e+15 ||r(i)||/||b|| 1.384062932474e+13
    0 KSP Residual norm 1.668189141494e-01
    1 KSP Residual norm 1.877558049570e-14
 94 KSP preconditioned resid norm 4.405021386174e+02 true resid norm 2.456969950409e+15 ||r(i)||/||b|| 1.399186698643e+13
    0 KSP Residual norm 1.776534479465e-01
    1 KSP Residual norm 2.310772953932e-14
 95 KSP preconditioned resid norm 4.293421493884e+02 true resid norm 2.491683283369e+15 ||r(i)||/||b|| 1.418955126717e+13
    0 KSP Residual norm 1.606412366904e-01
    1 KSP Residual norm 2.122396211016e-14
 96 KSP preconditioned resid norm 4.173639478383e+02 true resid norm 2.540093955020e+15 ||r(i)||/||b|| 1.446523867570e+13
    0 KSP Residual norm 7.346533923868e-02
    1 KSP Residual norm 1.503078855333e-14
 97 KSP preconditioned resid norm 4.071406475666e+02 true resid norm 2.585692441776e+15 ||r(i)||/||b|| 1.472491135153e+13
    0 KSP Residual norm 9.920241840132e-02
    1 KSP Residual norm 4.032077331726e-14
 98 KSP preconditioned resid norm 3.923770546792e+02 true resid norm 2.664480942542e+15 ||r(i)||/||b|| 1.517359336435e+13
    0 KSP Residual norm 8.231708914902e-02
    1 KSP Residual norm 3.770470752765e-14
 99 KSP preconditioned resid norm 3.696685934377e+02 true resid norm 2.790356292077e+15 ||r(i)||/||b|| 1.589042392521e+13
    0 KSP Residual norm 5.209831489793e-02
    1 KSP Residual norm 7.913084380445e-15
100 KSP preconditioned resid norm 3.522302511012e+02 true resid norm 2.891433737297e+15 ||r(i)||/||b|| 1.646603624339e+13
    0 KSP Residual norm 5.717762359557e-02
    1 KSP Residual norm 6.387846873809e-15
101 KSP preconditioned resid norm 3.289451358269e+02 true resid norm 3.043740158723e+15 ||r(i)||/||b|| 1.733338555282e+13
    0 KSP Residual norm 5.905335730113e-02
    1 KSP Residual norm 1.253434192456e-14
102 KSP preconditioned resid norm 3.041026456067e+02 true resid norm 3.223224057165e+15 ||r(i)||/||b|| 1.835550421275e+13
    0 KSP Residual norm 7.361347595838e-02
    1 KSP Residual norm 1.589751445909e-14
103 KSP preconditioned resid norm 2.721797720469e+02 true resid norm 3.434699217170e+15 ||r(i)||/||b|| 1.955980559593e+13
    0 KSP Residual norm 7.666368265704e-02
    1 KSP Residual norm 2.047784953441e-14
104 KSP preconditioned resid norm 2.495064987590e+02 true resid norm 3.595571483255e+15 ||r(i)||/||b|| 2.047593537949e+13
    0 KSP Residual norm 7.972669728289e-02
    1 KSP Residual norm 1.587845242165e-14
105 KSP preconditioned resid norm 2.226326066385e+02 true resid norm 3.801867800407e+15 ||r(i)||/||b|| 2.165074446859e+13
    0 KSP Residual norm 9.235885856035e-02
    1 KSP Residual norm 8.108441479733e-15
106 KSP preconditioned resid norm 2.073865351310e+02 true resid norm 3.926005860070e+15 ||r(i)||/||b|| 2.235768157153e+13
    0 KSP Residual norm 8.288096354148e-02
    1 KSP Residual norm 8.226581209870e-15
107 KSP preconditioned resid norm 1.889509610510e+02 true resid norm 4.115951929688e+15 ||r(i)||/||b|| 2.343937983985e+13
    0 KSP Residual norm 1.077517535712e-01
    1 KSP Residual norm 1.263977595841e-14
108 KSP preconditioned resid norm 1.749949838100e+02 true resid norm 4.278800082488e+15 ||r(i)||/||b|| 2.436676183433e+13
    0 KSP Residual norm 1.124921729581e-01
    1 KSP Residual norm 8.947834815232e-15
109 KSP preconditioned resid norm 1.618193213731e+02 true resid norm 4.465831458563e+15 ||r(i)||/||b|| 2.543186160728e+13
    0 KSP Residual norm 1.266675799102e-01
    1 KSP Residual norm 5.644406386791e-15
110 KSP preconditioned resid norm 1.465181112551e+02 true resid norm 4.714655904952e+15 ||r(i)||/||b|| 2.684885840704e+13
    0 KSP Residual norm 1.616539885274e-01
    1 KSP Residual norm 1.087196543493e-14
111 KSP preconditioned resid norm 1.318107859469e+02 true resid norm 5.037611757045e+15 ||r(i)||/||b|| 2.868801615670e+13
    0 KSP Residual norm 2.019418195399e-01
    1 KSP Residual norm 8.813045811269e-15
112 KSP preconditioned resid norm 1.242084506988e+02 true resid norm 5.234477234429e+15 ||r(i)||/||b|| 2.980911882762e+13
    0 KSP Residual norm 1.743305360210e-01
    1 KSP Residual norm 1.078322696740e-14
113 KSP preconditioned resid norm 1.155780623602e+02 true resid norm 5.582223086850e+15 ||r(i)||/||b|| 3.178944980861e+13
    0 KSP Residual norm 2.373146309370e-01
    1 KSP Residual norm 1.121934786619e-14
114 KSP preconditioned resid norm 1.021440272152e+02 true resid norm 6.169174800806e+15 ||r(i)||/||b|| 3.513200200701e+13
    0 KSP Residual norm 3.577417995151e-01
    1 KSP Residual norm 1.608185800429e-14
115 KSP preconditioned resid norm 9.495516498203e+01 true resid norm 6.557142282859e+15 ||r(i)||/||b|| 3.734138572497e+13
    0 KSP Residual norm 3.326441461139e-01
    1 KSP Residual norm 1.475599163182e-14
116 KSP preconditioned resid norm 8.974660138822e+01 true resid norm 6.966234249946e+15 ||r(i)||/||b|| 3.967106842530e+13
    0 KSP Residual norm 3.608712631594e-01
    1 KSP Residual norm 3.057682945540e-14
117 KSP preconditioned resid norm 8.668620768379e+01 true resid norm 7.370496356350e+15 ||r(i)||/||b|| 4.197324620306e+13
    0 KSP Residual norm 3.693428002447e-01
    1 KSP Residual norm 1.397475726963e-14
118 KSP preconditioned resid norm 8.544499569894e+01 true resid norm 7.721073813452e+15 ||r(i)||/||b|| 4.396970250787e+13
    0 KSP Residual norm 3.692697763536e-01
    1 KSP Residual norm 2.527602062420e-14
119 KSP preconditioned resid norm 8.540356853154e+01 true resid norm 7.783986693879e+15 ||r(i)||/||b|| 4.432797659035e+13
    0 KSP Residual norm 2.544114362896e-01
    1 KSP Residual norm 1.003176996544e-14
    0 KSP Residual norm 7.149544086266e+01
    1 KSP Residual norm 3.620617423011e-12
120 KSP preconditioned resid norm 8.509182647946e+01 true resid norm 7.567149874280e+15 ||r(i)||/||b|| 4.309314181466e+13
    0 KSP Residual norm 8.405465613062e-01
    1 KSP Residual norm 4.069686873734e-14
121 KSP preconditioned resid norm 8.501310511443e+01 true resid norm 7.594940035779e+15 ||r(i)||/||b|| 4.325140025944e+13
    0 KSP Residual norm 1.631956253110e-01
    1 KSP Residual norm 2.619300070627e-14
122 KSP preconditioned resid norm 8.493474643777e+01 true resid norm 7.626607781411e+15 ||r(i)||/||b|| 4.343174063543e+13
    0 KSP Residual norm 1.862156946512e-01
    1 KSP Residual norm 3.067356159902e-14
123 KSP preconditioned resid norm 8.488333556760e+01 true resid norm 7.656182108667e+15 ||r(i)||/||b|| 4.360015948528e+13
    0 KSP Residual norm 2.292116881356e-01
    1 KSP Residual norm 3.302487897840e-14
124 KSP preconditioned resid norm 8.487226386783e+01 true resid norm 7.669732222341e+15 ||r(i)||/||b|| 4.367732420118e+13
    0 KSP Residual norm 1.672163974636e-01
    1 KSP Residual norm 1.388193683457e-14
125 KSP preconditioned resid norm 8.487223185288e+01 true resid norm 7.668341733505e+15 ||r(i)||/||b|| 4.366940569373e+13
    0 KSP Residual norm 1.953837842424e-01
    1 KSP Residual norm 3.224928125577e-14
126 KSP preconditioned resid norm 8.485866327100e+01 true resid norm 7.639207170331e+15 ||r(i)||/||b|| 4.350349119707e+13
    0 KSP Residual norm 1.920848608123e-01
    1 KSP Residual norm 3.937923070844e-14
127 KSP preconditioned resid norm 8.480918955298e+01 true resid norm 7.584336070638e+15 ||r(i)||/||b|| 4.319101316770e+13
    0 KSP Residual norm 1.760053086227e-01
    1 KSP Residual norm 4.078484056150e-14
128 KSP preconditioned resid norm 8.461824097068e+01 true resid norm 7.465571340945e+15 ||r(i)||/||b|| 4.251467591732e+13
    0 KSP Residual norm 1.572514546188e-01
    1 KSP Residual norm 1.500036257427e-14
129 KSP preconditioned resid norm 8.425430309267e+01 true resid norm 7.263958693975e+15 ||r(i)||/||b|| 4.136653923021e+13
    0 KSP Residual norm 1.803203692911e-01
    1 KSP Residual norm 1.100923154553e-14
130 KSP preconditioned resid norm 8.380956131992e+01 true resid norm 7.064381669302e+15 ||r(i)||/||b|| 4.022999493413e+13
    0 KSP Residual norm 1.475756125120e-01
    1 KSP Residual norm 6.340526362351e-15
131 KSP preconditioned resid norm 8.314252130468e+01 true resid norm 6.808447742483e+15 ||r(i)||/||b|| 3.877251131258e+13
    0 KSP Residual norm 1.425784809582e-01
    1 KSP Residual norm 2.287330326722e-14
132 KSP preconditioned resid norm 8.226839212542e+01 true resid norm 6.516418982759e+15 ||r(i)||/||b|| 3.710947609247e+13
    0 KSP Residual norm 1.327916764308e-01
    1 KSP Residual norm 1.160678799057e-14
133 KSP preconditioned resid norm 8.078979442602e+01 true resid norm 6.095155862228e+15 ||r(i)||/||b|| 3.471048153099e+13
    0 KSP Residual norm 1.235477772951e-01
    1 KSP Residual norm 1.387437826422e-14
134 KSP preconditioned resid norm 7.933264236809e+01 true resid norm 5.736990224682e+15 ||r(i)||/||b|| 3.267081232022e+13
    0 KSP Residual norm 9.442608308610e-02
    1 KSP Residual norm 8.580779610678e-15
135 KSP preconditioned resid norm 7.629870801296e+01 true resid norm 5.098475070340e+15 ||r(i)||/||b|| 2.903461843560e+13
    0 KSP Residual norm 1.044574609148e-01
    1 KSP Residual norm 5.344151663174e-15
136 KSP preconditioned resid norm 7.384550506962e+01 true resid norm 4.620263607105e+15 ||r(i)||/||b|| 2.631131643353e+13
    0 KSP Residual norm 9.312986062637e-02
    1 KSP Residual norm 1.831837803733e-14
137 KSP preconditioned resid norm 7.019186147043e+01 true resid norm 3.995768136048e+15 ||r(i)||/||b|| 2.275496135348e+13
    0 KSP Residual norm 7.996095146259e-02
    1 KSP Residual norm 3.547339901511e-15
138 KSP preconditioned resid norm 6.549021238982e+01 true resid norm 3.271622426563e+15 ||r(i)||/||b|| 1.863112156283e+13
    0 KSP Residual norm 8.727364488516e-02
    1 KSP Residual norm 7.265180868689e-15
139 KSP preconditioned resid norm 6.216358370903e+01 true resid norm 2.825089749412e+15 ||r(i)||/||b|| 1.608822280954e+13
    0 KSP Residual norm 6.718899482930e-02
    1 KSP Residual norm 3.920662921030e-15
140 KSP preconditioned resid norm 5.819590254270e+01 true resid norm 2.365235650999e+15 ||r(i)||/||b|| 1.346946168993e+13
    0 KSP Residual norm 5.707477036849e-02
    1 KSP Residual norm 5.128671758811e-15
141 KSP preconditioned resid norm 5.322146484911e+01 true resid norm 1.862541531651e+15 ||r(i)||/||b|| 1.060673670967e+13
    0 KSP Residual norm 5.739912345712e-02
    1 KSP Residual norm 5.218644156412e-15
142 KSP preconditioned resid norm 4.838864057319e+01 true resid norm 1.460907841679e+15 ||r(i)||/||b|| 8.319527146358e+12
    0 KSP Residual norm 4.324734710895e-02
    1 KSP Residual norm 1.713271438493e-15
143 KSP preconditioned resid norm 4.288901931377e+01 true resid norm 1.075225961416e+15 ||r(i)||/||b|| 6.123159393948e+12
    0 KSP Residual norm 3.909274848556e-02
    1 KSP Residual norm 3.791735116392e-15
144 KSP preconditioned resid norm 3.774714230712e+01 true resid norm 7.813012526156e+14 ||r(i)||/||b|| 4.449327189008e+12
    0 KSP Residual norm 5.455399761613e-02
    1 KSP Residual norm 8.432667272675e-15
145 KSP preconditioned resid norm 3.210844092000e+01 true resid norm 5.182912921441e+14 ||r(i)||/||b|| 2.951547217213e+12
    0 KSP Residual norm 4.425351119629e-02
    1 KSP Residual norm 7.840730412096e-15
146 KSP preconditioned resid norm 2.633903313561e+01 true resid norm 3.154832144343e+14 ||r(i)||/||b|| 1.796602832722e+12
    0 KSP Residual norm 2.267810003654e-02
    1 KSP Residual norm 1.853325783419e-15
147 KSP preconditioned resid norm 2.195326852966e+01 true resid norm 1.974702011318e+14 ||r(i)||/||b|| 1.124546430680e+12
    0 KSP Residual norm 2.059533160127e-02
    1 KSP Residual norm 3.880033145575e-15
148 KSP preconditioned resid norm 1.932058747257e+01 true resid norm 1.401754982427e+14 ||r(i)||/||b|| 7.982665501638e+11
    0 KSP Residual norm 1.922159692313e-02
    1 KSP Residual norm 4.254698830779e-15
149 KSP preconditioned resid norm 1.720408953179e+01 true resid norm 1.028932388368e+14 ||r(i)||/||b|| 5.859528364877e+11
    0 KSP Residual norm 1.720490765467e-02
    1 KSP Residual norm 2.995400749171e-15
    0 KSP Residual norm 7.698566365971e-01
    1 KSP Residual norm 4.242734101262e-14
150 KSP preconditioned resid norm 1.559612972721e+01 true resid norm 8.129961677145e+13 ||r(i)||/||b|| 4.629822288729e+11
    0 KSP Residual norm 4.983152808428e-02
    1 KSP Residual norm 2.548021685714e-15
151 KSP preconditioned resid norm 1.528043473124e+01 true resid norm 8.168490748905e+13 ||r(i)||/||b|| 4.651763690458e+11
    0 KSP Residual norm 8.775434224923e-02
    1 KSP Residual norm 2.821242593794e-14
152 KSP preconditioned resid norm 1.473379227056e+01 true resid norm 8.241474869184e+13 ||r(i)||/||b|| 4.693326433336e+11
    0 KSP Residual norm 1.611027613575e-01
    1 KSP Residual norm 3.837537072715e-14
153 KSP preconditioned resid norm 1.446555241196e+01 true resid norm 8.283309499757e+13 ||r(i)||/||b|| 4.717150273196e+11
    0 KSP Residual norm 2.003053001324e-01
    1 KSP Residual norm 4.720744628996e-14
154 KSP preconditioned resid norm 1.433069699697e+01 true resid norm 8.320636394822e+13 ||r(i)||/||b|| 4.738407063524e+11
    0 KSP Residual norm 1.383592836455e-01
    1 KSP Residual norm 2.115917312023e-14
155 KSP preconditioned resid norm 1.398451149982e+01 true resid norm 8.447595182963e+13 ||r(i)||/||b|| 4.810707112457e+11
    0 KSP Residual norm 9.419635827286e-02
    1 KSP Residual norm 2.426183427348e-14
156 KSP preconditioned resid norm 1.338238360243e+01 true resid norm 8.694939355383e+13 ||r(i)||/||b|| 4.951563811164e+11
    0 KSP Residual norm 7.008329724485e-02
    1 KSP Residual norm 2.030808580056e-14
157 KSP preconditioned resid norm 1.285596687709e+01 true resid norm 8.942603293712e+13 ||r(i)||/||b|| 5.092602609048e+11
    0 KSP Residual norm 7.375596191492e-02
    1 KSP Residual norm 2.845017599242e-14
158 KSP preconditioned resid norm 1.259640678944e+01 true resid norm 9.096287132985e+13 ||r(i)||/||b|| 5.180121947114e+11
    0 KSP Residual norm 8.009801642531e-02
    1 KSP Residual norm 1.975915069711e-14
159 KSP preconditioned resid norm 1.150402693981e+01 true resid norm 9.770719346254e+13 ||r(i)||/||b|| 5.564195257325e+11
    0 KSP Residual norm 6.933590874665e-02
    1 KSP Residual norm 9.647642941187e-15
160 KSP preconditioned resid norm 1.091253999431e+01 true resid norm 1.013341514372e+14 ||r(i)||/||b|| 5.770741998110e+11
    0 KSP Residual norm 8.164615120399e-02
    1 KSP Residual norm 9.800066509091e-15
161 KSP preconditioned resid norm 1.005189955046e+01 true resid norm 1.071270499652e+14 ||r(i)||/||b|| 6.100633967920e+11
    0 KSP Residual norm 5.939988206716e-02
    1 KSP Residual norm 6.919428925773e-15
162 KSP preconditioned resid norm 9.249803514171e+00 true resid norm 1.126348254529e+14 ||r(i)||/||b|| 6.414288850030e+11
    0 KSP Residual norm 6.189802241163e-02
    1 KSP Residual norm 6.350798872997e-15
163 KSP preconditioned resid norm 8.498257632424e+00 true resid norm 1.184209993877e+14 ||r(i)||/||b|| 6.743797870045e+11
    0 KSP Residual norm 7.196680027343e-02
    1 KSP Residual norm 7.075248718013e-15
164 KSP preconditioned resid norm 7.683745538480e+00 true resid norm 1.250523967921e+14 ||r(i)||/||b|| 7.121440382118e+11
    0 KSP Residual norm 8.816725942938e-02
    1 KSP Residual norm 6.556663955684e-15
165 KSP preconditioned resid norm 7.203608281457e+00 true resid norm 1.292064598020e+14 ||r(i)||/||b|| 7.358004517055e+11
    0 KSP Residual norm 8.595327197871e-02
    1 KSP Residual norm 1.268691476289e-14
166 KSP preconditioned resid norm 6.554687098085e+00 true resid norm 1.355010983788e+14 ||r(i)||/||b|| 7.716469404586e+11
    0 KSP Residual norm 1.049820618324e-01
    1 KSP Residual norm 1.049392572381e-14
167 KSP preconditioned resid norm 6.040625888585e+00 true resid norm 1.410686273098e+14 ||r(i)||/||b|| 8.033527104998e+11
    0 KSP Residual norm 1.082599133933e-01
    1 KSP Residual norm 1.076305957967e-14
168 KSP preconditioned resid norm 5.602778075991e+00 true resid norm 1.472338183013e+14 ||r(i)||/||b|| 8.384620256483e+11
    0 KSP Residual norm 1.214867871266e-01
    1 KSP Residual norm 7.544134595691e-15
169 KSP preconditioned resid norm 5.137313587881e+00 true resid norm 1.546288829821e+14 ||r(i)||/||b|| 8.805751826902e+11
    0 KSP Residual norm 1.451422200433e-01
    1 KSP Residual norm 8.798919031561e-15
170 KSP preconditioned resid norm 4.772073779271e+00 true resid norm 1.617511555644e+14 ||r(i)||/||b|| 9.211348527816e+11
    0 KSP Residual norm 1.538997464631e-01
    1 KSP Residual norm 1.154848627985e-14
171 KSP preconditioned resid norm 4.429551959412e+00 true resid norm 1.699874542588e+14 ||r(i)||/||b|| 9.680386400149e+11
    0 KSP Residual norm 1.772777372295e-01
    1 KSP Residual norm 1.088781590122e-14
172 KSP preconditioned resid norm 4.058042007762e+00 true resid norm 1.807915970742e+14 ||r(i)||/||b|| 1.029565696604e+12
    0 KSP Residual norm 2.218964362063e-01
    1 KSP Residual norm 1.367276410642e-14
173 KSP preconditioned resid norm 3.659352909972e+00 true resid norm 1.979586060760e+14 ||r(i)||/||b|| 1.127327782163e+12
    0 KSP Residual norm 3.042932733202e-01
    1 KSP Residual norm 1.514786491688e-14
174 KSP preconditioned resid norm 3.345836830163e+00 true resid norm 2.142617703762e+14 ||r(i)||/||b|| 1.220170474971e+12
    0 KSP Residual norm 3.423019487483e-01
    1 KSP Residual norm 1.585379300763e-14
175 KSP preconditioned resid norm 3.144285094141e+00 true resid norm 2.281977537693e+14 ||r(i)||/||b|| 1.299532628314e+12
    0 KSP Residual norm 3.444560138891e-01
    1 KSP Residual norm 1.826154859425e-14
176 KSP preconditioned resid norm 3.022396458018e+00 true resid norm 2.394375101324e+14 ||r(i)||/||b|| 1.363540401777e+12
    0 KSP Residual norm 3.264841471998e-01
    1 KSP Residual norm 2.281531782132e-14
177 KSP preconditioned resid norm 2.937051498184e+00 true resid norm 2.511984383257e+14 ||r(i)||/||b|| 1.430516126446e+12
    0 KSP Residual norm 3.438912207642e-01
    1 KSP Residual norm 1.255498343538e-14
178 KSP preconditioned resid norm 2.894843703130e+00 true resid norm 2.630994251974e+14 ||r(i)||/||b|| 1.498289452403e+12
    0 KSP Residual norm 3.690538188432e-01
    1 KSP Residual norm 2.250517560947e-14
179 KSP preconditioned resid norm 2.891859475040e+00 true resid norm 2.664328621553e+14 ||r(i)||/||b|| 1.517272593208e+12
    0 KSP Residual norm 2.805084972468e-01
    1 KSP Residual norm 1.040787396795e-14
    0 KSP Residual norm 2.456335165427e+00
    1 KSP Residual norm 1.187478904410e-13
180 KSP preconditioned resid norm 2.881378939656e+00 true resid norm 2.599861140094e+14 ||r(i)||/||b|| 1.480559876173e+12
    0 KSP Residual norm 8.527765332166e-01
    1 KSP Residual norm 4.441865472488e-14
181 KSP preconditioned resid norm 2.879542572807e+00 true resid norm 2.605906041815e+14 ||r(i)||/||b|| 1.484002305773e+12
    0 KSP Residual norm 1.392188934233e-01
    1 KSP Residual norm 2.345546419849e-14
182 KSP preconditioned resid norm 2.877331841910e+00 true resid norm 2.614134834872e+14 ||r(i)||/||b|| 1.488688410212e+12
    0 KSP Residual norm 1.683164945024e-01
    1 KSP Residual norm 3.403904075903e-14
183 KSP preconditioned resid norm 2.874457206174e+00 true resid norm 2.627920202652e+14 ||r(i)||/||b|| 1.496538853491e+12
    0 KSP Residual norm 2.072401669340e-01
    1 KSP Residual norm 3.345257461923e-14
184 KSP preconditioned resid norm 2.874349932663e+00 true resid norm 2.629889650379e+14 ||r(i)||/||b|| 1.497660407730e+12
    0 KSP Residual norm 2.170144502745e-01
    1 KSP Residual norm 5.819885505904e-14
185 KSP preconditioned resid norm 2.874316515576e+00 true resid norm 2.632240654583e+14 ||r(i)||/||b|| 1.498999249424e+12
    0 KSP Residual norm 1.800384503143e-01
    1 KSP Residual norm 1.591860780959e-14
186 KSP preconditioned resid norm 2.873427056139e+00 true resid norm 2.616630691857e+14 ||r(i)||/||b|| 1.490109742164e+12
    0 KSP Residual norm 2.018927052803e-01
    1 KSP Residual norm 3.129174808875e-14
187 KSP preconditioned resid norm 2.871829462138e+00 true resid norm 2.600478851962e+14 ||r(i)||/||b|| 1.480911648579e+12
    0 KSP Residual norm 1.637917563527e-01
    1 KSP Residual norm 3.193446569020e-14
188 KSP preconditioned resid norm 2.866311791868e+00 true resid norm 2.569200071429e+14 ||r(i)||/||b|| 1.463099117472e+12
    0 KSP Residual norm 1.379315055220e-01
    1 KSP Residual norm 1.105628872594e-14
189 KSP preconditioned resid norm 2.846491410206e+00 true resid norm 2.470738274589e+14 ||r(i)||/||b|| 1.407027435992e+12
    0 KSP Residual norm 1.842917846689e-01
    1 KSP Residual norm 1.179166615236e-14
190 KSP preconditioned resid norm 2.819731512218e+00 true resid norm 2.362847153980e+14 ||r(i)||/||b|| 1.345585976022e+12
    0 KSP Residual norm 1.576426740575e-01
    1 KSP Residual norm 1.707484813968e-14
191 KSP preconditioned resid norm 2.792936291745e+00 true resid norm 2.273872017288e+14 ||r(i)||/||b|| 1.294916724756e+12
    0 KSP Residual norm 1.220909275811e-01
    1 KSP Residual norm 1.197393115191e-14
192 KSP preconditioned resid norm 2.756925837105e+00 true resid norm 2.167289779578e+14 ||r(i)||/||b|| 1.234220642864e+12
    0 KSP Residual norm 1.143566345141e-01
    1 KSP Residual norm 1.148499584951e-14
193 KSP preconditioned resid norm 2.712359961087e+00 true resid norm 2.044302013060e+14 ||r(i)||/||b|| 1.164181997508e+12
    0 KSP Residual norm 1.107756532337e-01
    1 KSP Residual norm 1.632152981890e-14
194 KSP preconditioned resid norm 2.634448327016e+00 true resid norm 1.861634496794e+14 ||r(i)||/||b|| 1.060157135913e+12
    0 KSP Residual norm 1.043405317003e-01
    1 KSP Residual norm 7.856186790365e-15
195 KSP preconditioned resid norm 2.554393404317e+00 true resid norm 1.695437914179e+14 ||r(i)||/||b|| 9.655120843051e+11
    0 KSP Residual norm 8.897340056754e-02
    1 KSP Residual norm 1.233077367022e-14
196 KSP preconditioned resid norm 2.423824906921e+00 true resid norm 1.453836419572e+14 ||r(i)||/||b|| 8.279257057783e+11
    0 KSP Residual norm 9.502812970292e-02
    1 KSP Residual norm 7.704791381187e-15
197 KSP preconditioned resid norm 2.301146621552e+00 true resid norm 1.254691319924e+14 ||r(i)||/||b|| 7.145172473306e+11
    0 KSP Residual norm 7.907420812051e-02
    1 KSP Residual norm 7.888966824591e-15
198 KSP preconditioned resid norm 2.127716661822e+00 true resid norm 1.001849406975e+14 ||r(i)||/||b|| 5.705297144763e+11
    0 KSP Residual norm 8.716253367866e-02
    1 KSP Residual norm 8.361962613217e-15
199 KSP preconditioned resid norm 2.009570453213e+00 true resid norm 8.505084049811e+13 ||r(i)||/||b|| 4.843445672325e+11
    0 KSP Residual norm 6.819264528613e-02
    1 KSP Residual norm 6.951257832233e-15
200 KSP preconditioned resid norm 1.877929062377e+00 true resid norm 7.067972158531e+13 ||r(i)||/||b|| 4.025044192727e+11
    0 KSP Residual norm 5.672402963659e-02
    1 KSP Residual norm 5.297852273456e-15
201 KSP preconditioned resid norm 1.742306242225e+00 true resid norm 5.778292864225e+13 ||r(i)||/||b|| 3.290602115481e+11
    0 KSP Residual norm 4.871933633585e-02
    1 KSP Residual norm 6.192002480595e-15
202 KSP preconditioned resid norm 1.552694419760e+00 true resid norm 4.295281880799e+13 ||r(i)||/||b|| 2.446062180589e+11
    0 KSP Residual norm 4.918330495290e-02
    1 KSP Residual norm 4.483591375824e-15
203 KSP preconditioned resid norm 1.405131030219e+00 true resid norm 3.341310972617e+13 ||r(i)||/||b|| 1.902798147018e+11
    0 KSP Residual norm 5.301758775286e-02
    1 KSP Residual norm 4.985298204897e-15
204 KSP preconditioned resid norm 1.207664654845e+00 true resid norm 2.297637594674e+13 ||r(i)||/||b|| 1.308450663076e+11
    0 KSP Residual norm 3.487114864986e-02
    1 KSP Residual norm 6.686322509946e-15
205 KSP preconditioned resid norm 1.053317934875e+00 true resid norm 1.622814116375e+13 ||r(i)||/||b|| 9.241545366171e+10
    0 KSP Residual norm 4.464047516038e-02
    1 KSP Residual norm 6.373082739763e-15
206 KSP preconditioned resid norm 8.888842477271e-01 true resid norm 1.056121318385e+13 ||r(i)||/||b|| 6.014362937534e+10
    0 KSP Residual norm 2.308297823471e-02
    1 KSP Residual norm 3.228552462555e-15
207 KSP preconditioned resid norm 7.509565241464e-01 true resid norm 6.806270118230e+12 ||r(i)||/||b|| 3.876011025375e+10
    0 KSP Residual norm 2.177134799295e-02
    1 KSP Residual norm 6.514276661277e-15
208 KSP preconditioned resid norm 6.625683546609e-01 true resid norm 4.847391962688e+12 ||r(i)||/||b|| 2.760475909025e+10
    0 KSP Residual norm 2.577304365446e-02
    1 KSP Residual norm 3.006506436827e-15
209 KSP preconditioned resid norm 5.988642171909e-01 true resid norm 3.692436202320e+12 ||r(i)||/||b|| 2.102755721133e+10
    0 KSP Residual norm 3.086253992372e-02
    1 KSP Residual norm 4.986918085249e-15
    0 KSP Residual norm 2.885326783279e-02
    1 KSP Residual norm 1.404475689675e-15
210 KSP preconditioned resid norm 5.549022199891e-01 true resid norm 3.047379519414e+12 ||r(i)||/||b|| 1.735411085745e+10
    0 KSP Residual norm 5.211250667338e-02
    1 KSP Residual norm 1.949072374552e-15
211 KSP preconditioned resid norm 5.455065633447e-01 true resid norm 3.068914211850e+12 ||r(i)||/||b|| 1.747674587466e+10
    0 KSP Residual norm 5.362579277780e-02
    1 KSP Residual norm 1.739560075111e-14
212 KSP preconditioned resid norm 5.256035528838e-01 true resid norm 3.117147854387e+12 ||r(i)||/||b|| 1.775142514396e+10
    0 KSP Residual norm 9.498397648598e-02
    1 KSP Residual norm 3.157070253707e-14
213 KSP preconditioned resid norm 5.188510171595e-01 true resid norm 3.135844570587e+12 ||r(i)||/||b|| 1.785789855284e+10
    0 KSP Residual norm 1.747223733427e-01
    1 KSP Residual norm 2.229812801717e-14
214 KSP preconditioned resid norm 5.064659649982e-01 true resid norm 3.177031272671e+12 ||r(i)||/||b|| 1.809244715083e+10
    0 KSP Residual norm 1.236869632461e-01
    1 KSP Residual norm 2.922225997772e-14
215 KSP preconditioned resid norm 4.942964291547e-01 true resid norm 3.227526236207e+12 ||r(i)||/||b|| 1.838000411226e+10
    0 KSP Residual norm 1.670277153783e-01
    1 KSP Residual norm 2.489463845279e-14
216 KSP preconditioned resid norm 4.748832016015e-01 true resid norm 3.319200539705e+12 ||r(i)||/||b|| 1.890206774614e+10
    0 KSP Residual norm 1.233207557671e-01
    1 KSP Residual norm 2.664414905660e-14
217 KSP preconditioned resid norm 4.515765272474e-01 true resid norm 3.439080465531e+12 ||r(i)||/||b|| 1.958475577666e+10
    0 KSP Residual norm 1.069169676118e-01
    1 KSP Residual norm 1.742013956853e-14
218 KSP preconditioned resid norm 4.373635821286e-01 true resid norm 3.528932804201e+12 ||r(i)||/||b|| 2.009644374862e+10
    0 KSP Residual norm 8.848611903705e-02
    1 KSP Residual norm 2.037010741050e-14
219 KSP preconditioned resid norm 4.009408906413e-01 true resid norm 3.761069194307e+12 ||r(i)||/||b|| 2.141840598610e+10
    0 KSP Residual norm 7.406641258785e-02
    1 KSP Residual norm 1.727865745898e-14
220 KSP preconditioned resid norm 3.740642106294e-01 true resid norm 3.936784283271e+12 ||r(i)||/||b|| 2.241906216095e+10
    0 KSP Residual norm 8.464274294020e-02
    1 KSP Residual norm 1.362084954420e-14
221 KSP preconditioned resid norm 3.517621171323e-01 true resid norm 4.097032495403e+12 ||r(i)||/||b|| 2.333163810377e+10
    0 KSP Residual norm 7.084819938922e-02
    1 KSP Residual norm 9.867274238529e-15
222 KSP preconditioned resid norm 3.229172006626e-01 true resid norm 4.313513535838e+12 ||r(i)||/||b|| 2.456444680066e+10
    0 KSP Residual norm 7.419457027247e-02
    1 KSP Residual norm 1.371011247946e-14
223 KSP preconditioned resid norm 2.994652166016e-01 true resid norm 4.502573148283e+12 ||r(i)||/||b|| 2.564109690352e+10
    0 KSP Residual norm 8.126563841148e-02
    1 KSP Residual norm 6.406045790162e-15
224 KSP preconditioned resid norm 2.773847405024e-01 true resid norm 4.710007856899e+12 ||r(i)||/||b|| 2.682238886471e+10
    0 KSP Residual norm 8.654362398008e-02
    1 KSP Residual norm 9.059827849603e-15
225 KSP preconditioned resid norm 2.501293925886e-01 true resid norm 4.969592381216e+12 ||r(i)||/||b|| 2.830066178188e+10
    0 KSP Residual norm 1.053285546577e-01
    1 KSP Residual norm 8.400900669162e-15
226 KSP preconditioned resid norm 2.304711303177e-01 true resid norm 5.185436529100e+12 ||r(i)||/||b|| 2.952984352523e+10
    0 KSP Residual norm 1.066853240120e-01
    1 KSP Residual norm 9.778263593415e-15
227 KSP preconditioned resid norm 2.100779081353e-01 true resid norm 5.450173944695e+12 ||r(i)||/||b|| 3.103746094835e+10
    0 KSP Residual norm 1.277024603368e-01
    1 KSP Residual norm 9.776514604684e-15
228 KSP preconditioned resid norm 1.902334377364e-01 true resid norm 5.764163371932e+12 ||r(i)||/||b|| 3.282555701372e+10
    0 KSP Residual norm 1.543910821598e-01
    1 KSP Residual norm 1.181391499448e-14
229 KSP preconditioned resid norm 1.696092543322e-01 true resid norm 6.179727454390e+12 ||r(i)||/||b|| 3.519209689148e+10
    0 KSP Residual norm 1.979926773607e-01
    1 KSP Residual norm 1.071619560571e-14
230 KSP preconditioned resid norm 1.581594612138e-01 true resid norm 6.486820673125e+12 ||r(i)||/||b|| 3.694092066861e+10
    0 KSP Residual norm 1.854916535800e-01
    1 KSP Residual norm 1.132398649899e-14
231 KSP preconditioned resid norm 1.508614670436e-01 true resid norm 6.725942677263e+12 ||r(i)||/||b|| 3.830266433782e+10
    0 KSP Residual norm 1.739948371107e-01
    1 KSP Residual norm 1.000596545317e-14
232 KSP preconditioned resid norm 1.423059331638e-01 true resid norm 7.059559742076e+12 ||r(i)||/||b|| 4.020253519074e+10
    0 KSP Residual norm 2.165302109324e-01
    1 KSP Residual norm 1.436273080547e-14
233 KSP preconditioned resid norm 1.315342545891e-01 true resid norm 7.576207806606e+12 ||r(i)||/||b|| 4.314472461251e+10
    0 KSP Residual norm 2.911479359997e-01
    1 KSP Residual norm 1.198219600577e-14
234 KSP preconditioned resid norm 1.237629426248e-01 true resid norm 8.062838626274e+12 ||r(i)||/||b|| 4.591597287265e+10
    0 KSP Residual norm 3.061700420075e-01
    1 KSP Residual norm 1.407708677210e-14
235 KSP preconditioned resid norm 1.167454862829e-01 true resid norm 8.626377131458e+12 ||r(i)||/||b|| 4.912519234437e+10
    0 KSP Residual norm 3.548961874561e-01
    1 KSP Residual norm 1.604305454787e-14
236 KSP preconditioned resid norm 1.118149553209e-01 true resid norm 9.193243533084e+12 ||r(i)||/||b|| 5.235336340495e+10
    0 KSP Residual norm 3.770259787025e-01
    1 KSP Residual norm 1.893803176438e-14
237 KSP preconditioned resid norm 1.093202512722e-01 true resid norm 9.616800691160e+12 ||r(i)||/||b|| 5.476542197162e+10
    0 KSP Residual norm 3.417889391749e-01
    1 KSP Residual norm 1.690901852777e-14
238 KSP preconditioned resid norm 1.083571127873e-01 true resid norm 9.931580028790e+12 ||r(i)||/||b|| 5.655801639121e+10
    0 KSP Residual norm 3.187112380794e-01
    1 KSP Residual norm 1.620010267590e-14
239 KSP preconditioned resid norm 1.082843905303e-01 true resid norm 1.003793770978e+13 ||r(i)||/||b|| 5.716369841234e+10
    0 KSP Residual norm 2.871816129329e-01
    1 KSP Residual norm 9.856603275885e-15
    0 KSP Residual norm 9.305816419653e-02
    1 KSP Residual norm 5.125943974901e-15
240 KSP preconditioned resid norm 1.078315051119e-01 true resid norm 9.849631662842e+12 ||r(i)||/||b|| 5.609133968810e+10
    0 KSP Residual norm 8.631975659100e-01
    1 KSP Residual norm 4.341548554567e-14
241 KSP preconditioned resid norm 1.077293243842e-01 true resid norm 9.870900635153e+12 ||r(i)||/||b|| 5.621246149159e+10
    0 KSP Residual norm 2.124036568843e-01
    1 KSP Residual norm 2.822614733058e-14
242 KSP preconditioned resid norm 1.075375019689e-01 true resid norm 9.914545172593e+12 ||r(i)||/||b|| 5.646100688485e+10
    0 KSP Residual norm 1.583603326980e-01
    1 KSP Residual norm 3.059478151273e-14
243 KSP preconditioned resid norm 1.074753395368e-01 true resid norm 9.944195858321e+12 ||r(i)||/||b|| 5.662986057827e+10
    0 KSP Residual norm 1.464411713550e-01
    1 KSP Residual norm 2.581305253579e-14
244 KSP preconditioned resid norm 1.074753393734e-01 true resid norm 9.944116001255e+12 ||r(i)||/||b|| 5.662940581103e+10
    0 KSP Residual norm 1.844774702344e-01
    1 KSP Residual norm 2.734713125893e-14
245 KSP preconditioned resid norm 1.074691947874e-01 true resid norm 9.924463134528e+12 ||r(i)||/||b|| 5.651748734939e+10
    0 KSP Residual norm 2.072421499599e-01
    1 KSP Residual norm 3.536389172473e-14
246 KSP preconditioned resid norm 1.073633495242e-01 true resid norm 9.811984249327e+12 ||r(i)||/||b|| 5.587694650751e+10
    0 KSP Residual norm 2.090367772690e-01
    1 KSP Residual norm 2.022736372740e-14
247 KSP preconditioned resid norm 1.072871234598e-01 true resid norm 9.751058413422e+12 ||r(i)||/||b|| 5.552998817703e+10
    0 KSP Residual norm 1.467686068074e-01
    1 KSP Residual norm 2.528166708051e-14
248 KSP preconditioned resid norm 1.067011226183e-01 true resid norm 9.474124334909e+12 ||r(i)||/||b|| 5.395291362229e+10
    0 KSP Residual norm 1.509317584687e-01
    1 KSP Residual norm 8.128514111878e-15
249 KSP preconditioned resid norm 1.055794830704e-01 true resid norm 9.010857808915e+12 ||r(i)||/||b|| 5.131471952883e+10
    0 KSP Residual norm 1.686711500127e-01
    1 KSP Residual norm 1.486145068985e-14
250 KSP preconditioned resid norm 1.047264121276e-01 true resid norm 8.722577180229e+12 ||r(i)||/||b|| 4.967302903495e+10
    0 KSP Residual norm 1.142587525903e-01
    1 KSP Residual norm 1.667766960153e-14
251 KSP preconditioned resid norm 1.029467816886e-01 true resid norm 8.186043104130e+12 ||r(i)||/||b|| 4.661759344640e+10
    0 KSP Residual norm 1.321819326806e-01
    1 KSP Residual norm 1.013710018293e-14
252 KSP preconditioned resid norm 1.004305894140e-01 true resid norm 7.495640695546e+12 ||r(i)||/||b|| 4.268591383168e+10
    0 KSP Residual norm 1.307320262440e-01
    1 KSP Residual norm 1.163000419497e-14
253 KSP preconditioned resid norm 9.795525188712e-02 true resid norm 6.920433832017e+12 ||r(i)||/||b|| 3.941024579885e+10
    0 KSP Residual norm 1.033010276042e-01
    1 KSP Residual norm 2.057300677142e-14
254 KSP preconditioned resid norm 9.555346666676e-02 true resid norm 6.409436126785e+12 ||r(i)||/||b|| 3.650023384661e+10
    0 KSP Residual norm 1.001483252949e-01
    1 KSP Residual norm 3.022216578126e-14
255 KSP preconditioned resid norm 9.212243463287e-02 true resid norm 5.754536094258e+12 ||r(i)||/||b|| 3.277073192779e+10
    0 KSP Residual norm 8.638821676481e-02
    1 KSP Residual norm 7.181126476117e-15
256 KSP preconditioned resid norm 8.758708194374e-02 true resid norm 4.960276502644e+12 ||r(i)||/||b|| 2.824761004072e+10
    0 KSP Residual norm 8.754618472946e-02
    1 KSP Residual norm 8.117223947162e-15
257 KSP preconditioned resid norm 8.129609425535e-02 true resid norm 4.021894178468e+12 ||r(i)||/||b|| 2.290374303083e+10
    0 KSP Residual norm 8.467147798403e-02
    1 KSP Residual norm 6.784150236776e-15
258 KSP preconditioned resid norm 7.531175302380e-02 true resid norm 3.231810388767e+12 ||r(i)||/||b|| 1.840440135521e+10
    0 KSP Residual norm 7.848478043310e-02
    1 KSP Residual norm 4.316675777061e-15
259 KSP preconditioned resid norm 7.147270516207e-02 true resid norm 2.780270355409e+12 ||r(i)||/||b|| 1.583298688400e+10
    0 KSP Residual norm 6.058373929961e-02
    1 KSP Residual norm 5.289429363899e-15
260 KSP preconditioned resid norm 6.629489690362e-02 true resid norm 2.268100553137e+12 ||r(i)||/||b|| 1.291630011432e+10
    0 KSP Residual norm 5.613908443002e-02
    1 KSP Residual norm 8.820012013287e-15
261 KSP preconditioned resid norm 6.208842131630e-02 true resid norm 1.905339947374e+12 ||r(i)||/||b|| 1.085046363842e+10
    0 KSP Residual norm 4.231798995468e-02
    1 KSP Residual norm 7.630919261092e-15
262 KSP preconditioned resid norm 5.627458278077e-02 true resid norm 1.483145028925e+12 ||r(i)||/||b|| 8.446162706573e+09
    0 KSP Residual norm 4.916578646329e-02
    1 KSP Residual norm 2.949348030580e-15
263 KSP preconditioned resid norm 4.990039343986e-02 true resid norm 1.096548664620e+12 ||r(i)||/||b|| 6.244587182255e+09
    0 KSP Residual norm 4.483292043233e-02
    1 KSP Residual norm 4.418728740841e-15
264 KSP preconditioned resid norm 4.497116392959e-02 true resid norm 8.467826607120e+11 ||r(i)||/||b|| 4.822228433493e+09
    0 KSP Residual norm 3.343913990765e-02
    1 KSP Residual norm 4.058113449723e-15
265 KSP preconditioned resid norm 3.747770397703e-02 true resid norm 5.348773999832e+11 ||r(i)||/||b|| 3.046001207043e+09
    0 KSP Residual norm 3.638852525403e-02
    1 KSP Residual norm 6.127995084333e-15
266 KSP preconditioned resid norm 3.272498533581e-02 true resid norm 3.761035937528e+11 ||r(i)||/||b|| 2.141821659655e+09
    0 KSP Residual norm 2.134376559679e-02
    1 KSP Residual norm 2.972817521485e-15
267 KSP preconditioned resid norm 2.833964662941e-02 true resid norm 2.584023473356e+11 ||r(i)||/||b|| 1.471540696824e+09
    0 KSP Residual norm 3.350744666503e-02
    1 KSP Residual norm 7.530068076823e-15
268 KSP preconditioned resid norm 2.427356052923e-02 true resid norm 1.695160385358e+11 ||r(i)||/||b|| 9.653540381580e+08
    0 KSP Residual norm 3.167316747264e-02
    1 KSP Residual norm 5.083477541133e-15
269 KSP preconditioned resid norm 2.223267214607e-02 true resid norm 1.346277567493e+11 ||r(i)||/||b|| 7.666734649336e+08
    0 KSP Residual norm 2.410458980223e-02
    1 KSP Residual norm 5.490623589024e-15
    0 KSP Residual norm 1.051400199236e-03
    1 KSP Residual norm 4.641030410088e-17
270 KSP preconditioned resid norm 2.051294383185e-02 true resid norm 1.110745980536e+11 ||r(i)||/||b|| 6.325437562959e+08
    0 KSP Residual norm 5.136682259001e-02
    1 KSP Residual norm 2.027427674949e-15
271 KSP preconditioned resid norm 2.015854957434e-02 true resid norm 1.116964726126e+11 ||r(i)||/||b|| 6.360851858972e+08
    0 KSP Residual norm 5.642231017164e-02
    1 KSP Residual norm 1.134158249079e-14
272 KSP preconditioned resid norm 1.928855547464e-02 true resid norm 1.133138446679e+11 ||r(i)||/||b|| 6.452957400029e+08
    0 KSP Residual norm 9.765186556955e-02
    1 KSP Residual norm 2.234729757801e-14
273 KSP preconditioned resid norm 1.901642751801e-02 true resid norm 1.139196332011e+11 ||r(i)||/||b|| 6.487455634645e+08
    0 KSP Residual norm 2.089884619353e-01
    1 KSP Residual norm 3.975660349867e-14
274 KSP preconditioned resid norm 1.867376689073e-02 true resid norm 1.148722535933e+11 ||r(i)||/||b|| 6.541705129284e+08
    0 KSP Residual norm 1.440256051332e-01
    1 KSP Residual norm 3.175387513871e-14
275 KSP preconditioned resid norm 1.820278690528e-02 true resid norm 1.164715122429e+11 ||r(i)||/||b|| 6.632779154420e+08
    0 KSP Residual norm 9.908548901254e-02
    1 KSP Residual norm 1.514068651114e-14
276 KSP preconditioned resid norm 1.749874765680e-02 true resid norm 1.194547409423e+11 ||r(i)||/||b|| 6.802667024419e+08
    0 KSP Residual norm 1.148081477012e-01
    1 KSP Residual norm 3.134244668133e-14
277 KSP preconditioned resid norm 1.687371324494e-02 true resid norm 1.224936496306e+11 ||r(i)||/||b|| 6.975725739051e+08
    0 KSP Residual norm 9.748609335503e-02
    1 KSP Residual norm 2.910045348598e-14
278 KSP preconditioned resid norm 1.639579962064e-02 true resid norm 1.252604619142e+11 ||r(i)||/||b|| 7.133289202302e+08
    0 KSP Residual norm 9.037786907532e-02
    1 KSP Residual norm 3.140553015773e-14
279 KSP preconditioned resid norm 1.496516824281e-02 true resid norm 1.337998766917e+11 ||r(i)||/||b|| 7.619588823868e+08
    0 KSP Residual norm 6.843201195034e-02
    1 KSP Residual norm 1.476997112843e-14
280 KSP preconditioned resid norm 1.418033786605e-02 true resid norm 1.386300123404e+11 ||r(i)||/||b|| 7.894653708208e+08
    0 KSP Residual norm 8.555563116090e-02
    1 KSP Residual norm 1.378906607762e-14
281 KSP preconditioned resid norm 1.331743441195e-02 true resid norm 1.444341012579e+11 ||r(i)||/||b|| 8.225182944417e+08
    0 KSP Residual norm 6.574073569061e-02
    1 KSP Residual norm 6.115370955524e-15
282 KSP preconditioned resid norm 1.222654523959e-02 true resid norm 1.521352340423e+11 ||r(i)||/||b|| 8.663744374713e+08
    0 KSP Residual norm 6.383344046193e-02
    1 KSP Residual norm 7.856819645912e-15
283 KSP preconditioned resid norm 1.131428865743e-02 true resid norm 1.595357992507e+11 ||r(i)||/||b|| 9.085189187270e+08
    0 KSP Residual norm 7.311734144150e-02
    1 KSP Residual norm 1.115920122563e-14
284 KSP preconditioned resid norm 1.037046304893e-02 true resid norm 1.680264075889e+11 ||r(i)||/||b|| 9.568709396714e+08
    0 KSP Residual norm 8.592477540254e-02
    1 KSP Residual norm 1.156068322093e-14
285 KSP preconditioned resid norm 9.688198762175e-03 true resid norm 1.743227657802e+11 ||r(i)||/||b|| 9.927272212254e+08
    0 KSP Residual norm 8.426922320142e-02
    1 KSP Residual norm 3.949284064332e-15
286 KSP preconditioned resid norm 9.052118320697e-03 true resid norm 1.811488172856e+11 ||r(i)||/||b|| 1.031599981835e+09
    0 KSP Residual norm 9.186368600513e-02
    1 KSP Residual norm 6.582672988054e-15
287 KSP preconditioned resid norm 8.110683448667e-03 true resid norm 1.926556955885e+11 ||r(i)||/||b|| 1.097128952026e+09
    0 KSP Residual norm 1.262092759332e-01
    1 KSP Residual norm 7.546825301272e-15
288 KSP preconditioned resid norm 7.508139123502e-03 true resid norm 2.010760697421e+11 ||r(i)||/||b|| 1.145081005780e+09
    0 KSP Residual norm 1.232480811525e-01
    1 KSP Residual norm 7.782003264457e-15
289 KSP preconditioned resid norm 6.917241898136e-03 true resid norm 2.109957958410e+11 ||r(i)||/||b|| 1.201571516824e+09
    0 KSP Residual norm 1.458453127507e-01
    1 KSP Residual norm 7.940187999184e-15
290 KSP preconditioned resid norm 6.270807515459e-03 true resid norm 2.235532907593e+11 ||r(i)||/||b|| 1.273083501963e+09
    0 KSP Residual norm 1.819572252522e-01
    1 KSP Residual norm 1.436046038556e-14
291 KSP preconditioned resid norm 5.723445930406e-03 true resid norm 2.366865076416e+11 ||r(i)||/||b|| 1.347874088510e+09
    0 KSP Residual norm 2.049783709059e-01
    1 KSP Residual norm 1.076610048324e-14
292 KSP preconditioned resid norm 5.384061758061e-03 true resid norm 2.476830100424e+11 ||r(i)||/||b|| 1.410496587773e+09
    0 KSP Residual norm 1.979746680572e-01
    1 KSP Residual norm 1.027368530784e-14
293 KSP preconditioned resid norm 5.001851591856e-03 true resid norm 2.646739127192e+11 ||r(i)||/||b|| 1.507255789160e+09
    0 KSP Residual norm 2.598181997627e-01
    1 KSP Residual norm 1.148559409323e-14
294 KSP preconditioned resid norm 4.705087086658e-03 true resid norm 2.809591417686e+11 ||r(i)||/||b|| 1.599996344926e+09
    0 KSP Residual norm 2.769227109196e-01
    1 KSP Residual norm 1.366070705781e-14
295 KSP preconditioned resid norm 4.424601809451e-03 true resid norm 3.023642732917e+11 ||r(i)||/||b|| 1.721893543160e+09
    0 KSP Residual norm 3.397692724522e-01
    1 KSP Residual norm 1.290250727597e-14
296 KSP preconditioned resid norm 4.204816135054e-03 true resid norm 3.239122788695e+11 ||r(i)||/||b|| 1.844604375589e+09
    0 KSP Residual norm 3.716721838185e-01
    1 KSP Residual norm 2.596154084612e-14
297 KSP preconditioned resid norm 4.020991299471e-03 true resid norm 3.491083171568e+11 ||r(i)||/||b|| 1.988089897763e+09
    0 KSP Residual norm 4.261036489188e-01
    1 KSP Residual norm 1.822196692684e-14
298 KSP preconditioned resid norm 3.962923728563e-03 true resid norm 3.653307902232e+11 ||r(i)||/||b|| 2.080473072941e+09
    0 KSP Residual norm 3.697803614075e-01
    1 KSP Residual norm 2.384951372987e-14
299 KSP preconditioned resid norm 3.957387938402e-03 true resid norm 3.700700457571e+11 ||r(i)||/||b|| 2.107462020459e+09
    0 KSP Residual norm 2.629908750446e-01
    1 KSP Residual norm 1.183986125549e-14
    0 KSP Residual norm 3.422441367284e-03
    1 KSP Residual norm 1.636073791245e-16
300 KSP preconditioned resid norm 3.939103706412e-03 true resid norm 3.622465539444e+11 ||r(i)||/||b|| 2.062909071493e+09
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 8.689675100410e-01
    1 KSP Residual norm 4.110406281660e-14
301 KSP preconditioned resid norm 3.936147418317e-03 true resid norm 3.628689205460e+11 ||r(i)||/||b|| 2.066453303161e+09
    0 KSP Residual norm 1.941237217684e-01
    1 KSP Residual norm 3.654342959634e-14
302 KSP preconditioned resid norm 3.931462764084e-03 true resid norm 3.639587685780e+11 ||r(i)||/||b|| 2.072659731814e+09
    0 KSP Residual norm 1.714532365736e-01
    1 KSP Residual norm 2.465173478608e-14
303 KSP preconditioned resid norm 3.926430936071e-03 true resid norm 3.655824828049e+11 ||r(i)||/||b|| 2.081906403098e+09
    0 KSP Residual norm 1.465762168832e-01
    1 KSP Residual norm 1.776189431029e-14
304 KSP preconditioned resid norm 3.926017212455e-03 true resid norm 3.661256993569e+11 ||r(i)||/||b|| 2.084999893818e+09
    0 KSP Residual norm 1.372160993447e-01
    1 KSP Residual norm 2.732388886982e-14
305 KSP preconditioned resid norm 3.925345705573e-03 true resid norm 3.649008716223e+11 ||r(i)||/||b|| 2.078024787451e+09
    0 KSP Residual norm 1.757222143455e-01
    1 KSP Residual norm 2.703342797030e-14
306 KSP preconditioned resid norm 3.923355352898e-03 true resid norm 3.626445385881e+11 ||r(i)||/||b|| 2.065175500595e+09
    0 KSP Residual norm 2.082277875927e-01
    1 KSP Residual norm 4.030968503734e-14
307 KSP preconditioned resid norm 3.917018032874e-03 true resid norm 3.580382977176e+11 ||r(i)||/||b|| 2.038944040353e+09
    0 KSP Residual norm 1.876152800596e-01
    1 KSP Residual norm 3.861888673792e-14
308 KSP preconditioned resid norm 3.903310183725e-03 true resid norm 3.514819371400e+11 ||r(i)||/||b|| 2.001607106256e+09
    0 KSP Residual norm 1.350617692262e-01
    1 KSP Residual norm 1.714074604894e-14
309 KSP preconditioned resid norm 3.868426817964e-03 true resid norm 3.361175125711e+11 ||r(i)||/||b|| 1.914110315807e+09
    0 KSP Residual norm 1.737802075693e-01
    1 KSP Residual norm 1.065291850979e-14
310 KSP preconditioned resid norm 3.830522327434e-03 true resid norm 3.221653934227e+11 ||r(i)||/||b|| 1.834656273127e+09
    0 KSP Residual norm 1.406895635003e-01
    1 KSP Residual norm 7.661562948385e-15
311 KSP preconditioned resid norm 3.796427162378e-03 true resid norm 3.115929492422e+11 ||r(i)||/||b|| 1.774448685863e+09
    0 KSP Residual norm 1.156924079072e-01
    1 KSP Residual norm 2.624744488131e-14
312 KSP preconditioned resid norm 3.690308765222e-03 true resid norm 2.821289622466e+11 ||r(i)||/||b|| 1.606658197882e+09
    0 KSP Residual norm 1.372604233523e-01
    1 KSP Residual norm 5.427199790975e-15
313 KSP preconditioned resid norm 3.593413434155e-03 true resid norm 2.581294623390e+11 ||r(i)||/||b|| 1.469986680841e+09
    0 KSP Residual norm 1.172594571495e-01
    1 KSP Residual norm 1.734038988634e-14
314 KSP preconditioned resid norm 3.480212917648e-03 true resid norm 2.333509621663e+11 ||r(i)||/||b|| 1.328878940193e+09
    0 KSP Residual norm 1.030133709721e-01
    1 KSP Residual norm 5.340025165053e-15
315 KSP preconditioned resid norm 3.353610727554e-03 true resid norm 2.081539379027e+11 ||r(i)||/||b|| 1.185387803116e+09
    0 KSP Residual norm 9.546183183988e-02
    1 KSP Residual norm 9.474779979399e-15
316 KSP preconditioned resid norm 3.194400816588e-03 true resid norm 1.800135422579e+11 ||r(i)||/||b|| 1.025134857107e+09
    0 KSP Residual norm 9.082679756430e-02
    1 KSP Residual norm 4.137707563338e-15
317 KSP preconditioned resid norm 3.071660466318e-03 true resid norm 1.608410018372e+11 ||r(i)||/||b|| 9.159517410037e+08
    0 KSP Residual norm 6.986802333543e-02
    1 KSP Residual norm 5.891987058382e-15
318 KSP preconditioned resid norm 2.839836959694e-03 true resid norm 1.286425107952e+11 ||r(i)||/||b|| 7.325888945235e+08
    0 KSP Residual norm 8.065370739430e-02
    1 KSP Residual norm 8.586015622114e-15
319 KSP preconditioned resid norm 2.631447805934e-03 true resid norm 1.035751986247e+11 ||r(i)||/||b|| 5.898364373600e+08
    0 KSP Residual norm 6.709365439290e-02
    1 KSP Residual norm 4.626622373775e-15
320 KSP preconditioned resid norm 2.421698672480e-03 true resid norm 8.242093003462e+10 ||r(i)||/||b|| 4.693678446293e+08
    0 KSP Residual norm 5.533068594810e-02
    1 KSP Residual norm 6.352988984759e-15
321 KSP preconditioned resid norm 2.249646162938e-03 true resid norm 6.795739661676e+10 ||r(i)||/||b|| 3.870014177616e+08
    0 KSP Residual norm 4.580381531151e-02
    1 KSP Residual norm 5.767752580444e-15
322 KSP preconditioned resid norm 2.051650980233e-03 true resid norm 5.361859971127e+10 ||r(i)||/||b|| 3.053453360445e+08
    0 KSP Residual norm 3.957321613322e-02
    1 KSP Residual norm 4.444123762553e-15
323 KSP preconditioned resid norm 1.852638069944e-03 true resid norm 4.140385628580e+10 ||r(i)||/||b|| 2.357852401816e+08
    0 KSP Residual norm 5.032160513475e-02
    1 KSP Residual norm 1.437828688493e-14
324 KSP preconditioned resid norm 1.586960792034e-03 true resid norm 2.821637588504e+10 ||r(i)||/||b|| 1.606856356371e+08
    0 KSP Residual norm 3.112779650514e-02
    1 KSP Residual norm 5.727563482493e-15
325 KSP preconditioned resid norm 1.397072877149e-03 true resid norm 2.041761460730e+10 ||r(i)||/||b|| 1.162735212606e+08
    0 KSP Residual norm 2.763371056357e-02
    1 KSP Residual norm 5.639127741743e-15
326 KSP preconditioned resid norm 1.221051611758e-03 true resid norm 1.446657118383e+10 ||r(i)||/||b|| 8.238372623165e+07
    0 KSP Residual norm 2.087280082280e-02
    1 KSP Residual norm 1.532244282116e-15
327 KSP preconditioned resid norm 1.033482057986e-03 true resid norm 9.360214184176e+09 ||r(i)||/||b|| 5.330422205925e+07
    0 KSP Residual norm 2.412350779009e-02
    1 KSP Residual norm 6.040755977793e-15
328 KSP preconditioned resid norm 9.116882133916e-04 true resid norm 6.661870351799e+09 ||r(i)||/||b|| 3.793778748809e+07
    0 KSP Residual norm 4.694453546376e-02
    1 KSP Residual norm 6.632693106872e-15
329 KSP preconditioned resid norm 8.282548180128e-04 true resid norm 5.144717363016e+09 ||r(i)||/||b|| 2.929795743498e+07
    0 KSP Residual norm 4.284103666232e-02
    1 KSP Residual norm 9.000495611341e-15
    0 KSP Residual norm 3.857159406248e-05
    1 KSP Residual norm 1.807976737916e-18
330 KSP preconditioned resid norm 7.530630893338e-04 true resid norm 4.075399789633e+09 ||r(i)||/||b|| 2.320844492363e+07
    0 KSP Residual norm 5.117414233737e-02
    1 KSP Residual norm 2.753811269095e-15
331 KSP preconditioned resid norm 7.378843605824e-04 true resid norm 4.106334585676e+09 ||r(i)||/||b|| 2.338461132380e+07
    0 KSP Residual norm 1.058784968427e-01
    1 KSP Residual norm 2.806454406138e-14
332 KSP preconditioned resid norm 7.208109673083e-04 true resid norm 4.143108086041e+09 ||r(i)||/||b|| 2.359402777419e+07
    0 KSP Residual norm 2.042506304248e-01
    1 KSP Residual norm 3.102912293216e-14
333 KSP preconditioned resid norm 7.065440015463e-04 true resid norm 4.177434934991e+09 ||r(i)||/||b|| 2.378951111923e+07
    0 KSP Residual norm 1.422215659160e-01
    1 KSP Residual norm 2.501684006696e-14
334 KSP preconditioned resid norm 6.922130798635e-04 true resid norm 4.218518046304e+09 ||r(i)||/||b|| 2.402346979210e+07
    0 KSP Residual norm 9.637430765000e-02
    1 KSP Residual norm 2.696302183947e-14
335 KSP preconditioned resid norm 6.743986454519e-04 true resid norm 4.282620435472e+09 ||r(i)||/||b|| 2.438851784758e+07
    0 KSP Residual norm 9.564667165661e-02
    1 KSP Residual norm 2.321690857301e-14
336 KSP preconditioned resid norm 6.468451089725e-04 true resid norm 4.403779004208e+09 ||r(i)||/||b|| 2.507848744926e+07
    0 KSP Residual norm 1.229076988553e-01
    1 KSP Residual norm 3.248769277105e-14
337 KSP preconditioned resid norm 6.112383860139e-04 true resid norm 4.572889268801e+09 ||r(i)||/||b|| 2.604153070008e+07
    0 KSP Residual norm 8.020334312596e-02
    1 KSP Residual norm 2.060848308948e-14
338 KSP preconditioned resid norm 5.788902799897e-04 true resid norm 4.751423567671e+09 ||r(i)||/||b|| 2.705824161341e+07
    0 KSP Residual norm 5.292620453901e-02
    1 KSP Residual norm 1.569420098068e-14
339 KSP preconditioned resid norm 5.410935892311e-04 true resid norm 4.973526607240e+09 ||r(i)||/||b|| 2.832306627535e+07
    0 KSP Residual norm 6.732626069050e-02
    1 KSP Residual norm 1.904390383312e-14
340 KSP preconditioned resid norm 5.009948786042e-04 true resid norm 5.234837867811e+09 ||r(i)||/||b|| 2.981117255006e+07
    0 KSP Residual norm 6.824656168048e-02
    1 KSP Residual norm 1.465230609570e-14
341 KSP preconditioned resid norm 4.659625875994e-04 true resid norm 5.473363530127e+09 ||r(i)||/||b|| 3.116952019262e+07
    0 KSP Residual norm 6.680257126080e-02
    1 KSP Residual norm 1.499795900289e-14
342 KSP preconditioned resid norm 4.188737491331e-04 true resid norm 5.804840588010e+09 ||r(i)||/||b|| 3.305720420853e+07
    0 KSP Residual norm 7.663881661976e-02
    1 KSP Residual norm 1.348626999566e-14
343 KSP preconditioned resid norm 3.888174107377e-04 true resid norm 6.055882640284e+09 ||r(i)||/||b|| 3.448682975313e+07
    0 KSP Residual norm 7.550588930007e-02
    1 KSP Residual norm 5.810506118595e-15
344 KSP preconditioned resid norm 3.757521942558e-04 true resid norm 6.184885124251e+09 ||r(i)||/||b|| 3.522146861034e+07
    0 KSP Residual norm 9.699014290239e-02
    1 KSP Residual norm 1.512483488204e-14
345 KSP preconditioned resid norm 3.517425591232e-04 true resid norm 6.438959263708e+09 ||r(i)||/||b|| 3.666836117954e+07
    0 KSP Residual norm 9.581820536421e-02
    1 KSP Residual norm 1.297802479441e-14
346 KSP preconditioned resid norm 3.188163998220e-04 true resid norm 6.808945943561e+09 ||r(i)||/||b|| 3.877534845075e+07
    0 KSP Residual norm 1.112282608412e-01
    1 KSP Residual norm 8.934160118744e-15
347 KSP preconditioned resid norm 2.976271547968e-04 true resid norm 7.089267610639e+09 ||r(i)||/||b|| 4.037171452698e+07
    0 KSP Residual norm 1.097268867979e-01
    1 KSP Residual norm 1.346905677201e-14
348 KSP preconditioned resid norm 2.760598176598e-04 true resid norm 7.404379197336e+09 ||r(i)||/||b|| 4.216620102700e+07
    0 KSP Residual norm 1.275714537379e-01
    1 KSP Residual norm 1.393995566652e-14
349 KSP preconditioned resid norm 2.491152197103e-04 true resid norm 7.856285580077e+09 ||r(i)||/||b|| 4.473970177192e+07
    0 KSP Residual norm 1.636809622968e-01
    1 KSP Residual norm 6.528601051804e-15
350 KSP preconditioned resid norm 2.261875421951e-04 true resid norm 8.300044966044e+09 ||r(i)||/||b|| 4.726680728308e+07
    0 KSP Residual norm 1.844767798499e-01
    1 KSP Residual norm 9.965383200474e-15
351 KSP preconditioned resid norm 2.108222499389e-04 true resid norm 8.660693905734e+09 ||r(i)||/||b|| 4.932061831651e+07
    0 KSP Residual norm 1.804402847968e-01
    1 KSP Residual norm 1.044990721389e-14
352 KSP preconditioned resid norm 1.952757682812e-04 true resid norm 9.171398383610e+09 ||r(i)||/||b|| 5.222896040780e+07
    0 KSP Residual norm 2.243993926974e-01
    1 KSP Residual norm 1.060036179430e-14
353 KSP preconditioned resid norm 1.857516307760e-04 true resid norm 9.612319190889e+09 ||r(i)||/||b|| 5.473990087981e+07
    0 KSP Residual norm 2.169232562665e-01
    1 KSP Residual norm 7.847038296565e-15
354 KSP preconditioned resid norm 1.755630407243e-04 true resid norm 1.022795215943e+10 ||r(i)||/||b|| 5.824578608891e+07
    0 KSP Residual norm 2.706403088480e-01
    1 KSP Residual norm 1.385640888601e-14
355 KSP preconditioned resid norm 1.629837424048e-04 true resid norm 1.128528581762e+10 ||r(i)||/||b|| 6.426705301698e+07
    0 KSP Residual norm 3.864462189446e-01
    1 KSP Residual norm 1.750159592573e-14
356 KSP preconditioned resid norm 1.523697398411e-04 true resid norm 1.237194867639e+10 ||r(i)||/||b|| 7.045534285603e+07
    0 KSP Residual norm 4.396910599064e-01
    1 KSP Residual norm 1.558489229106e-14
357 KSP preconditioned resid norm 1.479102506497e-04 true resid norm 1.303733768943e+10 ||r(i)||/||b|| 7.424457705610e+07
    0 KSP Residual norm 3.704655085365e-01
    1 KSP Residual norm 2.552079543082e-14
358 KSP preconditioned resid norm 1.460096349773e-04 true resid norm 1.352450072155e+10 ||r(i)||/||b|| 7.701885614123e+07
    0 KSP Residual norm 3.330524337806e-01
    1 KSP Residual norm 1.249387256428e-14
359 KSP preconditioned resid norm 1.458849827096e-04 true resid norm 1.366141869934e+10 ||r(i)||/||b|| 7.779857187726e+07
    0 KSP Residual norm 2.506916160917e-01
    1 KSP Residual norm 1.241916700050e-14
    0 KSP Residual norm 1.271223582046e-04
    1 KSP Residual norm 6.097927485411e-18
360 KSP preconditioned resid norm 1.455026626572e-04 true resid norm 1.345524299294e+10 ||r(i)||/||b|| 7.662444963809e+07
    0 KSP Residual norm 8.737717097093e-01
    1 KSP Residual norm 3.950702964754e-14
361 KSP preconditioned resid norm 1.453653589202e-04 true resid norm 1.349948577101e+10 ||r(i)||/||b|| 7.687640187127e+07
    0 KSP Residual norm 1.329927151475e-01
    1 KSP Residual norm 1.442345915700e-14
362 KSP preconditioned resid norm 1.452932335715e-04 true resid norm 1.352941874316e+10 ||r(i)||/||b|| 7.704686311958e+07
    0 KSP Residual norm 1.848191576197e-01
    1 KSP Residual norm 2.318196826569e-14
363 KSP preconditioned resid norm 1.452077085053e-04 true resid norm 1.358040481119e+10 ||r(i)||/||b|| 7.733721680577e+07
    0 KSP Residual norm 1.838397768184e-01
    1 KSP Residual norm 3.018720109462e-14
364 KSP preconditioned resid norm 1.452068424347e-04 true resid norm 1.358658974421e+10 ||r(i)||/||b|| 7.737243854715e+07
    0 KSP Residual norm 1.893211055741e-01
    1 KSP Residual norm 2.205052232884e-14
365 KSP preconditioned resid norm 1.451988195240e-04 true resid norm 1.356415073143e+10 ||r(i)||/||b|| 7.724465363790e+07
    0 KSP Residual norm 1.985197960881e-01
    1 KSP Residual norm 3.139653106468e-14
366 KSP preconditioned resid norm 1.450322012808e-04 true resid norm 1.341939854662e+10 ||r(i)||/||b|| 7.642032393234e+07
    0 KSP Residual norm 1.767284477804e-01
    1 KSP Residual norm 2.500766293079e-14
367 KSP preconditioned resid norm 1.448660392702e-04 true resid norm 1.330873409029e+10 ||r(i)||/||b|| 7.579011583687e+07
    0 KSP Residual norm 1.340344154347e-01
    1 KSP Residual norm 3.224068360290e-14
368 KSP preconditioned resid norm 1.440561644899e-04 true resid norm 1.296085311722e+10 ||r(i)||/||b|| 7.380901537549e+07
    0 KSP Residual norm 1.431596358775e-01
    1 KSP Residual norm 1.982158693092e-14
369 KSP preconditioned resid norm 1.424259451750e-04 true resid norm 1.234613349126e+10 ||r(i)||/||b|| 7.030833143798e+07
    0 KSP Residual norm 1.579827213754e-01
    1 KSP Residual norm 2.479550477092e-14
370 KSP preconditioned resid norm 1.405134706181e-04 true resid norm 1.171425599420e+10 ||r(i)||/||b|| 6.670993745307e+07
    0 KSP Residual norm 1.368445142149e-01
    1 KSP Residual norm 9.282781706174e-15
371 KSP preconditioned resid norm 1.384045644474e-04 true resid norm 1.108995050694e+10 ||r(i)||/||b|| 6.315466428613e+07
    0 KSP Residual norm 1.249655070777e-01
    1 KSP Residual norm 1.216181515764e-14
372 KSP preconditioned resid norm 1.349464774298e-04 true resid norm 1.017989050712e+10 ||r(i)||/||b|| 5.797208626355e+07
    0 KSP Residual norm 1.225625228406e-01
    1 KSP Residual norm 1.648618859724e-14
373 KSP preconditioned resid norm 1.299650235031e-04 true resid norm 9.022746031412e+09 ||r(i)||/||b|| 5.138242016467e+07
    0 KSP Residual norm 1.228291793551e-01
    1 KSP Residual norm 1.862062891308e-14
374 KSP preconditioned resid norm 1.244499402556e-04 true resid norm 7.872007787314e+09 ||r(i)||/||b|| 4.482923605066e+07
    0 KSP Residual norm 1.134427886212e-01
    1 KSP Residual norm 1.107258931901e-14
375 KSP preconditioned resid norm 1.196895128318e-04 true resid norm 6.960466866168e+09 ||r(i)||/||b|| 3.963822452883e+07
    0 KSP Residual norm 9.950649015460e-02
    1 KSP Residual norm 9.566681063980e-15
376 KSP preconditioned resid norm 1.150083249018e-04 true resid norm 6.147642417833e+09 ||r(i)||/||b|| 3.500938014165e+07
    0 KSP Residual norm 8.775509097828e-02
    1 KSP Residual norm 3.520658949477e-15
377 KSP preconditioned resid norm 1.078871827785e-04 true resid norm 5.102194105304e+09 ||r(i)||/||b|| 2.905579746650e+07
    0 KSP Residual norm 8.068583860496e-02
    1 KSP Residual norm 5.813080004255e-15
378 KSP preconditioned resid norm 1.020385331017e-04 true resid norm 4.355003319652e+09 ||r(i)||/||b|| 2.480072137793e+07
    0 KSP Residual norm 6.338182300117e-02
    1 KSP Residual norm 7.875764136671e-15
379 KSP preconditioned resid norm 9.619002775224e-05 true resid norm 3.697867140899e+09 ||r(i)||/||b|| 2.105848513139e+07
    0 KSP Residual norm 5.881890909876e-02
    1 KSP Residual norm 4.836863157033e-15
380 KSP preconditioned resid norm 9.035467035326e-05 true resid norm 3.118903114672e+09 ||r(i)||/||b|| 1.776142093915e+07
KSP Object: 4 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 1, factorization LOWER
    Preconditioner for the Schur complement formed from S itself
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       4 MPI processes
        type: cg
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      PC Object:      (fieldsplit_0_)       4 MPI processes
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 0, needed 0
            Factored matrix follows:
              Mat Object:               4 MPI processes
                type: mpiaij
                rows=71946, cols=71946
                package used to perform factorization: mumps
                total: nonzeros=6.47715e+07, allocated nonzeros=6.47715e+07
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   0
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):                         1
                    ICNTL(13) (efficiency control):                         0
                    ICNTL(14) (percentage of estimated workspace increase): 20
                    ICNTL(18) (input mat struct):                           3
                    ICNTL(19) (Shur complement info):                       0
                    ICNTL(20) (rhs sparse pattern):                         0
                    ICNTL(21) (somumpstion struct):                            1
                    ICNTL(22) (in-core/out-of-core facility):               0
                    ICNTL(23) (max size of memory can be allocated locally):0
                    ICNTL(24) (detection of null pivot rows):               0
                    ICNTL(25) (computation of a null space basis):          0
                    ICNTL(26) (Schur options for rhs or solution):          0
                    ICNTL(27) (experimental parameter):                     -8
                    ICNTL(28) (use parallel or sequential ordering):        1
                    ICNTL(29) (parallel ordering):                          0
                    ICNTL(30) (user-specified set of entries in inv(A)):    0
                    ICNTL(31) (factors is discarded in the solve phase):    0
                    ICNTL(33) (compute determinant):                        0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absomumpste pivoting threshold):      0
                    CNTL(4) (vamumpse of static pivoting):         -1
                    CNTL(5) (fixation for null pivots):         0
                    RINFO(1) (local estimated flops for the elimination after analysis):
                      [0] 1.6957e+10
                      [1] 1.67964e+10
                      [2] 1.70959e+10
                      [3] 1.7073e+10
                    RINFO(2) (local estimated flops for the assembly after factorization):
                      [0]  3.99956e+07
                      [1]  3.71513e+07
                      [2]  4.43658e+07
                      [3]  2.95262e+07
                    RINFO(3) (local estimated flops for the elimination after factorization):
                      [0]  1.732e+10
                      [1]  1.7234e+10
                      [2]  1.70959e+10
                      [3]  1.62723e+10
                    INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                    [0] 243
                    [1] 237
                    [2] 256
                    [3] 212
                    INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                      [0] 243
                      [1] 237
                      [2] 256
                      [3] 212
                    INFO(23) (num of pivots eliminated on this processor after factorization):
                      [0] 23748
                      [1] 15630
                      [2] 20355
                      [3] 12213
                    RINFOG(1) (global estimated flops for the elimination after analysis): 6.79222e+10
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1.51039e+08
                    RINFOG(3) (global estimated flops for the elimination after factorization): 6.79222e+10
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0,0)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 64771542
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 1209207
                    INFOG(5) (estimated maximum front size in the complete tree): 2562
                    INFOG(6) (number of nodes in the complete tree): 3832
                    INFOG(7) (ordering option effectively use after analysis): 5
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 64771542
                    INFOG(10) (total integer space store the matrix factors after factorization): 1208659
                    INFOG(11) (order of largest frontal matrix after factorization): 2562
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 256
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 948
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 256
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 948
                    INFOG(20) (estimated number of entries in the factors): 64771542
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 212
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 789
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 58207698
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 229, 844
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): 7
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         4 MPI processes
          type: mpiaij
          total: nonzeros=2.96023e+06, allocated nonzeros=2.96023e+06
            using I-node (on process 0) routines: found 6259 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       4 MPI processes
        type: preonly
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_1_)       4 MPI processes
        type: lsc
          KSP Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: preonly
          PC Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: bjacobi
              block Jacobi: number of blocks = 4
              Local solve is same for all blocks, in the following KSP and PC objects:
            KSP Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: preonly
            PC Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: ilu
                ILU: out-of-place factorization
                0 levels of fill
                using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                factor fill ratio given 1, needed 1
                    Mat Object:                     1 MPI processes
                      type: seqaij
                      rows=0, cols=0
                      package used to perform factorization: petsc
                      total: nonzeros=0, allocated nonzeros=0
                        not using I-node routines
                type: seqaij
                rows=0, cols=0
              type: mpiaij
              rows=3183, cols=3183
              total: nonzeros=9549, allocated nonzeros=9549
                not using I-node (on process 0) routines
        Mat Object:        (fieldsplit_1_)         4 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
                total: nonzeros=3183, allocated nonzeros=3183
            A10
                type: mpiaij
                rows=3183, cols=71946
                total: nonzeros=19098, allocated nonzeros=19098
            KSP of A00
                type: cg
                type: lu
                        type: mpiaij
                              [0] 1.6957e+10
                              [1] 1.67964e+10
                              [2] 1.70959e+10
                              [3] 1.7073e+10
                              [0]  3.99956e+07
                              [1]  3.71513e+07
                              [2]  4.43658e+07
                              [3]  2.95262e+07
                              [0]  1.732e+10
                              [1]  1.7234e+10
                              [2]  1.70959e+10
                              [3]  1.62723e+10
                            [0] 243
                            [1] 237
                            [2] 256
                            [3] 212
                              [0] 243
                              [1] 237
                              [2] 256
                              [3] 212
                              [0] 23748
                              [1] 15630
                              [2] 20355
                              [3] 12213
                  type: mpiaij
            A01
                type: mpiaij
                rows=71946, cols=3183
                  using I-node (on process 0) routines: found 3757 nodes, limit used is 5
    type: mpiaij
    rows=75129, cols=75129
    total: nonzeros=3.0016e+06, allocated nonzeros=1.26217e+07
 Recovering stress ...
 Cleaning up ...
 Finished
0.01user 0.03system 0:40.70elapsed 0%CPU (0avgtext+0avgdata 17056maxresident)k
904inputs+0outputs (3major+1802minor)pagefaults 0swaps
salloc: Relinquishing job allocation 79009
salloc: Granted job allocation 79008
 Reading input ...
 Partitioning mesh ...
 Reading mesh data ...
 Forming [K] ...
 Applying constraints ...
 Forming RHS ...
 Setting up solver ...
 Solving ...
  0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.598278213552e+05 true resid norm 6.423512943905e+15 ||r(i)||/||b|| 3.658039801496e+13
  2 KSP preconditioned resid norm 4.421363398396e+05 true resid norm 1.938122873265e+16 ||r(i)||/||b|| 1.103715470414e+14
  3 KSP preconditioned resid norm 3.187714266989e+05 true resid norm 2.595569488051e+16 ||r(i)||/||b|| 1.478115881100e+14
  4 KSP preconditioned resid norm 2.009250685731e+05 true resid norm 4.269068986797e+16 ||r(i)||/||b|| 2.431134552917e+14
  5 KSP preconditioned resid norm 1.299557266250e+05 true resid norm 5.664566692593e+16 ||r(i)||/||b|| 3.225837730956e+14
  6 KSP preconditioned resid norm 1.070108696541e+05 true resid norm 6.757083396954e+16 ||r(i)||/||b|| 3.848000342482e+14
  7 KSP preconditioned resid norm 9.205344823934e+04 true resid norm 8.073944995171e+16 ||r(i)||/||b|| 4.597922103582e+14
  8 KSP preconditioned resid norm 8.698599347251e+04 true resid norm 9.596166057921e+16 ||r(i)||/||b|| 5.464791258021e+14
  9 KSP preconditioned resid norm 8.674528784539e+04 true resid norm 1.014395579435e+17 ||r(i)||/||b|| 5.776744651155e+14
 10 KSP preconditioned resid norm 7.633154167998e+04 true resid norm 5.663942256556e+16 ||r(i)||/||b|| 3.225482129294e+14
 11 KSP preconditioned resid norm 5.726963014918e+04 true resid norm 3.255239259030e+16 ||r(i)||/||b|| 1.853782327040e+14
 12 KSP preconditioned resid norm 3.933249871854e+04 true resid norm 5.893837891722e+16 ||r(i)||/||b|| 3.356402295716e+14
 13 KSP preconditioned resid norm 2.986641999324e+04 true resid norm 7.405028344525e+16 ||r(i)||/||b|| 4.216989776782e+14
 14 KSP preconditioned resid norm 2.633745666937e+04 true resid norm 8.472086806682e+16 ||r(i)||/||b|| 4.824654517117e+14
 15 KSP preconditioned resid norm 2.608339084208e+04 true resid norm 8.969329343812e+16 ||r(i)||/||b|| 5.107822467070e+14
 16 KSP preconditioned resid norm 2.488827926174e+04 true resid norm 7.386717952238e+16 ||r(i)||/||b|| 4.206562438291e+14
 17 KSP preconditioned resid norm 2.127496521837e+04 true resid norm 3.884168517181e+16 ||r(i)||/||b|| 2.211942772692e+14
 18 KSP preconditioned resid norm 1.563809118446e+04 true resid norm 2.054810743673e+16 ||r(i)||/||b|| 1.170166472853e+14
 19 KSP preconditioned resid norm 1.136562830178e+04 true resid norm 4.048500849886e+16 ||r(i)||/||b|| 2.305526177747e+14
 20 KSP preconditioned resid norm 9.662175529016e+03 true resid norm 5.237903358199e+16 ||r(i)||/||b|| 2.982862979806e+14
 21 KSP preconditioned resid norm 9.530658333081e+03 true resid norm 5.684529709698e+16 ||r(i)||/||b|| 3.237206200478e+14
 22 KSP preconditioned resid norm 9.299377613844e+03 true resid norm 4.717621951212e+16 ||r(i)||/||b|| 2.686574934409e+14
 23 KSP preconditioned resid norm 7.559054781177e+03 true resid norm 1.967879836939e+16 ||r(i)||/||b|| 1.120661362551e+14
 24 KSP preconditioned resid norm 5.773171779442e+03 true resid norm 1.503038207188e+16 ||r(i)||/||b|| 8.559449685985e+13
 25 KSP preconditioned resid norm 4.675136883937e+03 true resid norm 3.083933334216e+16 ||r(i)||/||b|| 1.756227625014e+14
 26 KSP preconditioned resid norm 4.619378203964e+03 true resid norm 3.484189753965e+16 ||r(i)||/||b|| 1.984164258291e+14
 27 KSP preconditioned resid norm 4.393843972597e+03 true resid norm 2.542715244756e+16 ||r(i)||/||b|| 1.448016630528e+14
 28 KSP preconditioned resid norm 3.659887718417e+03 true resid norm 6.968079702291e+15 ||r(i)||/||b|| 3.968157784311e+13
 29 KSP preconditioned resid norm 2.468848759677e+03 true resid norm 1.079956395636e+16 ||r(i)||/||b|| 6.150098106151e+13
 30 KSP preconditioned resid norm 1.864796910441e+03 true resid norm 1.493669666429e+16 ||r(i)||/||b|| 8.506098046037e+13
 31 KSP preconditioned resid norm 1.851274436483e+03 true resid norm 1.517346418548e+16 ||r(i)||/||b|| 8.640931590201e+13
 32 KSP preconditioned resid norm 1.844524113469e+03 true resid norm 1.551800988833e+16 ||r(i)||/||b|| 8.837142278256e+13
 33 KSP preconditioned resid norm 1.843313509513e+03 true resid norm 1.522935935101e+16 ||r(i)||/||b|| 8.672762574585e+13
 34 KSP preconditioned resid norm 1.818448641203e+03 true resid norm 1.340161908290e+16 ||r(i)||/||b|| 7.631907406096e+13
 35 KSP preconditioned resid norm 1.761501351737e+03 true resid norm 9.701610689032e+15 ||r(i)||/||b|| 5.524839499665e+13
 36 KSP preconditioned resid norm 1.587903182351e+03 true resid norm 3.006466867338e+15 ||r(i)||/||b|| 1.712112290991e+13
 37 KSP preconditioned resid norm 1.424674192381e+03 true resid norm 3.330040454395e+15 ||r(i)||/||b|| 1.896379851515e+13
 38 KSP preconditioned resid norm 1.223589331013e+03 true resid norm 7.090044535635e+15 ||r(i)||/||b|| 4.037613893242e+13
 39 KSP preconditioned resid norm 1.217042925271e+03 true resid norm 7.803451047400e+15 ||r(i)||/||b|| 4.443882151354e+13
 40 KSP preconditioned resid norm 1.210937465891e+03 true resid norm 6.896760418758e+15 ||r(i)||/||b|| 3.927543126871e+13
 41 KSP preconditioned resid norm 1.139515965864e+03 true resid norm 4.397710228518e+15 ||r(i)||/||b|| 2.504392719661e+13
 42 KSP preconditioned resid norm 9.844313363552e+02 true resid norm 2.063347155848e+15 ||r(i)||/||b|| 1.175027759158e+13
 43 KSP preconditioned resid norm 8.134473256619e+02 true resid norm 3.162170274309e+15 ||r(i)||/||b|| 1.800781725443e+13
 44 KSP preconditioned resid norm 7.167053701822e+02 true resid norm 6.294910273859e+15 ||r(i)||/||b|| 3.584803600415e+13
 45 KSP preconditioned resid norm 6.962717083756e+02 true resid norm 6.711029585626e+15 ||r(i)||/||b|| 3.821773778245e+13
 46 KSP preconditioned resid norm 6.927406658772e+02 true resid norm 6.102891293465e+15 ||r(i)||/||b|| 3.475453299566e+13
 47 KSP preconditioned resid norm 6.104613558502e+02 true resid norm 1.348418985388e+15 ||r(i)||/||b|| 7.678929521455e+12
 48 KSP preconditioned resid norm 4.947332360362e+02 true resid norm 3.525127520461e+15 ||r(i)||/||b|| 2.007477355118e+13
 49 KSP preconditioned resid norm 4.128569311177e+02 true resid norm 7.381606168160e+15 ||r(i)||/||b|| 4.203651397281e+13
 50 KSP preconditioned resid norm 4.128555858135e+02 true resid norm 7.386790205685e+15 ||r(i)||/||b|| 4.206603584933e+13
 51 KSP preconditioned resid norm 3.995142906102e+02 true resid norm 5.174163353743e+15 ||r(i)||/||b|| 2.946564543844e+13
 52 KSP preconditioned resid norm 3.398724348924e+02 true resid norm 1.795681743007e+15 ||r(i)||/||b|| 1.022598591161e+13
 53 KSP preconditioned resid norm 2.582635865429e+02 true resid norm 1.065592994159e+15 ||r(i)||/||b|| 6.068301907178e+12
 54 KSP preconditioned resid norm 1.942336466476e+02 true resid norm 2.315650760727e+15 ||r(i)||/||b|| 1.318708738205e+13
 55 KSP preconditioned resid norm 1.780428610647e+02 true resid norm 2.677037580411e+15 ||r(i)||/||b|| 1.524510046879e+13
 56 KSP preconditioned resid norm 1.700699391492e+02 true resid norm 3.421212998216e+15 ||r(i)||/||b|| 1.948300474547e+13
 57 KSP preconditioned resid norm 1.696493267328e+02 true resid norm 3.269908568092e+15 ||r(i)||/||b|| 1.862136154124e+13
 58 KSP preconditioned resid norm 1.506929748059e+02 true resid norm 1.808390502696e+15 ||r(i)||/||b|| 1.029835931410e+13
 59 KSP preconditioned resid norm 1.240787458056e+02 true resid norm 6.663534486569e+14 ||r(i)||/||b|| 3.794726434487e+12
 60 KSP preconditioned resid norm 1.157829983215e+02 true resid norm 1.130780847653e+15 ||r(i)||/||b|| 6.439531427128e+12
 61 KSP preconditioned resid norm 1.157796703883e+02 true resid norm 1.131509662988e+15 ||r(i)||/||b|| 6.443681859341e+12
 62 KSP preconditioned resid norm 1.157785293613e+02 true resid norm 1.132964508976e+15 ||r(i)||/||b|| 6.451966865653e+12
 63 KSP preconditioned resid norm 1.157199903582e+02 true resid norm 1.115006939543e+15 ||r(i)||/||b|| 6.349702724058e+12
 64 KSP preconditioned resid norm 1.146344365975e+02 true resid norm 9.897225252928e+14 ||r(i)||/||b|| 5.636237400897e+12
 65 KSP preconditioned resid norm 1.099927272891e+02 true resid norm 6.314461681629e+14 ||r(i)||/||b|| 3.595937668085e+12
 66 KSP preconditioned resid norm 1.059910545350e+02 true resid norm 4.913476628990e+14 ||r(i)||/||b|| 2.798109574858e+12
 67 KSP preconditioned resid norm 1.029682260529e+02 true resid norm 5.270094367253e+14 ||r(i)||/||b|| 3.001195003638e+12
 68 KSP preconditioned resid norm 1.023121023363e+02 true resid norm 5.711176277756e+14 ||r(i)||/||b|| 3.252380795342e+12
 69 KSP preconditioned resid norm 1.022818674567e+02 true resid norm 5.528815353501e+14 ||r(i)||/||b|| 3.148530530699e+12
 70 KSP preconditioned resid norm 1.016711964340e+02 true resid norm 4.892143108744e+14 ||r(i)||/||b|| 2.785960635976e+12
 71 KSP preconditioned resid norm 9.783670449849e+01 true resid norm 8.075062190937e+14 ||r(i)||/||b|| 4.598558320339e+12
 72 KSP preconditioned resid norm 9.297125493721e+01 true resid norm 1.418932304648e+15 ||r(i)||/||b|| 8.080486318556e+12
 73 KSP preconditioned resid norm 9.024342817965e+01 true resid norm 1.822117383425e+15 ||r(i)||/||b|| 1.037653067686e+13
 74 KSP preconditioned resid norm 9.022915567731e+01 true resid norm 1.793734928753e+15 ||r(i)||/||b|| 1.021489926153e+13
 75 KSP preconditioned resid norm 8.654020807346e+01 true resid norm 1.378342523434e+15 ||r(i)||/||b|| 7.849337044771e+12
 76 KSP preconditioned resid norm 7.824470332642e+01 true resid norm 6.887264923035e+14 ||r(i)||/||b|| 3.922135665005e+12
 77 KSP preconditioned resid norm 6.933902305081e+01 true resid norm 4.001788567778e+14 ||r(i)||/||b|| 2.278924629862e+12
 78 KSP preconditioned resid norm 6.111029596781e+01 true resid norm 8.990216751018e+14 ||r(i)||/||b|| 5.119717355050e+12
 79 KSP preconditioned resid norm 6.052457451972e+01 true resid norm 1.038799252649e+15 ||r(i)||/||b|| 5.915717840284e+12
 80 KSP preconditioned resid norm 5.982916701975e+01 true resid norm 8.122329384891e+14 ||r(i)||/||b|| 4.625475877492e+12
 81 KSP preconditioned resid norm 5.472847286515e+01 true resid norm 3.261724168907e+14 ||r(i)||/||b|| 1.857475330953e+12
 82 KSP preconditioned resid norm 4.705564259934e+01 true resid norm 3.873293003694e+14 ||r(i)||/||b|| 2.205749423112e+12
 83 KSP preconditioned resid norm 3.875293844888e+01 true resid norm 9.915723130017e+14 ||r(i)||/||b|| 5.646771507580e+12
 84 KSP preconditioned resid norm 3.752007823180e+01 true resid norm 1.183842304947e+15 ||r(i)||/||b|| 6.741703967917e+12
 85 KSP preconditioned resid norm 3.751814586336e+01 true resid norm 1.191376622304e+15 ||r(i)||/||b|| 6.784610136259e+12
 86 KSP preconditioned resid norm 3.545906287093e+01 true resid norm 8.010012535302e+14 ||r(i)||/||b|| 4.561514068780e+12
 87 KSP preconditioned resid norm 3.016927381502e+01 true resid norm 2.096547884375e+14 ||r(i)||/||b|| 1.193934794521e+12
 88 KSP preconditioned resid norm 2.595797020041e+01 true resid norm 5.781551449568e+14 ||r(i)||/||b|| 3.292457803325e+12
 89 KSP preconditioned resid norm 2.431814395444e+01 true resid norm 8.373221520170e+14 ||r(i)||/||b|| 4.768353057743e+12
 90 KSP preconditioned resid norm 2.419007128340e+01 true resid norm 9.458145602756e+14 ||r(i)||/||b|| 5.386191849438e+12
 91 KSP preconditioned resid norm 2.418985479856e+01 true resid norm 9.456196991434e+14 ||r(i)||/||b|| 5.385082161043e+12
 92 KSP preconditioned resid norm 2.417422094832e+01 true resid norm 9.338606389867e+14 ||r(i)||/||b|| 5.318117074404e+12
 93 KSP preconditioned resid norm 2.399682638989e+01 true resid norm 8.239131879372e+14 ||r(i)||/||b|| 4.691992155650e+12
 94 KSP preconditioned resid norm 2.347990061529e+01 true resid norm 5.758811247477e+14 ||r(i)||/||b|| 3.279507792159e+12
 95 KSP preconditioned resid norm 2.317576427891e+01 true resid norm 4.648997976941e+14 ||r(i)||/||b|| 2.647495192309e+12
 96 KSP preconditioned resid norm 2.257226431826e+01 true resid norm 2.698576382857e+14 ||r(i)||/||b|| 1.536775889155e+12
 97 KSP preconditioned resid norm 2.214410432961e+01 true resid norm 2.012456758637e+14 ||r(i)||/||b|| 1.146046872820e+12
 98 KSP preconditioned resid norm 2.213931822377e+01 true resid norm 2.023089301094e+14 ||r(i)||/||b|| 1.152101856104e+12
 99 KSP preconditioned resid norm 2.208588382827e+01 true resid norm 2.030851676254e+14 ||r(i)||/||b|| 1.156522346502e+12
100 KSP preconditioned resid norm 2.202243648243e+01 true resid norm 2.215590489413e+14 ||r(i)||/||b|| 1.261726763045e+12
101 KSP preconditioned resid norm 2.168083689592e+01 true resid norm 2.512890878838e+14 ||r(i)||/||b|| 1.431032354396e+12
102 KSP preconditioned resid norm 2.168020292686e+01 true resid norm 2.479141826676e+14 ||r(i)||/||b|| 1.411813061596e+12
103 KSP preconditioned resid norm 2.157247007086e+01 true resid norm 2.214827950420e+14 ||r(i)||/||b|| 1.261292514992e+12
104 KSP preconditioned resid norm 2.084234283050e+01 true resid norm 1.903742949023e+14 ||r(i)||/||b|| 1.084136910777e+12
105 KSP preconditioned resid norm 1.953449641542e+01 true resid norm 2.170389187419e+14 ||r(i)||/||b|| 1.235985682857e+12
106 KSP preconditioned resid norm 1.807383475067e+01 true resid norm 4.030037324419e+14 ||r(i)||/||b|| 2.295011633506e+12
107 KSP preconditioned resid norm 1.608363181466e+01 true resid norm 6.615648433348e+14 ||r(i)||/||b|| 3.767456451513e+12
108 KSP preconditioned resid norm 1.540664146839e+01 true resid norm 8.161690838364e+14 ||r(i)||/||b|| 4.647891301062e+12
109 KSP preconditioned resid norm 1.539806765978e+01 true resid norm 8.031109823862e+14 ||r(i)||/||b|| 4.573528479264e+12
110 KSP preconditioned resid norm 1.500376511467e+01 true resid norm 6.721986290227e+14 ||r(i)||/||b|| 3.828013364259e+12
111 KSP preconditioned resid norm 1.422725209437e+01 true resid norm 3.479679053556e+14 ||r(i)||/||b|| 1.981595520317e+12
112 KSP preconditioned resid norm 1.379945740031e+01 true resid norm 2.034814218620e+14 ||r(i)||/||b|| 1.158778921342e+12
113 KSP preconditioned resid norm 1.363797458150e+01 true resid norm 1.739177470708e+14 ||r(i)||/||b|| 9.904207347713e+11
114 KSP preconditioned resid norm 1.358289054680e+01 true resid norm 1.810806633853e+14 ||r(i)||/||b|| 1.031211861374e+12
115 KSP preconditioned resid norm 1.281735475027e+01 true resid norm 3.060385425933e+14 ||r(i)||/||b|| 1.742817644137e+12
116 KSP preconditioned resid norm 1.199583599528e+01 true resid norm 5.270983461652e+14 ||r(i)||/||b|| 3.001701322023e+12
117 KSP preconditioned resid norm 1.174988815172e+01 true resid norm 5.706455305712e+14 ||r(i)||/||b|| 3.249692312609e+12
118 KSP preconditioned resid norm 1.163364583819e+01 true resid norm 5.557577297715e+14 ||r(i)||/||b|| 3.164909782617e+12
119 KSP preconditioned resid norm 1.150734102719e+01 true resid norm 4.444630681836e+14 ||r(i)||/||b|| 2.531112816163e+12
120 KSP preconditioned resid norm 1.089200826845e+01 true resid norm 1.939041645161e+14 ||r(i)||/||b|| 1.104238689437e+12
121 KSP preconditioned resid norm 1.075988028467e+01 true resid norm 1.998888904135e+14 ||r(i)||/||b|| 1.138320298246e+12
122 KSP preconditioned resid norm 1.064140507137e+01 true resid norm 2.105261696882e+14 ||r(i)||/||b|| 1.198897106149e+12
123 KSP preconditioned resid norm 1.052013508415e+01 true resid norm 2.341474414652e+14 ||r(i)||/||b|| 1.333414702793e+12
124 KSP preconditioned resid norm 1.051711998999e+01 true resid norm 2.302186000312e+14 ||r(i)||/||b|| 1.311040873293e+12
125 KSP preconditioned resid norm 1.043636031947e+01 true resid norm 2.126432353421e+14 ||r(i)||/||b|| 1.210953297974e+12
126 KSP preconditioned resid norm 1.034172555340e+01 true resid norm 1.912541379018e+14 ||r(i)||/||b|| 1.089147410078e+12
127 KSP preconditioned resid norm 1.018172019219e+01 true resid norm 1.659024395687e+14 ||r(i)||/||b|| 9.447754404906e+11
128 KSP preconditioned resid norm 9.985693057631e+00 true resid norm 1.356785077811e+14 ||r(i)||/||b|| 7.726572453501e+11
129 KSP preconditioned resid norm 9.979396625910e+00 true resid norm 1.307609335369e+14 ||r(i)||/||b|| 7.446528146452e+11
130 KSP preconditioned resid norm 9.931647767858e+00 true resid norm 1.472008427511e+14 ||r(i)||/||b|| 8.382742376323e+11
131 KSP preconditioned resid norm 9.849459584026e+00 true resid norm 1.801125916915e+14 ||r(i)||/||b|| 1.025698920375e+12
132 KSP preconditioned resid norm 9.688338620908e+00 true resid norm 2.431561636866e+14 ||r(i)||/||b|| 1.384717260652e+12
133 KSP preconditioned resid norm 9.653638081152e+00 true resid norm 2.681392129647e+14 ||r(i)||/||b|| 1.526989860427e+12
134 KSP preconditioned resid norm 9.625227378606e+00 true resid norm 2.556456989644e+14 ||r(i)||/||b|| 1.455842231595e+12
135 KSP preconditioned resid norm 9.510469551367e+00 true resid norm 2.356857223521e+14 ||r(i)||/||b|| 1.342174851265e+12
136 KSP preconditioned resid norm 9.311262628453e+00 true resid norm 1.813247990861e+14 ||r(i)||/||b|| 1.032602156869e+12
137 KSP preconditioned resid norm 8.496681822499e+00 true resid norm 1.110559696168e+14 ||r(i)||/||b|| 6.324376717218e+11
138 KSP preconditioned resid norm 7.616859591822e+00 true resid norm 2.432558891525e+14 ||r(i)||/||b|| 1.385285173765e+12
139 KSP preconditioned resid norm 7.369595364139e+00 true resid norm 3.141468295058e+14 ||r(i)||/||b|| 1.788992434329e+12
140 KSP preconditioned resid norm 7.357820656078e+00 true resid norm 3.377604377039e+14 ||r(i)||/||b|| 1.923466388690e+12
141 KSP preconditioned resid norm 7.266040336282e+00 true resid norm 2.854752590002e+14 ||r(i)||/||b|| 1.625714572204e+12
142 KSP preconditioned resid norm 6.816659148098e+00 true resid norm 1.249887885912e+14 ||r(i)||/||b|| 7.117818044425e+11
143 KSP preconditioned resid norm 6.378163918028e+00 true resid norm 8.055787212918e+13 ||r(i)||/||b|| 4.587581672922e+11
144 KSP preconditioned resid norm 6.261029449882e+00 true resid norm 9.977655883777e+13 ||r(i)||/||b|| 5.682040756704e+11
145 KSP preconditioned resid norm 6.214633120628e+00 true resid norm 1.318013178069e+14 ||r(i)||/||b|| 7.505775587870e+11
146 KSP preconditioned resid norm 6.207644628966e+00 true resid norm 1.193014418655e+14 ||r(i)||/||b|| 6.793937001933e+11
147 KSP preconditioned resid norm 5.891477122112e+00 true resid norm 7.112628078462e+13 ||r(i)||/||b|| 4.050474690635e+11
148 KSP preconditioned resid norm 5.541483303411e+00 true resid norm 1.650592277942e+14 ||r(i)||/||b|| 9.399735474158e+11
149 KSP preconditioned resid norm 5.492410219709e+00 true resid norm 2.258077005605e+14 ||r(i)||/||b|| 1.285921836459e+12
150 KSP preconditioned resid norm 5.458541392235e+00 true resid norm 1.900989296854e+14 ||r(i)||/||b|| 1.082568770521e+12
151 KSP preconditioned resid norm 5.458387299042e+00 true resid norm 1.902472823779e+14 ||r(i)||/||b|| 1.083413604273e+12
152 KSP preconditioned resid norm 5.457860124922e+00 true resid norm 1.913469274966e+14 ||r(i)||/||b|| 1.089675825034e+12
153 KSP preconditioned resid norm 5.457399009783e+00 true resid norm 1.891753206004e+14 ||r(i)||/||b|| 1.077309033640e+12
154 KSP preconditioned resid norm 5.437863987680e+00 true resid norm 1.653562940607e+14 ||r(i)||/||b|| 9.416652700543e+11
155 KSP preconditioned resid norm 5.416787761257e+00 true resid norm 1.461507401107e+14 ||r(i)||/||b|| 8.322941496525e+11
156 KSP preconditioned resid norm 5.398307109159e+00 true resid norm 1.306020506252e+14 ||r(i)||/||b|| 7.437480137675e+11
157 KSP preconditioned resid norm 5.382855191804e+00 true resid norm 1.164603795666e+14 ||r(i)||/||b|| 6.632145174648e+11
158 KSP preconditioned resid norm 5.380423128513e+00 true resid norm 1.099542663154e+14 ||r(i)||/||b|| 6.261637300937e+11
159 KSP preconditioned resid norm 5.374859084371e+00 true resid norm 1.230562839833e+14 ||r(i)||/||b|| 7.007766444409e+11
160 KSP preconditioned resid norm 5.343330818539e+00 true resid norm 1.617549407255e+14 ||r(i)||/||b|| 9.211564083851e+11
161 KSP preconditioned resid norm 5.313386300458e+00 true resid norm 1.949614968387e+14 ||r(i)||/||b|| 1.110259948759e+12
162 KSP preconditioned resid norm 5.305156807574e+00 true resid norm 2.167041713453e+14 ||r(i)||/||b|| 1.234079375030e+12
163 KSP preconditioned resid norm 5.302288854295e+00 true resid norm 2.071969491865e+14 ||r(i)||/||b|| 1.179937977072e+12
164 KSP preconditioned resid norm 5.269823647432e+00 true resid norm 2.047500468533e+14 ||r(i)||/||b|| 1.166003442802e+12
165 KSP preconditioned resid norm 5.167981346807e+00 true resid norm 1.347204187772e+14 ||r(i)||/||b|| 7.672011534261e+11
166 KSP preconditioned resid norm 4.943638894138e+00 true resid norm 1.104946705459e+14 ||r(i)||/||b|| 6.292412053026e+11
167 KSP preconditioned resid norm 4.585756505323e+00 true resid norm 6.368799627739e+13 ||r(i)||/||b|| 3.626881852574e+11
168 KSP preconditioned resid norm 4.220001997990e+00 true resid norm 1.634659962016e+14 ||r(i)||/||b|| 9.309004675769e+11
169 KSP preconditioned resid norm 4.206275934587e+00 true resid norm 1.707558711430e+14 ||r(i)||/||b|| 9.724145937511e+11
170 KSP preconditioned resid norm 4.187313597963e+00 true resid norm 1.607630116424e+14 ||r(i)||/||b|| 9.155076051558e+11
171 KSP preconditioned resid norm 4.079389132676e+00 true resid norm 8.609086263452e+13 ||r(i)||/||b|| 4.902672491086e+11
172 KSP preconditioned resid norm 4.000951705220e+00 true resid norm 4.832575423627e+13 ||r(i)||/||b|| 2.752038237913e+11
173 KSP preconditioned resid norm 3.968309939241e+00 true resid norm 4.867187563114e+13 ||r(i)||/||b|| 2.771749038680e+11
174 KSP preconditioned resid norm 3.965355241668e+00 true resid norm 4.914226983036e+13 ||r(i)||/||b|| 2.798536883869e+11
175 KSP preconditioned resid norm 3.925713966351e+00 true resid norm 5.051835159459e+13 ||r(i)||/||b|| 2.876901509389e+11
176 KSP preconditioned resid norm 3.871442062684e+00 true resid norm 1.134027479202e+14 ||r(i)||/||b|| 6.458020231509e+11
177 KSP preconditioned resid norm 3.670840390486e+00 true resid norm 1.451295211343e+14 ||r(i)||/||b|| 8.264785473579e+11
178 KSP preconditioned resid norm 3.627801487329e+00 true resid norm 1.548327670525e+14 ||r(i)||/||b|| 8.817362546007e+11
179 KSP preconditioned resid norm 3.625353909567e+00 true resid norm 1.448111660342e+14 ||r(i)||/||b|| 8.246655898108e+11
180 KSP preconditioned resid norm 3.489187683674e+00 true resid norm 6.526040773648e+13 ||r(i)||/||b|| 3.716426993245e+11
181 KSP preconditioned resid norm 3.477988311428e+00 true resid norm 6.605679306842e+13 ||r(i)||/||b|| 3.761779268037e+11
182 KSP preconditioned resid norm 3.450252485717e+00 true resid norm 6.902743913726e+13 ||r(i)||/||b|| 3.930950586766e+11
183 KSP preconditioned resid norm 3.432891398819e+00 true resid norm 7.443017997285e+13 ||r(i)||/||b|| 4.238623992056e+11
184 KSP preconditioned resid norm 3.429401963752e+00 true resid norm 7.193653821770e+13 ||r(i)||/||b|| 4.096616949015e+11
185 KSP preconditioned resid norm 3.402753697392e+00 true resid norm 6.619060775227e+13 ||r(i)||/||b|| 3.769399700093e+11
186 KSP preconditioned resid norm 3.365344754595e+00 true resid norm 5.787263460112e+13 ||r(i)||/||b|| 3.295710659215e+11
187 KSP preconditioned resid norm 3.333860758000e+00 true resid norm 5.286042303103e+13 ||r(i)||/||b|| 3.010276978657e+11
188 KSP preconditioned resid norm 3.280951184012e+00 true resid norm 4.487501136122e+13 ||r(i)||/||b|| 2.555526533307e+11
189 KSP preconditioned resid norm 3.274901345142e+00 true resid norm 4.216755107484e+13 ||r(i)||/||b|| 2.401343026945e+11
190 KSP preconditioned resid norm 3.269766489834e+00 true resid norm 4.566718330079e+13 ||r(i)||/||b|| 2.600638865295e+11
191 KSP preconditioned resid norm 3.224282149858e+00 true resid norm 6.014715696957e+13 ||r(i)||/||b|| 3.425239367662e+11
192 KSP preconditioned resid norm 3.190061156246e+00 true resid norm 7.489485410637e+13 ||r(i)||/||b|| 4.265086092934e+11
193 KSP preconditioned resid norm 3.174670622367e+00 true resid norm 8.375034387468e+13 ||r(i)||/||b|| 4.769385443105e+11
194 KSP preconditioned resid norm 3.174669599011e+00 true resid norm 8.368810612367e+13 ||r(i)||/||b|| 4.765841149315e+11
195 KSP preconditioned resid norm 3.161385505086e+00 true resid norm 7.567270930158e+13 ||r(i)||/||b|| 4.309383119946e+11
196 KSP preconditioned resid norm 3.096104483416e+00 true resid norm 5.310942114269e+13 ||r(i)||/||b|| 3.024456836484e+11
197 KSP preconditioned resid norm 2.890744457445e+00 true resid norm 3.994989614098e+13 ||r(i)||/||b|| 2.275052785377e+11
198 KSP preconditioned resid norm 2.467527000711e+00 true resid norm 1.522868258783e+14 ||r(i)||/||b|| 8.672377173844e+11
199 KSP preconditioned resid norm 2.383286040847e+00 true resid norm 1.874146376472e+14 ||r(i)||/||b|| 1.067282357618e+12
200 KSP preconditioned resid norm 2.377677655552e+00 true resid norm 2.016380246410e+14 ||r(i)||/||b|| 1.148281206986e+12
201 KSP preconditioned resid norm 2.338075769967e+00 true resid norm 1.712742596292e+14 ||r(i)||/||b|| 9.753666944655e+11
202 KSP preconditioned resid norm 2.263046833056e+00 true resid norm 1.100049031547e+14 ||r(i)||/||b|| 6.264520950039e+11
203 KSP preconditioned resid norm 2.087852652579e+00 true resid norm 2.994461865954e+13 ||r(i)||/||b|| 1.705275724573e+11
204 KSP preconditioned resid norm 2.007978318730e+00 true resid norm 3.902414615090e+13 ||r(i)||/||b|| 2.222333497044e+11
205 KSP preconditioned resid norm 2.007794121017e+00 true resid norm 3.997900843259e+13 ||r(i)||/||b|| 2.276710662030e+11
206 KSP preconditioned resid norm 1.990340363260e+00 true resid norm 2.955605641295e+13 ||r(i)||/||b|| 1.683148016949e+11
207 KSP preconditioned resid norm 1.933402028333e+00 true resid norm 3.966903044733e+13 ||r(i)||/||b|| 2.259058143578e+11
208 KSP preconditioned resid norm 1.832793003811e+00 true resid norm 9.682342679101e+13 ||r(i)||/||b|| 5.513866820410e+11
209 KSP preconditioned resid norm 1.813616245556e+00 true resid norm 1.223607688510e+14 ||r(i)||/||b|| 6.968158490648e+11
210 KSP preconditioned resid norm 1.773130779026e+00 true resid norm 1.066236841099e+14 ||r(i)||/||b|| 6.071968464333e+11
211 KSP preconditioned resid norm 1.772584830402e+00 true resid norm 1.069079970412e+14 ||r(i)||/||b|| 6.088159418220e+11
212 KSP preconditioned resid norm 1.770976105151e+00 true resid norm 1.087835209619e+14 ||r(i)||/||b|| 6.194966101890e+11
213 KSP preconditioned resid norm 1.770973048299e+00 true resid norm 1.089542042522e+14 ||r(i)||/||b|| 6.204686114521e+11
214 KSP preconditioned resid norm 1.758886456895e+00 true resid norm 8.479357845122e+13 ||r(i)||/||b|| 4.828795202789e+11
215 KSP preconditioned resid norm 1.742030866566e+00 true resid norm 5.582748508382e+13 ||r(i)||/||b|| 3.179244196087e+11
216 KSP preconditioned resid norm 1.718022070763e+00 true resid norm 2.704018886646e+13 ||r(i)||/||b|| 1.539875267276e+11
217 KSP preconditioned resid norm 1.696292837687e+00 true resid norm 1.749811486465e+13 ||r(i)||/||b|| 9.964765570648e+10
218 KSP preconditioned resid norm 1.690048480269e+00 true resid norm 2.513788931053e+13 ||r(i)||/||b|| 1.431543774046e+11
219 KSP preconditioned resid norm 1.686282962967e+00 true resid norm 1.945553472563e+13 ||r(i)||/||b|| 1.107947022248e+11
220 KSP preconditioned resid norm 1.655955991493e+00 true resid norm 3.243058909820e+13 ||r(i)||/||b|| 1.846845904152e+11
221 KSP preconditioned resid norm 1.612547703436e+00 true resid norm 6.996479117954e+13 ||r(i)||/||b|| 3.984330584730e+11
222 KSP preconditioned resid norm 1.592432434959e+00 true resid norm 8.751037594164e+13 ||r(i)||/||b|| 4.983510440998e+11
223 KSP preconditioned resid norm 1.592307656748e+00 true resid norm 8.560617673493e+13 ||r(i)||/||b|| 4.875070767116e+11
224 KSP preconditioned resid norm 1.566116384754e+00 true resid norm 8.332212832354e+13 ||r(i)||/||b|| 4.744999572891e+11
225 KSP preconditioned resid norm 1.511745201901e+00 true resid norm 5.089325612967e+13 ||r(i)||/||b|| 2.898251442409e+11
226 KSP preconditioned resid norm 1.445254159360e+00 true resid norm 3.385040442580e+13 ||r(i)||/||b|| 1.927701053421e+11
227 KSP preconditioned resid norm 1.360552734183e+00 true resid norm 1.476185891824e+13 ||r(i)||/||b|| 8.406532054739e+10
228 KSP preconditioned resid norm 1.246018368109e+00 true resid norm 2.657896590600e+13 ||r(i)||/||b|| 1.513609702600e+11
229 KSP preconditioned resid norm 1.234565282845e+00 true resid norm 3.292979573825e+13 ||r(i)||/||b|| 1.875274550197e+11
230 KSP preconditioned resid norm 1.234556093198e+00 true resid norm 3.303205109670e+13 ||r(i)||/||b|| 1.881097752771e+11
231 KSP preconditioned resid norm 1.223622511917e+00 true resid norm 2.208248107041e+13 ||r(i)||/||b|| 1.257545448678e+11
232 KSP preconditioned resid norm 1.210980434409e+00 true resid norm 1.542295263348e+13 ||r(i)||/||b|| 8.783009403508e+10
233 KSP preconditioned resid norm 1.182304375476e+00 true resid norm 1.477289800812e+13 ||r(i)||/||b|| 8.412818557237e+10
234 KSP preconditioned resid norm 1.181925536452e+00 true resid norm 1.421319533202e+13 ||r(i)||/||b|| 8.094081024669e+10
235 KSP preconditioned resid norm 1.181097014157e+00 true resid norm 1.340812930501e+13 ||r(i)||/||b|| 7.635614824732e+10
236 KSP preconditioned resid norm 1.139325286816e+00 true resid norm 1.259155720183e+13 ||r(i)||/||b|| 7.170596184572e+10
237 KSP preconditioned resid norm 1.054521342867e+00 true resid norm 4.023699395379e+13 ||r(i)||/||b|| 2.291402331728e+11
238 KSP preconditioned resid norm 9.221108351721e-01 true resid norm 2.190315343620e+13 ||r(i)||/||b|| 1.247333160960e+11
239 KSP preconditioned resid norm 8.694114847957e-01 true resid norm 2.406683225069e+13 ||r(i)||/||b|| 1.370549589263e+11
240 KSP preconditioned resid norm 8.572287007726e-01 true resid norm 3.648678138668e+13 ||r(i)||/||b|| 2.077836531295e+11
241 KSP preconditioned resid norm 8.569741281629e-01 true resid norm 3.634105281283e+13 ||r(i)||/||b|| 2.069537631177e+11
242 KSP preconditioned resid norm 8.546636466972e-01 true resid norm 3.506620503540e+13 ||r(i)||/||b|| 1.996938043514e+11
243 KSP preconditioned resid norm 8.436981690934e-01 true resid norm 2.951646328876e+13 ||r(i)||/||b|| 1.680893281489e+11
244 KSP preconditioned resid norm 8.173174100365e-01 true resid norm 1.824446706210e+13 ||r(i)||/||b|| 1.038979562321e+11
245 KSP preconditioned resid norm 7.819864387751e-01 true resid norm 7.776718832744e+12 ||r(i)||/||b|| 4.428658782763e+10
246 KSP preconditioned resid norm 7.494727650930e-01 true resid norm 9.390814897668e+12 ||r(i)||/||b|| 5.347848593774e+10
247 KSP preconditioned resid norm 7.397424145173e-01 true resid norm 1.239122155493e+13 ||r(i)||/||b|| 7.056509737419e+10
248 KSP preconditioned resid norm 7.246093261829e-01 true resid norm 2.036047657616e+13 ||r(i)||/||b|| 1.159481335889e+11
249 KSP preconditioned resid norm 7.245038778291e-01 true resid norm 1.963876697176e+13 ||r(i)||/||b|| 1.118381668448e+11
250 KSP preconditioned resid norm 7.171029204552e-01 true resid norm 9.527294292595e+12 ||r(i)||/||b|| 5.425570404734e+10
251 KSP preconditioned resid norm 6.952339007733e-01 true resid norm 8.813498953048e+12 ||r(i)||/||b|| 5.019080718329e+10
252 KSP preconditioned resid norm 6.616924086753e-01 true resid norm 2.108382041551e+13 ||r(i)||/||b|| 1.200674069174e+11
253 KSP preconditioned resid norm 6.448191214386e-01 true resid norm 3.210805413021e+13 ||r(i)||/||b|| 1.828478295017e+11
254 KSP preconditioned resid norm 6.422075541827e-01 true resid norm 3.557756209357e+13 ||r(i)||/||b|| 2.026058627343e+11
255 KSP preconditioned resid norm 6.416647613441e-01 true resid norm 3.380009792729e+13 ||r(i)||/||b|| 1.924836216447e+11
256 KSP preconditioned resid norm 6.402280834143e-01 true resid norm 2.953288783796e+13 ||r(i)||/||b|| 1.681828621002e+11
257 KSP preconditioned resid norm 6.350183274762e-01 true resid norm 2.019635706586e+13 ||r(i)||/||b|| 1.150135115120e+11
258 KSP preconditioned resid norm 6.268519717549e-01 true resid norm 8.111866952331e+12 ||r(i)||/||b|| 4.619517767800e+10
259 KSP preconditioned resid norm 6.259448365356e-01 true resid norm 6.274138275600e+12 ||r(i)||/||b|| 3.572974435119e+10
260 KSP preconditioned resid norm 6.185273691470e-01 true resid norm 1.328310119998e+13 ||r(i)||/||b|| 7.564414254497e+10
261 KSP preconditioned resid norm 5.799540271653e-01 true resid norm 3.941950358614e+13 ||r(i)||/||b|| 2.244848174707e+11
262 KSP preconditioned resid norm 5.592595784538e-01 true resid norm 6.141084463330e+13 ||r(i)||/||b|| 3.497203413052e+11
263 KSP preconditioned resid norm 5.534201157748e-01 true resid norm 7.435564413187e+13 ||r(i)||/||b|| 4.234379350917e+11
264 KSP preconditioned resid norm 5.528810608860e-01 true resid norm 7.763287354101e+13 ||r(i)||/||b|| 4.421009871039e+11
265 KSP preconditioned resid norm 5.469595863469e-01 true resid norm 7.004373972883e+13 ||r(i)||/||b|| 3.988826519246e+11
266 KSP preconditioned resid norm 4.945292416960e-01 true resid norm 4.228774811832e+13 ||r(i)||/||b|| 2.408187966356e+11
267 KSP preconditioned resid norm 4.281890068775e-01 true resid norm 1.125884213676e+13 ||r(i)||/||b|| 6.411646246328e+10
268 KSP preconditioned resid norm 4.084231601522e-01 true resid norm 2.127490364486e+13 ||r(i)||/||b|| 1.211555810435e+11
269 KSP preconditioned resid norm 4.001208915779e-01 true resid norm 3.267071702508e+13 ||r(i)||/||b|| 1.860520625782e+11
270 KSP preconditioned resid norm 3.984419205712e-01 true resid norm 2.966020373146e+13 ||r(i)||/||b|| 1.689078962207e+11
271 KSP preconditioned resid norm 3.983169885607e-01 true resid norm 2.985688873765e+13 ||r(i)||/||b|| 1.700279711506e+11
272 KSP preconditioned resid norm 3.983124521919e-01 true resid norm 2.995123552363e+13 ||r(i)||/||b|| 1.705652539447e+11
273 KSP preconditioned resid norm 3.970518487040e-01 true resid norm 2.679057592981e+13 ||r(i)||/||b|| 1.525660396609e+11
274 KSP preconditioned resid norm 3.939367745543e-01 true resid norm 2.092683959757e+13 ||r(i)||/||b|| 1.191734380174e+11
275 KSP preconditioned resid norm 3.908410919474e-01 true resid norm 1.686677707108e+13 ||r(i)||/||b|| 9.605233520626e+10
276 KSP preconditioned resid norm 3.864892438875e-01 true resid norm 1.308673657633e+13 ||r(i)||/||b|| 7.452589211849e+10
277 KSP preconditioned resid norm 3.810077620712e-01 true resid norm 8.711820645292e+12 ||r(i)||/||b|| 4.961177309405e+10
278 KSP preconditioned resid norm 3.799753478575e-01 true resid norm 7.283942147984e+12 ||r(i)||/||b|| 4.148034030880e+10
279 KSP preconditioned resid norm 3.797915436438e-01 true resid norm 8.282722196918e+12 ||r(i)||/||b|| 4.716815818018e+10
280 KSP preconditioned resid norm 3.782267745986e-01 true resid norm 1.343417477314e+13 ||r(i)||/||b|| 7.650447107297e+10
281 KSP preconditioned resid norm 3.767711703315e-01 true resid norm 1.850915006024e+13 ||r(i)||/||b|| 1.054052637606e+11
282 KSP preconditioned resid norm 3.760725811208e-01 true resid norm 2.146321377790e+13 ||r(i)||/||b|| 1.222279630371e+11
283 KSP preconditioned resid norm 3.760725798486e-01 true resid norm 2.145927689153e+13 ||r(i)||/||b|| 1.222055433935e+11
284 KSP preconditioned resid norm 3.726641668459e-01 true resid norm 1.486048146819e+13 ||r(i)||/||b|| 8.462695281341e+10
285 KSP preconditioned resid norm 3.629918107955e-01 true resid norm 5.461478467526e+12 ||r(i)||/||b|| 3.110183755165e+10
286 KSP preconditioned resid norm 3.465171750557e-01 true resid norm 1.207028659269e+13 ||r(i)||/||b|| 6.873744811775e+10
287 KSP preconditioned resid norm 3.331409716393e-01 true resid norm 2.006105462605e+13 ||r(i)||/||b|| 1.142429958854e+11
288 KSP preconditioned resid norm 3.239240346132e-01 true resid norm 3.105697669784e+13 ||r(i)||/||b|| 1.768621903107e+11
289 KSP preconditioned resid norm 3.238957055659e-01 true resid norm 3.157956806648e+13 ||r(i)||/||b|| 1.798382254539e+11
290 KSP preconditioned resid norm 3.157544915738e-01 true resid norm 2.092815634087e+13 ||r(i)||/||b|| 1.191809365613e+11
291 KSP preconditioned resid norm 2.852382588503e-01 true resid norm 2.979472210968e+12 ||r(i)||/||b|| 1.696739468006e+10
292 KSP preconditioned resid norm 2.694150546753e-01 true resid norm 1.436731569255e+13 ||r(i)||/||b|| 8.181848951342e+10
293 KSP preconditioned resid norm 2.641931974470e-01 true resid norm 1.861155923250e+13 ||r(i)||/||b|| 1.059884599516e+11
294 KSP preconditioned resid norm 2.641198814870e-01 true resid norm 1.793981239430e+13 ||r(i)||/||b|| 1.021630194300e+11
295 KSP preconditioned resid norm 2.637318754754e-01 true resid norm 1.659027423690e+13 ||r(i)||/||b|| 9.447771648676e+10
296 KSP preconditioned resid norm 2.595722151521e-01 true resid norm 1.208243067646e+13 ||r(i)||/||b|| 6.880660582345e+10
297 KSP preconditioned resid norm 2.491740116565e-01 true resid norm 2.771289873763e+12 ||r(i)||/||b|| 1.578184514959e+10
298 KSP preconditioned resid norm 2.415305724877e-01 true resid norm 7.852236246693e+12 ||r(i)||/||b|| 4.471664176906e+10
299 KSP preconditioned resid norm 2.408045892302e-01 true resid norm 9.473449724245e+12 ||r(i)||/||b|| 5.394907187295e+10
300 KSP preconditioned resid norm 2.340555162432e-01 true resid norm 3.319865257484e+12 ||r(i)||/||b|| 1.890585315782e+10
301 KSP preconditioned resid norm 2.337976114563e-01 true resid norm 3.340283381850e+12 ||r(i)||/||b|| 1.902212958203e+10
302 KSP preconditioned resid norm 2.333327903686e-01 true resid norm 3.415389327731e+12 ||r(i)||/||b|| 1.944984030942e+10
303 KSP preconditioned resid norm 2.332588418708e-01 true resid norm 3.475181431476e+12 ||r(i)||/||b|| 1.979034230143e+10
304 KSP preconditioned resid norm 2.326010662742e-01 true resid norm 3.181161063381e+12 ||r(i)||/||b|| 1.811596533927e+10
305 KSP preconditioned resid norm 2.315413201851e-01 true resid norm 2.933253862391e+12 ||r(i)||/||b|| 1.670419203669e+10
306 KSP preconditioned resid norm 2.304630572502e-01 true resid norm 2.715749947702e+12 ||r(i)||/||b|| 1.546555831110e+10
307 KSP preconditioned resid norm 2.292865323373e-01 true resid norm 2.503342572809e+12 ||r(i)||/||b|| 1.425594818300e+10
308 KSP preconditioned resid norm 2.291299261731e-01 true resid norm 2.431749785546e+12 ||r(i)||/||b|| 1.384824406907e+10
309 KSP preconditioned resid norm 2.286328421233e-01 true resid norm 2.568787793883e+12 ||r(i)||/||b|| 1.462864335089e+10
310 KSP preconditioned resid norm 2.219499874016e-01 true resid norm 3.330410350857e+12 ||r(i)||/||b|| 1.896590498865e+10
311 KSP preconditioned resid norm 2.147861496159e-01 true resid norm 4.183733540267e+12 ||r(i)||/||b|| 2.382538019741e+10
312 KSP preconditioned resid norm 2.085908097212e-01 true resid norm 5.269197084207e+12 ||r(i)||/||b|| 3.000684022011e+10
313 KSP preconditioned resid norm 2.077913842950e-01 true resid norm 5.622549320884e+12 ||r(i)||/||b|| 3.201909824309e+10
314 KSP preconditioned resid norm 2.074683531125e-01 true resid norm 5.380881874823e+12 ||r(i)||/||b|| 3.064285887978e+10
315 KSP preconditioned resid norm 2.049851408085e-01 true resid norm 4.681933765100e+12 ||r(i)||/||b|| 2.666251350354e+10
316 KSP preconditioned resid norm 1.972228619533e-01 true resid norm 3.213437404698e+12 ||r(i)||/||b|| 1.829977152479e+10
317 KSP preconditioned resid norm 1.890934720736e-01 true resid norm 1.861733116751e+12 ||r(i)||/||b|| 1.060213297663e+10
318 KSP preconditioned resid norm 1.708640605511e-01 true resid norm 5.900505719991e+12 ||r(i)||/||b|| 3.360199467359e+10
319 KSP preconditioned resid norm 1.663553073051e-01 true resid norm 7.175237786099e+12 ||r(i)||/||b|| 4.086129449097e+10
320 KSP preconditioned resid norm 1.658645928614e-01 true resid norm 7.758811670795e+12 ||r(i)||/||b|| 4.418461074482e+10
321 KSP preconditioned resid norm 1.622193976534e-01 true resid norm 5.257250867666e+12 ||r(i)||/||b|| 2.993880932180e+10
322 KSP preconditioned resid norm 1.538134435071e-01 true resid norm 1.761918308713e+12 ||r(i)||/||b|| 1.003371108074e+10
323 KSP preconditioned resid norm 1.475401894061e-01 true resid norm 2.439997291723e+12 ||r(i)||/||b|| 1.389521168029e+10
324 KSP preconditioned resid norm 1.465929441051e-01 true resid norm 3.261115459698e+12 ||r(i)||/||b|| 1.857128685351e+10
325 KSP preconditioned resid norm 1.465393365067e-01 true resid norm 3.532319290848e+12 ||r(i)||/||b|| 2.011572899495e+10
326 KSP preconditioned resid norm 1.454914804114e-01 true resid norm 2.395332308598e+12 ||r(i)||/||b|| 1.364085508845e+10
327 KSP preconditioned resid norm 1.390786123266e-01 true resid norm 2.528026009523e+12 ||r(i)||/||b|| 1.439651455957e+10
328 KSP preconditioned resid norm 1.374343106603e-01 true resid norm 3.812158646060e+12 ||r(i)||/||b|| 2.170934841835e+10
329 KSP preconditioned resid norm 1.374341181714e-01 true resid norm 3.791013558642e+12 ||r(i)||/||b|| 2.158893211024e+10
330 KSP preconditioned resid norm 1.352522554178e-01 true resid norm 1.974296331181e+12 ||r(i)||/||b|| 1.124315405367e+10
331 KSP preconditioned resid norm 1.350655877373e-01 true resid norm 1.991730189414e+12 ||r(i)||/||b|| 1.134243578295e+10
332 KSP preconditioned resid norm 1.348111499178e-01 true resid norm 2.041450090606e+12 ||r(i)||/||b|| 1.162557894631e+10
333 KSP preconditioned resid norm 1.347849508207e-01 true resid norm 2.070098875209e+12 ||r(i)||/||b|| 1.178872704807e+10
334 KSP preconditioned resid norm 1.347064718924e-01 true resid norm 1.986607521799e+12 ||r(i)||/||b|| 1.131326339365e+10
335 KSP preconditioned resid norm 1.343983613005e-01 true resid norm 1.851271628553e+12 ||r(i)||/||b|| 1.054255725763e+10
336 KSP preconditioned resid norm 1.336229788762e-01 true resid norm 1.667659941047e+12 ||r(i)||/||b|| 9.496931808159e+09
337 KSP preconditioned resid norm 1.325162653711e-01 true resid norm 1.468835090963e+12 ||r(i)||/||b|| 8.364670969763e+09
338 KSP preconditioned resid norm 1.322680103842e-01 true resid norm 1.408300477178e+12 ||r(i)||/||b|| 8.019940557400e+09
339 KSP preconditioned resid norm 1.319145624423e-01 true resid norm 1.509021321087e+12 ||r(i)||/||b|| 8.593522114840e+09
340 KSP preconditioned resid norm 1.301020989018e-01 true resid norm 1.939032411134e+12 ||r(i)||/||b|| 1.104233430875e+10
341 KSP preconditioned resid norm 1.265364340713e-01 true resid norm 3.097593434152e+12 ||r(i)||/||b|| 1.764006731197e+10
342 KSP preconditioned resid norm 1.233025029546e-01 true resid norm 4.405615884105e+12 ||r(i)||/||b|| 2.508894804898e+10
343 KSP preconditioned resid norm 1.217458096040e-01 true resid norm 5.448234354847e+12 ||r(i)||/||b|| 3.102641543957e+10
344 KSP preconditioned resid norm 1.216044613872e-01 true resid norm 5.205265234000e+12 ||r(i)||/||b|| 2.964276334398e+10
345 KSP preconditioned resid norm 1.202483376431e-01 true resid norm 4.373819937611e+12 ||r(i)||/||b|| 2.490787759919e+10
346 KSP preconditioned resid norm 1.142262444908e-01 true resid norm 2.410382502863e+12 ||r(i)||/||b|| 1.372656241110e+10
347 KSP preconditioned resid norm 1.034106328028e-01 true resid norm 1.402453552596e+12 ||r(i)||/||b|| 7.986643694730e+09
348 KSP preconditioned resid norm 9.616103472769e-02 true resid norm 3.393076323304e+12 ||r(i)||/||b|| 1.932277298816e+10
349 KSP preconditioned resid norm 9.259589822073e-02 true resid norm 4.915943835511e+12 ||r(i)||/||b|| 2.799514591043e+10
350 KSP preconditioned resid norm 9.235272729717e-02 true resid norm 5.600460755060e+12 ||r(i)||/||b|| 3.189330904698e+10
351 KSP preconditioned resid norm 9.219524424992e-02 true resid norm 5.004185758598e+12 ||r(i)||/||b|| 2.849766294376e+10
352 KSP preconditioned resid norm 9.013478975958e-02 true resid norm 1.354932500749e+12 ||r(i)||/||b|| 7.716022462104e+09
353 KSP preconditioned resid norm 8.753727009852e-02 true resid norm 2.615102379560e+12 ||r(i)||/||b|| 1.489239404195e+10
354 KSP preconditioned resid norm 8.737394501163e-02 true resid norm 3.256844376132e+12 ||r(i)||/||b|| 1.854696403542e+10
355 KSP preconditioned resid norm 8.731164789228e-02 true resid norm 3.679087592003e+12 ||r(i)||/||b|| 2.095154000975e+10
356 KSP preconditioned resid norm 8.686035696790e-02 true resid norm 2.606571260249e+12 ||r(i)||/||b|| 1.484381132052e+10
357 KSP preconditioned resid norm 8.510853060356e-02 true resid norm 9.410247297091e+11 ||r(i)||/||b|| 5.358914888984e+09
358 KSP preconditioned resid norm 8.456101573028e-02 true resid norm 2.187983263684e+12 ||r(i)||/||b|| 1.246005096192e+10
359 KSP preconditioned resid norm 8.455208355692e-02 true resid norm 2.388461620241e+12 ||r(i)||/||b|| 1.360172813145e+10
360 KSP preconditioned resid norm 8.282898790796e-02 true resid norm 8.621883722570e+11 ||r(i)||/||b|| 4.909960343577e+09
361 KSP preconditioned resid norm 8.272531817972e-02 true resid norm 8.633101635311e+11 ||r(i)||/||b|| 4.916348681494e+09
362 KSP preconditioned resid norm 8.254591608780e-02 true resid norm 8.673672359825e+11 ||r(i)||/||b|| 4.939452756530e+09
363 KSP preconditioned resid norm 8.246541279676e-02 true resid norm 8.718796820962e+11 ||r(i)||/||b|| 4.965150077653e+09
364 KSP preconditioned resid norm 8.241801614853e-02 true resid norm 8.671459105212e+11 ||r(i)||/||b|| 4.938192359993e+09
365 KSP preconditioned resid norm 8.212818717225e-02 true resid norm 8.587064176355e+11 ||r(i)||/||b|| 4.890131429549e+09
366 KSP preconditioned resid norm 8.194338791810e-02 true resid norm 8.545028564125e+11 ||r(i)||/||b|| 4.866193135354e+09
367 KSP preconditioned resid norm 8.171085097872e-02 true resid norm 8.509831240026e+11 ||r(i)||/||b|| 4.846149085691e+09
368 KSP preconditioned resid norm 8.161620694246e-02 true resid norm 8.497340417759e+11 ||r(i)||/||b|| 4.839035855686e+09
369 KSP preconditioned resid norm 8.156115260727e-02 true resid norm 8.491439509018e+11 ||r(i)||/||b|| 4.835675426708e+09
370 KSP preconditioned resid norm 8.063518312109e-02 true resid norm 8.485155476082e+11 ||r(i)||/||b|| 4.832096817496e+09
371 KSP preconditioned resid norm 7.923271766690e-02 true resid norm 8.588597971885e+11 ||r(i)||/||b|| 4.891004890091e+09
372 KSP preconditioned resid norm 7.803394074240e-02 true resid norm 9.006066172395e+11 ||r(i)||/||b|| 5.128743228390e+09
373 KSP preconditioned resid norm 7.794468296789e-02 true resid norm 9.117020640296e+11 ||r(i)||/||b|| 5.191929192718e+09
374 KSP preconditioned resid norm 7.789560350182e-02 true resid norm 9.012718632073e+11 ||r(i)||/||b|| 5.132531647980e+09
375 KSP preconditioned resid norm 7.726439270554e-02 true resid norm 8.586478043639e+11 ||r(i)||/||b|| 4.889797640729e+09
376 KSP preconditioned resid norm 7.571815304778e-02 true resid norm 7.859006686039e+11 ||r(i)||/||b|| 4.475519783148e+09
377 KSP preconditioned resid norm 7.229778169081e-02 true resid norm 7.199635191238e+11 ||r(i)||/||b|| 4.100023198488e+09
378 KSP preconditioned resid norm 6.397340351388e-02 true resid norm 1.019822843376e+12 ||r(i)||/||b|| 5.807651645013e+09
379 KSP preconditioned resid norm 6.206292899595e-02 true resid norm 1.188216539089e+12 ||r(i)||/||b|| 6.766614204318e+09
380 KSP preconditioned resid norm 6.196521462769e-02 true resid norm 1.124045327968e+12 ||r(i)||/||b|| 6.401174223978e+09
381 KSP preconditioned resid norm 5.991532104364e-02 true resid norm 7.442069871361e+11 ||r(i)||/||b|| 4.238084056604e+09
382 KSP preconditioned resid norm 5.520548141478e-02 true resid norm 7.033003686501e+11 ||r(i)||/||b|| 4.005130468944e+09
383 KSP preconditioned resid norm 5.363722028702e-02 true resid norm 9.204398617490e+11 ||r(i)||/||b|| 5.241688899150e+09
384 KSP preconditioned resid norm 5.357854244551e-02 true resid norm 9.679742638260e+11 ||r(i)||/||b|| 5.512386158198e+09
385 KSP preconditioned resid norm 5.353846275978e-02 true resid norm 9.122890587478e+11 ||r(i)||/||b|| 5.195271989815e+09
386 KSP preconditioned resid norm 5.127828730979e-02 true resid norm 5.397803438917e+11 ||r(i)||/||b|| 3.073922321421e+09
387 KSP preconditioned resid norm 4.779149659066e-02 true resid norm 7.151556879314e+11 ||r(i)||/||b|| 4.072643728696e+09
388 KSP preconditioned resid norm 4.453398637579e-02 true resid norm 1.396877441705e+12 ||r(i)||/||b|| 7.954889052439e+09
389 KSP preconditioned resid norm 4.229884991114e-02 true resid norm 2.320750680264e+12 ||r(i)||/||b|| 1.321613022639e+10
390 KSP preconditioned resid norm 4.227141787457e-02 true resid norm 2.410982268811e+12 ||r(i)||/||b|| 1.372997793735e+10
391 KSP preconditioned resid norm 4.226967821924e-02 true resid norm 2.405619775441e+12 ||r(i)||/||b|| 1.369943979669e+10
392 KSP preconditioned resid norm 4.221372313301e-02 true resid norm 2.329085067743e+12 ||r(i)||/||b|| 1.326359260622e+10
393 KSP preconditioned resid norm 4.155609966799e-02 true resid norm 1.810164248293e+12 ||r(i)||/||b|| 1.030846037881e+10
394 KSP preconditioned resid norm 3.984904493432e-02 true resid norm 7.675743853622e+11 ||r(i)||/||b|| 4.371155902983e+09
395 KSP preconditioned resid norm 3.825027307918e-02 true resid norm 4.185151745600e+11 ||r(i)||/||b|| 2.383345654379e+09
396 KSP preconditioned resid norm 3.763881169814e-02 true resid norm 8.271169350618e+11 ||r(i)||/||b|| 4.710236743304e+09
397 KSP preconditioned resid norm 3.693767673821e-02 true resid norm 1.445874605711e+12 ||r(i)||/||b|| 8.233916397230e+09
398 KSP preconditioned resid norm 3.655336108976e-02 true resid norm 1.951696829437e+12 ||r(i)||/||b|| 1.111445519746e+10
399 KSP preconditioned resid norm 3.631459017681e-02 true resid norm 1.521939263936e+12 ||r(i)||/||b|| 8.667086766314e+09
400 KSP preconditioned resid norm 3.535829901366e-02 true resid norm 4.129825555092e+11 ||r(i)||/||b|| 2.351838687909e+09
401 KSP preconditioned resid norm 3.306227938654e-02 true resid norm 1.743545317737e+12 ||r(i)||/||b|| 9.929081210999e+09
402 KSP preconditioned resid norm 3.237217236740e-02 true resid norm 2.637614832312e+12 ||r(i)||/||b|| 1.502059717459e+10
403 KSP preconditioned resid norm 3.229588503023e-02 true resid norm 2.838708688793e+12 ||r(i)||/||b|| 1.616577947167e+10
404 KSP preconditioned resid norm 3.221312023156e-02 true resid norm 2.631900255728e+12 ||r(i)||/||b|| 1.498805400269e+10
405 KSP preconditioned resid norm 3.128674650292e-02 true resid norm 1.788603572226e+12 ||r(i)||/||b|| 1.018567739092e+10
406 KSP preconditioned resid norm 2.906677117599e-02 true resid norm 5.532805319168e+11 ||r(i)||/||b|| 3.150802722465e+09
407 KSP preconditioned resid norm 2.646322183153e-02 true resid norm 1.125449605044e+12 ||r(i)||/||b|| 6.409171252212e+09
408 KSP preconditioned resid norm 2.555613075126e-02 true resid norm 1.788020242410e+12 ||r(i)||/||b|| 1.018235546458e+10
409 KSP preconditioned resid norm 2.524431021639e-02 true resid norm 2.496704664068e+12 ||r(i)||/||b|| 1.421814685126e+10
410 KSP preconditioned resid norm 2.518030459049e-02 true resid norm 2.153170063032e+12 ||r(i)||/||b|| 1.226179795813e+10
411 KSP preconditioned resid norm 2.483081199074e-02 true resid norm 1.288184341021e+12 ||r(i)||/||b|| 7.335907364507e+09
412 KSP preconditioned resid norm 2.421322742969e-02 true resid norm 4.654342665955e+11 ||r(i)||/||b|| 2.650538867212e+09
413 KSP preconditioned resid norm 2.406880750280e-02 true resid norm 2.461138537084e+11 ||r(i)||/||b|| 1.401560610879e+09
414 KSP preconditioned resid norm 2.406137336500e-02 true resid norm 2.570585037746e+11 ||r(i)||/||b|| 1.463887823270e+09
415 KSP preconditioned resid norm 2.405151767205e-02 true resid norm 2.456408679897e+11 ||r(i)||/||b|| 1.398867068265e+09
416 KSP preconditioned resid norm 2.366488268271e-02 true resid norm 5.476635939531e+11 ||r(i)||/||b|| 3.118815579583e+09
417 KSP preconditioned resid norm 2.318091177565e-02 true resid norm 1.255400569078e+12 ||r(i)||/||b|| 7.149211480715e+09
418 KSP preconditioned resid norm 2.317653711428e-02 true resid norm 1.290066344908e+12 ||r(i)||/||b|| 7.346624934756e+09
419 KSP preconditioned resid norm 2.297691251598e-02 true resid norm 1.023329583721e+12 ||r(i)||/||b|| 5.827621707918e+09
420 KSP preconditioned resid norm 2.223563066277e-02 true resid norm 6.947559472807e+11 ||r(i)||/||b|| 3.956471995421e+09
421 KSP preconditioned resid norm 2.207591596678e-02 true resid norm 7.277570512278e+11 ||r(i)||/||b|| 4.144405533948e+09
422 KSP preconditioned resid norm 2.192159198929e-02 true resid norm 7.832565151219e+11 ||r(i)||/||b|| 4.460461949898e+09
423 KSP preconditioned resid norm 2.185247147135e-02 true resid norm 8.595230163286e+11 ||r(i)||/||b|| 4.894781767374e+09
424 KSP preconditioned resid norm 2.185084575688e-02 true resid norm 8.423052356273e+11 ||r(i)||/||b|| 4.796730548907e+09
425 KSP preconditioned resid norm 2.184027206302e-02 true resid norm 7.874820929027e+11 ||r(i)||/||b|| 4.484525623221e+09
426 KSP preconditioned resid norm 2.180574611184e-02 true resid norm 6.882090989991e+11 ||r(i)||/||b|| 3.919189231616e+09
427 KSP preconditioned resid norm 2.166857906443e-02 true resid norm 5.212834704447e+11 ||r(i)||/||b|| 2.968586970091e+09
428 KSP preconditioned resid norm 2.159097506805e-02 true resid norm 4.034244503683e+11 ||r(i)||/||b|| 2.297407523315e+09
429 KSP preconditioned resid norm 2.158895718874e-02 true resid norm 4.137932807816e+11 ||r(i)||/||b|| 2.356455577982e+09
430 KSP preconditioned resid norm 2.144608377764e-02 true resid norm 5.707555847347e+11 ||r(i)||/||b|| 3.250319045230e+09
431 KSP preconditioned resid norm 2.102844428927e-02 true resid norm 8.954067244875e+11 ||r(i)||/||b|| 5.099131060069e+09
432 KSP preconditioned resid norm 2.043855604252e-02 true resid norm 1.579549885579e+12 ||r(i)||/||b|| 8.995165729961e+09
433 KSP preconditioned resid norm 2.009798102446e-02 true resid norm 2.188070885454e+12 ||r(i)||/||b|| 1.246054994733e+10
434 KSP preconditioned resid norm 1.996946332503e-02 true resid norm 2.549838325591e+12 ||r(i)||/||b|| 1.452073057818e+10
435 KSP preconditioned resid norm 1.995647707137e-02 true resid norm 2.680808177026e+12 ||r(i)||/||b|| 1.526657313121e+10
436 KSP preconditioned resid norm 1.988125326167e-02 true resid norm 2.348426065382e+12 ||r(i)||/||b|| 1.337373504663e+10
437 KSP preconditioned resid norm 1.898974930191e-02 true resid norm 1.218972146414e+12 ||r(i)||/||b|| 6.941760166809e+09
438 KSP preconditioned resid norm 1.696428871787e-02 true resid norm 3.026205745736e+11 ||r(i)||/||b|| 1.723353118783e+09
439 KSP preconditioned resid norm 1.589383908182e-02 true resid norm 1.469775790684e+12 ||r(i)||/||b|| 8.370028033799e+09
440 KSP preconditioned resid norm 1.578856928747e-02 true resid norm 1.654607025409e+12 ||r(i)||/||b|| 9.422598518346e+09
441 KSP preconditioned resid norm 1.551247109488e-02 true resid norm 1.442783527791e+12 ||r(i)||/||b|| 8.216313434240e+09
442 KSP preconditioned resid norm 1.452922185421e-02 true resid norm 4.930974509265e+11 ||r(i)||/||b|| 2.808074206835e+09
443 KSP preconditioned resid norm 1.322597574636e-02 true resid norm 6.258068580126e+11 ||r(i)||/||b|| 3.563823120854e+09
444 KSP preconditioned resid norm 1.248114500958e-02 true resid norm 1.255462163215e+12 ||r(i)||/||b|| 7.149562244861e+09
445 KSP preconditioned resid norm 1.232420552748e-02 true resid norm 1.428758773085e+12 ||r(i)||/||b|| 8.136445749113e+09
446 KSP preconditioned resid norm 1.210183666940e-02 true resid norm 1.113947512959e+12 ||r(i)||/||b|| 6.343669538405e+09
447 KSP preconditioned resid norm 1.098375596479e-02 true resid norm 6.623811396906e+11 ||r(i)||/||b|| 3.772105067598e+09
448 KSP preconditioned resid norm 1.016183389490e-02 true resid norm 1.004416279978e+11 ||r(i)||/||b|| 5.719914883828e+08
449 KSP preconditioned resid norm 8.946579568395e-03 true resid norm 3.185680683629e+11 ||r(i)||/||b|| 1.814170351541e+09
450 KSP preconditioned resid norm 8.941903973955e-03 true resid norm 3.415328417489e+11 ||r(i)||/||b|| 1.944949343989e+09
451 KSP preconditioned resid norm 8.941859110708e-03 true resid norm 3.414222834181e+11 ||r(i)||/||b|| 1.944319740254e+09
452 KSP preconditioned resid norm 8.937586314421e-03 true resid norm 3.373377321037e+11 ||r(i)||/||b|| 1.921059179545e+09
453 KSP preconditioned resid norm 8.857435678093e-03 true resid norm 2.969067995457e+11 ||r(i)||/||b|| 1.690814511557e+09
454 KSP preconditioned resid norm 8.484561477096e-03 true resid norm 1.648904346090e+11 ||r(i)||/||b|| 9.390123098578e+08
455 KSP preconditioned resid norm 8.064680909874e-03 true resid norm 6.485855267074e+10 ||r(i)||/||b|| 3.693542290782e+08
456 KSP preconditioned resid norm 7.880264947424e-03 true resid norm 7.274673519887e+10 ||r(i)||/||b|| 4.142755764801e+08
457 KSP preconditioned resid norm 7.593688239054e-03 true resid norm 1.445361395141e+11 ||r(i)||/||b|| 8.230993783529e+08
458 KSP preconditioned resid norm 7.462467793953e-03 true resid norm 2.021789922620e+11 ||r(i)||/||b|| 1.151361890572e+09
459 KSP preconditioned resid norm 7.446133179161e-03 true resid norm 1.788849926823e+11 ||r(i)||/||b|| 1.018708032250e+09
460 KSP preconditioned resid norm 7.348667644300e-03 true resid norm 1.054645854854e+11 ||r(i)||/||b|| 6.005960519154e+08
461 KSP preconditioned resid norm 7.111670463818e-03 true resid norm 8.554318742785e+10 ||r(i)||/||b|| 4.871483673973e+08
462 KSP preconditioned resid norm 6.928819885161e-03 true resid norm 1.869275057925e+11 ||r(i)||/||b|| 1.064508256081e+09
463 KSP preconditioned resid norm 6.911497814174e-03 true resid norm 2.062115664765e+11 ||r(i)||/||b|| 1.174326453900e+09
464 KSP preconditioned resid norm 6.905631098974e-03 true resid norm 1.906811421053e+11 ||r(i)||/||b|| 1.085884333553e+09
465 KSP preconditioned resid norm 6.716726820012e-03 true resid norm 9.813136700632e+10 ||r(i)||/||b|| 5.588350944710e+08
466 KSP preconditioned resid norm 6.199015524483e-03 true resid norm 1.333586080679e+11 ||r(i)||/||b|| 7.594459611812e+08
467 KSP preconditioned resid norm 5.532796739445e-03 true resid norm 3.569112996540e+11 ||r(i)||/||b|| 2.032526050993e+09
468 KSP preconditioned resid norm 5.360292734614e-03 true resid norm 4.755992375611e+11 ||r(i)||/||b|| 2.708425990190e+09
469 KSP preconditioned resid norm 5.342219637791e-03 true resid norm 5.151772931536e+11 ||r(i)||/||b|| 2.933813724110e+09
470 KSP preconditioned resid norm 5.332377875131e-03 true resid norm 4.601284207857e+11 ||r(i)||/||b|| 2.620323321105e+09
471 KSP preconditioned resid norm 5.189844708887e-03 true resid norm 1.790760088328e+11 ||r(i)||/||b|| 1.019795824378e+09
472 KSP preconditioned resid norm 5.049866465566e-03 true resid norm 5.152313973554e+10 ||r(i)||/||b|| 2.934121834836e+08
473 KSP preconditioned resid norm 4.924601896546e-03 true resid norm 1.677928034924e+11 ||r(i)||/||b|| 9.555406191908e+08
474 KSP preconditioned resid norm 4.924351655351e-03 true resid norm 1.738933523340e+11 ||r(i)||/||b|| 9.902818124731e+08
475 KSP preconditioned resid norm 4.924289830625e-03 true resid norm 1.772937150451e+11 ||r(i)||/||b|| 1.009646079729e+09
476 KSP preconditioned resid norm 4.876495146769e-03 true resid norm 7.947838694965e+10 ||r(i)||/||b|| 4.526107526511e+08
477 KSP preconditioned resid norm 4.778812651601e-03 true resid norm 1.558755330076e+11 ||r(i)||/||b|| 8.876745618800e+08
478 KSP preconditioned resid norm 4.755402622058e-03 true resid norm 2.205314865771e+11 ||r(i)||/||b|| 1.255875036646e+09
479 KSP preconditioned resid norm 4.755321537318e-03 true resid norm 2.242726552323e+11 ||r(i)||/||b|| 1.277180113734e+09
480 KSP preconditioned resid norm 4.644535254442e-03 true resid norm 7.822908083997e+10 ||r(i)||/||b|| 4.454962476857e+08
481 KSP preconditioned resid norm 4.632047119055e-03 true resid norm 7.991822757006e+10 ||r(i)||/||b|| 4.551155417125e+08
482 KSP preconditioned resid norm 4.612904266289e-03 true resid norm 8.633846252556e+10 ||r(i)||/||b|| 4.916772723532e+08
483 KSP preconditioned resid norm 4.610144234326e-03 true resid norm 9.030386603281e+10 ||r(i)||/||b|| 5.142593142751e+08
484 KSP preconditioned resid norm 4.604192845375e-03 true resid norm 8.230498241659e+10 ||r(i)||/||b|| 4.687075501684e+08
485 KSP preconditioned resid norm 4.564896521330e-03 true resid norm 6.060884575469e+10 ||r(i)||/||b|| 3.451531459958e+08
486 KSP preconditioned resid norm 4.546464306921e-03 true resid norm 4.872040768046e+10 ||r(i)||/||b|| 2.774512824938e+08
487 KSP preconditioned resid norm 4.526348213322e-03 true resid norm 4.510654738498e+10 ||r(i)||/||b|| 2.568711966229e+08
488 KSP preconditioned resid norm 4.523746573565e-03 true resid norm 4.683371377026e+10 ||r(i)||/||b|| 2.667070036592e+08
489 KSP preconditioned resid norm 4.522949666646e-03 true resid norm 4.552503866918e+10 ||r(i)||/||b|| 2.592544062272e+08
490 KSP preconditioned resid norm 4.504493562917e-03 true resid norm 5.209398625762e+10 ||r(i)||/||b|| 2.966630203957e+08
491 KSP preconditioned resid norm 4.424828850570e-03 true resid norm 1.544598998033e+11 ||r(i)||/||b|| 8.796128631636e+08
492 KSP preconditioned resid norm 4.338171328969e-03 true resid norm 2.844045719702e+11 ||r(i)||/||b|| 1.619617260959e+09
493 KSP preconditioned resid norm 4.255536926378e-03 true resid norm 4.382320759656e+11 ||r(i)||/||b|| 2.495628778479e+09
494 KSP preconditioned resid norm 4.229260600674e-03 true resid norm 5.282692430595e+11 ||r(i)||/||b|| 3.008369304916e+09
495 KSP preconditioned resid norm 4.223256517614e-03 true resid norm 4.857613635841e+11 ||r(i)||/||b|| 2.766296911887e+09
496 KSP preconditioned resid norm 4.136338595951e-03 true resid norm 3.512867560712e+11 ||r(i)||/||b|| 2.000495595897e+09
497 KSP preconditioned resid norm 3.946602463360e-03 true resid norm 1.832798358993e+11 ||r(i)||/||b|| 1.043735632490e+09
498 KSP preconditioned resid norm 3.453206785283e-03 true resid norm 1.333858086954e+11 ||r(i)||/||b|| 7.596008623685e+08
499 KSP preconditioned resid norm 3.126641781407e-03 true resid norm 3.661688364605e+11 ||r(i)||/||b|| 2.085245549495e+09
500 KSP preconditioned resid norm 3.072454365635e-03 true resid norm 4.367597724160e+11 ||r(i)||/||b|| 2.487244355452e+09
501 KSP preconditioned resid norm 3.069829058366e-03 true resid norm 4.195014946846e+11 ||r(i)||/||b|| 2.388962515907e+09
502 KSP preconditioned resid norm 2.883500007164e-03 true resid norm 1.789975834398e+11 ||r(i)||/||b|| 1.019349210179e+09
503 KSP preconditioned resid norm 2.412663722535e-03 true resid norm 1.641891705673e+11 ||r(i)||/||b|| 9.350187757928e+08
504 KSP preconditioned resid norm 2.352077771113e-03 true resid norm 2.578756112588e+11 ||r(i)||/||b|| 1.468541058542e+09
505 KSP preconditioned resid norm 2.349699627521e-03 true resid norm 2.420151436910e+11 ||r(i)||/||b|| 1.378219419681e+09
506 KSP preconditioned resid norm 2.253261082551e-03 true resid norm 1.477198125861e+11 ||r(i)||/||b|| 8.412296489915e+08
507 KSP preconditioned resid norm 2.117496752659e-03 true resid norm 2.502313428203e+10 ||r(i)||/||b|| 1.425008744611e+08
508 KSP preconditioned resid norm 2.020618048397e-03 true resid norm 6.554994550831e+10 ||r(i)||/||b|| 3.732915489534e+08
509 KSP preconditioned resid norm 1.992845917187e-03 true resid norm 9.910197077001e+10 ||r(i)||/||b|| 5.643624550136e+08
510 KSP preconditioned resid norm 1.962007082941e-03 true resid norm 8.209270536124e+10 ||r(i)||/||b|| 4.674986821795e+08
511 KSP preconditioned resid norm 1.961075306017e-03 true resid norm 8.239042222491e+10 ||r(i)||/||b|| 4.691941098161e+08
512 KSP preconditioned resid norm 1.956798179749e-03 true resid norm 8.497102060464e+10 ||r(i)||/||b|| 4.838900116803e+08
513 KSP preconditioned resid norm 1.956585953911e-03 true resid norm 8.663197416314e+10 ||r(i)||/||b|| 4.933487522145e+08
514 KSP preconditioned resid norm 1.911127535137e-03 true resid norm 5.254354959573e+10 ||r(i)||/||b|| 2.992231780516e+08
515 KSP preconditioned resid norm 1.825050318119e-03 true resid norm 1.205423016569e+10 ||r(i)||/||b|| 6.864601053593e+07
516 KSP preconditioned resid norm 1.702727067567e-03 true resid norm 8.691898767780e+10 ||r(i)||/||b|| 4.949832267915e+08
517 KSP preconditioned resid norm 1.575077603748e-03 true resid norm 1.678911784643e+11 ||r(i)||/||b|| 9.561008415579e+08
518 KSP preconditioned resid norm 1.553332075472e-03 true resid norm 1.915078454545e+11 ||r(i)||/||b|| 1.090592215022e+09
519 KSP preconditioned resid norm 1.552121970944e-03 true resid norm 1.846348983938e+11 ||r(i)||/||b|| 1.051452395236e+09
520 KSP preconditioned resid norm 1.518013706982e-03 true resid norm 1.426334653778e+11 ||r(i)||/||b|| 8.122640958829e+08
521 KSP preconditioned resid norm 1.410696251789e-03 true resid norm 2.885210286931e+10 ||r(i)||/||b|| 1.643059515478e+08
522 KSP preconditioned resid norm 1.267570105467e-03 true resid norm 1.187734543987e+11 ||r(i)||/||b|| 6.763869355376e+08
523 KSP preconditioned resid norm 1.227286861495e-03 true resid norm 1.525664114203e+11 ||r(i)||/||b|| 8.688298914012e+08
524 KSP preconditioned resid norm 1.217056207751e-03 true resid norm 1.718144113257e+11 ||r(i)||/||b|| 9.784427315529e+08
525 KSP preconditioned resid norm 1.186114694759e-03 true resid norm 1.373831599556e+11 ||r(i)||/||b|| 7.823648392420e+08
526 KSP preconditioned resid norm 1.115137377131e-03 true resid norm 7.634117128305e+10 ||r(i)||/||b|| 4.347450460284e+08
527 KSP preconditioned resid norm 1.036168964439e-03 true resid norm 2.813784237214e+10 ||r(i)||/||b|| 1.602384057203e+08
528 KSP preconditioned resid norm 1.008529357209e-03 true resid norm 9.431002050913e+09 ||r(i)||/||b|| 5.370734233977e+07
529 KSP preconditioned resid norm 1.002545899539e-03 true resid norm 1.580928344462e+10 ||r(i)||/||b|| 9.003015729646e+07
530 KSP preconditioned resid norm 1.001044030393e-03 true resid norm 1.102846358442e+10 ||r(i)||/||b|| 6.280451069913e+07
531 KSP preconditioned resid norm 9.852021598370e-04 true resid norm 4.195448622877e+10 ||r(i)||/||b|| 2.389209484224e+08
532 KSP preconditioned resid norm 9.691131299573e-04 true resid norm 7.663773271522e+10 ||r(i)||/||b|| 4.364338937538e+08
533 KSP preconditioned resid norm 9.562269910907e-04 true resid norm 1.076463013683e+11 ||r(i)||/||b|| 6.130204116154e+08
534 KSP preconditioned resid norm 9.545583556159e-04 true resid norm 1.135933278122e+11 ||r(i)||/||b|| 6.468873308892e+08
535 KSP preconditioned resid norm 9.470351105911e-04 true resid norm 9.687360218422e+10 ||r(i)||/||b|| 5.516724191245e+08
536 KSP preconditioned resid norm 9.174176771380e-04 true resid norm 6.066146213665e+10 ||r(i)||/||b|| 3.454527839371e+08
537 KSP preconditioned resid norm 8.636721736575e-04 true resid norm 1.993342436665e+10 ||r(i)||/||b|| 1.135161715249e+08
538 KSP preconditioned resid norm 8.192013866524e-04 true resid norm 1.450978609755e+10 ||r(i)||/||b|| 8.262982501873e+07
539 KSP preconditioned resid norm 8.061723688304e-04 true resid norm 3.106291289771e+10 ||r(i)||/||b|| 1.768959955752e+08
540 KSP preconditioned resid norm 8.061240703341e-04 true resid norm 3.052293614382e+10 ||r(i)||/||b|| 1.738209547449e+08
541 KSP preconditioned resid norm 8.061159019417e-04 true resid norm 3.058586668252e+10 ||r(i)||/||b|| 1.741793293872e+08
542 KSP preconditioned resid norm 8.055832977323e-04 true resid norm 2.940404373948e+10 ||r(i)||/||b|| 1.674491252111e+08
543 KSP preconditioned resid norm 8.011598611197e-04 true resid norm 2.471293892149e+10 ||r(i)||/||b|| 1.407343847147e+08
544 KSP preconditioned resid norm 7.921014666310e-04 true resid norm 1.837280168337e+10 ||r(i)||/||b|| 1.046287917681e+08
545 KSP preconditioned resid norm 7.833595745957e-04 true resid norm 1.321607741808e+10 ||r(i)||/||b|| 7.526245784384e+07
546 KSP preconditioned resid norm 7.773918326701e-04 true resid norm 1.030955860607e+10 ||r(i)||/||b|| 5.871051564180e+07
547 KSP preconditioned resid norm 7.745620001638e-04 true resid norm 9.112905031628e+09 ||r(i)||/||b|| 5.189585450213e+07
548 KSP preconditioned resid norm 7.740136037520e-04 true resid norm 8.419501078298e+09 ||r(i)||/||b|| 4.794708179482e+07
549 KSP preconditioned resid norm 7.722928268624e-04 true resid norm 1.049955839169e+10 ||r(i)||/||b|| 5.979251981015e+07
550 KSP preconditioned resid norm 7.664750762967e-04 true resid norm 1.858263223266e+10 ||r(i)||/||b|| 1.058237274794e+08
551 KSP preconditioned resid norm 7.563299862673e-04 true resid norm 3.297697455153e+10 ||r(i)||/||b|| 1.877961272840e+08
552 KSP preconditioned resid norm 7.543705761967e-04 true resid norm 3.822881948391e+10 ||r(i)||/||b|| 2.177041510736e+08
553 KSP preconditioned resid norm 7.542158399799e-04 true resid norm 4.001213009543e+10 ||r(i)||/||b|| 2.278596862961e+08
554 KSP preconditioned resid norm 7.521293265612e-04 true resid norm 3.403626346312e+10 ||r(i)||/||b|| 1.938285289211e+08
555 KSP preconditioned resid norm 7.416950965955e-04 true resid norm 2.488167973246e+10 ||r(i)||/||b|| 1.416953240139e+08
556 KSP preconditioned resid norm 7.054460671726e-04 true resid norm 1.069038545685e+10 ||r(i)||/||b|| 6.087923514128e+07
557 KSP preconditioned resid norm 6.723596233551e-04 true resid norm 4.826313315080e+10 ||r(i)||/||b|| 2.748472114126e+08
558 KSP preconditioned resid norm 6.659385082178e-04 true resid norm 5.999069197269e+10 ||r(i)||/||b|| 3.416329053460e+08
559 KSP preconditioned resid norm 6.658202350976e-04 true resid norm 6.156816562653e+10 ||r(i)||/||b|| 3.506162474237e+08
560 KSP preconditioned resid norm 6.547040506518e-04 true resid norm 4.666674715963e+10 ||r(i)||/||b|| 2.657561680144e+08
561 KSP preconditioned resid norm 5.844352666647e-04 true resid norm 5.248501827612e+09 ||r(i)||/||b|| 2.988898559292e+07
562 KSP preconditioned resid norm 5.077133854698e-04 true resid norm 4.911855677739e+10 ||r(i)||/||b|| 2.797186481179e+08
563 KSP preconditioned resid norm 4.920929576139e-04 true resid norm 6.479587544472e+10 ||r(i)||/||b|| 3.689972969922e+08
564 KSP preconditioned resid norm 4.918835649437e-04 true resid norm 6.729439671602e+10 ||r(i)||/||b|| 3.832257889951e+08
565 KSP preconditioned resid norm 4.703399310010e-04 true resid norm 3.485904866337e+10 ||r(i)||/||b|| 1.985140974517e+08
566 KSP preconditioned resid norm 4.474811061246e-04 true resid norm 3.541098025014e+09 ||r(i)||/||b|| 2.016572182483e+07
567 KSP preconditioned resid norm 4.230407891772e-04 true resid norm 3.192300153359e+10 ||r(i)||/||b|| 1.817939984131e+08
568 KSP preconditioned resid norm 4.218651971064e-04 true resid norm 3.754767103675e+10 ||r(i)||/||b|| 2.138251705964e+08
569 KSP preconditioned resid norm 4.165861285478e-04 true resid norm 2.702192475393e+10 ||r(i)||/||b|| 1.538835168950e+08
570 KSP preconditioned resid norm 3.988746281883e-04 true resid norm 1.564881336083e+10 ||r(i)||/||b|| 8.911631784665e+07
571 KSP preconditioned resid norm 3.979325947012e-04 true resid norm 1.580464073361e+10 ||r(i)||/||b|| 9.000371814734e+07
572 KSP preconditioned resid norm 3.918646655240e-04 true resid norm 1.724849279013e+10 ||r(i)||/||b|| 9.822611660180e+07
573 KSP preconditioned resid norm 3.813318868871e-04 true resid norm 2.183096822238e+10 ||r(i)||/||b|| 1.243222382520e+08
574 KSP preconditioned resid norm 3.812199206269e-04 true resid norm 2.117350124532e+10 ||r(i)||/||b|| 1.205781181867e+08
575 KSP preconditioned resid norm 3.775534780325e-04 true resid norm 1.545759995873e+10 ||r(i)||/||b|| 8.802740241740e+07
576 KSP preconditioned resid norm 3.663265117637e-04 true resid norm 2.709812573731e+09 ||r(i)||/||b|| 1.543174636039e+07
577 KSP preconditioned resid norm 3.469600788306e-04 true resid norm 2.104442127151e+10 ||r(i)||/||b|| 1.198430380430e+08
578 KSP preconditioned resid norm 3.218221400959e-04 true resid norm 4.827651986055e+10 ||r(i)||/||b|| 2.749234455815e+08
579 KSP preconditioned resid norm 3.159142633650e-04 true resid norm 5.947894664883e+10 ||r(i)||/||b|| 3.387186358812e+08
580 KSP preconditioned resid norm 3.158757784362e-04 true resid norm 5.853711398982e+10 ||r(i)||/||b|| 3.333551200245e+08
581 KSP preconditioned resid norm 3.039420517331e-04 true resid norm 4.030471897495e+10 ||r(i)||/||b|| 2.295259112669e+08
582 KSP preconditioned resid norm 2.757600327684e-04 true resid norm 4.482197601150e+09 ||r(i)||/||b|| 2.552506294665e+07
583 KSP preconditioned resid norm 2.596438684754e-04 true resid norm 1.172878967238e+10 ||r(i)||/||b|| 6.679270333789e+07
584 KSP preconditioned resid norm 2.528824194106e-04 true resid norm 2.182545628648e+10 ||r(i)||/||b|| 1.242908490712e+08
585 KSP preconditioned resid norm 2.509394596484e-04 true resid norm 2.387508027483e+10 ||r(i)||/||b|| 1.359629764460e+08
586 KSP preconditioned resid norm 2.507880787449e-04 true resid norm 2.241355174256e+10 ||r(i)||/||b|| 1.276399146124e+08
587 KSP preconditioned resid norm 2.479827266195e-04 true resid norm 1.577647541424e+10 ||r(i)||/||b|| 8.984332326657e+07
588 KSP preconditioned resid norm 2.416639962173e-04 true resid norm 6.931502976215e+09 ||r(i)||/||b|| 3.947328197609e+07
589 KSP preconditioned resid norm 2.397800547684e-04 true resid norm 3.531160199136e+09 ||r(i)||/||b|| 2.010912823980e+07
590 KSP preconditioned resid norm 2.397581300989e-04 true resid norm 3.272823788840e+09 ||r(i)||/||b|| 1.863796303893e+07
591 KSP preconditioned resid norm 2.381927700788e-04 true resid norm 4.322328355329e+09 ||r(i)||/||b|| 2.461464512799e+07
592 KSP preconditioned resid norm 2.295688690620e-04 true resid norm 1.084571125107e+10 ||r(i)||/||b|| 6.176377906981e+07
593 KSP preconditioned resid norm 2.191296967620e-04 true resid norm 1.440682509655e+10 ||r(i)||/||b|| 8.204348629258e+07
594 KSP preconditioned resid norm 2.131890464017e-04 true resid norm 1.802610318890e+10 ||r(i)||/||b|| 1.026544252447e+08
595 KSP preconditioned resid norm 2.128615750391e-04 true resid norm 1.926485527393e+10 ||r(i)||/||b|| 1.097088275178e+08
596 KSP preconditioned resid norm 2.103093424487e-04 true resid norm 1.601158355520e+10 ||r(i)||/||b|| 9.118220892741e+07
597 KSP preconditioned resid norm 2.002703326724e-04 true resid norm 9.011830263785e+09 ||r(i)||/||b|| 5.132025743099e+07
598 KSP preconditioned resid norm 1.812528643223e-04 true resid norm 1.855743689471e+09 ||r(i)||/||b|| 1.056802459455e+07
599 KSP preconditioned resid norm 1.648481554293e-04 true resid norm 1.185373601681e+10 ||r(i)||/||b|| 6.750424343282e+07
600 KSP preconditioned resid norm 1.648277142351e-04 true resid norm 1.174086964094e+10 ||r(i)||/||b|| 6.686149592254e+07
601 KSP preconditioned resid norm 1.648266487826e-04 true resid norm 1.175065536477e+10 ||r(i)||/||b|| 6.691722332212e+07
602 KSP preconditioned resid norm 1.645364378275e-04 true resid norm 1.128883836019e+10 ||r(i)||/||b|| 6.428728391279e+07
603 KSP preconditioned resid norm 1.617283351697e-04 true resid norm 8.666047026016e+09 ||r(i)||/||b|| 4.935110307963e+07
604 KSP preconditioned resid norm 1.563495331577e-04 true resid norm 4.638424448370e+09 ||r(i)||/||b|| 2.641473816047e+07
605 KSP preconditioned resid norm 1.532577905154e-04 true resid norm 2.037953363833e+09 ||r(i)||/||b|| 1.160566590835e+07
606 KSP preconditioned resid norm 1.529790769593e-04 true resid norm 1.685952897620e+09 ||r(i)||/||b|| 9.601105900775e+06
607 KSP preconditioned resid norm 1.528899627964e-04 true resid norm 1.550807594371e+09 ||r(i)||/||b|| 8.831485130041e+06
608 KSP preconditioned resid norm 1.528768842246e-04 true resid norm 1.498982994341e+09 ||r(i)||/||b|| 8.536356200960e+06
609 KSP preconditioned resid norm 1.523478881665e-04 true resid norm 2.726800476436e+09 ||r(i)||/||b|| 1.552848847764e+07
610 KSP preconditioned resid norm 1.505914549230e-04 true resid norm 6.968816215625e+09 ||r(i)||/||b|| 3.968577211361e+07
611 KSP preconditioned resid norm 1.474807681861e-04 true resid norm 1.307410306868e+10 ||r(i)||/||b|| 7.445394725865e+07
612 KSP preconditioned resid norm 1.468510511764e-04 true resid norm 1.567946182273e+10 ||r(i)||/||b|| 8.929085364105e+07
613 KSP preconditioned resid norm 1.468151717479e-04 true resid norm 1.504109300596e+10 ||r(i)||/||b|| 8.565549311459e+07
614 KSP preconditioned resid norm 1.461845224480e-04 true resid norm 1.281876147133e+10 ||r(i)||/||b|| 7.299983681440e+07
615 KSP preconditioned resid norm 1.436626916314e-04 true resid norm 8.812476417186e+09 ||r(i)||/||b|| 5.018498408164e+07
616 KSP preconditioned resid norm 1.384034870969e-04 true resid norm 1.718785095522e+09 ||r(i)||/||b|| 9.788077559032e+06
617 KSP preconditioned resid norm 1.324630273582e-04 true resid norm 9.086766624892e+09 ||r(i)||/||b|| 5.174700241291e+07
618 KSP preconditioned resid norm 1.296278937868e-04 true resid norm 1.379006862770e+10 ||r(i)||/||b|| 7.853120301305e+07
619 KSP preconditioned resid norm 1.295296207841e-04 true resid norm 1.451894315250e+10 ||r(i)||/||b|| 8.268197229661e+07
620 KSP preconditioned resid norm 1.261318135745e-04 true resid norm 1.061166004551e+10 ||r(i)||/||b|| 6.043091240788e+07
621 KSP preconditioned resid norm 1.159951195720e-04 true resid norm 4.640385578344e+09 ||r(i)||/||b|| 2.642590633522e+07
622 KSP preconditioned resid norm 1.019086335187e-04 true resid norm 5.487423615005e+09 ||r(i)||/||b|| 3.124958907478e+07
623 KSP preconditioned resid norm 9.684434695139e-05 true resid norm 9.319082628344e+09 ||r(i)||/||b|| 5.306998750623e+07
624 KSP preconditioned resid norm 9.654335078091e-05 true resid norm 1.026751692044e+10 ||r(i)||/||b|| 5.847109811327e+07
625 KSP preconditioned resid norm 9.586472328416e-05 true resid norm 8.659828448981e+09 ||r(i)||/||b|| 4.931568974350e+07
626 KSP preconditioned resid norm 9.282628606304e-05 true resid norm 4.798713692328e+09 ||r(i)||/||b|| 2.732754776991e+07
KSP Object: 4 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 1, factorization LOWER
    Preconditioner for the Schur complement formed from S itself
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       4 MPI processes
        type: preonly
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_0_)       4 MPI processes
        type: gamg
          MG: type is MULTIPLICATIVE, levels=3 cycles=v
            Cycles per PCApply=1
            Using Galerkin computed coarse grid matrices
        Coarse grid solver -- level -------------------------------
          KSP Object:          (fieldsplit_0_mg_coarse_)           4 MPI processes
            type: preonly
            maximum iterations=1, initial guess is zero
          PC Object:          (fieldsplit_0_mg_coarse_)           4 MPI processes
            type: bjacobi
              block Jacobi: number of blocks = 4
              Local solve is same for all blocks, in the following KSP and PC objects:
            KSP Object:            (fieldsplit_0_mg_coarse_sub_)             1 MPI processes
              type: preonly
            PC Object:            (fieldsplit_0_mg_coarse_sub_)             1 MPI processes
              type: lu
                LU: out-of-place factorization
                tolerance for zero pivot 2.22045e-14
                using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                matrix ordering: nd
                factor fill ratio given 5, needed 1.01207
                  Factored matrix follows:
                    Mat Object:                     1 MPI processes
                      type: seqaij
                      rows=23, cols=23
                      package used to perform factorization: petsc
                      total: nonzeros=503, allocated nonzeros=503
                      total number of mallocs used during MatSetValues calls =0
                        using I-node routines: found 15 nodes, limit used is 5
              linear system matrix = precond matrix:
                type: seqaij
                rows=23, cols=23
                total: nonzeros=497, allocated nonzeros=497
                  using I-node routines: found 18 nodes, limit used is 5
            Mat Object:             4 MPI processes
              type: mpiaij
              rows=23, cols=23
                using I-node (on process 0) routines: found 18 nodes, limit used is 5
        Down solver (pre-smoother) on level 1 -------------------------------
          KSP Object:          (fieldsplit_0_mg_levels_1_)           4 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.0821344, max = 1.72482
            maximum iterations=2
            using nonzero initial guess
          PC Object:          (fieldsplit_0_mg_levels_1_)           4 MPI processes
            type: sor
              SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
              type: mpiaij
              rows=1019, cols=1019
              total: nonzeros=34719, allocated nonzeros=34719
                not using I-node (on process 0) routines
        Up solver (post-smoother) same as down solver (pre-smoother)
        Down solver (pre-smoother) on level 2 -------------------------------
          KSP Object:          (fieldsplit_0_mg_levels_2_)           4 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.156902, max = 3.29495
          PC Object:          (fieldsplit_0_mg_levels_2_)           4 MPI processes
            type: sor
            Mat Object:            (fieldsplit_0_)             4 MPI processes
              type: mpiaij
              rows=71946, cols=71946
              total: nonzeros=2.96023e+06, allocated nonzeros=2.96023e+06
                using I-node (on process 0) routines: found 6259 nodes, limit used is 5
          type: mpiaij
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       4 MPI processes
        type: preonly
      PC Object:      (fieldsplit_1_)       4 MPI processes
        type: lsc
          KSP Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: preonly
          PC Object:          (fieldsplit_1_lsc_)           4 MPI processes
            type: bjacobi
            KSP Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: preonly
            PC Object:            (fieldsplit_1_lsc_sub_)             1 MPI processes
              type: ilu
                ILU: out-of-place factorization
                0 levels of fill
                matrix ordering: natural
                factor fill ratio given 1, needed 1
                      type: seqaij
                      rows=0, cols=0
                      total: nonzeros=0, allocated nonzeros=0
                        not using I-node routines
                type: seqaij
                rows=0, cols=0
              type: mpiaij
              rows=3183, cols=3183
              total: nonzeros=9549, allocated nonzeros=9549
        Mat Object:        (fieldsplit_1_)         4 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
                total: nonzeros=3183, allocated nonzeros=3183
            A10
                type: mpiaij
                rows=3183, cols=71946
                total: nonzeros=19098, allocated nonzeros=19098
            KSP of A00
                type: preonly
                type: gamg
                    type: preonly
                    type: bjacobi
                      type: preonly
                      type: lu
                        matrix ordering: nd
                              type: seqaij
                              rows=23, cols=23
                        type: seqaij
                        rows=23, cols=23
                      type: mpiaij
                      rows=23, cols=23
                    type: chebyshev
                    type: sor
                      type: mpiaij
                    type: chebyshev
                    type: sor
                      type: mpiaij
                  type: mpiaij
            A01
                type: mpiaij
                rows=71946, cols=3183
                  using I-node (on process 0) routines: found 3757 nodes, limit used is 5
    type: mpiaij
    rows=75129, cols=75129
    total: nonzeros=3.0016e+06, allocated nonzeros=1.26217e+07
 Recovering stress ...
 Cleaning up ...
 Finished
0.01user 0.02system 0:16.80elapsed 0%CPU (0avgtext+0avgdata 17056maxresident)k
904inputs+0outputs (3major+1806minor)pagefaults 0swaps
salloc: Relinquishing job allocation 79008
salloc: Granted job allocation 79007
 Reading input ...
 Partitioning mesh ...
 Reading mesh data ...
 Forming [K] ...
 Applying constraints ...
 Forming RHS ...
 Setting up solver ...
 Solving ...
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 0.000000000000e+00
  0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm 1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
    0 KSP Residual norm 1.458554290527e-03
    1 KSP Residual norm 2.443523132385e-04
    2 KSP Residual norm 1.526975625938e-04
    3 KSP Residual norm 2.014215872825e-04
    4 KSP Residual norm 1.476966271575e-04
    5 KSP Residual norm 9.122757243249e-05
    6 KSP Residual norm 1.047856181139e-04
    7 KSP Residual norm 1.147488524595e-04
    8 KSP Residual norm 1.045417032000e-04
    9 KSP Residual norm 1.079705732917e-04
   10 KSP Residual norm 8.497852252670e-05
   11 KSP Residual norm 6.831445728983e-05
   12 KSP Residual norm 6.954068462504e-05
   13 KSP Residual norm 6.093026980090e-05
   14 KSP Residual norm 5.221858684731e-05
   15 KSP Residual norm 4.677505495486e-05
   16 KSP Residual norm 4.144856671247e-05
   17 KSP Residual norm 3.542015548564e-05
   18 KSP Residual norm 3.077721287010e-05
   19 KSP Residual norm 2.900753681509e-05
   20 KSP Residual norm 2.876772232961e-05
   21 KSP Residual norm 2.782865244825e-05
   22 KSP Residual norm 2.536365456623e-05
   23 KSP Residual norm 2.243212162085e-05
   24 KSP Residual norm 1.967158760290e-05
   25 KSP Residual norm 1.680895651382e-05
   26 KSP Residual norm 1.356166055062e-05
   27 KSP Residual norm 1.054810017706e-05
   28 KSP Residual norm 8.465627851240e-06
   29 KSP Residual norm 6.516458160634e-06
   30 KSP Residual norm 5.852661265719e-06
   31 KSP Residual norm 5.778044905151e-06
   32 KSP Residual norm 5.526592479324e-06
   33 KSP Residual norm 5.377995774695e-06
   34 KSP Residual norm 4.766413673254e-06
   35 KSP Residual norm 3.725169370300e-06
   36 KSP Residual norm 2.858872754067e-06
   37 KSP Residual norm 2.429697062121e-06
   38 KSP Residual norm 2.147367585432e-06
   39 KSP Residual norm 2.001025086617e-06
   40 KSP Residual norm 1.863348682851e-06
   41 KSP Residual norm 1.740846296551e-06
   42 KSP Residual norm 1.607907436767e-06
   43 KSP Residual norm 1.360087402410e-06
   44 KSP Residual norm 1.229680860159e-06
   45 KSP Residual norm 1.107487969698e-06
   46 KSP Residual norm 9.858758145950e-07
   47 KSP Residual norm 8.476936047597e-07
   48 KSP Residual norm 7.205399850111e-07
   49 KSP Residual norm 6.287921992929e-07
   50 KSP Residual norm 4.887400516822e-07
   51 KSP Residual norm 3.786489336871e-07
   52 KSP Residual norm 3.250515666351e-07
   53 KSP Residual norm 2.935685470083e-07
   54 KSP Residual norm 2.683763781902e-07
   55 KSP Residual norm 2.520124366175e-07
   56 KSP Residual norm 2.081511612269e-07
   57 KSP Residual norm 1.926821572998e-07
   58 KSP Residual norm 1.739477707764e-07
   59 KSP Residual norm 1.527781085294e-07
   60 KSP Residual norm 1.386486593697e-07
   61 KSP Residual norm 1.380585309557e-07
   62 KSP Residual norm 1.241062083013e-07
   63 KSP Residual norm 1.075235601659e-07
   64 KSP Residual norm 1.022859259930e-07
   65 KSP Residual norm 9.416544583143e-08
   66 KSP Residual norm 7.443131271013e-08
   67 KSP Residual norm 5.726970118462e-08
   68 KSP Residual norm 4.763134320298e-08
   69 KSP Residual norm 3.795994540583e-08
   70 KSP Residual norm 3.095116957380e-08
   71 KSP Residual norm 2.504320617006e-08
   72 KSP Residual norm 2.197758476947e-08
   73 KSP Residual norm 1.949130087394e-08
   74 KSP Residual norm 1.447911930994e-08
  1 KSP preconditioned resid norm 9.127511072040e+05 true resid norm 1.362119811364e+14 ||r(i)||/||b|| 7.756952508524e+11
    0 KSP Residual norm 2.118159765853e-03
    1 KSP Residual norm 6.335215968361e-04
    2 KSP Residual norm 1.003527880099e-03
    3 KSP Residual norm 2.425186737584e-03
    4 KSP Residual norm 1.545924874557e-03
    5 KSP Residual norm 1.135719649755e-03
    6 KSP Residual norm 1.122356230013e-03
    7 KSP Residual norm 7.845893770358e-04
    8 KSP Residual norm 5.530803114162e-04
    9 KSP Residual norm 5.458296360672e-04
   10 KSP Residual norm 3.887287897385e-04
   11 KSP Residual norm 3.684623158531e-04
   12 KSP Residual norm 3.395071253152e-04
   13 KSP Residual norm 2.772093983820e-04
   14 KSP Residual norm 2.501947745913e-04
   15 KSP Residual norm 2.218579795335e-04
   16 KSP Residual norm 2.181304610977e-04
   17 KSP Residual norm 1.935956621137e-04
   18 KSP Residual norm 1.715388915405e-04
   19 KSP Residual norm 1.522412948980e-04
   20 KSP Residual norm 1.277575863633e-04
   21 KSP Residual norm 1.056621401075e-04
   22 KSP Residual norm 7.498521323183e-05
   23 KSP Residual norm 6.062531233758e-05
   24 KSP Residual norm 5.479547449311e-05
   25 KSP Residual norm 4.885757554560e-05
   26 KSP Residual norm 4.029801003083e-05
   27 KSP Residual norm 3.591733350388e-05
   28 KSP Residual norm 3.337761887714e-05
   29 KSP Residual norm 3.198393580179e-05
   30 KSP Residual norm 3.069961534982e-05
   31 KSP Residual norm 2.955390544445e-05
   32 KSP Residual norm 2.598688701551e-05
   33 KSP Residual norm 2.203998557497e-05
   34 KSP Residual norm 1.870530768035e-05
   35 KSP Residual norm 1.516729851782e-05
   36 KSP Residual norm 1.328472104150e-05
   37 KSP Residual norm 1.112484772139e-05
   38 KSP Residual norm 9.348277197652e-06
   39 KSP Residual norm 8.081145286199e-06
   40 KSP Residual norm 7.348530292858e-06
   41 KSP Residual norm 7.157909756123e-06
   42 KSP Residual norm 6.806355468615e-06
   43 KSP Residual norm 6.072841029014e-06
   44 KSP Residual norm 5.173333653906e-06
   45 KSP Residual norm 3.812675096393e-06
   46 KSP Residual norm 2.975956719089e-06
   47 KSP Residual norm 2.377042720804e-06
   48 KSP Residual norm 2.153333750758e-06
   49 KSP Residual norm 1.993041019384e-06
   50 KSP Residual norm 2.082172224275e-06
   51 KSP Residual norm 2.145205085477e-06
   52 KSP Residual norm 1.831483680779e-06
   53 KSP Residual norm 1.460931622910e-06
   54 KSP Residual norm 1.261318452725e-06
   55 KSP Residual norm 1.159293828002e-06
   56 KSP Residual norm 9.154894198031e-07
   57 KSP Residual norm 7.611453343045e-07
   58 KSP Residual norm 6.786785453445e-07
   59 KSP Residual norm 6.625510979426e-07
   60 KSP Residual norm 5.976351205378e-07
   61 KSP Residual norm 4.781690371194e-07
   62 KSP Residual norm 3.938124531241e-07
   63 KSP Residual norm 2.955258894181e-07
   64 KSP Residual norm 2.188814810276e-07
   65 KSP Residual norm 1.629996919271e-07
   66 KSP Residual norm 1.298294484605e-07
   67 KSP Residual norm 1.003724704125e-07
   68 KSP Residual norm 7.619728392688e-08
   69 KSP Residual norm 5.935877330937e-08
   70 KSP Residual norm 5.251359439852e-08
   71 KSP Residual norm 4.697585582364e-08
   72 KSP Residual norm 4.087074088091e-08
   73 KSP Residual norm 3.256494389770e-08
   74 KSP Residual norm 2.438036988038e-08
   75 KSP Residual norm 2.016970749018e-08
  2 KSP preconditioned resid norm 8.626934097311e+05 true resid norm 7.140669210036e+14 ||r(i)||/||b|| 4.066443456678e+12
    0 KSP Residual norm 2.121634416290e-03
    1 KSP Residual norm 5.832590584079e-04
    2 KSP Residual norm 8.933603398054e-04
    3 KSP Residual norm 2.014663205673e-03
    4 KSP Residual norm 1.165196521648e-03
    5 KSP Residual norm 9.626894660113e-04
    6 KSP Residual norm 9.220499099680e-04
    7 KSP Residual norm 7.532447592303e-04
    8 KSP Residual norm 5.781332011526e-04
    9 KSP Residual norm 5.373510027896e-04
   10 KSP Residual norm 4.083768312978e-04
   11 KSP Residual norm 3.895941176461e-04
   12 KSP Residual norm 3.680749227535e-04
   13 KSP Residual norm 3.243100026463e-04
   14 KSP Residual norm 3.191216677156e-04
   15 KSP Residual norm 2.816828178821e-04
   16 KSP Residual norm 2.684434998550e-04
   17 KSP Residual norm 2.492988047891e-04
   18 KSP Residual norm 1.946006691240e-04
   19 KSP Residual norm 1.577535528055e-04
   20 KSP Residual norm 1.197098848127e-04
   21 KSP Residual norm 9.833084120150e-05
   22 KSP Residual norm 7.714351102884e-05
   23 KSP Residual norm 6.471381928356e-05
   24 KSP Residual norm 5.764240452275e-05
   25 KSP Residual norm 4.766450480650e-05
   26 KSP Residual norm 3.967647015185e-05
   27 KSP Residual norm 3.601749096709e-05
   28 KSP Residual norm 3.135071159310e-05
   29 KSP Residual norm 2.743607943832e-05
   30 KSP Residual norm 2.333891385128e-05
   31 KSP Residual norm 2.065291384346e-05
   32 KSP Residual norm 1.632157339076e-05
   33 KSP Residual norm 1.385904616531e-05
   34 KSP Residual norm 1.216123385251e-05
   35 KSP Residual norm 1.119791939626e-05
   36 KSP Residual norm 1.018093123240e-05
   37 KSP Residual norm 8.436740028435e-06
   38 KSP Residual norm 7.318549276463e-06
   39 KSP Residual norm 6.247323885315e-06
   40 KSP Residual norm 5.755644460560e-06
   41 KSP Residual norm 5.524921970483e-06
   42 KSP Residual norm 5.476592921821e-06
   43 KSP Residual norm 5.345262846172e-06
   44 KSP Residual norm 4.383201474491e-06
   45 KSP Residual norm 3.058930013757e-06
   46 KSP Residual norm 2.326928382096e-06
   47 KSP Residual norm 1.833177617474e-06
   48 KSP Residual norm 1.486141936302e-06
   49 KSP Residual norm 1.268775280871e-06
   50 KSP Residual norm 1.014764686856e-06
   51 KSP Residual norm 8.712527430261e-07
   52 KSP Residual norm 7.448330261622e-07
   53 KSP Residual norm 6.331415929439e-07
   54 KSP Residual norm 5.667390248714e-07
   55 KSP Residual norm 5.222098846876e-07
   56 KSP Residual norm 4.269429224062e-07
   57 KSP Residual norm 3.988402738064e-07
   58 KSP Residual norm 3.986042871115e-07
   59 KSP Residual norm 3.766809542061e-07
   60 KSP Residual norm 3.631236153372e-07
   61 KSP Residual norm 3.423133948992e-07
   62 KSP Residual norm 3.054262356047e-07
   63 KSP Residual norm 2.504194459945e-07
   64 KSP Residual norm 1.904813285389e-07
   65 KSP Residual norm 1.588771497818e-07
   66 KSP Residual norm 1.453420252582e-07
   67 KSP Residual norm 1.217809505240e-07
   68 KSP Residual norm 1.009800586139e-07
   69 KSP Residual norm 9.254027255920e-08
   70 KSP Residual norm 8.562839467242e-08
   71 KSP Residual norm 7.073129996800e-08
   72 KSP Residual norm 5.324506678657e-08
   73 KSP Residual norm 4.342118023774e-08
   74 KSP Residual norm 3.584371992560e-08
   75 KSP Residual norm 3.149002455231e-08
   76 KSP Residual norm 2.765584156115e-08
   77 KSP Residual norm 2.203726144736e-08
   78 KSP Residual norm 1.724483256904e-08
  3 KSP preconditioned resid norm 6.917411796180e+05 true resid norm 2.788569211433e+15 ||r(i)||/||b|| 1.588024692053e+13
    0 KSP Residual norm 1.112183529852e-03
    1 KSP Residual norm 5.455688303432e-04
    2 KSP Residual norm 8.453301842306e-04
    3 KSP Residual norm 1.072687137328e-03
    4 KSP Residual norm 7.111872271491e-04
    5 KSP Residual norm 7.872689524016e-04
    6 KSP Residual norm 6.182681208124e-04
    7 KSP Residual norm 6.176186968745e-04
    8 KSP Residual norm 5.146246114208e-04
    9 KSP Residual norm 4.461815584742e-04
   10 KSP Residual norm 3.755214099804e-04
   11 KSP Residual norm 3.030289038255e-04
   12 KSP Residual norm 2.521097757210e-04
   13 KSP Residual norm 2.043666764161e-04
   14 KSP Residual norm 1.789058586696e-04
   15 KSP Residual norm 1.658756267215e-04
   16 KSP Residual norm 1.448707635576e-04
   17 KSP Residual norm 1.263635532211e-04
   18 KSP Residual norm 1.175427664014e-04
   19 KSP Residual norm 1.068846873611e-04
   20 KSP Residual norm 1.016024893865e-04
   21 KSP Residual norm 8.769970709747e-05
   22 KSP Residual norm 7.471728877888e-05
   23 KSP Residual norm 6.986780473420e-05
   24 KSP Residual norm 6.238626893677e-05
   25 KSP Residual norm 5.363693929622e-05
   26 KSP Residual norm 4.611227663271e-05
   27 KSP Residual norm 4.196926220422e-05
   28 KSP Residual norm 4.116254475716e-05
   29 KSP Residual norm 4.214702881118e-05
   30 KSP Residual norm 3.736499055738e-05
   31 KSP Residual norm 3.086684423347e-05
   32 KSP Residual norm 2.277655266281e-05
   33 KSP Residual norm 1.897354363037e-05
   34 KSP Residual norm 1.700980333378e-05
   35 KSP Residual norm 1.541184065153e-05
   36 KSP Residual norm 1.392044716605e-05
   37 KSP Residual norm 1.195512207648e-05
   38 KSP Residual norm 9.752529615505e-06
   39 KSP Residual norm 9.242458286882e-06
   40 KSP Residual norm 8.955493048486e-06
   41 KSP Residual norm 8.225498630135e-06
   42 KSP Residual norm 7.928867871685e-06
   43 KSP Residual norm 7.270708896890e-06
   44 KSP Residual norm 5.822540627390e-06
   45 KSP Residual norm 5.078410819163e-06
   46 KSP Residual norm 4.625181589827e-06
   47 KSP Residual norm 3.837005260832e-06
   48 KSP Residual norm 3.300458858425e-06
   49 KSP Residual norm 3.151686106849e-06
   50 KSP Residual norm 3.235837806350e-06
   51 KSP Residual norm 2.919310420550e-06
   52 KSP Residual norm 2.410548522036e-06
   53 KSP Residual norm 1.911164510170e-06
   54 KSP Residual norm 1.539027190792e-06
   55 KSP Residual norm 1.462542934336e-06
   56 KSP Residual norm 1.437185862915e-06
   57 KSP Residual norm 1.444828984891e-06
   58 KSP Residual norm 1.156933380849e-06
   59 KSP Residual norm 1.037462808644e-06
   60 KSP Residual norm 8.517004248871e-07
   61 KSP Residual norm 6.178096950995e-07
   62 KSP Residual norm 5.428127074882e-07
   63 KSP Residual norm 5.092075166993e-07
   64 KSP Residual norm 4.303559611141e-07
   65 KSP Residual norm 3.182951762614e-07
   66 KSP Residual norm 2.410774738927e-07
   67 KSP Residual norm 1.827720465310e-07
   68 KSP Residual norm 1.470587842470e-07
   69 KSP Residual norm 1.214345122157e-07
   70 KSP Residual norm 9.937590548964e-08
   71 KSP Residual norm 7.966377026472e-08
   72 KSP Residual norm 6.203672035646e-08
   73 KSP Residual norm 5.685137232389e-08
   74 KSP Residual norm 4.932632522158e-08
   75 KSP Residual norm 3.973551506940e-08
   76 KSP Residual norm 3.343764268923e-08
   77 KSP Residual norm 2.808344449328e-08
   78 KSP Residual norm 2.370724255012e-08
   79 KSP Residual norm 1.979003937285e-08
   80 KSP Residual norm 1.568358754511e-08
   81 KSP Residual norm 1.319722769947e-08
   82 KSP Residual norm 1.135448200817e-08
   83 KSP Residual norm 9.108819584852e-09
  4 KSP preconditioned resid norm 5.948195614265e+05 true resid norm 3.828393420795e+15 ||r(i)||/||b|| 2.180180164865e+13
    0 KSP Residual norm 2.366134666029e-03
    1 KSP Residual norm 6.190808191358e-04
    2 KSP Residual norm 9.027995442355e-04
    3 KSP Residual norm 1.887849221230e-03
    4 KSP Residual norm 1.339477414022e-03
    5 KSP Residual norm 1.150633711807e-03
    6 KSP Residual norm 9.400210086583e-04
    7 KSP Residual norm 8.457671922067e-04
    8 KSP Residual norm 6.363782000781e-04
    9 KSP Residual norm 5.502091992996e-04
   10 KSP Residual norm 4.164886285662e-04
   11 KSP Residual norm 3.417283869063e-04
   12 KSP Residual norm 2.638604858957e-04
   13 KSP Residual norm 2.045911104075e-04
   14 KSP Residual norm 2.027281229106e-04
   15 KSP Residual norm 1.859072831032e-04
   16 KSP Residual norm 1.837118459745e-04
   17 KSP Residual norm 1.708411329875e-04
   18 KSP Residual norm 1.447258634246e-04
   19 KSP Residual norm 1.401489027174e-04
   20 KSP Residual norm 1.154278749177e-04
   21 KSP Residual norm 9.522454071119e-05
   22 KSP Residual norm 8.088954011184e-05
   23 KSP Residual norm 6.707919256941e-05
   24 KSP Residual norm 5.760475943156e-05
   25 KSP Residual norm 5.255878572114e-05
   26 KSP Residual norm 4.645626237734e-05
   27 KSP Residual norm 3.979799793971e-05
   28 KSP Residual norm 3.541020304317e-05
   29 KSP Residual norm 3.284484054434e-05
   30 KSP Residual norm 3.408695693072e-05
   31 KSP Residual norm 3.476264544016e-05
   32 KSP Residual norm 3.191018564080e-05
   33 KSP Residual norm 2.789884934232e-05
   34 KSP Residual norm 2.360312270493e-05
   35 KSP Residual norm 2.224559533273e-05
   36 KSP Residual norm 1.965779470703e-05
   37 KSP Residual norm 1.520750257749e-05
   38 KSP Residual norm 1.190569367477e-05
   39 KSP Residual norm 9.575387075546e-06
   40 KSP Residual norm 8.584494703270e-06
   41 KSP Residual norm 7.975779046071e-06
   42 KSP Residual norm 7.583538058107e-06
   43 KSP Residual norm 7.079686038979e-06
   44 KSP Residual norm 6.461134253262e-06
   45 KSP Residual norm 5.492538180627e-06
   46 KSP Residual norm 4.332693373689e-06
   47 KSP Residual norm 3.288246918674e-06
   48 KSP Residual norm 2.891220636972e-06
   49 KSP Residual norm 2.805230665973e-06
   50 KSP Residual norm 2.529889749263e-06
   51 KSP Residual norm 2.289109317321e-06
   52 KSP Residual norm 2.083997675248e-06
   53 KSP Residual norm 1.678328539832e-06
   54 KSP Residual norm 1.463627970874e-06
   55 KSP Residual norm 1.326615803618e-06
   56 KSP Residual norm 1.183287739943e-06
   57 KSP Residual norm 1.099902486703e-06
   58 KSP Residual norm 9.711017638628e-07
   59 KSP Residual norm 8.717737263683e-07
   60 KSP Residual norm 7.158813669130e-07
   61 KSP Residual norm 5.555211434149e-07
   62 KSP Residual norm 4.364635863369e-07
   63 KSP Residual norm 3.273158469623e-07
   64 KSP Residual norm 2.408346771072e-07
   65 KSP Residual norm 1.791539103301e-07
   66 KSP Residual norm 1.471306759533e-07
   67 KSP Residual norm 1.117364600410e-07
   68 KSP Residual norm 9.605693098442e-08
   69 KSP Residual norm 8.362357228390e-08
   70 KSP Residual norm 6.995263596925e-08
   71 KSP Residual norm 6.244814108441e-08
   72 KSP Residual norm 5.145266972274e-08
   73 KSP Residual norm 4.096018528648e-08
   74 KSP Residual norm 3.211624329837e-08
   75 KSP Residual norm 2.803590960630e-08
   76 KSP Residual norm 2.578079591351e-08
   77 KSP Residual norm 2.191141346209e-08
  5 KSP preconditioned resid norm 5.365287940041e+05 true resid norm 4.508998341363e+15 ||r(i)||/||b|| 2.567768686951e+13
    0 KSP Residual norm 1.488312829038e-03
    1 KSP Residual norm 6.460112936415e-04
    2 KSP Residual norm 1.056712758220e-03
    3 KSP Residual norm 1.745811175619e-03
    4 KSP Residual norm 1.093364613342e-03
    5 KSP Residual norm 9.414266168559e-04
    6 KSP Residual norm 7.787487001053e-04
    7 KSP Residual norm 5.599829545994e-04
    8 KSP Residual norm 4.408760623419e-04
    9 KSP Residual norm 4.446319636040e-04
   10 KSP Residual norm 3.740975490781e-04
   11 KSP Residual norm 3.571189071501e-04
   12 KSP Residual norm 3.260620628953e-04
   13 KSP Residual norm 2.681837780733e-04
   14 KSP Residual norm 2.448807205660e-04
   15 KSP Residual norm 1.960603432773e-04
   16 KSP Residual norm 1.757459789551e-04
   17 KSP Residual norm 1.383133100717e-04
   18 KSP Residual norm 1.084657557844e-04
   19 KSP Residual norm 8.876117375686e-05
   20 KSP Residual norm 7.411090297872e-05
   21 KSP Residual norm 6.177947581896e-05
   22 KSP Residual norm 5.998575104883e-05
   23 KSP Residual norm 6.202820594681e-05
   24 KSP Residual norm 5.799270894202e-05
   25 KSP Residual norm 6.024437873714e-05
   26 KSP Residual norm 5.453680776174e-05
   27 KSP Residual norm 4.400235720632e-05
   28 KSP Residual norm 4.043795686355e-05
   29 KSP Residual norm 3.540341520985e-05
   30 KSP Residual norm 3.006268590824e-05
   31 KSP Residual norm 2.568008761880e-05
   32 KSP Residual norm 2.052479757148e-05
   33 KSP Residual norm 1.968115039631e-05
   34 KSP Residual norm 1.676990886905e-05
   35 KSP Residual norm 1.427190005100e-05
   36 KSP Residual norm 1.223456101213e-05
   37 KSP Residual norm 1.076187951184e-05
   38 KSP Residual norm 9.830057519170e-06
   39 KSP Residual norm 8.863874585165e-06
   40 KSP Residual norm 8.568008042638e-06
   41 KSP Residual norm 7.819005069427e-06
   42 KSP Residual norm 7.463291453451e-06
   43 KSP Residual norm 7.206096105249e-06
   44 KSP Residual norm 6.477872180838e-06
   45 KSP Residual norm 5.514540533508e-06
   46 KSP Residual norm 4.548975927847e-06
   47 KSP Residual norm 4.103764888127e-06
   48 KSP Residual norm 3.871548983945e-06
   49 KSP Residual norm 3.690238177172e-06
   50 KSP Residual norm 3.285270031352e-06
   51 KSP Residual norm 2.885431612205e-06
   52 KSP Residual norm 2.407232211460e-06
   53 KSP Residual norm 2.005443492844e-06
   54 KSP Residual norm 1.613518039061e-06
   55 KSP Residual norm 1.342306029637e-06
   56 KSP Residual norm 1.136987079652e-06
   57 KSP Residual norm 1.036955019472e-06
   58 KSP Residual norm 1.002879761731e-06
   59 KSP Residual norm 9.393157341316e-07
   60 KSP Residual norm 7.523704309410e-07
   61 KSP Residual norm 5.652190214322e-07
   62 KSP Residual norm 4.381366902976e-07
   63 KSP Residual norm 3.515412993628e-07
   64 KSP Residual norm 2.880607395009e-07
   65 KSP Residual norm 2.501032500012e-07
   66 KSP Residual norm 2.188061022144e-07
   67 KSP Residual norm 1.904015122725e-07
   68 KSP Residual norm 1.660059731128e-07
   69 KSP Residual norm 1.439741622467e-07
   70 KSP Residual norm 1.173835837313e-07
   71 KSP Residual norm 1.029374441887e-07
   72 KSP Residual norm 8.879549261250e-08
   73 KSP Residual norm 7.932687645151e-08
   74 KSP Residual norm 7.075714692934e-08
   75 KSP Residual norm 5.873245093168e-08
   76 KSP Residual norm 4.975099776932e-08
   77 KSP Residual norm 3.789187803489e-08
   78 KSP Residual norm 2.841682897460e-08
   79 KSP Residual norm 2.356667833821e-08
   80 KSP Residual norm 2.008965117265e-08
   81 KSP Residual norm 1.667308433084e-08
   82 KSP Residual norm 1.483050619945e-08
  6 KSP preconditioned resid norm 5.020843588217e+05 true resid norm 4.938401705202e+15 ||r(i)||/||b|| 2.812303820536e+13
    0 KSP Residual norm 1.769514873888e-03
    1 KSP Residual norm 7.554255342708e-04
    2 KSP Residual norm 1.202681910651e-03
    3 KSP Residual norm 2.038479102336e-03
    4 KSP Residual norm 1.320280561979e-03
    5 KSP Residual norm 1.002093237465e-03
    6 KSP Residual norm 8.517597405316e-04
    7 KSP Residual norm 6.589603937718e-04
    8 KSP Residual norm 5.229862226745e-04
    9 KSP Residual norm 4.574646622057e-04
   10 KSP Residual norm 3.920956735403e-04
   11 KSP Residual norm 3.337687236588e-04
   12 KSP Residual norm 2.528757959888e-04
   13 KSP Residual norm 1.781583443076e-04
   14 KSP Residual norm 1.617656168152e-04
   15 KSP Residual norm 1.374378055356e-04
   16 KSP Residual norm 1.172504417565e-04
   17 KSP Residual norm 1.018598102463e-04
   18 KSP Residual norm 8.915959904021e-05
   19 KSP Residual norm 9.036094657626e-05
   20 KSP Residual norm 8.386103130714e-05
   21 KSP Residual norm 7.043820218181e-05
   22 KSP Residual norm 6.110769472221e-05
   23 KSP Residual norm 5.197530241963e-05
   24 KSP Residual norm 4.239057154037e-05
   25 KSP Residual norm 3.853336656959e-05
   26 KSP Residual norm 3.783247867377e-05
   27 KSP Residual norm 3.374702046416e-05
   28 KSP Residual norm 2.981912122697e-05
   29 KSP Residual norm 2.852801491964e-05
   30 KSP Residual norm 2.528568531242e-05
   31 KSP Residual norm 1.932794755519e-05
   32 KSP Residual norm 1.572979284664e-05
   33 KSP Residual norm 1.282607648586e-05
   34 KSP Residual norm 1.050688214084e-05
   35 KSP Residual norm 9.721266551595e-06
   36 KSP Residual norm 8.806047021634e-06
   37 KSP Residual norm 7.510563478671e-06
   38 KSP Residual norm 6.315274300959e-06
   39 KSP Residual norm 5.475208261207e-06
   40 KSP Residual norm 4.880013023308e-06
   41 KSP Residual norm 4.027825691436e-06
   42 KSP Residual norm 3.616763004376e-06
   43 KSP Residual norm 3.154009626456e-06
   44 KSP Residual norm 2.735595632597e-06
   45 KSP Residual norm 2.192881534181e-06
   46 KSP Residual norm 1.780721015588e-06
   47 KSP Residual norm 1.473095387198e-06
   48 KSP Residual norm 1.259999717299e-06
   49 KSP Residual norm 1.088330476906e-06
   50 KSP Residual norm 8.847386412245e-07
   51 KSP Residual norm 7.456259219502e-07
   52 KSP Residual norm 6.188172638722e-07
   53 KSP Residual norm 5.080014079749e-07
   54 KSP Residual norm 4.211944223204e-07
   55 KSP Residual norm 3.499397153718e-07
   56 KSP Residual norm 2.978554863615e-07
   57 KSP Residual norm 2.605161821846e-07
   58 KSP Residual norm 2.312101778210e-07
   59 KSP Residual norm 2.183027965109e-07
   60 KSP Residual norm 1.986979980414e-07
   61 KSP Residual norm 1.971501196954e-07
   62 KSP Residual norm 1.997808288405e-07
   63 KSP Residual norm 1.801005728651e-07
   64 KSP Residual norm 1.724328152593e-07
   65 KSP Residual norm 1.662819679382e-07
   66 KSP Residual norm 1.600228513100e-07
   67 KSP Residual norm 1.439887883000e-07
   68 KSP Residual norm 1.204805806011e-07
   69 KSP Residual norm 1.011600152477e-07
   70 KSP Residual norm 8.182701259323e-08
   71 KSP Residual norm 6.860467259226e-08
   72 KSP Residual norm 5.608141910120e-08
   73 KSP Residual norm 4.770127115125e-08
   74 KSP Residual norm 4.543428546534e-08
   75 KSP Residual norm 4.007728483313e-08
   76 KSP Residual norm 3.463284158971e-08
   77 KSP Residual norm 3.293514608251e-08
   78 KSP Residual norm 2.987452930718e-08
   79 KSP Residual norm 2.571116300800e-08
   80 KSP Residual norm 2.394291171936e-08
   81 KSP Residual norm 2.137522468758e-08
   82 KSP Residual norm 1.805059519812e-08
   83 KSP Residual norm 1.586340314220e-08
  7 KSP preconditioned resid norm 4.691102991691e+05 true resid norm 5.504651150469e+15 ||r(i)||/||b|| 3.134769584433e+13
    0 KSP Residual norm 1.527422325655e-03
    1 KSP Residual norm 6.018453284980e-04
    2 KSP Residual norm 7.874985643985e-04
    3 KSP Residual norm 1.166196559295e-03
    4 KSP Residual norm 5.330064308678e-04
    5 KSP Residual norm 6.341587189666e-04
    6 KSP Residual norm 6.625149610418e-04
    7 KSP Residual norm 4.785656112730e-04
    8 KSP Residual norm 4.703646902479e-04
    9 KSP Residual norm 4.430265312971e-04
   10 KSP Residual norm 4.007430377692e-04
   11 KSP Residual norm 3.658240807850e-04
   12 KSP Residual norm 2.858403156771e-04
   13 KSP Residual norm 2.065252933060e-04
   14 KSP Residual norm 2.001905572058e-04
   15 KSP Residual norm 1.898029574879e-04
   16 KSP Residual norm 1.674888020043e-04
   17 KSP Residual norm 1.478289449473e-04
   18 KSP Residual norm 1.422716276178e-04
   19 KSP Residual norm 1.326107688631e-04
   20 KSP Residual norm 1.057705886133e-04
   21 KSP Residual norm 9.083121059249e-05
   22 KSP Residual norm 8.735642387423e-05
   23 KSP Residual norm 7.143879099212e-05
   24 KSP Residual norm 6.184941755080e-05
   25 KSP Residual norm 5.503446822490e-05
   26 KSP Residual norm 4.509501821798e-05
   27 KSP Residual norm 4.068271819980e-05
   28 KSP Residual norm 3.740655856657e-05
   29 KSP Residual norm 3.540939518352e-05
   30 KSP Residual norm 3.441643749841e-05
   31 KSP Residual norm 3.048728643928e-05
   32 KSP Residual norm 2.560618875028e-05
   33 KSP Residual norm 2.442189390263e-05
   34 KSP Residual norm 2.288011439488e-05
   35 KSP Residual norm 1.919028530538e-05
   36 KSP Residual norm 1.506850956179e-05
   37 KSP Residual norm 1.136038711293e-05
   38 KSP Residual norm 9.282310045553e-06
   39 KSP Residual norm 8.245337078777e-06
   40 KSP Residual norm 7.967169020193e-06
   41 KSP Residual norm 7.454169708382e-06
   42 KSP Residual norm 6.536449227047e-06
   43 KSP Residual norm 5.474238251264e-06
   44 KSP Residual norm 4.421274577576e-06
   45 KSP Residual norm 3.630078833617e-06
   46 KSP Residual norm 3.129858660419e-06
   47 KSP Residual norm 2.813374761293e-06
   48 KSP Residual norm 2.587719864297e-06
   49 KSP Residual norm 2.224641633428e-06
   50 KSP Residual norm 1.872844390087e-06
   51 KSP Residual norm 1.732747111978e-06
   52 KSP Residual norm 1.489933469199e-06
   53 KSP Residual norm 1.194830480675e-06
   54 KSP Residual norm 1.085916253766e-06
   55 KSP Residual norm 9.824508220387e-07
   56 KSP Residual norm 1.010269768433e-06
   57 KSP Residual norm 1.016322527198e-06
   58 KSP Residual norm 9.104609424094e-07
   59 KSP Residual norm 8.195207568388e-07
   60 KSP Residual norm 6.884598594270e-07
   61 KSP Residual norm 5.899005691761e-07
   62 KSP Residual norm 4.812008714856e-07
   63 KSP Residual norm 3.840555394231e-07
   64 KSP Residual norm 3.319490925880e-07
   65 KSP Residual norm 2.774601986995e-07
   66 KSP Residual norm 2.346167139757e-07
   67 KSP Residual norm 2.348872575486e-07
   68 KSP Residual norm 2.119788835727e-07
   69 KSP Residual norm 1.769423196698e-07
   70 KSP Residual norm 1.460596452810e-07
   71 KSP Residual norm 1.193532978581e-07
   72 KSP Residual norm 1.034328374361e-07
   73 KSP Residual norm 9.641065250990e-08
   74 KSP Residual norm 8.330389561692e-08
   75 KSP Residual norm 6.478808679032e-08
   76 KSP Residual norm 4.839997978880e-08
   77 KSP Residual norm 3.603684065269e-08
   78 KSP Residual norm 2.864204842742e-08
   79 KSP Residual norm 2.222153649771e-08
   80 KSP Residual norm 1.812607266569e-08
   81 KSP Residual norm 1.527061479378e-08
  8 KSP preconditioned resid norm 4.500808358610e+05 true resid norm 5.950241483066e+15 ||r(i)||/||b|| 3.388522816666e+13
    0 KSP Residual norm 9.929657397867e-04
    1 KSP Residual norm 4.902876453791e-04
    2 KSP Residual norm 7.559847546165e-04
    3 KSP Residual norm 1.054393061562e-03
    4 KSP Residual norm 6.055772034347e-04
    5 KSP Residual norm 5.635524283518e-04
    6 KSP Residual norm 4.568396742433e-04
    7 KSP Residual norm 3.584099288095e-04
    8 KSP Residual norm 3.178576484198e-04
    9 KSP Residual norm 2.547543900920e-04
   10 KSP Residual norm 1.784251514264e-04
   11 KSP Residual norm 1.647555699220e-04
   12 KSP Residual norm 1.414872559198e-04
   13 KSP Residual norm 1.117786292845e-04
   14 KSP Residual norm 1.090192322288e-04
   15 KSP Residual norm 8.900454547982e-05
   16 KSP Residual norm 8.346961909198e-05
   17 KSP Residual norm 7.446711921831e-05
   18 KSP Residual norm 5.799234857060e-05
   19 KSP Residual norm 5.033824206817e-05
   20 KSP Residual norm 4.665813278179e-05
   21 KSP Residual norm 4.256100960811e-05
   22 KSP Residual norm 3.908892921780e-05
   23 KSP Residual norm 3.276750994252e-05
   24 KSP Residual norm 2.954099933430e-05
   25 KSP Residual norm 2.536999847468e-05
   26 KSP Residual norm 2.186412716443e-05
   27 KSP Residual norm 1.994227883577e-05
   28 KSP Residual norm 1.815190381738e-05
   29 KSP Residual norm 1.757818035909e-05
   30 KSP Residual norm 1.659161868569e-05
   31 KSP Residual norm 1.368718205339e-05
   32 KSP Residual norm 1.173228497672e-05
   33 KSP Residual norm 1.084139960618e-05
   34 KSP Residual norm 1.046181691502e-05
   35 KSP Residual norm 9.856219072178e-06
   36 KSP Residual norm 8.949732576945e-06
   37 KSP Residual norm 8.031018084880e-06
   38 KSP Residual norm 6.827642170103e-06
   39 KSP Residual norm 5.969773433539e-06
   40 KSP Residual norm 5.381266124258e-06
   41 KSP Residual norm 4.568703418801e-06
   42 KSP Residual norm 4.255442440527e-06
   43 KSP Residual norm 3.467073470314e-06
   44 KSP Residual norm 2.779168301414e-06
   45 KSP Residual norm 2.427111019689e-06
   46 KSP Residual norm 2.187905281589e-06
   47 KSP Residual norm 2.072694161060e-06
   48 KSP Residual norm 1.934433997310e-06
   49 KSP Residual norm 1.871616071656e-06
   50 KSP Residual norm 1.770825491245e-06
   51 KSP Residual norm 1.591519924697e-06
   52 KSP Residual norm 1.316226263058e-06
   53 KSP Residual norm 1.008636192991e-06
   54 KSP Residual norm 8.324978134901e-07
   55 KSP Residual norm 7.440883250546e-07
   56 KSP Residual norm 6.241613621927e-07
   57 KSP Residual norm 5.889489323059e-07
   58 KSP Residual norm 5.485295952931e-07
   59 KSP Residual norm 5.172101894151e-07
   60 KSP Residual norm 4.755149723296e-07
   61 KSP Residual norm 4.239045087594e-07
   62 KSP Residual norm 3.583844835911e-07
   63 KSP Residual norm 2.973104934794e-07
   64 KSP Residual norm 2.737087525212e-07
   65 KSP Residual norm 2.504228001347e-07
   66 KSP Residual norm 2.175835643014e-07
   67 KSP Residual norm 1.782239566180e-07
   68 KSP Residual norm 1.398876654733e-07
   69 KSP Residual norm 1.243251281054e-07
   70 KSP Residual norm 1.096852436426e-07
   71 KSP Residual norm 9.509159609015e-08
   72 KSP Residual norm 8.493077703498e-08
   73 KSP Residual norm 8.014336951229e-08
   74 KSP Residual norm 7.381630016116e-08
   75 KSP Residual norm 6.609518299482e-08
   76 KSP Residual norm 5.653639079658e-08
   77 KSP Residual norm 4.894221048879e-08
   78 KSP Residual norm 4.305927517180e-08
   79 KSP Residual norm 3.915247682279e-08
   80 KSP Residual norm 3.543175807015e-08
   81 KSP Residual norm 2.860488312897e-08
   82 KSP Residual norm 2.407236546821e-08
   83 KSP Residual norm 2.044171572991e-08
   84 KSP Residual norm 1.635455342896e-08
   85 KSP Residual norm 1.411433457232e-08
   86 KSP Residual norm 1.215986886164e-08
   87 KSP Residual norm 1.077340974712e-08
   88 KSP Residual norm 9.395234868584e-09
  9 KSP preconditioned resid norm 4.250017833169e+05 true resid norm 6.670775950304e+15 ||r(i)||/||b|| 3.798850278059e+13
    0 KSP Residual norm 9.200254261475e-04
    1 KSP Residual norm 5.026832893650e-04
    2 KSP Residual norm 7.666367615071e-04
    3 KSP Residual norm 8.705943922492e-04
    4 KSP Residual norm 5.646459712524e-04
    5 KSP Residual norm 6.588493249227e-04
    6 KSP Residual norm 5.231050716195e-04
    7 KSP Residual norm 3.685995698304e-04
    8 KSP Residual norm 3.034729621818e-04
    9 KSP Residual norm 2.521184397522e-04
   10 KSP Residual norm 2.104732600449e-04
   11 KSP Residual norm 1.703912268183e-04
   12 KSP Residual norm 1.354329037777e-04
   13 KSP Residual norm 1.161211341991e-04
   14 KSP Residual norm 1.012831477647e-04
   15 KSP Residual norm 8.660495544495e-05
   16 KSP Residual norm 6.316880992678e-05
   17 KSP Residual norm 4.690754740217e-05
   18 KSP Residual norm 3.748021802120e-05
   19 KSP Residual norm 3.012542988496e-05
   20 KSP Residual norm 2.449929942689e-05
   21 KSP Residual norm 2.164049659353e-05
   22 KSP Residual norm 1.989638436244e-05
   23 KSP Residual norm 1.774693897896e-05
   24 KSP Residual norm 1.592703834611e-05
   25 KSP Residual norm 1.401764611911e-05
   26 KSP Residual norm 1.175314669513e-05
   27 KSP Residual norm 9.736243974266e-06
   28 KSP Residual norm 8.675432629691e-06
   29 KSP Residual norm 8.355692597077e-06
   30 KSP Residual norm 7.838784741412e-06
   31 KSP Residual norm 7.469193190213e-06
   32 KSP Residual norm 6.401811844866e-06
   33 KSP Residual norm 5.699841128770e-06
   34 KSP Residual norm 5.098776305195e-06
   35 KSP Residual norm 5.060202209001e-06
   36 KSP Residual norm 4.828789978454e-06
   37 KSP Residual norm 4.327525907492e-06
   38 KSP Residual norm 3.917921800783e-06
   39 KSP Residual norm 3.620194481807e-06
   40 KSP Residual norm 3.120745519737e-06
   41 KSP Residual norm 2.682541335973e-06
   42 KSP Residual norm 2.384578475669e-06
   43 KSP Residual norm 2.383680000394e-06
   44 KSP Residual norm 2.152159496154e-06
   45 KSP Residual norm 1.728707913893e-06
   46 KSP Residual norm 1.496837742317e-06
   47 KSP Residual norm 1.201019823118e-06
   48 KSP Residual norm 9.486848633177e-07
   49 KSP Residual norm 7.494833422803e-07
   50 KSP Residual norm 6.817552715651e-07
   51 KSP Residual norm 6.344596909119e-07
   52 KSP Residual norm 5.797101100600e-07
   53 KSP Residual norm 4.655820368251e-07
   54 KSP Residual norm 4.165240240650e-07
   55 KSP Residual norm 3.460916052170e-07
   56 KSP Residual norm 2.600177993180e-07
   57 KSP Residual norm 2.246119587309e-07
   58 KSP Residual norm 2.011821254588e-07
   59 KSP Residual norm 1.819845981449e-07
   60 KSP Residual norm 1.666569264012e-07
   61 KSP Residual norm 1.436604560548e-07
   62 KSP Residual norm 1.276587088656e-07
   63 KSP Residual norm 1.144636358343e-07
   64 KSP Residual norm 1.032454211393e-07
   65 KSP Residual norm 1.047993675460e-07
   66 KSP Residual norm 1.000193922051e-07
   67 KSP Residual norm 9.180687880429e-08
   68 KSP Residual norm 8.214049905738e-08
   69 KSP Residual norm 6.745832360433e-08
   70 KSP Residual norm 5.581906787117e-08
   71 KSP Residual norm 4.630074362701e-08
   72 KSP Residual norm 3.511733315896e-08
   73 KSP Residual norm 2.847611309449e-08
   74 KSP Residual norm 2.379609914911e-08
   75 KSP Residual norm 2.204080814832e-08
   76 KSP Residual norm 1.868848687109e-08
   77 KSP Residual norm 1.558881848560e-08
   78 KSP Residual norm 1.419681957837e-08
   79 KSP Residual norm 1.253008934831e-08
   80 KSP Residual norm 1.181813806603e-08
   81 KSP Residual norm 1.138361116878e-08
   82 KSP Residual norm 1.068134133328e-08
   83 KSP Residual norm 9.791384955514e-09
   84 KSP Residual norm 8.445017061187e-09
 10 KSP preconditioned resid norm 4.051635153763e+05 true resid norm 7.414259071687e+15 ||r(i)||/||b|| 4.222246459170e+13
    0 KSP Residual norm 1.411279505320e-03
    1 KSP Residual norm 7.209624613977e-04
    2 KSP Residual norm 1.013550000279e-03
    3 KSP Residual norm 1.329722578055e-03
    4 KSP Residual norm 9.299374430975e-04
    5 KSP Residual norm 9.942662240769e-04
    6 KSP Residual norm 6.792656465301e-04
    7 KSP Residual norm 4.683452755646e-04
    8 KSP Residual norm 3.992715074611e-04
    9 KSP Residual norm 3.511431604995e-04
   10 KSP Residual norm 3.111979031550e-04
   11 KSP Residual norm 2.766221017318e-04
   12 KSP Residual norm 2.109137983476e-04
   13 KSP Residual norm 1.662041206546e-04
   14 KSP Residual norm 1.398102151659e-04
   15 KSP Residual norm 1.400556053078e-04
   16 KSP Residual norm 1.379179889368e-04
   17 KSP Residual norm 1.268873434229e-04
   18 KSP Residual norm 1.047101319592e-04
   19 KSP Residual norm 9.331480445280e-05
   20 KSP Residual norm 8.923232325618e-05
   21 KSP Residual norm 7.570662411081e-05
   22 KSP Residual norm 6.676541969887e-05
   23 KSP Residual norm 6.221192581325e-05
   24 KSP Residual norm 5.958345257685e-05
   25 KSP Residual norm 5.665881061978e-05
   26 KSP Residual norm 5.120506512044e-05
   27 KSP Residual norm 4.246868334557e-05
   28 KSP Residual norm 3.831321898572e-05
   29 KSP Residual norm 3.587959246487e-05
   30 KSP Residual norm 3.392221891532e-05
   31 KSP Residual norm 2.901134960129e-05
   32 KSP Residual norm 2.336738717744e-05
   33 KSP Residual norm 2.041689746657e-05
   34 KSP Residual norm 1.815689228967e-05
   35 KSP Residual norm 1.564169691250e-05
   36 KSP Residual norm 1.367788319918e-05
   37 KSP Residual norm 1.204491060549e-05
   38 KSP Residual norm 1.005190704326e-05
   39 KSP Residual norm 8.444382862709e-06
   40 KSP Residual norm 7.461525396347e-06
   41 KSP Residual norm 6.648844443497e-06
   42 KSP Residual norm 5.512834496401e-06
   43 KSP Residual norm 4.646669659544e-06
   44 KSP Residual norm 4.019218409906e-06
   45 KSP Residual norm 3.313439333579e-06
   46 KSP Residual norm 2.946430101063e-06
   47 KSP Residual norm 3.013172151866e-06
   48 KSP Residual norm 3.121787615489e-06
   49 KSP Residual norm 2.899554392415e-06
   50 KSP Residual norm 2.631906303388e-06
   51 KSP Residual norm 2.222379968828e-06
   52 KSP Residual norm 1.891132078561e-06
   53 KSP Residual norm 1.487269144552e-06
   54 KSP Residual norm 1.330743450427e-06
   55 KSP Residual norm 1.153298630154e-06
   56 KSP Residual norm 9.837001884336e-07
   57 KSP Residual norm 9.462488905838e-07
   58 KSP Residual norm 8.159219117588e-07
   59 KSP Residual norm 7.053692968344e-07
   60 KSP Residual norm 5.852092375603e-07
   61 KSP Residual norm 5.152501907863e-07
   62 KSP Residual norm 4.916268459686e-07
   63 KSP Residual norm 4.395264829083e-07
   64 KSP Residual norm 3.748901354410e-07
   65 KSP Residual norm 3.235816789575e-07
   66 KSP Residual norm 2.721611241940e-07
   67 KSP Residual norm 2.362337360615e-07
   68 KSP Residual norm 1.990056944395e-07
   69 KSP Residual norm 1.783713283092e-07
   70 KSP Residual norm 1.488298351018e-07
   71 KSP Residual norm 1.199228386691e-07
   72 KSP Residual norm 1.101628376416e-07
   73 KSP Residual norm 1.064611915990e-07
   74 KSP Residual norm 9.245248268909e-08
   75 KSP Residual norm 8.045119268170e-08
   76 KSP Residual norm 7.164372389583e-08
   77 KSP Residual norm 5.897550067188e-08
   78 KSP Residual norm 5.081315281605e-08
   79 KSP Residual norm 4.511493511029e-08
   80 KSP Residual norm 4.134344906919e-08
   81 KSP Residual norm 3.639898286485e-08
   82 KSP Residual norm 3.159308391246e-08
   83 KSP Residual norm 2.524885503680e-08
   84 KSP Residual norm 1.945248424195e-08
   85 KSP Residual norm 1.761737475196e-08
   86 KSP Residual norm 1.541422422114e-08
   87 KSP Residual norm 1.212892098515e-08
 11 KSP preconditioned resid norm 3.880015722902e+05 true resid norm 8.151564986314e+15 ||r(i)||/||b|| 4.642124866068e+13
    0 KSP Residual norm 1.122716868788e-03
    1 KSP Residual norm 6.008808533038e-04
    2 KSP Residual norm 8.746901486366e-04
    3 KSP Residual norm 9.675719644774e-04
    4 KSP Residual norm 6.304857576912e-04
    5 KSP Residual norm 6.570214073237e-04
    6 KSP Residual norm 5.052071154901e-04
    7 KSP Residual norm 4.304615634874e-04
    8 KSP Residual norm 3.834416080452e-04
    9 KSP Residual norm 3.159183513395e-04
   10 KSP Residual norm 2.937905902811e-04
   11 KSP Residual norm 2.405098072791e-04
   12 KSP Residual norm 1.793551829062e-04
   13 KSP Residual norm 1.538545824359e-04
   14 KSP Residual norm 1.343317570233e-04
   15 KSP Residual norm 1.174204668875e-04
   16 KSP Residual norm 1.147415887521e-04
   17 KSP Residual norm 1.090709538620e-04
   18 KSP Residual norm 9.906670909342e-05
   19 KSP Residual norm 8.811596697872e-05
   20 KSP Residual norm 7.939148563411e-05
   21 KSP Residual norm 7.155753313988e-05
   22 KSP Residual norm 7.256620200825e-05
   23 KSP Residual norm 6.755550431329e-05
   24 KSP Residual norm 6.686160083169e-05
   25 KSP Residual norm 5.955937553796e-05
   26 KSP Residual norm 4.746574986832e-05
   27 KSP Residual norm 4.126635464198e-05
   28 KSP Residual norm 3.404096975607e-05
   29 KSP Residual norm 3.076848529963e-05
   30 KSP Residual norm 2.784101022334e-05
   31 KSP Residual norm 2.391938044908e-05
   32 KSP Residual norm 1.950884595540e-05
   33 KSP Residual norm 1.705158155397e-05
   34 KSP Residual norm 1.520903833371e-05
   35 KSP Residual norm 1.249213038474e-05
   36 KSP Residual norm 1.058160083137e-05
   37 KSP Residual norm 9.284507036373e-06
   38 KSP Residual norm 8.757954083754e-06
   39 KSP Residual norm 8.195893501203e-06
   40 KSP Residual norm 7.019599668936e-06
   41 KSP Residual norm 5.620825670329e-06
   42 KSP Residual norm 4.932913838607e-06
   43 KSP Residual norm 4.363079222424e-06
   44 KSP Residual norm 3.202394102474e-06
   45 KSP Residual norm 2.540107419165e-06
   46 KSP Residual norm 2.079814007785e-06
   47 KSP Residual norm 1.900196960299e-06
   48 KSP Residual norm 1.845644821932e-06
   49 KSP Residual norm 1.700279138062e-06
   50 KSP Residual norm 1.518564339413e-06
   51 KSP Residual norm 1.292591923086e-06
   52 KSP Residual norm 1.054511094545e-06
   53 KSP Residual norm 8.437084330216e-07
   54 KSP Residual norm 7.666930913055e-07
   55 KSP Residual norm 7.396953754101e-07
   56 KSP Residual norm 6.403041855562e-07
   57 KSP Residual norm 6.338848815188e-07
   58 KSP Residual norm 6.445911176637e-07
   59 KSP Residual norm 5.587648495519e-07
   60 KSP Residual norm 4.493675868183e-07
   61 KSP Residual norm 3.751369595937e-07
   62 KSP Residual norm 3.452352201801e-07
   63 KSP Residual norm 3.306976430352e-07
   64 KSP Residual norm 3.161092208678e-07
   65 KSP Residual norm 2.735594513429e-07
   66 KSP Residual norm 2.150194814698e-07
   67 KSP Residual norm 1.794154549059e-07
   68 KSP Residual norm 1.485349674374e-07
   69 KSP Residual norm 1.171367396097e-07
   70 KSP Residual norm 8.618131070106e-08
   71 KSP Residual norm 6.828400533145e-08
   72 KSP Residual norm 5.751941286285e-08
   73 KSP Residual norm 4.660222107664e-08
   74 KSP Residual norm 4.004667546977e-08
   75 KSP Residual norm 3.579380735855e-08
   76 KSP Residual norm 3.077152509197e-08
   77 KSP Residual norm 2.696045956599e-08
   78 KSP Residual norm 2.495900645150e-08
   79 KSP Residual norm 2.403357077445e-08
   80 KSP Residual norm 2.394915077750e-08
   81 KSP Residual norm 2.217405978792e-08
   82 KSP Residual norm 2.053050255384e-08
   83 KSP Residual norm 1.710274427764e-08
   84 KSP Residual norm 1.311093930139e-08
   85 KSP Residual norm 1.030213845590e-08
 12 KSP preconditioned resid norm 3.741403203347e+05 true resid norm 8.948453074716e+15 ||r(i)||/||b|| 5.095933921981e+13
    0 KSP Residual norm 1.100806057211e-03
    1 KSP Residual norm 6.577291415384e-04
    2 KSP Residual norm 1.048309555084e-03
    3 KSP Residual norm 1.117110319452e-03
    4 KSP Residual norm 6.625286495026e-04
    5 KSP Residual norm 6.160736713854e-04
    6 KSP Residual norm 4.468025399915e-04
    7 KSP Residual norm 3.425480962131e-04
    8 KSP Residual norm 2.813853772798e-04
    9 KSP Residual norm 2.223382544106e-04
   10 KSP Residual norm 1.797286574771e-04
   11 KSP Residual norm 1.546165261470e-04
   12 KSP Residual norm 1.424932511566e-04
   13 KSP Residual norm 1.289292806564e-04
   14 KSP Residual norm 1.082005147602e-04
   15 KSP Residual norm 9.287904294910e-05
   16 KSP Residual norm 8.201311042269e-05
   17 KSP Residual norm 6.809773868750e-05
   18 KSP Residual norm 6.025972381858e-05
   19 KSP Residual norm 5.674859783110e-05
   20 KSP Residual norm 5.663754637967e-05
   21 KSP Residual norm 5.402993686216e-05
   22 KSP Residual norm 4.870753390569e-05
   23 KSP Residual norm 4.663393563839e-05
   24 KSP Residual norm 4.161348668758e-05
   25 KSP Residual norm 3.317451239796e-05
   26 KSP Residual norm 2.731027132468e-05
   27 KSP Residual norm 2.462064152491e-05
   28 KSP Residual norm 2.430835583592e-05
   29 KSP Residual norm 2.417411815501e-05
   30 KSP Residual norm 2.061414764703e-05
   31 KSP Residual norm 1.780807411335e-05
   32 KSP Residual norm 1.505486222387e-05
   33 KSP Residual norm 1.330518334944e-05
   34 KSP Residual norm 1.193912739898e-05
   35 KSP Residual norm 1.120691851760e-05
   36 KSP Residual norm 1.022333587184e-05
   37 KSP Residual norm 9.384895313995e-06
   38 KSP Residual norm 7.740221628598e-06
   39 KSP Residual norm 6.287892496063e-06
   40 KSP Residual norm 6.011999913701e-06
   41 KSP Residual norm 5.437488480571e-06
   42 KSP Residual norm 5.083442598145e-06
   43 KSP Residual norm 4.677988691041e-06
   44 KSP Residual norm 3.865991896605e-06
   45 KSP Residual norm 3.331218522568e-06
   46 KSP Residual norm 2.839017185796e-06
   47 KSP Residual norm 2.571079213875e-06
   48 KSP Residual norm 2.364850078864e-06
   49 KSP Residual norm 1.993638556637e-06
   50 KSP Residual norm 1.571108954534e-06
   51 KSP Residual norm 1.312909890124e-06
   52 KSP Residual norm 1.186715359094e-06
   53 KSP Residual norm 9.981062704104e-07
   54 KSP Residual norm 8.560047123095e-07
   55 KSP Residual norm 7.384475525843e-07
   56 KSP Residual norm 5.877495150335e-07
   57 KSP Residual norm 4.817942529451e-07
   58 KSP Residual norm 3.872015792209e-07
   59 KSP Residual norm 3.069987194596e-07
   60 KSP Residual norm 2.422136466907e-07
   61 KSP Residual norm 1.995139647837e-07
   62 KSP Residual norm 1.609971638595e-07
   63 KSP Residual norm 1.304093109524e-07
   64 KSP Residual norm 1.079522417317e-07
   65 KSP Residual norm 9.449448515878e-08
   66 KSP Residual norm 8.395371583770e-08
   67 KSP Residual norm 7.513531914746e-08
   68 KSP Residual norm 6.347499399425e-08
   69 KSP Residual norm 5.142261546478e-08
   70 KSP Residual norm 4.099511898433e-08
   71 KSP Residual norm 3.570300378045e-08
   72 KSP Residual norm 3.299806467809e-08
   73 KSP Residual norm 3.061456314443e-08
   74 KSP Residual norm 2.623432508532e-08
   75 KSP Residual norm 2.422341421294e-08
   76 KSP Residual norm 2.344073736418e-08
   77 KSP Residual norm 2.119450666598e-08
   78 KSP Residual norm 1.846946786987e-08
   79 KSP Residual norm 1.612504341588e-08
   80 KSP Residual norm 1.525327989441e-08
   81 KSP Residual norm 1.324228014875e-08
   82 KSP Residual norm 1.142821576457e-08
   83 KSP Residual norm 9.525344010032e-09
 13 KSP preconditioned resid norm 3.532140696819e+05 true resid norm 1.028226620724e+16 ||r(i)||/||b|| 5.855509183857e+13
    0 KSP Residual norm 1.227266045511e-03
    1 KSP Residual norm 5.447297984266e-04
    2 KSP Residual norm 8.246023615042e-04
    3 KSP Residual norm 1.016008283971e-03
    4 KSP Residual norm 4.657979761309e-04
    5 KSP Residual norm 5.061163020278e-04
    6 KSP Residual norm 4.426729389847e-04
    7 KSP Residual norm 3.238243221960e-04
    8 KSP Residual norm 2.646832838726e-04
    9 KSP Residual norm 2.059711839729e-04
   10 KSP Residual norm 1.480021196030e-04
   11 KSP Residual norm 1.167905945715e-04
   12 KSP Residual norm 9.427696513830e-05
   13 KSP Residual norm 8.203541359160e-05
   14 KSP Residual norm 7.466639075924e-05
   15 KSP Residual norm 6.970570901991e-05
   16 KSP Residual norm 7.211965322671e-05
   17 KSP Residual norm 6.298075380451e-05
   18 KSP Residual norm 5.074960900055e-05
   19 KSP Residual norm 4.514720236487e-05
   20 KSP Residual norm 3.853683174505e-05
   21 KSP Residual norm 3.738423001375e-05
   22 KSP Residual norm 3.709620904948e-05
   23 KSP Residual norm 3.142770872224e-05
   24 KSP Residual norm 2.848631585846e-05
   25 KSP Residual norm 2.562061058508e-05
   26 KSP Residual norm 2.169952343122e-05
   27 KSP Residual norm 1.843706154138e-05
   28 KSP Residual norm 1.619100785386e-05
   29 KSP Residual norm 1.420378837809e-05
   30 KSP Residual norm 1.232002380120e-05
   31 KSP Residual norm 1.047042057508e-05
   32 KSP Residual norm 8.127398704757e-06
   33 KSP Residual norm 6.752017594785e-06
   34 KSP Residual norm 5.981342215874e-06
   35 KSP Residual norm 5.549067177236e-06
   36 KSP Residual norm 5.328108423986e-06
   37 KSP Residual norm 4.738309219215e-06
   38 KSP Residual norm 4.212749550733e-06
   39 KSP Residual norm 3.393898149761e-06
   40 KSP Residual norm 2.877927596096e-06
   41 KSP Residual norm 2.723313626964e-06
   42 KSP Residual norm 2.555495230140e-06
   43 KSP Residual norm 2.372522752692e-06
   44 KSP Residual norm 2.212579417735e-06
   45 KSP Residual norm 1.756195477009e-06
   46 KSP Residual norm 1.512099855840e-06
   47 KSP Residual norm 1.328880831649e-06
   48 KSP Residual norm 1.306042041683e-06
   49 KSP Residual norm 1.263516418337e-06
   50 KSP Residual norm 1.200549322100e-06
   51 KSP Residual norm 1.132632757850e-06
   52 KSP Residual norm 1.039805417880e-06
   53 KSP Residual norm 8.439350435988e-07
   54 KSP Residual norm 6.860715496219e-07
   55 KSP Residual norm 5.508211742582e-07
   56 KSP Residual norm 4.283152270733e-07
   57 KSP Residual norm 3.833253253564e-07
   58 KSP Residual norm 3.660761718311e-07
   59 KSP Residual norm 3.788499665563e-07
   60 KSP Residual norm 3.923257840629e-07
   61 KSP Residual norm 3.332719937087e-07
   62 KSP Residual norm 2.762242120717e-07
   63 KSP Residual norm 2.491688031842e-07
   64 KSP Residual norm 2.075512941491e-07
   65 KSP Residual norm 1.830265280253e-07
   66 KSP Residual norm 1.696931286980e-07
   67 KSP Residual norm 1.496252483305e-07
   68 KSP Residual norm 1.359020030144e-07
   69 KSP Residual norm 1.177107263386e-07
   70 KSP Residual norm 9.572491139085e-08
   71 KSP Residual norm 8.271075371502e-08
   72 KSP Residual norm 7.843118965192e-08
   73 KSP Residual norm 7.624679608790e-08
   74 KSP Residual norm 6.323188798955e-08
   75 KSP Residual norm 5.450929130695e-08
   76 KSP Residual norm 4.728026130130e-08
   77 KSP Residual norm 3.690713027026e-08
   78 KSP Residual norm 2.859737703704e-08
   79 KSP Residual norm 2.188241157878e-08
   80 KSP Residual norm 1.806077048037e-08
   81 KSP Residual norm 1.518605739665e-08
   82 KSP Residual norm 1.229808906365e-08
   83 KSP Residual norm 1.061568380973e-08
 14 KSP preconditioned resid norm 3.306243387330e+05 true resid norm 1.207917655474e+16 ||r(i)||/||b|| 6.878807436431e+13
    0 KSP Residual norm 1.459432290838e-03
    1 KSP Residual norm 5.177694546374e-04
    2 KSP Residual norm 7.633997715428e-04
    3 KSP Residual norm 9.877976742848e-04
    4 KSP Residual norm 4.200357547174e-04
    5 KSP Residual norm 4.211594841571e-04
    6 KSP Residual norm 3.232605114025e-04
    7 KSP Residual norm 2.605123987139e-04
    8 KSP Residual norm 2.332504809664e-04
    9 KSP Residual norm 2.124526459244e-04
   10 KSP Residual norm 1.839763132207e-04
   11 KSP Residual norm 1.600669335903e-04
   12 KSP Residual norm 1.351695692210e-04
   13 KSP Residual norm 1.119178924099e-04
   14 KSP Residual norm 1.069523586410e-04
   15 KSP Residual norm 9.804367761906e-05
   16 KSP Residual norm 1.054276789421e-04
   17 KSP Residual norm 9.539107180572e-05
   18 KSP Residual norm 7.764874131566e-05
   19 KSP Residual norm 7.302935596796e-05
   20 KSP Residual norm 6.474901449940e-05
   21 KSP Residual norm 5.984922018873e-05
   22 KSP Residual norm 5.405159983081e-05
   23 KSP Residual norm 4.695603825105e-05
   24 KSP Residual norm 4.086670619422e-05
   25 KSP Residual norm 3.469454967883e-05
   26 KSP Residual norm 2.756686133114e-05
   27 KSP Residual norm 2.326495609470e-05
   28 KSP Residual norm 2.126439346970e-05
   29 KSP Residual norm 1.948357948039e-05
   30 KSP Residual norm 1.755298230261e-05
   31 KSP Residual norm 1.607621313879e-05
   32 KSP Residual norm 1.531089867882e-05
   33 KSP Residual norm 1.454208559897e-05
   34 KSP Residual norm 1.389506093092e-05
   35 KSP Residual norm 1.258612479997e-05
   36 KSP Residual norm 1.138599379362e-05
   37 KSP Residual norm 9.413442310771e-06
   38 KSP Residual norm 7.507957864729e-06
   39 KSP Residual norm 6.045511467564e-06
   40 KSP Residual norm 5.489633705423e-06
   41 KSP Residual norm 4.922716726317e-06
   42 KSP Residual norm 4.149569625497e-06
   43 KSP Residual norm 3.548235691340e-06
   44 KSP Residual norm 3.034898161568e-06
   45 KSP Residual norm 2.411746177837e-06
   46 KSP Residual norm 2.030258462211e-06
   47 KSP Residual norm 1.710648711823e-06
   48 KSP Residual norm 1.627083264795e-06
   49 KSP Residual norm 1.681648902998e-06
   50 KSP Residual norm 1.513821678675e-06
   51 KSP Residual norm 1.331216028835e-06
   52 KSP Residual norm 1.144376302051e-06
   53 KSP Residual norm 9.106034615301e-07
   54 KSP Residual norm 8.177818316452e-07
   55 KSP Residual norm 7.307874915659e-07
   56 KSP Residual norm 6.516247159255e-07
   57 KSP Residual norm 6.250263205941e-07
   58 KSP Residual norm 5.706483785491e-07
   59 KSP Residual norm 4.958566052577e-07
   60 KSP Residual norm 3.936161272306e-07
   61 KSP Residual norm 3.164833774631e-07
   62 KSP Residual norm 2.878817619036e-07
   63 KSP Residual norm 2.667989753790e-07
   64 KSP Residual norm 2.370790828550e-07
   65 KSP Residual norm 2.222940416236e-07
   66 KSP Residual norm 2.058942142729e-07
   67 KSP Residual norm 1.771742345211e-07
   68 KSP Residual norm 1.539046780393e-07
   69 KSP Residual norm 1.316500082810e-07
   70 KSP Residual norm 1.131952124929e-07
   71 KSP Residual norm 1.023916402035e-07
   72 KSP Residual norm 8.685913831782e-08
   73 KSP Residual norm 7.412771219194e-08
   74 KSP Residual norm 6.097126422574e-08
   75 KSP Residual norm 4.863425079193e-08
   76 KSP Residual norm 3.950374358809e-08
   77 KSP Residual norm 3.265334139673e-08
   78 KSP Residual norm 2.800050071506e-08
   79 KSP Residual norm 2.687040208216e-08
   80 KSP Residual norm 2.504901206204e-08
   81 KSP Residual norm 2.217777011225e-08
   82 KSP Residual norm 1.899252358757e-08
   83 KSP Residual norm 1.532282428560e-08
   84 KSP Residual norm 1.151789037598e-08
 15 KSP preconditioned resid norm 3.076994286453e+05 true resid norm 1.412211206135e+16 ||r(i)||/||b|| 8.042211240599e+13
    0 KSP Residual norm 9.764234654438e-04
    1 KSP Residual norm 5.489953732263e-04
    2 KSP Residual norm 8.749783110445e-04
    3 KSP Residual norm 8.888547231329e-04
    4 KSP Residual norm 4.529115004058e-04
    5 KSP Residual norm 4.860423654622e-04
    6 KSP Residual norm 3.287254848119e-04
    7 KSP Residual norm 2.232670268195e-04
    8 KSP Residual norm 1.876484330318e-04
    9 KSP Residual norm 1.525064956599e-04
   10 KSP Residual norm 1.208670435123e-04
   11 KSP Residual norm 1.028323886916e-04
   12 KSP Residual norm 7.772774008753e-05
   13 KSP Residual norm 6.752649158855e-05
   14 KSP Residual norm 6.504161985039e-05
   15 KSP Residual norm 5.904951311588e-05
   16 KSP Residual norm 5.543844939544e-05
   17 KSP Residual norm 4.615173256967e-05
   18 KSP Residual norm 3.799649666412e-05
   19 KSP Residual norm 3.730733034732e-05
   20 KSP Residual norm 3.606579011292e-05
   21 KSP Residual norm 3.299019027953e-05
   22 KSP Residual norm 3.133517799975e-05
   23 KSP Residual norm 2.938428020786e-05
   24 KSP Residual norm 2.721543127547e-05
   25 KSP Residual norm 2.551548018198e-05
   26 KSP Residual norm 2.213065569460e-05
   27 KSP Residual norm 1.939231079258e-05
   28 KSP Residual norm 1.775454795321e-05
   29 KSP Residual norm 1.568041345539e-05
   30 KSP Residual norm 1.450072435892e-05
   31 KSP Residual norm 1.228486363809e-05
   32 KSP Residual norm 9.164130602858e-06
   33 KSP Residual norm 7.457318710014e-06
   34 KSP Residual norm 6.244901632835e-06
   35 KSP Residual norm 5.747392763597e-06
   36 KSP Residual norm 5.657878370579e-06
   37 KSP Residual norm 4.983694063528e-06
   38 KSP Residual norm 4.473040049383e-06
   39 KSP Residual norm 3.932591714728e-06
   40 KSP Residual norm 3.444085299692e-06
   41 KSP Residual norm 2.836538436918e-06
   42 KSP Residual norm 2.263428801519e-06
   43 KSP Residual norm 1.893766046004e-06
   44 KSP Residual norm 1.616942774810e-06
   45 KSP Residual norm 1.431508738610e-06
   46 KSP Residual norm 1.264420486557e-06
   47 KSP Residual norm 1.124190695961e-06
   48 KSP Residual norm 1.061696091503e-06
   49 KSP Residual norm 1.017025023220e-06
   50 KSP Residual norm 9.320447033483e-07
   51 KSP Residual norm 9.209793239494e-07
   52 KSP Residual norm 8.175080114526e-07
   53 KSP Residual norm 6.490646229583e-07
   54 KSP Residual norm 5.019016355281e-07
   55 KSP Residual norm 4.198722502674e-07
   56 KSP Residual norm 3.756672730086e-07
   57 KSP Residual norm 3.605745424031e-07
   58 KSP Residual norm 3.048796236760e-07
   59 KSP Residual norm 2.579874371926e-07
   60 KSP Residual norm 2.133016847868e-07
   61 KSP Residual norm 1.871571346571e-07
   62 KSP Residual norm 1.684993102107e-07
   63 KSP Residual norm 1.399548580012e-07
   64 KSP Residual norm 1.163755908148e-07
   65 KSP Residual norm 1.010738340893e-07
   66 KSP Residual norm 8.957923623371e-08
   67 KSP Residual norm 8.812367491528e-08
   68 KSP Residual norm 8.495145999334e-08
   69 KSP Residual norm 7.402801205774e-08
   70 KSP Residual norm 5.738516273128e-08
   71 KSP Residual norm 5.165840544128e-08
   72 KSP Residual norm 4.781686500394e-08
   73 KSP Residual norm 4.216651531229e-08
   74 KSP Residual norm 4.143466233621e-08
   75 KSP Residual norm 3.678394992614e-08
   76 KSP Residual norm 3.155260951661e-08
   77 KSP Residual norm 2.665212150931e-08
   78 KSP Residual norm 2.277533135085e-08
   79 KSP Residual norm 1.942564024377e-08
   80 KSP Residual norm 1.642312107108e-08
   81 KSP Residual norm 1.359787956392e-08
   82 KSP Residual norm 1.084745939350e-08
   83 KSP Residual norm 8.897116416397e-09
 16 KSP preconditioned resid norm 2.709447111564e+05 true resid norm 1.756802993155e+16 ||r(i)||/||b|| 1.000458055968e+14
    0 KSP Residual norm 1.006665543077e-03
    1 KSP Residual norm 5.895749726952e-04
    2 KSP Residual norm 8.025235967352e-04
    3 KSP Residual norm 7.152189058079e-04
    4 KSP Residual norm 4.846790001718e-04
    5 KSP Residual norm 4.677406752836e-04
    6 KSP Residual norm 3.724837178428e-04
    7 KSP Residual norm 2.742675706877e-04
    8 KSP Residual norm 2.388662852402e-04
    9 KSP Residual norm 1.945942299314e-04
   10 KSP Residual norm 1.594878261667e-04
   11 KSP Residual norm 1.327032521003e-04
   12 KSP Residual norm 1.061558146642e-04
   13 KSP Residual norm 9.159945027617e-05
   14 KSP Residual norm 8.979385708770e-05
   15 KSP Residual norm 8.846500098469e-05
   16 KSP Residual norm 7.478542512343e-05
   17 KSP Residual norm 5.796343876666e-05
   18 KSP Residual norm 5.057527325271e-05
   19 KSP Residual norm 4.559837389235e-05
   20 KSP Residual norm 3.995001619217e-05
   21 KSP Residual norm 3.709269854324e-05
   22 KSP Residual norm 3.524419479059e-05
   23 KSP Residual norm 3.197962503758e-05
   24 KSP Residual norm 2.850779201751e-05
   25 KSP Residual norm 2.619239942769e-05
   26 KSP Residual norm 2.158099863421e-05
   27 KSP Residual norm 1.838456422539e-05
   28 KSP Residual norm 1.679939483916e-05
   29 KSP Residual norm 1.559798356750e-05
   30 KSP Residual norm 1.389078783891e-05
   31 KSP Residual norm 1.230756735543e-05
   32 KSP Residual norm 1.036043808588e-05
   33 KSP Residual norm 8.406954609656e-06
   34 KSP Residual norm 7.702409645961e-06
   35 KSP Residual norm 7.763526406491e-06
   36 KSP Residual norm 6.921207319542e-06
   37 KSP Residual norm 5.613224065244e-06
   38 KSP Residual norm 4.543750542402e-06
   39 KSP Residual norm 4.244335245093e-06
   40 KSP Residual norm 3.863807735471e-06
   41 KSP Residual norm 3.265515940597e-06
   42 KSP Residual norm 3.042299669021e-06
   43 KSP Residual norm 2.938283558895e-06
   44 KSP Residual norm 2.634864096186e-06
   45 KSP Residual norm 2.122139872450e-06
   46 KSP Residual norm 1.834700632190e-06
   47 KSP Residual norm 1.678691839842e-06
   48 KSP Residual norm 1.631914047786e-06
   49 KSP Residual norm 1.527765669795e-06
   50 KSP Residual norm 1.398370393210e-06
   51 KSP Residual norm 1.317678290275e-06
   52 KSP Residual norm 1.146021421948e-06
   53 KSP Residual norm 9.024594194983e-07
   54 KSP Residual norm 7.664948872376e-07
   55 KSP Residual norm 6.402294319727e-07
   56 KSP Residual norm 5.892367718234e-07
   57 KSP Residual norm 5.376061205510e-07
   58 KSP Residual norm 4.538359670196e-07
   59 KSP Residual norm 3.878851824806e-07
   60 KSP Residual norm 3.363043882561e-07
   61 KSP Residual norm 2.836355279035e-07
   62 KSP Residual norm 2.652346207214e-07
   63 KSP Residual norm 2.518746871928e-07
   64 KSP Residual norm 2.185671835739e-07
   65 KSP Residual norm 2.325660767046e-07
   66 KSP Residual norm 2.107215034343e-07
   67 KSP Residual norm 1.962801545641e-07
   68 KSP Residual norm 1.843457663841e-07
   69 KSP Residual norm 1.520648017635e-07
   70 KSP Residual norm 1.187434097302e-07
   71 KSP Residual norm 9.419538658356e-08
   72 KSP Residual norm 7.587845565008e-08
   73 KSP Residual norm 6.895613663244e-08
   74 KSP Residual norm 5.785708345932e-08
   75 KSP Residual norm 4.601479926402e-08
   76 KSP Residual norm 4.006359993181e-08
   77 KSP Residual norm 3.432622256133e-08
   78 KSP Residual norm 3.009006020118e-08
   79 KSP Residual norm 2.711199022491e-08
   80 KSP Residual norm 2.329136306763e-08
   81 KSP Residual norm 1.978765156074e-08
   82 KSP Residual norm 1.687387852349e-08
   83 KSP Residual norm 1.252086360136e-08
   84 KSP Residual norm 1.009300072156e-08
   85 KSP Residual norm 8.301525016312e-09
 17 KSP preconditioned resid norm 2.491269146610e+05 true resid norm 1.976009758694e+16 ||r(i)||/||b|| 1.125291162105e+14
    0 KSP Residual norm 1.047460439316e-03
    1 KSP Residual norm 4.919547070189e-04
    2 KSP Residual norm 7.436613474197e-04
    3 KSP Residual norm 1.016601540646e-03
    4 KSP Residual norm 4.834002402018e-04
    5 KSP Residual norm 3.841456559995e-04
    6 KSP Residual norm 3.091528583130e-04
    7 KSP Residual norm 2.244716515111e-04
    8 KSP Residual norm 2.036058849090e-04
    9 KSP Residual norm 1.659843045113e-04
   10 KSP Residual norm 1.430423906551e-04
   11 KSP Residual norm 1.143870290674e-04
   12 KSP Residual norm 8.247368346501e-05
   13 KSP Residual norm 6.837045207442e-05
   14 KSP Residual norm 6.741780718848e-05
   15 KSP Residual norm 6.420177699846e-05
   16 KSP Residual norm 5.832569400485e-05
   17 KSP Residual norm 5.257713558213e-05
   18 KSP Residual norm 4.463237663341e-05
   19 KSP Residual norm 4.289717643227e-05
   20 KSP Residual norm 3.925425113427e-05
   21 KSP Residual norm 3.642518503266e-05
   22 KSP Residual norm 3.382442626620e-05
   23 KSP Residual norm 3.011084282428e-05
   24 KSP Residual norm 2.619779074135e-05
   25 KSP Residual norm 2.126870383081e-05
   26 KSP Residual norm 1.916858295220e-05
   27 KSP Residual norm 1.787278551239e-05
   28 KSP Residual norm 1.630367244253e-05
   29 KSP Residual norm 1.448418257010e-05
   30 KSP Residual norm 1.297702817759e-05
   31 KSP Residual norm 1.163154365095e-05
   32 KSP Residual norm 1.112403023070e-05
   33 KSP Residual norm 9.562485089284e-06
   34 KSP Residual norm 8.090875215548e-06
   35 KSP Residual norm 7.365316880616e-06
   36 KSP Residual norm 6.490558913849e-06
   37 KSP Residual norm 5.490720696473e-06
   38 KSP Residual norm 4.889993822583e-06
   39 KSP Residual norm 4.240229108611e-06
   40 KSP Residual norm 4.055809490180e-06
   41 KSP Residual norm 3.711705751009e-06
   42 KSP Residual norm 3.072702194758e-06
   43 KSP Residual norm 2.847854845271e-06
   44 KSP Residual norm 2.591918260342e-06
   45 KSP Residual norm 2.106166307304e-06
   46 KSP Residual norm 1.825735977728e-06
   47 KSP Residual norm 1.652433417938e-06
   48 KSP Residual norm 1.663190707162e-06
   49 KSP Residual norm 1.516622999196e-06
   50 KSP Residual norm 1.181290840831e-06
   51 KSP Residual norm 1.029068488627e-06
   52 KSP Residual norm 8.423105866540e-07
   53 KSP Residual norm 6.587332873009e-07
   54 KSP Residual norm 5.961621074795e-07
   55 KSP Residual norm 4.998087026841e-07
   56 KSP Residual norm 4.511507612384e-07
   57 KSP Residual norm 4.460497909512e-07
   58 KSP Residual norm 4.105831049055e-07
   59 KSP Residual norm 3.676751228872e-07
   60 KSP Residual norm 2.958046501445e-07
   61 KSP Residual norm 2.417258417823e-07
   62 KSP Residual norm 2.030642525828e-07
   63 KSP Residual norm 1.560066698513e-07
   64 KSP Residual norm 1.372480903474e-07
   65 KSP Residual norm 1.295951349641e-07
   66 KSP Residual norm 1.252167878690e-07
   67 KSP Residual norm 1.229654012693e-07
   68 KSP Residual norm 1.189378346191e-07
   69 KSP Residual norm 9.854574354458e-08
   70 KSP Residual norm 8.419440019896e-08
   71 KSP Residual norm 7.514176463563e-08
   72 KSP Residual norm 6.898096360473e-08
   73 KSP Residual norm 6.590957946669e-08
   74 KSP Residual norm 5.820989756204e-08
   75 KSP Residual norm 4.650085553019e-08
   76 KSP Residual norm 3.617544162585e-08
   77 KSP Residual norm 2.682816549403e-08
   78 KSP Residual norm 2.069272280887e-08
   79 KSP Residual norm 1.720897137942e-08
   80 KSP Residual norm 1.491930893360e-08
   81 KSP Residual norm 1.302497792373e-08
   82 KSP Residual norm 1.151142679282e-08
   83 KSP Residual norm 1.013626025008e-08
 18 KSP preconditioned resid norm 2.169456154145e+05 true resid norm 2.315539961842e+16 ||r(i)||/||b|| 1.318645640842e+14
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 1.104926636821e-03
    1 KSP Residual norm 4.901360946873e-04
    2 KSP Residual norm 7.483102349257e-04
    3 KSP Residual norm 9.196903999372e-04
    4 KSP Residual norm 3.695002350688e-04
    5 KSP Residual norm 3.467871154561e-04
    6 KSP Residual norm 2.910736640461e-04
    7 KSP Residual norm 2.168040412436e-04
    8 KSP Residual norm 1.748089027602e-04
    9 KSP Residual norm 1.355236100671e-04
   10 KSP Residual norm 1.039409243028e-04
   11 KSP Residual norm 8.905983498733e-05
   12 KSP Residual norm 6.833132900943e-05
   13 KSP Residual norm 5.462032713138e-05
   14 KSP Residual norm 4.617069050036e-05
   15 KSP Residual norm 4.124988498795e-05
   16 KSP Residual norm 4.100007304891e-05
   17 KSP Residual norm 3.861618642049e-05
   18 KSP Residual norm 3.311774686138e-05
   19 KSP Residual norm 2.861282278629e-05
   20 KSP Residual norm 2.650770404091e-05
   21 KSP Residual norm 2.623837784316e-05
   22 KSP Residual norm 2.477307973651e-05
   23 KSP Residual norm 2.193020294856e-05
   24 KSP Residual norm 1.978158125720e-05
   25 KSP Residual norm 1.628800002949e-05
   26 KSP Residual norm 1.337066349183e-05
   27 KSP Residual norm 1.056084362902e-05
   28 KSP Residual norm 8.327146674636e-06
   29 KSP Residual norm 7.476520001124e-06
   30 KSP Residual norm 6.758688660092e-06
   31 KSP Residual norm 6.344916596862e-06
   32 KSP Residual norm 5.639172949263e-06
   33 KSP Residual norm 5.019162446101e-06
   34 KSP Residual norm 4.329666750214e-06
   35 KSP Residual norm 3.932025165108e-06
   36 KSP Residual norm 3.824661744409e-06
   37 KSP Residual norm 3.612800792369e-06
   38 KSP Residual norm 3.115762198290e-06
   39 KSP Residual norm 2.644784127796e-06
   40 KSP Residual norm 2.410462138367e-06
   41 KSP Residual norm 2.231325971284e-06
   42 KSP Residual norm 2.192679923140e-06
   43 KSP Residual norm 2.095458366674e-06
   44 KSP Residual norm 1.728215328947e-06
   45 KSP Residual norm 1.424776653802e-06
   46 KSP Residual norm 1.267997887003e-06
   47 KSP Residual norm 1.142675191748e-06
   48 KSP Residual norm 1.023886780243e-06
   49 KSP Residual norm 9.001970836361e-07
   50 KSP Residual norm 7.768838339449e-07
   51 KSP Residual norm 6.724756885041e-07
   52 KSP Residual norm 5.987063594814e-07
   53 KSP Residual norm 5.447521724472e-07
   54 KSP Residual norm 4.292668513514e-07
   55 KSP Residual norm 3.205033569052e-07
   56 KSP Residual norm 2.709805126595e-07
   57 KSP Residual norm 2.789370480631e-07
   58 KSP Residual norm 2.966717039899e-07
   59 KSP Residual norm 2.983681045338e-07
   60 KSP Residual norm 2.743015317437e-07
   61 KSP Residual norm 2.253539038506e-07
   62 KSP Residual norm 1.971698697952e-07
   63 KSP Residual norm 1.747084246538e-07
   64 KSP Residual norm 1.522096036417e-07
   65 KSP Residual norm 1.304048372684e-07
   66 KSP Residual norm 1.071001473850e-07
   67 KSP Residual norm 9.071875432813e-08
   68 KSP Residual norm 7.484051013814e-08
   69 KSP Residual norm 6.824342689597e-08
   70 KSP Residual norm 6.458097324937e-08
   71 KSP Residual norm 5.498262048912e-08
   72 KSP Residual norm 4.680346480838e-08
   73 KSP Residual norm 3.941139784530e-08
   74 KSP Residual norm 3.222185743391e-08
   75 KSP Residual norm 2.724758428997e-08
   76 KSP Residual norm 2.435119329492e-08
   77 KSP Residual norm 2.133393055823e-08
   78 KSP Residual norm 1.939351540643e-08
   79 KSP Residual norm 1.750266617565e-08
   80 KSP Residual norm 1.511157745552e-08
   81 KSP Residual norm 1.298075717751e-08
   82 KSP Residual norm 1.060778061111e-08
 19 KSP preconditioned resid norm 1.853355800655e+05 true resid norm 2.647055850521e+16 ||r(i)||/||b|| 1.507436155659e+14
    0 KSP Residual norm 1.003394072838e-03
    1 KSP Residual norm 5.696683252227e-04
    2 KSP Residual norm 7.732470294927e-04
    3 KSP Residual norm 7.060559354310e-04
    4 KSP Residual norm 4.241476918480e-04
    5 KSP Residual norm 3.959355987071e-04
    6 KSP Residual norm 3.448304989909e-04
    7 KSP Residual norm 2.622563588950e-04
    8 KSP Residual norm 2.134878116972e-04
    9 KSP Residual norm 1.971741545468e-04
   10 KSP Residual norm 1.905991690342e-04
   11 KSP Residual norm 1.875717643270e-04
   12 KSP Residual norm 1.654126756784e-04
   13 KSP Residual norm 1.546681671198e-04
   14 KSP Residual norm 1.407597959742e-04
   15 KSP Residual norm 1.301279903165e-04
   16 KSP Residual norm 1.335640781539e-04
   17 KSP Residual norm 1.276671033626e-04
   18 KSP Residual norm 1.126807978273e-04
   19 KSP Residual norm 9.249888114060e-05
   20 KSP Residual norm 7.957117048478e-05
   21 KSP Residual norm 6.549436075359e-05
   22 KSP Residual norm 6.123550879741e-05
   23 KSP Residual norm 5.500682467595e-05
   24 KSP Residual norm 4.608792819387e-05
   25 KSP Residual norm 3.704104678580e-05
   26 KSP Residual norm 3.044396889081e-05
   27 KSP Residual norm 2.621815700709e-05
   28 KSP Residual norm 2.312945424914e-05
   29 KSP Residual norm 2.136627206694e-05
   30 KSP Residual norm 1.748794168727e-05
   31 KSP Residual norm 1.519585022652e-05
   32 KSP Residual norm 1.346370869511e-05
   33 KSP Residual norm 1.244136226406e-05
   34 KSP Residual norm 1.036703813047e-05
   35 KSP Residual norm 9.127586098080e-06
   36 KSP Residual norm 8.589276252940e-06
   37 KSP Residual norm 7.439087298358e-06
   38 KSP Residual norm 6.032096842967e-06
   39 KSP Residual norm 5.371001354826e-06
   40 KSP Residual norm 5.052628561343e-06
   41 KSP Residual norm 4.235581891213e-06
   42 KSP Residual norm 4.006341188218e-06
   43 KSP Residual norm 3.674875844409e-06
   44 KSP Residual norm 3.118907549004e-06
   45 KSP Residual norm 2.838510594690e-06
   46 KSP Residual norm 2.552724420933e-06
   47 KSP Residual norm 2.485876074870e-06
   48 KSP Residual norm 2.329343858497e-06
   49 KSP Residual norm 2.129840644699e-06
   50 KSP Residual norm 1.911315218659e-06
   51 KSP Residual norm 1.708689794884e-06
   52 KSP Residual norm 1.337006783095e-06
   53 KSP Residual norm 1.010201566588e-06
   54 KSP Residual norm 7.812537281814e-07
   55 KSP Residual norm 6.065635032670e-07
   56 KSP Residual norm 4.745408866103e-07
   57 KSP Residual norm 4.497898757200e-07
   58 KSP Residual norm 4.410483435916e-07
   59 KSP Residual norm 4.054157667251e-07
   60 KSP Residual norm 3.677507331387e-07
   61 KSP Residual norm 3.232768365893e-07
   62 KSP Residual norm 2.752489805134e-07
   63 KSP Residual norm 2.168346903127e-07
   64 KSP Residual norm 1.935391974554e-07
   65 KSP Residual norm 1.716880482916e-07
   66 KSP Residual norm 1.538439103468e-07
   67 KSP Residual norm 1.484143529597e-07
   68 KSP Residual norm 1.304001182758e-07
   69 KSP Residual norm 1.096602465484e-07
   70 KSP Residual norm 9.276994685310e-08
   71 KSP Residual norm 7.584105921700e-08
   72 KSP Residual norm 6.162511740874e-08
   73 KSP Residual norm 5.973182970634e-08
   74 KSP Residual norm 5.537962543187e-08
   75 KSP Residual norm 5.097661590262e-08
   76 KSP Residual norm 4.342942447113e-08
   77 KSP Residual norm 3.218873643226e-08
   78 KSP Residual norm 2.245432765023e-08
   79 KSP Residual norm 1.719369765218e-08
   80 KSP Residual norm 1.277469549039e-08
   81 KSP Residual norm 9.288274152713e-09
 20 KSP preconditioned resid norm 1.684388285095e+05 true resid norm 2.847986111485e+16 ||r(i)||/||b|| 1.621861221562e+14
    0 KSP Residual norm 9.537382633878e-04
    1 KSP Residual norm 5.805828678495e-04
    2 KSP Residual norm 7.965481811167e-04
    3 KSP Residual norm 7.111994300477e-04
    4 KSP Residual norm 4.204604609856e-04
    5 KSP Residual norm 3.377502975996e-04
    6 KSP Residual norm 2.471202748238e-04
    7 KSP Residual norm 1.839752037246e-04
    8 KSP Residual norm 1.492243582648e-04
    9 KSP Residual norm 1.339640368056e-04
   10 KSP Residual norm 1.102253289921e-04
   11 KSP Residual norm 9.211440024755e-05
   12 KSP Residual norm 8.135009310268e-05
   13 KSP Residual norm 7.426343872420e-05
   14 KSP Residual norm 7.141467046487e-05
   15 KSP Residual norm 6.751872578598e-05
   16 KSP Residual norm 6.099760203763e-05
   17 KSP Residual norm 5.130445074494e-05
   18 KSP Residual norm 4.237438001810e-05
   19 KSP Residual norm 3.896618823252e-05
   20 KSP Residual norm 3.726344868786e-05
   21 KSP Residual norm 3.454550895663e-05
   22 KSP Residual norm 3.202807156908e-05
   23 KSP Residual norm 2.613934877233e-05
   24 KSP Residual norm 1.993928582774e-05
   25 KSP Residual norm 1.665949348566e-05
   26 KSP Residual norm 1.469515167173e-05
   27 KSP Residual norm 1.309464698227e-05
   28 KSP Residual norm 1.120570391983e-05
   29 KSP Residual norm 1.000025419139e-05
   30 KSP Residual norm 8.992698775246e-06
   31 KSP Residual norm 8.546494427485e-06
   32 KSP Residual norm 7.619433610613e-06
   33 KSP Residual norm 6.684353305851e-06
   34 KSP Residual norm 5.805665463552e-06
   35 KSP Residual norm 5.538825845230e-06
   36 KSP Residual norm 5.576972541327e-06
   37 KSP Residual norm 5.153810552137e-06
   38 KSP Residual norm 4.479657577698e-06
   39 KSP Residual norm 4.113747150514e-06
   40 KSP Residual norm 3.768004090406e-06
   41 KSP Residual norm 3.265930621579e-06
   42 KSP Residual norm 2.674433544064e-06
   43 KSP Residual norm 2.249961923301e-06
   44 KSP Residual norm 1.896980704269e-06
   45 KSP Residual norm 1.590077828881e-06
   46 KSP Residual norm 1.433599415304e-06
   47 KSP Residual norm 1.264942493409e-06
   48 KSP Residual norm 1.147269407683e-06
   49 KSP Residual norm 1.071149972893e-06
   50 KSP Residual norm 9.960572128471e-07
   51 KSP Residual norm 9.054498144213e-07
   52 KSP Residual norm 7.913472707524e-07
   53 KSP Residual norm 6.676027659634e-07
   54 KSP Residual norm 5.767292660234e-07
   55 KSP Residual norm 4.747825693063e-07
   56 KSP Residual norm 3.873369549872e-07
   57 KSP Residual norm 3.615075410476e-07
   58 KSP Residual norm 3.565791759558e-07
   59 KSP Residual norm 3.395980578492e-07
   60 KSP Residual norm 3.075627537411e-07
   61 KSP Residual norm 2.547754484475e-07
   62 KSP Residual norm 2.307419116310e-07
   63 KSP Residual norm 2.078221774477e-07
   64 KSP Residual norm 1.949611630826e-07
   65 KSP Residual norm 1.896807262403e-07
   66 KSP Residual norm 1.593277329169e-07
   67 KSP Residual norm 1.420542254058e-07
   68 KSP Residual norm 1.204522352312e-07
   69 KSP Residual norm 9.055826906855e-08
   70 KSP Residual norm 7.923260846165e-08
   71 KSP Residual norm 6.764523107534e-08
   72 KSP Residual norm 5.145174923238e-08
   73 KSP Residual norm 4.778528619223e-08
   74 KSP Residual norm 4.740345233515e-08
   75 KSP Residual norm 3.974844378837e-08
   76 KSP Residual norm 3.524092573411e-08
   77 KSP Residual norm 2.934993321551e-08
   78 KSP Residual norm 2.313698716287e-08
   79 KSP Residual norm 1.964932311386e-08
   80 KSP Residual norm 1.693938270624e-08
   81 KSP Residual norm 1.386799725078e-08
   82 KSP Residual norm 1.113391565463e-08
   83 KSP Residual norm 8.631102817980e-09
 21 KSP preconditioned resid norm 1.487806487874e+05 true resid norm 3.106924793675e+16 ||r(i)||/||b|| 1.769320721351e+14
    0 KSP Residual norm 8.810993976025e-04
    1 KSP Residual norm 4.913918413805e-04
    2 KSP Residual norm 5.907714832462e-04
    3 KSP Residual norm 4.976750762555e-04
    4 KSP Residual norm 3.115264025829e-04
    5 KSP Residual norm 3.179209881946e-04
    6 KSP Residual norm 2.532800518764e-04
    7 KSP Residual norm 1.636904534251e-04
    8 KSP Residual norm 1.357757591304e-04
    9 KSP Residual norm 1.298703024028e-04
   10 KSP Residual norm 1.238484927286e-04
   11 KSP Residual norm 1.308135661460e-04
   12 KSP Residual norm 1.257468923606e-04
   13 KSP Residual norm 1.084311062611e-04
   14 KSP Residual norm 1.016543604295e-04
   15 KSP Residual norm 9.676356124751e-05
   16 KSP Residual norm 8.575190221132e-05
   17 KSP Residual norm 7.943696412936e-05
   18 KSP Residual norm 6.756756438112e-05
   19 KSP Residual norm 5.663282149118e-05
   20 KSP Residual norm 4.994174797292e-05
   21 KSP Residual norm 4.259147023293e-05
   22 KSP Residual norm 3.717689923584e-05
   23 KSP Residual norm 3.117252650288e-05
   24 KSP Residual norm 2.817084233291e-05
   25 KSP Residual norm 2.677111718607e-05
   26 KSP Residual norm 2.223989377061e-05
   27 KSP Residual norm 1.840409375961e-05
   28 KSP Residual norm 1.629031423294e-05
   29 KSP Residual norm 1.480731244178e-05
   30 KSP Residual norm 1.450633839369e-05
   31 KSP Residual norm 1.383421165283e-05
   32 KSP Residual norm 1.126659173232e-05
   33 KSP Residual norm 9.046222000982e-06
   34 KSP Residual norm 7.423634843579e-06
   35 KSP Residual norm 6.448874764476e-06
   36 KSP Residual norm 5.769499084658e-06
   37 KSP Residual norm 4.878605782202e-06
   38 KSP Residual norm 4.623523488208e-06
   39 KSP Residual norm 4.629385226328e-06
   40 KSP Residual norm 4.513863767124e-06
   41 KSP Residual norm 4.176769507365e-06
   42 KSP Residual norm 3.736387002214e-06
   43 KSP Residual norm 3.481315629465e-06
   44 KSP Residual norm 3.132910696786e-06
   45 KSP Residual norm 2.509756400312e-06
   46 KSP Residual norm 2.113275513921e-06
   47 KSP Residual norm 1.881671265557e-06
   48 KSP Residual norm 1.699549513344e-06
   49 KSP Residual norm 1.532260506137e-06
   50 KSP Residual norm 1.412358396491e-06
   51 KSP Residual norm 1.123774096400e-06
   52 KSP Residual norm 9.429909862981e-07
   53 KSP Residual norm 7.748560647461e-07
   54 KSP Residual norm 5.999205728586e-07
   55 KSP Residual norm 4.561585762233e-07
   56 KSP Residual norm 3.706628650552e-07
   57 KSP Residual norm 3.265410172797e-07
   58 KSP Residual norm 3.293590423008e-07
   59 KSP Residual norm 3.391473249581e-07
   60 KSP Residual norm 3.141948913859e-07
   61 KSP Residual norm 2.734434019163e-07
   62 KSP Residual norm 2.122393814236e-07
   63 KSP Residual norm 1.799312618961e-07
   64 KSP Residual norm 1.524589865814e-07
   65 KSP Residual norm 1.420346798007e-07
   66 KSP Residual norm 1.329670334278e-07
   67 KSP Residual norm 1.236468730866e-07
   68 KSP Residual norm 1.081920532807e-07
   69 KSP Residual norm 8.640326460684e-08
   70 KSP Residual norm 7.233329781509e-08
   71 KSP Residual norm 5.873858313210e-08
   72 KSP Residual norm 4.862676487180e-08
   73 KSP Residual norm 3.863378706232e-08
   74 KSP Residual norm 2.830135007971e-08
   75 KSP Residual norm 2.354496966257e-08
   76 KSP Residual norm 1.945874592626e-08
   77 KSP Residual norm 1.466758952108e-08
   78 KSP Residual norm 1.243539154133e-08
   79 KSP Residual norm 9.933994823062e-09
   80 KSP Residual norm 8.686746036269e-09
 22 KSP preconditioned resid norm 1.324121731957e+05 true resid norm 3.364664152788e+16 ||r(i)||/||b|| 1.916097234807e+14
    0 KSP Residual norm 8.236570261854e-04
    1 KSP Residual norm 4.706242811827e-04
    2 KSP Residual norm 5.562488873553e-04
    3 KSP Residual norm 5.609783800068e-04
    4 KSP Residual norm 3.454545651402e-04
    5 KSP Residual norm 2.877563228972e-04
    6 KSP Residual norm 2.462870604430e-04
    7 KSP Residual norm 1.716609037117e-04
    8 KSP Residual norm 1.458496918538e-04
    9 KSP Residual norm 1.246082437876e-04
   10 KSP Residual norm 1.053101658509e-04
   11 KSP Residual norm 1.029900301184e-04
   12 KSP Residual norm 1.036363762928e-04
   13 KSP Residual norm 9.824668678896e-05
   14 KSP Residual norm 9.680288224021e-05
   15 KSP Residual norm 7.812856544877e-05
   16 KSP Residual norm 6.294674948349e-05
   17 KSP Residual norm 5.560159461833e-05
   18 KSP Residual norm 4.530925425629e-05
   19 KSP Residual norm 3.766396771754e-05
   20 KSP Residual norm 3.269389848494e-05
   21 KSP Residual norm 3.117697933641e-05
   22 KSP Residual norm 2.917855994036e-05
   23 KSP Residual norm 2.776502616972e-05
   24 KSP Residual norm 2.774930874360e-05
   25 KSP Residual norm 2.630073186780e-05
   26 KSP Residual norm 2.264785016088e-05
   27 KSP Residual norm 1.950080597855e-05
   28 KSP Residual norm 1.638213857905e-05
   29 KSP Residual norm 1.440300714192e-05
   30 KSP Residual norm 1.299794654707e-05
   31 KSP Residual norm 1.128794452692e-05
   32 KSP Residual norm 9.351390145761e-06
   33 KSP Residual norm 8.372411327498e-06
   34 KSP Residual norm 7.863111974186e-06
   35 KSP Residual norm 7.081928409805e-06
   36 KSP Residual norm 6.328178952492e-06
   37 KSP Residual norm 5.770678494521e-06
   38 KSP Residual norm 4.779970847015e-06
   39 KSP Residual norm 4.425298365097e-06
   40 KSP Residual norm 4.079181634024e-06
   41 KSP Residual norm 3.595296107917e-06
   42 KSP Residual norm 3.173499176922e-06
   43 KSP Residual norm 2.805457693519e-06
   44 KSP Residual norm 2.578107803412e-06
   45 KSP Residual norm 2.075042306164e-06
   46 KSP Residual norm 1.755417060717e-06
   47 KSP Residual norm 1.494531720767e-06
   48 KSP Residual norm 1.131456404472e-06
   49 KSP Residual norm 9.072178494548e-07
   50 KSP Residual norm 7.929093739793e-07
   51 KSP Residual norm 6.369327555831e-07
   52 KSP Residual norm 4.950467387802e-07
   53 KSP Residual norm 4.162092175812e-07
   54 KSP Residual norm 3.860153378126e-07
   55 KSP Residual norm 3.438318181045e-07
   56 KSP Residual norm 2.702820435485e-07
   57 KSP Residual norm 2.073784010026e-07
   58 KSP Residual norm 1.651892741294e-07
   59 KSP Residual norm 1.503215788499e-07
   60 KSP Residual norm 1.369953027125e-07
   61 KSP Residual norm 1.111914925219e-07
   62 KSP Residual norm 9.430048851337e-08
   63 KSP Residual norm 7.984752571888e-08
   64 KSP Residual norm 6.530383059670e-08
   65 KSP Residual norm 5.609768876872e-08
   66 KSP Residual norm 4.851481014568e-08
   67 KSP Residual norm 4.362544737446e-08
   68 KSP Residual norm 3.837273733659e-08
   69 KSP Residual norm 3.267537354674e-08
   70 KSP Residual norm 2.757925624430e-08
   71 KSP Residual norm 2.346703494081e-08
   72 KSP Residual norm 2.055401461567e-08
   73 KSP Residual norm 1.802215498353e-08
   74 KSP Residual norm 1.651584385615e-08
   75 KSP Residual norm 1.528391030961e-08
   76 KSP Residual norm 1.335118078025e-08
   77 KSP Residual norm 1.123265559933e-08
   78 KSP Residual norm 9.495952915143e-09
   79 KSP Residual norm 7.787131255500e-09
 23 KSP preconditioned resid norm 1.154787064400e+05 true resid norm 3.664739272329e+16 ||r(i)||/||b|| 2.086982969810e+14
    0 KSP Residual norm 1.561371442395e-03
    1 KSP Residual norm 5.546154721467e-04
    2 KSP Residual norm 5.137400913198e-04
    3 KSP Residual norm 8.288166432585e-04
    4 KSP Residual norm 3.970276322695e-04
    5 KSP Residual norm 2.404563958565e-04
    6 KSP Residual norm 2.405035565019e-04
    7 KSP Residual norm 1.695008772452e-04
    8 KSP Residual norm 1.248158759227e-04
    9 KSP Residual norm 1.235448001048e-04
   10 KSP Residual norm 1.116421920902e-04
   11 KSP Residual norm 1.034494992550e-04
   12 KSP Residual norm 9.646733806247e-05
   13 KSP Residual norm 8.533215401184e-05
   14 KSP Residual norm 8.558747902630e-05
   15 KSP Residual norm 8.287881075581e-05
   16 KSP Residual norm 6.964571124122e-05
   17 KSP Residual norm 5.336826311381e-05
   18 KSP Residual norm 4.271570823568e-05
   19 KSP Residual norm 3.445993009786e-05
   20 KSP Residual norm 2.489905393520e-05
   21 KSP Residual norm 1.902151191460e-05
   22 KSP Residual norm 1.699915744743e-05
   23 KSP Residual norm 1.563527709466e-05
   24 KSP Residual norm 1.461637347331e-05
   25 KSP Residual norm 1.426211606485e-05
   26 KSP Residual norm 1.297804137498e-05
   27 KSP Residual norm 1.184760374627e-05
   28 KSP Residual norm 1.120599992241e-05
   29 KSP Residual norm 1.094260507369e-05
   30 KSP Residual norm 9.730912037432e-06
   31 KSP Residual norm 8.125057600001e-06
   32 KSP Residual norm 6.194194833738e-06
   33 KSP Residual norm 5.505758411786e-06
   34 KSP Residual norm 5.018672482728e-06
   35 KSP Residual norm 4.617820329755e-06
   36 KSP Residual norm 4.290480808024e-06
   37 KSP Residual norm 4.077490465777e-06
   38 KSP Residual norm 3.786772056769e-06
   39 KSP Residual norm 3.383737529423e-06
   40 KSP Residual norm 2.969295091019e-06
   41 KSP Residual norm 2.611618958681e-06
   42 KSP Residual norm 2.325420372727e-06
   43 KSP Residual norm 1.968790355182e-06
   44 KSP Residual norm 1.752245246567e-06
   45 KSP Residual norm 1.439594540088e-06
   46 KSP Residual norm 1.219326411444e-06
   47 KSP Residual norm 1.029236420209e-06
   48 KSP Residual norm 8.760970900512e-07
   49 KSP Residual norm 7.429762117272e-07
   50 KSP Residual norm 6.763390133587e-07
   51 KSP Residual norm 6.660291833363e-07
   52 KSP Residual norm 6.411817883412e-07
   53 KSP Residual norm 5.410486176647e-07
   54 KSP Residual norm 4.959970164233e-07
   55 KSP Residual norm 4.670367172974e-07
   56 KSP Residual norm 4.068916423305e-07
   57 KSP Residual norm 3.724788298233e-07
   58 KSP Residual norm 3.515328700066e-07
   59 KSP Residual norm 3.148652656014e-07
   60 KSP Residual norm 2.862742320464e-07
   61 KSP Residual norm 2.407543434259e-07
   62 KSP Residual norm 2.100653986253e-07
   63 KSP Residual norm 1.803017590707e-07
   64 KSP Residual norm 1.555781249095e-07
   65 KSP Residual norm 1.433530752521e-07
   66 KSP Residual norm 1.321537121012e-07
   67 KSP Residual norm 1.132092024354e-07
   68 KSP Residual norm 8.942805346621e-08
   69 KSP Residual norm 7.110908541938e-08
   70 KSP Residual norm 5.547505324779e-08
   71 KSP Residual norm 4.431699413762e-08
   72 KSP Residual norm 3.826647519651e-08
   73 KSP Residual norm 3.644532359166e-08
   74 KSP Residual norm 2.916786706694e-08
   75 KSP Residual norm 2.500274485671e-08
   76 KSP Residual norm 2.012316307652e-08
   77 KSP Residual norm 1.517678510171e-08
 24 KSP preconditioned resid norm 9.690339957219e+04 true resid norm 4.059415187015e+16 ||r(i)||/||b|| 2.311741636480e+14
    0 KSP Residual norm 1.556379584761e-03
    1 KSP Residual norm 5.880421344453e-04
    2 KSP Residual norm 4.821259040552e-04
    3 KSP Residual norm 6.527388586404e-04
    4 KSP Residual norm 3.151411320522e-04
    5 KSP Residual norm 2.112469967696e-04
    6 KSP Residual norm 1.961263520180e-04
    7 KSP Residual norm 1.442249596814e-04
    8 KSP Residual norm 1.230318626522e-04
    9 KSP Residual norm 1.142902071994e-04
   10 KSP Residual norm 9.188953457618e-05
   11 KSP Residual norm 8.151038952014e-05
   12 KSP Residual norm 7.979013714226e-05
   13 KSP Residual norm 6.750838636857e-05
   14 KSP Residual norm 5.644018931222e-05
   15 KSP Residual norm 4.650616005477e-05
   16 KSP Residual norm 3.700155124834e-05
   17 KSP Residual norm 2.760156237493e-05
   18 KSP Residual norm 2.145589868147e-05
   19 KSP Residual norm 1.851807700041e-05
   20 KSP Residual norm 1.594718920076e-05
   21 KSP Residual norm 1.387886974918e-05
   22 KSP Residual norm 1.217932491402e-05
   23 KSP Residual norm 1.079699866349e-05
   24 KSP Residual norm 1.004503911227e-05
   25 KSP Residual norm 1.065822418695e-05
   26 KSP Residual norm 9.608929912134e-06
   27 KSP Residual norm 8.097127754963e-06
   28 KSP Residual norm 7.457033495404e-06
   29 KSP Residual norm 6.722010154956e-06
   30 KSP Residual norm 5.796871056490e-06
   31 KSP Residual norm 5.302460347968e-06
   32 KSP Residual norm 4.568449546353e-06
   33 KSP Residual norm 4.061053565689e-06
   34 KSP Residual norm 3.469318836675e-06
   35 KSP Residual norm 3.060564125877e-06
   36 KSP Residual norm 2.863167602510e-06
   37 KSP Residual norm 2.747194414911e-06
   38 KSP Residual norm 2.416301399707e-06
   39 KSP Residual norm 2.104212895593e-06
   40 KSP Residual norm 1.971671732801e-06
   41 KSP Residual norm 1.805369446860e-06
   42 KSP Residual norm 1.639537698386e-06
   43 KSP Residual norm 1.431106743958e-06
   44 KSP Residual norm 1.288705217354e-06
   45 KSP Residual norm 1.212898252127e-06
   46 KSP Residual norm 1.119049981475e-06
   47 KSP Residual norm 1.094697639307e-06
   48 KSP Residual norm 9.996240591188e-07
   49 KSP Residual norm 8.490281680693e-07
   50 KSP Residual norm 7.068362841619e-07
   51 KSP Residual norm 6.077406959056e-07
   52 KSP Residual norm 5.126824929047e-07
   53 KSP Residual norm 4.130004917292e-07
   54 KSP Residual norm 3.527425680000e-07
   55 KSP Residual norm 2.984846749382e-07
   56 KSP Residual norm 2.445708088157e-07
   57 KSP Residual norm 2.155906130165e-07
   58 KSP Residual norm 1.809125784884e-07
   59 KSP Residual norm 1.442086482951e-07
   60 KSP Residual norm 1.136136701697e-07
   61 KSP Residual norm 9.220393875071e-08
   62 KSP Residual norm 7.748596207000e-08
   63 KSP Residual norm 6.053968956046e-08
   64 KSP Residual norm 4.764097896279e-08
   65 KSP Residual norm 4.150184523880e-08
   66 KSP Residual norm 3.661923466782e-08
   67 KSP Residual norm 2.864045491650e-08
   68 KSP Residual norm 2.296038006028e-08
   69 KSP Residual norm 2.190301906963e-08
   70 KSP Residual norm 2.132992436822e-08
   71 KSP Residual norm 2.019488349175e-08
   72 KSP Residual norm 1.876187802996e-08
   73 KSP Residual norm 1.613489776597e-08
   74 KSP Residual norm 1.354484515904e-08
 25 KSP preconditioned resid norm 8.541750248371e+04 true resid norm 4.382054411186e+16 ||r(i)||/||b|| 2.495477099279e+14
    0 KSP Residual norm 1.263160981846e-03
    1 KSP Residual norm 5.453863094632e-04
    2 KSP Residual norm 5.465013343199e-04
    3 KSP Residual norm 6.990937414369e-04
    4 KSP Residual norm 3.588790812459e-04
    5 KSP Residual norm 2.422243339963e-04
    6 KSP Residual norm 2.132798833348e-04
    7 KSP Residual norm 1.385817991349e-04
    8 KSP Residual norm 1.198158582849e-04
    9 KSP Residual norm 1.167098732958e-04
   10 KSP Residual norm 1.041730138467e-04
   11 KSP Residual norm 9.718092852428e-05
   12 KSP Residual norm 1.017281492243e-04
   13 KSP Residual norm 9.524346237582e-05
   14 KSP Residual norm 8.107307810974e-05
   15 KSP Residual norm 6.479791655019e-05
   16 KSP Residual norm 5.143584203258e-05
   17 KSP Residual norm 3.927492572006e-05
   18 KSP Residual norm 3.502501673341e-05
   19 KSP Residual norm 3.428225753375e-05
   20 KSP Residual norm 3.022513398514e-05
   21 KSP Residual norm 2.585093494495e-05
   22 KSP Residual norm 2.255662419475e-05
   23 KSP Residual norm 2.031245914470e-05
   24 KSP Residual norm 1.895129486522e-05
   25 KSP Residual norm 1.873167003650e-05
   26 KSP Residual norm 1.767149809833e-05
   27 KSP Residual norm 1.533669672743e-05
   28 KSP Residual norm 1.337823819625e-05
   29 KSP Residual norm 1.164935426879e-05
   30 KSP Residual norm 1.030469085932e-05
   31 KSP Residual norm 9.251274258045e-06
   32 KSP Residual norm 7.889319407405e-06
   33 KSP Residual norm 7.398648887843e-06
   34 KSP Residual norm 6.719989233090e-06
   35 KSP Residual norm 6.224124778495e-06
   36 KSP Residual norm 5.906840948528e-06
   37 KSP Residual norm 5.882272084145e-06
   38 KSP Residual norm 5.130111966192e-06
   39 KSP Residual norm 4.143513923016e-06
   40 KSP Residual norm 3.593655808976e-06
   41 KSP Residual norm 3.259585052371e-06
   42 KSP Residual norm 2.965155208210e-06
   43 KSP Residual norm 2.496942520079e-06
   44 KSP Residual norm 2.139425725541e-06
   45 KSP Residual norm 1.883717681849e-06
   46 KSP Residual norm 1.634940574794e-06
   47 KSP Residual norm 1.462141403815e-06
   48 KSP Residual norm 1.198755279973e-06
   49 KSP Residual norm 9.194929820665e-07
   50 KSP Residual norm 7.373590476703e-07
   51 KSP Residual norm 6.349903500526e-07
   52 KSP Residual norm 4.988886313989e-07
   53 KSP Residual norm 4.062403989953e-07
   54 KSP Residual norm 3.539366182036e-07
   55 KSP Residual norm 3.151049803850e-07
   56 KSP Residual norm 2.604651077725e-07
   57 KSP Residual norm 2.313045737876e-07
   58 KSP Residual norm 1.868022189852e-07
   59 KSP Residual norm 1.587127262635e-07
   60 KSP Residual norm 1.336758372606e-07
   61 KSP Residual norm 1.026283395787e-07
   62 KSP Residual norm 8.337435004763e-08
   63 KSP Residual norm 7.379664552643e-08
   64 KSP Residual norm 6.493089452340e-08
   65 KSP Residual norm 5.710022886919e-08
   66 KSP Residual norm 5.549855150226e-08
   67 KSP Residual norm 5.249395746603e-08
   68 KSP Residual norm 4.913946936156e-08
   69 KSP Residual norm 4.021655118277e-08
   70 KSP Residual norm 3.217659488217e-08
   71 KSP Residual norm 2.787984477306e-08
   72 KSP Residual norm 2.565797697943e-08
   73 KSP Residual norm 2.488147056304e-08
   74 KSP Residual norm 2.328565929184e-08
   75 KSP Residual norm 2.076902358323e-08
   76 KSP Residual norm 1.950959738939e-08
   77 KSP Residual norm 1.723016112698e-08
   78 KSP Residual norm 1.481096851263e-08
   79 KSP Residual norm 1.222480916986e-08
 26 KSP preconditioned resid norm 6.738179237233e+04 true resid norm 4.935818323004e+16 ||r(i)||/||b|| 2.810832645030e+14
    0 KSP Residual norm 2.532727541976e-03
    1 KSP Residual norm 8.981129308270e-04
    2 KSP Residual norm 4.096783864848e-04
    3 KSP Residual norm 4.447317134801e-04
    4 KSP Residual norm 3.283447255887e-04
    5 KSP Residual norm 1.992638886033e-04
    6 KSP Residual norm 2.084015185779e-04
    7 KSP Residual norm 1.628211883442e-04
    8 KSP Residual norm 1.009145418314e-04
    9 KSP Residual norm 9.211134174709e-05
   10 KSP Residual norm 8.821799290148e-05
   11 KSP Residual norm 8.097534529147e-05
   12 KSP Residual norm 8.643643984467e-05
   13 KSP Residual norm 7.714889764732e-05
   14 KSP Residual norm 7.165927997121e-05
   15 KSP Residual norm 6.503150014903e-05
   16 KSP Residual norm 5.702863105054e-05
   17 KSP Residual norm 4.638791482164e-05
   18 KSP Residual norm 3.648950094184e-05
   19 KSP Residual norm 3.139922867124e-05
   20 KSP Residual norm 2.949160237399e-05
   21 KSP Residual norm 2.903589835737e-05
   22 KSP Residual norm 2.867593287288e-05
   23 KSP Residual norm 2.656223924611e-05
   24 KSP Residual norm 2.440204151754e-05
   25 KSP Residual norm 2.118657498380e-05
   26 KSP Residual norm 1.826875212691e-05
   27 KSP Residual norm 1.615747344423e-05
   28 KSP Residual norm 1.324436188513e-05
   29 KSP Residual norm 1.095085310540e-05
   30 KSP Residual norm 9.865457945830e-06
   31 KSP Residual norm 8.844360249318e-06
   32 KSP Residual norm 7.013022656729e-06
   33 KSP Residual norm 5.925900762305e-06
   34 KSP Residual norm 5.476203232789e-06
   35 KSP Residual norm 5.047108232130e-06
   36 KSP Residual norm 4.542341419913e-06
   37 KSP Residual norm 4.024443913505e-06
   38 KSP Residual norm 3.777402182145e-06
   39 KSP Residual norm 3.516395778645e-06
   40 KSP Residual norm 3.067438356702e-06
   41 KSP Residual norm 2.581799296313e-06
   42 KSP Residual norm 2.163930954787e-06
   43 KSP Residual norm 1.789094058217e-06
   44 KSP Residual norm 1.632487994790e-06
   45 KSP Residual norm 1.495577674001e-06
   46 KSP Residual norm 1.342875805099e-06
   47 KSP Residual norm 1.280885115626e-06
   48 KSP Residual norm 1.262726664063e-06
   49 KSP Residual norm 1.077173225008e-06
   50 KSP Residual norm 8.570281319406e-07
   51 KSP Residual norm 7.276861091825e-07
   52 KSP Residual norm 6.280839861458e-07
   53 KSP Residual norm 5.562558050428e-07
   54 KSP Residual norm 4.688731967329e-07
   55 KSP Residual norm 3.903576210168e-07
   56 KSP Residual norm 3.249526367587e-07
   57 KSP Residual norm 3.069134430532e-07
   58 KSP Residual norm 2.722985340041e-07
   59 KSP Residual norm 2.315377531067e-07
   60 KSP Residual norm 2.201907468262e-07
   61 KSP Residual norm 1.941356329188e-07
   62 KSP Residual norm 1.721379303241e-07
   63 KSP Residual norm 1.522248727037e-07
   64 KSP Residual norm 1.511021089591e-07
   65 KSP Residual norm 1.416684233369e-07
   66 KSP Residual norm 1.227387882380e-07
   67 KSP Residual norm 1.055908672073e-07
   68 KSP Residual norm 9.629719013476e-08
   69 KSP Residual norm 8.119707222122e-08
   70 KSP Residual norm 6.199254637314e-08
   71 KSP Residual norm 5.113871963314e-08
   72 KSP Residual norm 4.125768123565e-08
   73 KSP Residual norm 3.233628356351e-08
   74 KSP Residual norm 2.630359020570e-08
   75 KSP Residual norm 2.359214974889e-08
 27 KSP preconditioned resid norm 5.559954270401e+04 true resid norm 5.372513401960e+16 ||r(i)||/||b|| 3.059520239169e+14
    0 KSP Residual norm 2.458298763858e-03
    1 KSP Residual norm 8.860325879629e-04
    2 KSP Residual norm 4.588496391882e-04
    3 KSP Residual norm 5.823852512060e-04
    4 KSP Residual norm 4.684206540287e-04
    5 KSP Residual norm 2.258498957237e-04
    6 KSP Residual norm 1.601370153283e-04
    7 KSP Residual norm 1.285999085506e-04
    8 KSP Residual norm 1.079431492907e-04
    9 KSP Residual norm 1.068766482225e-04
   10 KSP Residual norm 8.595115134436e-05
   11 KSP Residual norm 6.772446087951e-05
   12 KSP Residual norm 7.997266800771e-05
   13 KSP Residual norm 8.215819893902e-05
   14 KSP Residual norm 7.809073521416e-05
   15 KSP Residual norm 7.049933338204e-05
   16 KSP Residual norm 6.153117053635e-05
   17 KSP Residual norm 5.152907441677e-05
   18 KSP Residual norm 4.131243606234e-05
   19 KSP Residual norm 3.653936713893e-05
   20 KSP Residual norm 3.670612866217e-05
   21 KSP Residual norm 3.469717857852e-05
   22 KSP Residual norm 2.954091202217e-05
   23 KSP Residual norm 2.497407543625e-05
   24 KSP Residual norm 2.264578796404e-05
   25 KSP Residual norm 2.203727754619e-05
   26 KSP Residual norm 2.059452450624e-05
   27 KSP Residual norm 1.823633324603e-05
   28 KSP Residual norm 1.534306868733e-05
   29 KSP Residual norm 1.205296972946e-05
   30 KSP Residual norm 1.010201361142e-05
   31 KSP Residual norm 8.966613986159e-06
   32 KSP Residual norm 7.161708702442e-06
   33 KSP Residual norm 6.294437066998e-06
   34 KSP Residual norm 5.743344950855e-06
   35 KSP Residual norm 5.265851938943e-06
   36 KSP Residual norm 4.569796627003e-06
   37 KSP Residual norm 3.865843219107e-06
   38 KSP Residual norm 3.495988681295e-06
   39 KSP Residual norm 3.321436596148e-06
   40 KSP Residual norm 2.898443695496e-06
   41 KSP Residual norm 2.518640123053e-06
   42 KSP Residual norm 2.412762687014e-06
   43 KSP Residual norm 2.094921708489e-06
   44 KSP Residual norm 1.885836807155e-06
   45 KSP Residual norm 1.635967124173e-06
   46 KSP Residual norm 1.275692301594e-06
   47 KSP Residual norm 1.066201426259e-06
   48 KSP Residual norm 1.015176008824e-06
   49 KSP Residual norm 9.594540463366e-07
   50 KSP Residual norm 8.891235336799e-07
   51 KSP Residual norm 8.386074587068e-07
   52 KSP Residual norm 7.394466893496e-07
   53 KSP Residual norm 6.247670879141e-07
   54 KSP Residual norm 5.512270753400e-07
   55 KSP Residual norm 4.583853117419e-07
   56 KSP Residual norm 3.513592819269e-07
   57 KSP Residual norm 3.007522853264e-07
   58 KSP Residual norm 2.799635694475e-07
   59 KSP Residual norm 2.373251646745e-07
   60 KSP Residual norm 2.053307975849e-07
   61 KSP Residual norm 1.781955416543e-07
   62 KSP Residual norm 1.520456708599e-07
   63 KSP Residual norm 1.305278155902e-07
   64 KSP Residual norm 1.247296876179e-07
   65 KSP Residual norm 1.251804981556e-07
   66 KSP Residual norm 1.172659686614e-07
   67 KSP Residual norm 1.022193992228e-07
   68 KSP Residual norm 8.689306315290e-08
   69 KSP Residual norm 6.975176862999e-08
   70 KSP Residual norm 5.369088629595e-08
   71 KSP Residual norm 4.201788088418e-08
   72 KSP Residual norm 3.585898255279e-08
   73 KSP Residual norm 3.060707840494e-08
   74 KSP Residual norm 2.526507406218e-08
   75 KSP Residual norm 2.302835156508e-08
 28 KSP preconditioned resid norm 4.606515567878e+04 true resid norm 5.783437414963e+16 ||r(i)||/||b|| 3.293531816336e+14
    0 KSP Residual norm 3.330167966816e-03
    1 KSP Residual norm 1.166614978432e-03
    2 KSP Residual norm 4.977076305009e-04
    3 KSP Residual norm 5.095461459787e-04
    4 KSP Residual norm 4.747858390030e-04
    5 KSP Residual norm 2.440217064195e-04
    6 KSP Residual norm 1.751104956341e-04
    7 KSP Residual norm 1.412153092133e-04
    8 KSP Residual norm 1.038130149122e-04
    9 KSP Residual norm 9.692495691618e-05
   10 KSP Residual norm 8.503472373424e-05
   11 KSP Residual norm 7.023573382913e-05
   12 KSP Residual norm 7.927166546752e-05
   13 KSP Residual norm 7.838446576939e-05
   14 KSP Residual norm 7.190482942204e-05
   15 KSP Residual norm 6.706937890436e-05
   16 KSP Residual norm 5.785140194637e-05
   17 KSP Residual norm 4.539131844559e-05
   18 KSP Residual norm 3.428795842485e-05
   19 KSP Residual norm 2.953860301033e-05
   20 KSP Residual norm 2.657054843252e-05
   21 KSP Residual norm 2.269546682447e-05
   22 KSP Residual norm 1.842762634814e-05
   23 KSP Residual norm 1.586278074104e-05
   24 KSP Residual norm 1.418321548295e-05
   25 KSP Residual norm 1.428621000145e-05
   26 KSP Residual norm 1.381084130888e-05
   27 KSP Residual norm 1.315707270932e-05
   28 KSP Residual norm 1.241605930814e-05
   29 KSP Residual norm 1.084224179468e-05
   30 KSP Residual norm 8.810422424630e-06
   31 KSP Residual norm 7.745459019640e-06
   32 KSP Residual norm 6.472052902758e-06
   33 KSP Residual norm 5.578443757592e-06
   34 KSP Residual norm 4.766765111330e-06
   35 KSP Residual norm 4.074383764034e-06
   36 KSP Residual norm 3.487468681544e-06
   37 KSP Residual norm 3.160861250108e-06
   38 KSP Residual norm 3.016671170262e-06
   39 KSP Residual norm 2.839181283894e-06
   40 KSP Residual norm 2.599154368057e-06
   41 KSP Residual norm 2.362026226551e-06
   42 KSP Residual norm 2.348722714966e-06
   43 KSP Residual norm 2.177595113405e-06
   44 KSP Residual norm 1.973295820098e-06
   45 KSP Residual norm 1.723782728176e-06
   46 KSP Residual norm 1.311679210459e-06
   47 KSP Residual norm 1.007973849961e-06
   48 KSP Residual norm 8.436412131832e-07
   49 KSP Residual norm 7.477532633586e-07
   50 KSP Residual norm 6.696960026556e-07
   51 KSP Residual norm 6.386178770376e-07
   52 KSP Residual norm 6.042337366551e-07
   53 KSP Residual norm 5.341764196295e-07
   54 KSP Residual norm 4.945411067002e-07
   55 KSP Residual norm 4.571638274256e-07
   56 KSP Residual norm 3.801193049780e-07
   57 KSP Residual norm 3.246928135180e-07
   58 KSP Residual norm 3.094877886287e-07
   59 KSP Residual norm 2.771049744814e-07
   60 KSP Residual norm 2.500935768214e-07
   61 KSP Residual norm 2.310724465447e-07
   62 KSP Residual norm 2.085745148626e-07
   63 KSP Residual norm 1.744735959340e-07
   64 KSP Residual norm 1.509478279392e-07
   65 KSP Residual norm 1.358954071493e-07
   66 KSP Residual norm 1.167340661337e-07
   67 KSP Residual norm 1.021900109069e-07
   68 KSP Residual norm 8.899532715016e-08
   69 KSP Residual norm 8.006765682760e-08
   70 KSP Residual norm 7.018250953598e-08
   71 KSP Residual norm 5.664446960496e-08
   72 KSP Residual norm 4.364335238503e-08
   73 KSP Residual norm 3.225710840994e-08
 29 KSP preconditioned resid norm 3.847038156005e+04 true resid norm 6.227152566671e+16 ||r(i)||/||b|| 3.546217177080e+14
    0 KSP Residual norm 4.202966787944e-03
    1 KSP Residual norm 1.476228608294e-03
    2 KSP Residual norm 6.078893181096e-04
    3 KSP Residual norm 5.162213519161e-04
    4 KSP Residual norm 4.907152857467e-04
    5 KSP Residual norm 2.637215509866e-04
    6 KSP Residual norm 2.010791109289e-04
    7 KSP Residual norm 1.921418660075e-04
    8 KSP Residual norm 1.360429566542e-04
    9 KSP Residual norm 1.232082276212e-04
   10 KSP Residual norm 1.118122749298e-04
   11 KSP Residual norm 8.855241262449e-05
   12 KSP Residual norm 9.578167955567e-05
   13 KSP Residual norm 9.728393408392e-05
   14 KSP Residual norm 9.148679109032e-05
   15 KSP Residual norm 8.400718910102e-05
   16 KSP Residual norm 7.067989753275e-05
   17 KSP Residual norm 5.597927515879e-05
   18 KSP Residual norm 4.443794083219e-05
   19 KSP Residual norm 3.905097938906e-05
   20 KSP Residual norm 3.773247510791e-05
   21 KSP Residual norm 3.640986535985e-05
   22 KSP Residual norm 3.319083246437e-05
   23 KSP Residual norm 2.998367684259e-05
   24 KSP Residual norm 2.626685507765e-05
   25 KSP Residual norm 2.594007510751e-05
   26 KSP Residual norm 2.526568911596e-05
   27 KSP Residual norm 2.269335562029e-05
   28 KSP Residual norm 1.865868014539e-05
   29 KSP Residual norm 1.587284482795e-05
   30 KSP Residual norm 1.348975295845e-05
   31 KSP Residual norm 1.221250531481e-05
   32 KSP Residual norm 1.012410350609e-05
   33 KSP Residual norm 8.650012518139e-06
   34 KSP Residual norm 7.468922340080e-06
   35 KSP Residual norm 6.551584695498e-06
   36 KSP Residual norm 5.790829479362e-06
   37 KSP Residual norm 5.322203833066e-06
   38 KSP Residual norm 4.893153971012e-06
   39 KSP Residual norm 4.345808327390e-06
   40 KSP Residual norm 3.689817967514e-06
   41 KSP Residual norm 3.212922552460e-06
   42 KSP Residual norm 2.992187105683e-06
   43 KSP Residual norm 2.655583659965e-06
   44 KSP Residual norm 2.269001782011e-06
   45 KSP Residual norm 2.062820568696e-06
   46 KSP Residual norm 1.793993524875e-06
   47 KSP Residual norm 1.620561353911e-06
   48 KSP Residual norm 1.558144431224e-06
   49 KSP Residual norm 1.365019964765e-06
   50 KSP Residual norm 1.134587733675e-06
   51 KSP Residual norm 1.026575836641e-06
   52 KSP Residual norm 9.187620210473e-07
   53 KSP Residual norm 7.544642568055e-07
   54 KSP Residual norm 6.394745655338e-07
   55 KSP Residual norm 5.742379060414e-07
   56 KSP Residual norm 4.971178596498e-07
   57 KSP Residual norm 4.608218030992e-07
   58 KSP Residual norm 4.359319043829e-07
   59 KSP Residual norm 3.863190705487e-07
   60 KSP Residual norm 3.459223040039e-07
   61 KSP Residual norm 2.859792196232e-07
   62 KSP Residual norm 2.319741419507e-07
   63 KSP Residual norm 1.823871484709e-07
   64 KSP Residual norm 1.585690065684e-07
   65 KSP Residual norm 1.405853273542e-07
   66 KSP Residual norm 1.301176318742e-07
   67 KSP Residual norm 1.303446840750e-07
   68 KSP Residual norm 1.191442369748e-07
   69 KSP Residual norm 1.016544010795e-07
   70 KSP Residual norm 8.381356465844e-08
   71 KSP Residual norm 6.958741218310e-08
   72 KSP Residual norm 5.667207918522e-08
   73 KSP Residual norm 4.463762060517e-08
   74 KSP Residual norm 3.570573769498e-08
    0 KSP Residual norm 2.561030501163e+02
    1 KSP Residual norm 8.836165701345e+01
    2 KSP Residual norm 3.062123346477e+01
    3 KSP Residual norm 1.751946280215e+01
    4 KSP Residual norm 1.593042090879e+01
    5 KSP Residual norm 9.001478876471e+00
    6 KSP Residual norm 5.144242671251e+00
    7 KSP Residual norm 4.274948494095e+00
    8 KSP Residual norm 3.198965978367e+00
    9 KSP Residual norm 2.861732283102e+00
   10 KSP Residual norm 2.753783810750e+00
   11 KSP Residual norm 1.953048037505e+00
   12 KSP Residual norm 1.666516164050e+00
   13 KSP Residual norm 1.550244629808e+00
   14 KSP Residual norm 1.435050153277e+00
   15 KSP Residual norm 1.415962906052e+00
   16 KSP Residual norm 1.362117136956e+00
   17 KSP Residual norm 1.389161559294e+00
   18 KSP Residual norm 1.202872558983e+00
   19 KSP Residual norm 8.623780487822e-01
   20 KSP Residual norm 6.992608823968e-01
   21 KSP Residual norm 6.210826811507e-01
   22 KSP Residual norm 5.560173122598e-01
   23 KSP Residual norm 5.046947259723e-01
   24 KSP Residual norm 4.696872623868e-01
   25 KSP Residual norm 4.869911928727e-01
   26 KSP Residual norm 4.944861821388e-01
   27 KSP Residual norm 4.766650251589e-01
   28 KSP Residual norm 4.204824246722e-01
   29 KSP Residual norm 3.514495840277e-01
   30 KSP Residual norm 2.571778777698e-01
   31 KSP Residual norm 2.152328565921e-01
   32 KSP Residual norm 1.871195935424e-01
   33 KSP Residual norm 1.737397580891e-01
   34 KSP Residual norm 1.637274475870e-01
   35 KSP Residual norm 1.633080010112e-01
   36 KSP Residual norm 1.574801409758e-01
   37 KSP Residual norm 1.287109783196e-01
   38 KSP Residual norm 9.939546805435e-02
   39 KSP Residual norm 8.347268333523e-02
   40 KSP Residual norm 7.315246118620e-02
   41 KSP Residual norm 6.168543819919e-02
   42 KSP Residual norm 5.571146020382e-02
   43 KSP Residual norm 4.921127306288e-02
   44 KSP Residual norm 4.196320755575e-02
   45 KSP Residual norm 4.045096390520e-02
   46 KSP Residual norm 3.583856895768e-02
   47 KSP Residual norm 2.966981574858e-02
   48 KSP Residual norm 2.674067714817e-02
   49 KSP Residual norm 2.470758707879e-02
   50 KSP Residual norm 2.160278212171e-02
   51 KSP Residual norm 1.799655748966e-02
   52 KSP Residual norm 1.585798913990e-02
   53 KSP Residual norm 1.313791274135e-02
   54 KSP Residual norm 1.033589043269e-02
   55 KSP Residual norm 9.693683874679e-03
   56 KSP Residual norm 8.950684424769e-03
   57 KSP Residual norm 6.944499386194e-03
   58 KSP Residual norm 5.111071810144e-03
   59 KSP Residual norm 3.768053417896e-03
   60 KSP Residual norm 2.986414434813e-03
   61 KSP Residual norm 2.477901432098e-03
 30 KSP preconditioned resid norm 3.341483541882e+04 true resid norm 6.606668648019e+16 ||r(i)||/||b|| 3.762342674607e+14
    0 KSP Residual norm 7.797259945442e-03
    1 KSP Residual norm 2.679501064942e-03
    2 KSP Residual norm 9.584759442441e-04
    3 KSP Residual norm 5.797289656897e-04
    4 KSP Residual norm 5.520259770641e-04
    5 KSP Residual norm 3.116626077413e-04
    6 KSP Residual norm 1.868471808470e-04
    7 KSP Residual norm 1.673264745192e-04
    8 KSP Residual norm 1.379472773140e-04
    9 KSP Residual norm 1.342369259729e-04
   10 KSP Residual norm 1.300813713935e-04
   11 KSP Residual norm 9.811989055758e-05
   12 KSP Residual norm 9.454850504853e-05
   13 KSP Residual norm 9.484914974655e-05
   14 KSP Residual norm 9.202930116087e-05
   15 KSP Residual norm 8.890497265314e-05
   16 KSP Residual norm 8.143285754864e-05
   17 KSP Residual norm 7.295428613524e-05
   18 KSP Residual norm 5.614277397680e-05
   19 KSP Residual norm 4.108344334938e-05
   20 KSP Residual norm 3.778468854239e-05
   21 KSP Residual norm 3.714372508864e-05
   22 KSP Residual norm 3.506071987150e-05
   23 KSP Residual norm 3.240235906008e-05
   24 KSP Residual norm 3.006912713671e-05
   25 KSP Residual norm 3.004714161980e-05
   26 KSP Residual norm 2.968594648008e-05
   27 KSP Residual norm 2.807930547027e-05
   28 KSP Residual norm 2.434595876551e-05
   29 KSP Residual norm 1.979734001230e-05
   30 KSP Residual norm 1.440035923661e-05
   31 KSP Residual norm 1.175020281064e-05
   32 KSP Residual norm 9.350918145626e-06
   33 KSP Residual norm 7.646393875997e-06
   34 KSP Residual norm 6.306665340007e-06
   35 KSP Residual norm 5.483551514071e-06
   36 KSP Residual norm 4.675905845790e-06
   37 KSP Residual norm 3.954450758555e-06
   38 KSP Residual norm 3.383919840203e-06
   39 KSP Residual norm 3.151287951345e-06
   40 KSP Residual norm 2.835856823407e-06
   41 KSP Residual norm 2.195852572361e-06
   42 KSP Residual norm 1.830496232383e-06
   43 KSP Residual norm 1.505310977498e-06
   44 KSP Residual norm 1.270094286825e-06
   45 KSP Residual norm 1.233744824204e-06
   46 KSP Residual norm 1.111131007245e-06
   47 KSP Residual norm 9.290548502840e-07
   48 KSP Residual norm 7.996753766714e-07
   49 KSP Residual norm 6.861434803219e-07
   50 KSP Residual norm 5.550478072304e-07
   51 KSP Residual norm 4.534223790442e-07
   52 KSP Residual norm 3.921218050596e-07
   53 KSP Residual norm 3.242424310659e-07
   54 KSP Residual norm 2.652693775270e-07
   55 KSP Residual norm 2.500495028937e-07
   56 KSP Residual norm 2.201771254649e-07
   57 KSP Residual norm 1.679933859797e-07
   58 KSP Residual norm 1.245564232331e-07
   59 KSP Residual norm 1.007838988898e-07
   60 KSP Residual norm 9.771698237786e-08
   61 KSP Residual norm 9.800243337093e-08
   62 KSP Residual norm 9.455738173231e-08
   63 KSP Residual norm 7.946004819149e-08
   64 KSP Residual norm 6.440610372555e-08
 31 KSP preconditioned resid norm 3.296191763413e+04 true resid norm 6.615646640361e+16 ||r(i)||/||b|| 3.767455430449e+14
    0 KSP Residual norm 2.904144722677e-03
    1 KSP Residual norm 9.373684549838e-04
    2 KSP Residual norm 6.896595968003e-04
    3 KSP Residual norm 1.659195972770e-03
    4 KSP Residual norm 1.734578486636e-03
    5 KSP Residual norm 1.171151355373e-03
    6 KSP Residual norm 1.048638276144e-03
    7 KSP Residual norm 8.371975388609e-04
    8 KSP Residual norm 5.775672536419e-04
    9 KSP Residual norm 5.761628584397e-04
   10 KSP Residual norm 5.025132838387e-04
   11 KSP Residual norm 4.181865883556e-04
   12 KSP Residual norm 3.728074434143e-04
   13 KSP Residual norm 2.938452282494e-04
   14 KSP Residual norm 2.787110154328e-04
   15 KSP Residual norm 2.809873705928e-04
   16 KSP Residual norm 3.076063930203e-04
   17 KSP Residual norm 2.830617191700e-04
   18 KSP Residual norm 2.328607785399e-04
   19 KSP Residual norm 1.913047163477e-04
   20 KSP Residual norm 1.497771428830e-04
   21 KSP Residual norm 1.163652522617e-04
   22 KSP Residual norm 9.533307337996e-05
   23 KSP Residual norm 8.395041556320e-05
   24 KSP Residual norm 7.130152392621e-05
   25 KSP Residual norm 5.669716728571e-05
   26 KSP Residual norm 4.601740554886e-05
   27 KSP Residual norm 4.179109301190e-05
   28 KSP Residual norm 3.839908391757e-05
   29 KSP Residual norm 3.234709171163e-05
   30 KSP Residual norm 2.875606376627e-05
   31 KSP Residual norm 2.695776138209e-05
   32 KSP Residual norm 2.172186613244e-05
   33 KSP Residual norm 1.813899202853e-05
   34 KSP Residual norm 1.549698141987e-05
   35 KSP Residual norm 1.271397247367e-05
   36 KSP Residual norm 1.021722108874e-05
   37 KSP Residual norm 8.699684443694e-06
   38 KSP Residual norm 7.808715453059e-06
   39 KSP Residual norm 7.268042292887e-06
   40 KSP Residual norm 6.512367842549e-06
   41 KSP Residual norm 5.607165686161e-06
   42 KSP Residual norm 5.113585837530e-06
   43 KSP Residual norm 4.184641994601e-06
   44 KSP Residual norm 3.605545114354e-06
   45 KSP Residual norm 3.117061030589e-06
   46 KSP Residual norm 2.513810214960e-06
   47 KSP Residual norm 1.960496319790e-06
   48 KSP Residual norm 1.717924307862e-06
   49 KSP Residual norm 1.588866094637e-06
   50 KSP Residual norm 1.442720205623e-06
   51 KSP Residual norm 1.290576562383e-06
   52 KSP Residual norm 1.118197050529e-06
   53 KSP Residual norm 9.118619804648e-07
   54 KSP Residual norm 7.707014685986e-07
   55 KSP Residual norm 7.630101183250e-07
   56 KSP Residual norm 6.521313997880e-07
   57 KSP Residual norm 5.898581200397e-07
   58 KSP Residual norm 5.456276588104e-07
   59 KSP Residual norm 4.252023915298e-07
   60 KSP Residual norm 3.394011554638e-07
   61 KSP Residual norm 2.667137005476e-07
   62 KSP Residual norm 2.227852737240e-07
   63 KSP Residual norm 1.931766295071e-07
   64 KSP Residual norm 1.827060691266e-07
   65 KSP Residual norm 1.638484435979e-07
   66 KSP Residual norm 1.332291816230e-07
   67 KSP Residual norm 1.002097721413e-07
   68 KSP Residual norm 8.261219925635e-08
   69 KSP Residual norm 7.574036729502e-08
   70 KSP Residual norm 7.096904751142e-08
   71 KSP Residual norm 6.521151897598e-08
   72 KSP Residual norm 6.278867079833e-08
   73 KSP Residual norm 6.107563816735e-08
   74 KSP Residual norm 5.478639174238e-08
   75 KSP Residual norm 5.068904104777e-08
   76 KSP Residual norm 4.423794391261e-08
   77 KSP Residual norm 3.640955493348e-08
   78 KSP Residual norm 3.041644716433e-08
   79 KSP Residual norm 2.862829135848e-08
 32 KSP preconditioned resid norm 3.204272803125e+04 true resid norm 6.639310280626e+16 ||r(i)||/||b|| 3.780931317972e+14
    0 KSP Residual norm 2.028523756621e-03
    1 KSP Residual norm 8.876569712406e-04
    2 KSP Residual norm 9.188193328623e-04
    3 KSP Residual norm 1.266560799388e-03
    4 KSP Residual norm 1.234268416084e-03
    5 KSP Residual norm 1.175764976746e-03
    6 KSP Residual norm 1.267098102358e-03
    7 KSP Residual norm 1.082536923131e-03
    8 KSP Residual norm 9.335329621098e-04
    9 KSP Residual norm 8.197719400363e-04
   10 KSP Residual norm 5.855156348359e-04
   11 KSP Residual norm 5.009262627853e-04
   12 KSP Residual norm 4.308927868747e-04
   13 KSP Residual norm 3.218764927142e-04
   14 KSP Residual norm 2.643860477153e-04
   15 KSP Residual norm 2.325623755896e-04
   16 KSP Residual norm 2.150121250574e-04
   17 KSP Residual norm 2.012349369169e-04
   18 KSP Residual norm 1.884310415131e-04
   19 KSP Residual norm 1.887882895914e-04
   20 KSP Residual norm 1.620922731117e-04
   21 KSP Residual norm 1.260687411049e-04
   22 KSP Residual norm 9.266081005252e-05
   23 KSP Residual norm 7.164301468863e-05
   24 KSP Residual norm 6.060010692426e-05
   25 KSP Residual norm 5.264197558682e-05
   26 KSP Residual norm 4.125033470114e-05
   27 KSP Residual norm 3.327424455051e-05
   28 KSP Residual norm 2.745008555280e-05
   29 KSP Residual norm 2.382719610643e-05
   30 KSP Residual norm 2.238919683223e-05
   31 KSP Residual norm 2.047008359348e-05
   32 KSP Residual norm 1.710298147383e-05
   33 KSP Residual norm 1.499276775809e-05
   34 KSP Residual norm 1.365783854728e-05
   35 KSP Residual norm 1.157089747420e-05
   36 KSP Residual norm 9.491111576942e-06
   37 KSP Residual norm 8.021066958218e-06
   38 KSP Residual norm 6.886928664489e-06
   39 KSP Residual norm 5.306066294273e-06
   40 KSP Residual norm 4.291953383754e-06
   41 KSP Residual norm 3.861521821874e-06
   42 KSP Residual norm 3.489108780704e-06
   43 KSP Residual norm 3.506837509708e-06
   44 KSP Residual norm 3.497377191985e-06
   45 KSP Residual norm 2.979103396428e-06
   46 KSP Residual norm 2.218547467196e-06
   47 KSP Residual norm 1.926877053237e-06
   48 KSP Residual norm 1.780413795970e-06
   49 KSP Residual norm 1.510574363467e-06
   50 KSP Residual norm 1.344482159893e-06
   51 KSP Residual norm 1.162842933482e-06
   52 KSP Residual norm 9.686110235355e-07
   53 KSP Residual norm 8.217617451062e-07
   54 KSP Residual norm 6.807628842970e-07
   55 KSP Residual norm 6.289036905607e-07
   56 KSP Residual norm 5.983342704629e-07
   57 KSP Residual norm 5.918636606763e-07
   58 KSP Residual norm 5.703757954302e-07
   59 KSP Residual norm 4.584962449423e-07
   60 KSP Residual norm 3.962550272201e-07
   61 KSP Residual norm 3.154476086813e-07
   62 KSP Residual norm 2.667411808795e-07
   63 KSP Residual norm 2.408476589671e-07
   64 KSP Residual norm 2.214192017955e-07
   65 KSP Residual norm 1.959114317829e-07
   66 KSP Residual norm 1.732010527668e-07
   67 KSP Residual norm 1.428592882355e-07
   68 KSP Residual norm 1.141232657625e-07
   69 KSP Residual norm 9.634172841510e-08
   70 KSP Residual norm 8.430685594210e-08
   71 KSP Residual norm 8.209006692464e-08
   72 KSP Residual norm 7.783587416129e-08
   73 KSP Residual norm 6.985928952313e-08
   74 KSP Residual norm 5.847962598254e-08
   75 KSP Residual norm 5.182937693660e-08
   76 KSP Residual norm 4.771355973899e-08
   77 KSP Residual norm 3.958143414171e-08
   78 KSP Residual norm 3.147673914128e-08
   79 KSP Residual norm 2.747339961043e-08
   80 KSP Residual norm 2.396477243292e-08
   81 KSP Residual norm 2.056277979285e-08
   82 KSP Residual norm 1.789212741682e-08
 33 KSP preconditioned resid norm 2.994817324340e+04 true resid norm 6.707071577786e+16 ||r(i)||/||b|| 3.819519785712e+14
    0 KSP Residual norm 3.497608192516e-03
    1 KSP Residual norm 1.252043818295e-03
    2 KSP Residual norm 5.696723552997e-04
    3 KSP Residual norm 6.797518492903e-04
    4 KSP Residual norm 7.142091157792e-04
    5 KSP Residual norm 4.926896702847e-04
    6 KSP Residual norm 5.269037257366e-04
    7 KSP Residual norm 4.761410133646e-04
    8 KSP Residual norm 3.783683691436e-04
    9 KSP Residual norm 4.086614529668e-04
   10 KSP Residual norm 3.709875689061e-04
   11 KSP Residual norm 3.045979386093e-04
   12 KSP Residual norm 2.939427016228e-04
   13 KSP Residual norm 2.085106407861e-04
   14 KSP Residual norm 1.498141300579e-04
   15 KSP Residual norm 1.238623890144e-04
   16 KSP Residual norm 1.149556534544e-04
   17 KSP Residual norm 1.013265998930e-04
   18 KSP Residual norm 8.878643389115e-05
   19 KSP Residual norm 8.859973774871e-05
   20 KSP Residual norm 9.207371837586e-05
   21 KSP Residual norm 8.560349806843e-05
   22 KSP Residual norm 7.462046857923e-05
   23 KSP Residual norm 6.455341087625e-05
   24 KSP Residual norm 6.006355831581e-05
   25 KSP Residual norm 5.627721416734e-05
   26 KSP Residual norm 4.808613710491e-05
   27 KSP Residual norm 4.021137771455e-05
   28 KSP Residual norm 3.335847835798e-05
   29 KSP Residual norm 2.730499637432e-05
   30 KSP Residual norm 2.534401897779e-05
   31 KSP Residual norm 2.477626864724e-05
   32 KSP Residual norm 2.211349910047e-05
   33 KSP Residual norm 1.991776226779e-05
   34 KSP Residual norm 1.745023494380e-05
   35 KSP Residual norm 1.475407128769e-05
   36 KSP Residual norm 1.200720574114e-05
   37 KSP Residual norm 1.035195074627e-05
   38 KSP Residual norm 9.965243200742e-06
   39 KSP Residual norm 9.709371137245e-06
   40 KSP Residual norm 8.540665491641e-06
   41 KSP Residual norm 7.301730369111e-06
   42 KSP Residual norm 6.943881464745e-06
   43 KSP Residual norm 6.049212969577e-06
   44 KSP Residual norm 5.561340028762e-06
   45 KSP Residual norm 5.057262335930e-06
   46 KSP Residual norm 4.109471328295e-06
   47 KSP Residual norm 3.517028197167e-06
   48 KSP Residual norm 3.441769119869e-06
   49 KSP Residual norm 3.004705874164e-06
   50 KSP Residual norm 2.445452493814e-06
   51 KSP Residual norm 2.202899953692e-06
   52 KSP Residual norm 1.915823231868e-06
   53 KSP Residual norm 1.567616029765e-06
   54 KSP Residual norm 1.430359292474e-06
   55 KSP Residual norm 1.389146056863e-06
   56 KSP Residual norm 1.222334222011e-06
   57 KSP Residual norm 1.096157570403e-06
   58 KSP Residual norm 9.717051709099e-07
   59 KSP Residual norm 8.175803053283e-07
   60 KSP Residual norm 7.175769704252e-07
   61 KSP Residual norm 6.226268138772e-07
   62 KSP Residual norm 5.739329779006e-07
   63 KSP Residual norm 5.420049760341e-07
   64 KSP Residual norm 5.166886898884e-07
   65 KSP Residual norm 4.617547348970e-07
   66 KSP Residual norm 3.659692698579e-07
   67 KSP Residual norm 2.835236244727e-07
   68 KSP Residual norm 2.399596906063e-07
   69 KSP Residual norm 2.041867739512e-07
   70 KSP Residual norm 1.631059225505e-07
   71 KSP Residual norm 1.306121888779e-07
   72 KSP Residual norm 1.121152431501e-07
   73 KSP Residual norm 1.005781454747e-07
   74 KSP Residual norm 9.569674217905e-08
   75 KSP Residual norm 9.285958701444e-08
   76 KSP Residual norm 8.342188701241e-08
   77 KSP Residual norm 6.515847445233e-08
   78 KSP Residual norm 5.257140633432e-08
   79 KSP Residual norm 4.674491135263e-08
   80 KSP Residual norm 3.842818899627e-08
   81 KSP Residual norm 3.467828976262e-08
 34 KSP preconditioned resid norm 2.929463537058e+04 true resid norm 6.741363970494e+16 ||r(i)||/||b|| 3.839048498195e+14
    0 KSP Residual norm 2.589139700298e-03
    1 KSP Residual norm 9.983027718487e-04
    2 KSP Residual norm 7.007204205488e-04
    3 KSP Residual norm 1.225224334150e-03
    4 KSP Residual norm 1.359268313499e-03
    5 KSP Residual norm 1.151010144169e-03
    6 KSP Residual norm 1.314584298993e-03
    7 KSP Residual norm 9.906027188392e-04
    8 KSP Residual norm 5.557936682819e-04
    9 KSP Residual norm 4.491607146994e-04
   10 KSP Residual norm 3.567735763910e-04
   11 KSP Residual norm 2.794890581112e-04
   12 KSP Residual norm 2.755508236802e-04
   13 KSP Residual norm 2.190681644481e-04
   14 KSP Residual norm 1.829754524297e-04
   15 KSP Residual norm 1.673165003873e-04
   16 KSP Residual norm 1.605229614111e-04
   17 KSP Residual norm 1.496662818939e-04
   18 KSP Residual norm 1.359863660043e-04
   19 KSP Residual norm 1.274587727249e-04
   20 KSP Residual norm 1.094541880668e-04
   21 KSP Residual norm 8.730828177944e-05
   22 KSP Residual norm 7.070154511965e-05
   23 KSP Residual norm 5.962533554374e-05
   24 KSP Residual norm 4.979028126356e-05
   25 KSP Residual norm 4.414515735896e-05
   26 KSP Residual norm 4.030419076830e-05
   27 KSP Residual norm 3.799196089126e-05
   28 KSP Residual norm 3.559352262423e-05
   29 KSP Residual norm 3.157738649482e-05
   30 KSP Residual norm 2.796533992761e-05
   31 KSP Residual norm 2.662187181728e-05
   32 KSP Residual norm 2.285914119979e-05
   33 KSP Residual norm 2.050372960136e-05
   34 KSP Residual norm 1.877713021908e-05
   35 KSP Residual norm 1.546143623532e-05
   36 KSP Residual norm 1.230947537342e-05
   37 KSP Residual norm 1.047004633844e-05
   38 KSP Residual norm 1.000630157756e-05
   39 KSP Residual norm 1.031209247156e-05
   40 KSP Residual norm 9.324091175017e-06
   41 KSP Residual norm 7.856465251838e-06
   42 KSP Residual norm 7.267846769612e-06
   43 KSP Residual norm 6.629384892986e-06
   44 KSP Residual norm 5.940062001487e-06
   45 KSP Residual norm 4.866405176769e-06
   46 KSP Residual norm 4.109903372555e-06
   47 KSP Residual norm 3.709492951897e-06
   48 KSP Residual norm 3.684341808762e-06
   49 KSP Residual norm 3.634997061392e-06
   50 KSP Residual norm 3.324597818681e-06
   51 KSP Residual norm 2.871224282297e-06
   52 KSP Residual norm 2.461711329504e-06
   53 KSP Residual norm 2.101038752901e-06
   54 KSP Residual norm 2.043265823365e-06
   55 KSP Residual norm 1.933269066075e-06
   56 KSP Residual norm 1.718206916819e-06
   57 KSP Residual norm 1.546637466467e-06
   58 KSP Residual norm 1.283708430958e-06
   59 KSP Residual norm 9.179091529614e-07
   60 KSP Residual norm 7.173003333839e-07
   61 KSP Residual norm 5.753656753846e-07
   62 KSP Residual norm 4.602861709338e-07
   63 KSP Residual norm 3.506801284338e-07
   64 KSP Residual norm 2.928185807349e-07
   65 KSP Residual norm 2.453094164898e-07
   66 KSP Residual norm 1.946637405251e-07
   67 KSP Residual norm 1.526312961529e-07
   68 KSP Residual norm 1.293714316702e-07
   69 KSP Residual norm 1.095362693575e-07
   70 KSP Residual norm 8.860329645016e-08
   71 KSP Residual norm 7.376945042652e-08
   72 KSP Residual norm 6.788874756726e-08
   73 KSP Residual norm 6.169937240609e-08
   74 KSP Residual norm 5.225979194791e-08
   75 KSP Residual norm 4.488850373250e-08
   76 KSP Residual norm 3.770217755811e-08
   77 KSP Residual norm 2.894005449234e-08
   78 KSP Residual norm 2.220190849960e-08
 35 KSP preconditioned resid norm 2.807666085858e+04 true resid norm 6.829390007285e+16 ||r(i)||/||b|| 3.889177259351e+14
    0 KSP Residual norm 3.098662399116e-03
    1 KSP Residual norm 1.180547810119e-03
    2 KSP Residual norm 7.436704036245e-04
    3 KSP Residual norm 9.930700090533e-04
    4 KSP Residual norm 1.150959993373e-03
    5 KSP Residual norm 9.673225003264e-04
    6 KSP Residual norm 1.065935339232e-03
    7 KSP Residual norm 8.308041540495e-04
    8 KSP Residual norm 6.158700416638e-04
    9 KSP Residual norm 5.407803669533e-04
   10 KSP Residual norm 3.993953740973e-04
   11 KSP Residual norm 3.111767806300e-04
   12 KSP Residual norm 3.158121400737e-04
   13 KSP Residual norm 2.917974185044e-04
   14 KSP Residual norm 2.618667748065e-04
   15 KSP Residual norm 2.299670955265e-04
   16 KSP Residual norm 1.996762500852e-04
   17 KSP Residual norm 1.597174224603e-04
   18 KSP Residual norm 1.279315695407e-04
   19 KSP Residual norm 1.188389407269e-04
   20 KSP Residual norm 1.166072840864e-04
   21 KSP Residual norm 1.002838515736e-04
   22 KSP Residual norm 7.894440720864e-05
   23 KSP Residual norm 6.525893622434e-05
   24 KSP Residual norm 5.504880153731e-05
   25 KSP Residual norm 5.322585078355e-05
   26 KSP Residual norm 4.878772351575e-05
   27 KSP Residual norm 4.321419437546e-05
   28 KSP Residual norm 3.715287862839e-05
   29 KSP Residual norm 3.121464511085e-05
   30 KSP Residual norm 2.739541677709e-05
   31 KSP Residual norm 2.476287838252e-05
   32 KSP Residual norm 2.011894148168e-05
   33 KSP Residual norm 1.774369907698e-05
   34 KSP Residual norm 1.609978187105e-05
   35 KSP Residual norm 1.382882493105e-05
   36 KSP Residual norm 1.175604056930e-05
   37 KSP Residual norm 1.099471731396e-05
   38 KSP Residual norm 1.137546827360e-05
   39 KSP Residual norm 1.078631905743e-05
   40 KSP Residual norm 9.016333412395e-06
   41 KSP Residual norm 7.240946919130e-06
   42 KSP Residual norm 6.666750884017e-06
   43 KSP Residual norm 6.123543105095e-06
   44 KSP Residual norm 6.004987237460e-06
   45 KSP Residual norm 5.911099981011e-06
   46 KSP Residual norm 5.226322369404e-06
   47 KSP Residual norm 4.569614713640e-06
   48 KSP Residual norm 4.070573611138e-06
   49 KSP Residual norm 3.542094674392e-06
   50 KSP Residual norm 3.022366098988e-06
   51 KSP Residual norm 2.678088384944e-06
   52 KSP Residual norm 2.392334411702e-06
   53 KSP Residual norm 2.094546520202e-06
   54 KSP Residual norm 1.882135762528e-06
   55 KSP Residual norm 1.674145655792e-06
   56 KSP Residual norm 1.422304233988e-06
   57 KSP Residual norm 1.299727387385e-06
   58 KSP Residual norm 1.222209535345e-06
   59 KSP Residual norm 1.140815252444e-06
   60 KSP Residual norm 1.025476070598e-06
   61 KSP Residual norm 8.887532497863e-07
   62 KSP Residual norm 7.340876430948e-07
   63 KSP Residual norm 6.261403311382e-07
   64 KSP Residual norm 5.531483214585e-07
   65 KSP Residual norm 4.730880210327e-07
   66 KSP Residual norm 3.793560254514e-07
   67 KSP Residual norm 2.881108070948e-07
   68 KSP Residual norm 2.303591779009e-07
   69 KSP Residual norm 2.060969773595e-07
   70 KSP Residual norm 1.760921569719e-07
   71 KSP Residual norm 1.724202858344e-07
   72 KSP Residual norm 1.648948025189e-07
   73 KSP Residual norm 1.410951065221e-07
   74 KSP Residual norm 1.126471720254e-07
   75 KSP Residual norm 1.020990935966e-07
   76 KSP Residual norm 9.646852948285e-08
   77 KSP Residual norm 8.294022486813e-08
   78 KSP Residual norm 6.396943520277e-08
   79 KSP Residual norm 4.993732239955e-08
   80 KSP Residual norm 4.342332192073e-08
   81 KSP Residual norm 4.044956810083e-08
   82 KSP Residual norm 3.478198886369e-08
   83 KSP Residual norm 2.494949872366e-08
 36 KSP preconditioned resid norm 2.704691824793e+04 true resid norm 6.925862867453e+16 ||r(i)||/||b|| 3.944116288095e+14
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 4.108401652889e-03
    1 KSP Residual norm 1.558686954017e-03
    2 KSP Residual norm 8.971126816303e-04
    3 KSP Residual norm 1.057367938200e-03
    4 KSP Residual norm 1.399800497171e-03
    5 KSP Residual norm 1.170317714523e-03
    6 KSP Residual norm 1.262867794196e-03
    7 KSP Residual norm 1.094444816447e-03
    8 KSP Residual norm 6.607770391877e-04
    9 KSP Residual norm 5.809202363281e-04
   10 KSP Residual norm 5.098379368017e-04
   11 KSP Residual norm 3.853970598283e-04
   12 KSP Residual norm 3.550528841499e-04
   13 KSP Residual norm 2.678250361276e-04
   14 KSP Residual norm 1.992474091741e-04
   15 KSP Residual norm 1.585196677539e-04
   16 KSP Residual norm 1.413610604272e-04
   17 KSP Residual norm 1.396173588980e-04
   18 KSP Residual norm 1.320710568247e-04
   19 KSP Residual norm 1.314864457738e-04
   20 KSP Residual norm 1.316300114140e-04
   21 KSP Residual norm 1.149778459873e-04
   22 KSP Residual norm 9.272519564161e-05
   23 KSP Residual norm 7.555776782060e-05
   24 KSP Residual norm 6.327403158519e-05
   25 KSP Residual norm 5.637755173175e-05
   26 KSP Residual norm 5.240568823100e-05
   27 KSP Residual norm 4.828961568493e-05
   28 KSP Residual norm 4.031619101225e-05
   29 KSP Residual norm 3.248286666178e-05
   30 KSP Residual norm 2.990088184326e-05
   31 KSP Residual norm 2.974469609612e-05
   32 KSP Residual norm 2.713156428506e-05
   33 KSP Residual norm 2.463204444812e-05
   34 KSP Residual norm 2.185469452404e-05
   35 KSP Residual norm 1.901166412802e-05
   36 KSP Residual norm 1.667186961890e-05
   37 KSP Residual norm 1.367461489296e-05
   38 KSP Residual norm 1.266748964257e-05
   39 KSP Residual norm 1.197367175093e-05
   40 KSP Residual norm 1.039944114118e-05
   41 KSP Residual norm 8.404657078122e-06
   42 KSP Residual norm 7.150701407321e-06
   43 KSP Residual norm 6.032530367428e-06
   44 KSP Residual norm 5.439436120565e-06
   45 KSP Residual norm 5.003886250907e-06
   46 KSP Residual norm 4.172386795958e-06
   47 KSP Residual norm 3.720793813426e-06
   48 KSP Residual norm 3.834769373591e-06
   49 KSP Residual norm 3.848491703341e-06
   50 KSP Residual norm 3.710364079224e-06
   51 KSP Residual norm 3.645318788266e-06
   52 KSP Residual norm 3.386484957173e-06
   53 KSP Residual norm 2.866833072668e-06
   54 KSP Residual norm 2.421079647777e-06
   55 KSP Residual norm 2.150517237402e-06
   56 KSP Residual norm 1.793458801437e-06
   57 KSP Residual norm 1.489835872192e-06
   58 KSP Residual norm 1.205834005242e-06
   59 KSP Residual norm 8.941326022839e-07
   60 KSP Residual norm 6.944210427043e-07
   61 KSP Residual norm 5.434662369430e-07
   62 KSP Residual norm 4.354458673228e-07
   63 KSP Residual norm 3.531039219787e-07
   64 KSP Residual norm 3.092506626382e-07
   65 KSP Residual norm 2.574472375606e-07
   66 KSP Residual norm 2.017550955167e-07
   67 KSP Residual norm 1.652123030157e-07
   68 KSP Residual norm 1.381341422540e-07
   69 KSP Residual norm 1.078009310583e-07
   70 KSP Residual norm 8.110227070400e-08
   71 KSP Residual norm 6.524416703523e-08
   72 KSP Residual norm 5.483520579305e-08
   73 KSP Residual norm 4.696525450788e-08
   74 KSP Residual norm 3.838140100999e-08
 37 KSP preconditioned resid norm 2.615281748771e+04 true resid norm 7.028336818809e+16 ||r(i)||/||b|| 4.002472797368e+14
    0 KSP Residual norm 2.857560560081e-03
    1 KSP Residual norm 1.104770959879e-03
    2 KSP Residual norm 7.662633853876e-04
    3 KSP Residual norm 1.115532985323e-03
    4 KSP Residual norm 1.095273469154e-03
    5 KSP Residual norm 8.888003970555e-04
    6 KSP Residual norm 1.015926068748e-03
    7 KSP Residual norm 7.278166395353e-04
    8 KSP Residual norm 5.113633663251e-04
    9 KSP Residual norm 4.457152106190e-04
   10 KSP Residual norm 3.412574268163e-04
   11 KSP Residual norm 2.675765106861e-04
   12 KSP Residual norm 2.528170499816e-04
   13 KSP Residual norm 2.001673807049e-04
   14 KSP Residual norm 1.675234696539e-04
   15 KSP Residual norm 1.477392742362e-04
   16 KSP Residual norm 1.412322202718e-04
   17 KSP Residual norm 1.284334569411e-04
   18 KSP Residual norm 1.069470659362e-04
   19 KSP Residual norm 9.576615902980e-05
   20 KSP Residual norm 9.220340363418e-05
   21 KSP Residual norm 7.977547307586e-05
   22 KSP Residual norm 6.066604820007e-05
   23 KSP Residual norm 4.573346593964e-05
   24 KSP Residual norm 3.882953490518e-05
   25 KSP Residual norm 3.454137606841e-05
   26 KSP Residual norm 3.108810158657e-05
   27 KSP Residual norm 2.970589301021e-05
   28 KSP Residual norm 2.822496124694e-05
   29 KSP Residual norm 2.430865198627e-05
   30 KSP Residual norm 2.119627239434e-05
   31 KSP Residual norm 1.925528920007e-05
   32 KSP Residual norm 1.647278029984e-05
   33 KSP Residual norm 1.536893588300e-05
   34 KSP Residual norm 1.344143411297e-05
   35 KSP Residual norm 1.082326808862e-05
   36 KSP Residual norm 8.741951217121e-06
   37 KSP Residual norm 7.367445273265e-06
   38 KSP Residual norm 7.293542037939e-06
   39 KSP Residual norm 7.637502867865e-06
   40 KSP Residual norm 7.233085243491e-06
   41 KSP Residual norm 6.062750695567e-06
   42 KSP Residual norm 5.359944185252e-06
   43 KSP Residual norm 4.836168198110e-06
   44 KSP Residual norm 4.573736256242e-06
   45 KSP Residual norm 4.141315180545e-06
   46 KSP Residual norm 3.270700347947e-06
   47 KSP Residual norm 2.687983511988e-06
   48 KSP Residual norm 2.489653819132e-06
   49 KSP Residual norm 2.148799445605e-06
   50 KSP Residual norm 1.727205813320e-06
   51 KSP Residual norm 1.516309971034e-06
   52 KSP Residual norm 1.381133033019e-06
   53 KSP Residual norm 1.266130156460e-06
   54 KSP Residual norm 1.236586086348e-06
   55 KSP Residual norm 1.195719052432e-06
   56 KSP Residual norm 9.712831224611e-07
   57 KSP Residual norm 8.400776886181e-07
   58 KSP Residual norm 7.915763772898e-07
   59 KSP Residual norm 7.124033682623e-07
   60 KSP Residual norm 6.650462593872e-07
   61 KSP Residual norm 6.314529869288e-07
   62 KSP Residual norm 5.672033354059e-07
   63 KSP Residual norm 5.015958118280e-07
   64 KSP Residual norm 4.405544707050e-07
   65 KSP Residual norm 3.965605576749e-07
   66 KSP Residual norm 3.363776376485e-07
   67 KSP Residual norm 2.679789904113e-07
   68 KSP Residual norm 2.430799808722e-07
   69 KSP Residual norm 2.190582094554e-07
   70 KSP Residual norm 1.894083000238e-07
   71 KSP Residual norm 1.670692618900e-07
   72 KSP Residual norm 1.741406381315e-07
   73 KSP Residual norm 1.687684374006e-07
   74 KSP Residual norm 1.471750477195e-07
   75 KSP Residual norm 1.252336783031e-07
   76 KSP Residual norm 1.083570099164e-07
   77 KSP Residual norm 8.503665420745e-08
   78 KSP Residual norm 6.677870581341e-08
   79 KSP Residual norm 5.609795421669e-08
   80 KSP Residual norm 4.514482703256e-08
   81 KSP Residual norm 3.999462867830e-08
   82 KSP Residual norm 3.616652411385e-08
   83 KSP Residual norm 2.973110998452e-08
   84 KSP Residual norm 2.539814341891e-08
 38 KSP preconditioned resid norm 2.541030501437e+04 true resid norm 7.136706613174e+16 ||r(i)||/||b|| 4.064186850804e+14
    0 KSP Residual norm 3.686148294626e-03
    1 KSP Residual norm 1.345532220632e-03
    2 KSP Residual norm 6.833658915971e-04
    3 KSP Residual norm 8.850434281419e-04
    4 KSP Residual norm 1.108232958902e-03
    5 KSP Residual norm 8.277792446713e-04
    6 KSP Residual norm 8.042714435278e-04
    7 KSP Residual norm 6.131289088356e-04
    8 KSP Residual norm 3.666900651662e-04
    9 KSP Residual norm 3.204191828695e-04
   10 KSP Residual norm 2.663663109431e-04
   11 KSP Residual norm 2.080551324219e-04
   12 KSP Residual norm 2.114945974589e-04
   13 KSP Residual norm 1.707454155199e-04
   14 KSP Residual norm 1.344706069423e-04
   15 KSP Residual norm 1.139425554226e-04
   16 KSP Residual norm 9.817678376105e-05
   17 KSP Residual norm 8.727400604560e-05
   18 KSP Residual norm 7.635506906036e-05
   19 KSP Residual norm 6.290025387422e-05
   20 KSP Residual norm 5.488244385311e-05
   21 KSP Residual norm 4.513638929966e-05
   22 KSP Residual norm 3.773083539899e-05
   23 KSP Residual norm 3.293679796727e-05
   24 KSP Residual norm 2.798587934912e-05
   25 KSP Residual norm 2.521377074225e-05
   26 KSP Residual norm 2.348846990094e-05
   27 KSP Residual norm 2.212262645163e-05
   28 KSP Residual norm 1.890876233764e-05
   29 KSP Residual norm 1.496684565614e-05
   30 KSP Residual norm 1.238950229664e-05
   31 KSP Residual norm 1.137429905982e-05
   32 KSP Residual norm 9.799017814421e-06
   33 KSP Residual norm 8.307878475766e-06
   34 KSP Residual norm 7.340899704929e-06
   35 KSP Residual norm 6.677689108296e-06
   36 KSP Residual norm 5.679332575601e-06
   37 KSP Residual norm 4.737834499624e-06
   38 KSP Residual norm 4.379505883757e-06
   39 KSP Residual norm 4.284330021289e-06
   40 KSP Residual norm 3.890747717197e-06
   41 KSP Residual norm 3.306036088807e-06
   42 KSP Residual norm 2.996607191238e-06
   43 KSP Residual norm 2.593561320509e-06
   44 KSP Residual norm 2.335203258803e-06
   45 KSP Residual norm 2.106120581207e-06
   46 KSP Residual norm 1.759927495153e-06
   47 KSP Residual norm 1.572705467268e-06
   48 KSP Residual norm 1.687547116646e-06
   49 KSP Residual norm 1.719386795049e-06
   50 KSP Residual norm 1.544998385804e-06
   51 KSP Residual norm 1.333446714173e-06
   52 KSP Residual norm 1.094811287372e-06
   53 KSP Residual norm 9.063892297805e-07
   54 KSP Residual norm 8.096564319340e-07
   55 KSP Residual norm 7.123907398728e-07
   56 KSP Residual norm 5.950651432794e-07
   57 KSP Residual norm 5.554692830084e-07
   58 KSP Residual norm 5.730539381964e-07
   59 KSP Residual norm 5.250470947769e-07
   60 KSP Residual norm 4.622863074135e-07
   61 KSP Residual norm 3.983957170675e-07
   62 KSP Residual norm 3.471127522064e-07
   63 KSP Residual norm 2.963892116118e-07
   64 KSP Residual norm 2.787883709356e-07
   65 KSP Residual norm 2.493539929251e-07
   66 KSP Residual norm 2.087433845302e-07
   67 KSP Residual norm 1.639409560074e-07
   68 KSP Residual norm 1.252802573172e-07
   69 KSP Residual norm 1.040374486829e-07
   70 KSP Residual norm 8.889574737155e-08
   71 KSP Residual norm 7.352962046160e-08
   72 KSP Residual norm 6.415826766357e-08
   73 KSP Residual norm 5.526206322940e-08
   74 KSP Residual norm 4.356753510787e-08
   75 KSP Residual norm 3.933407322765e-08
   76 KSP Residual norm 3.906055827691e-08
   77 KSP Residual norm 3.753675323316e-08
   78 KSP Residual norm 3.516027149416e-08
 39 KSP preconditioned resid norm 2.376113533031e+04 true resid norm 7.421817678319e+16 ||r(i)||/||b|| 4.226550908175e+14
    0 KSP Residual norm 5.448485343978e-03
    1 KSP Residual norm 1.877712348206e-03
    2 KSP Residual norm 7.362219243307e-04
    3 KSP Residual norm 6.265769132019e-04
    4 KSP Residual norm 7.052791781458e-04
    5 KSP Residual norm 4.973103509996e-04
    6 KSP Residual norm 5.063675386823e-04
    7 KSP Residual norm 5.049992167159e-04
    8 KSP Residual norm 3.649104901125e-04
    9 KSP Residual norm 3.291398447245e-04
   10 KSP Residual norm 2.886394241620e-04
   11 KSP Residual norm 2.160852349208e-04
   12 KSP Residual norm 2.082404816652e-04
   13 KSP Residual norm 1.738379583037e-04
   14 KSP Residual norm 1.390340353887e-04
   15 KSP Residual norm 1.152863288511e-04
   16 KSP Residual norm 9.628953279095e-05
   17 KSP Residual norm 8.104871654253e-05
   18 KSP Residual norm 6.458748504441e-05
   19 KSP Residual norm 5.436750017737e-05
   20 KSP Residual norm 4.960330291745e-05
   21 KSP Residual norm 4.423910886965e-05
   22 KSP Residual norm 3.751608231988e-05
   23 KSP Residual norm 3.097507312067e-05
   24 KSP Residual norm 2.654398710180e-05
   25 KSP Residual norm 2.410632090359e-05
   26 KSP Residual norm 2.262168986884e-05
   27 KSP Residual norm 2.127761613142e-05
   28 KSP Residual norm 1.878551205942e-05
   29 KSP Residual norm 1.588904694442e-05
   30 KSP Residual norm 1.352796741991e-05
   31 KSP Residual norm 1.284549676333e-05
   32 KSP Residual norm 1.189560781697e-05
   33 KSP Residual norm 1.096187226724e-05
   34 KSP Residual norm 1.050800727191e-05
   35 KSP Residual norm 9.429216902562e-06
   36 KSP Residual norm 8.010134659411e-06
   37 KSP Residual norm 6.562086453106e-06
   38 KSP Residual norm 6.135151491360e-06
   39 KSP Residual norm 6.304572091082e-06
   40 KSP Residual norm 5.864883908410e-06
   41 KSP Residual norm 4.871422156216e-06
   42 KSP Residual norm 4.521521599310e-06
   43 KSP Residual norm 3.901020257269e-06
   44 KSP Residual norm 3.342878888644e-06
   45 KSP Residual norm 2.901185387312e-06
   46 KSP Residual norm 2.370929031289e-06
   47 KSP Residual norm 2.057534349427e-06
   48 KSP Residual norm 2.065635150279e-06
   49 KSP Residual norm 2.002078270314e-06
   50 KSP Residual norm 1.737075879530e-06
   51 KSP Residual norm 1.621980201008e-06
   52 KSP Residual norm 1.499306959800e-06
   53 KSP Residual norm 1.251524020016e-06
   54 KSP Residual norm 1.087278539075e-06
   55 KSP Residual norm 1.004359438887e-06
   56 KSP Residual norm 8.040096448021e-07
   57 KSP Residual norm 6.496437761905e-07
   58 KSP Residual norm 5.864154948851e-07
   59 KSP Residual norm 4.941356700083e-07
   60 KSP Residual norm 4.177694065962e-07
   61 KSP Residual norm 3.355073217862e-07
   62 KSP Residual norm 2.726079569897e-07
   63 KSP Residual norm 2.204324775599e-07
   64 KSP Residual norm 2.062625086352e-07
   65 KSP Residual norm 1.965139460809e-07
   66 KSP Residual norm 1.762017948813e-07
   67 KSP Residual norm 1.485340874688e-07
   68 KSP Residual norm 1.183767999852e-07
   69 KSP Residual norm 1.015263370843e-07
   70 KSP Residual norm 8.579107873501e-08
   71 KSP Residual norm 7.300894666406e-08
   72 KSP Residual norm 6.601708822975e-08
   73 KSP Residual norm 6.035259302725e-08
   74 KSP Residual norm 5.102759488665e-08
 40 KSP preconditioned resid norm 2.266470152499e+04 true resid norm 7.617450569713e+16 ||r(i)||/||b|| 4.337959246487e+14
    0 KSP Residual norm 4.894568495092e-03
    1 KSP Residual norm 1.730141626821e-03
    2 KSP Residual norm 7.321237484290e-04
    3 KSP Residual norm 7.477820481054e-04
    4 KSP Residual norm 8.675933051419e-04
    5 KSP Residual norm 6.353133919162e-04
    6 KSP Residual norm 7.216165540451e-04
    7 KSP Residual norm 6.852258520951e-04
    8 KSP Residual norm 4.634745820735e-04
    9 KSP Residual norm 3.801324619125e-04
   10 KSP Residual norm 2.893552023669e-04
   11 KSP Residual norm 1.935192439807e-04
   12 KSP Residual norm 1.776839577824e-04
   13 KSP Residual norm 1.497245878292e-04
   14 KSP Residual norm 1.278722324474e-04
   15 KSP Residual norm 1.088897777225e-04
   16 KSP Residual norm 9.195038416523e-05
   17 KSP Residual norm 7.839274698735e-05
   18 KSP Residual norm 6.361079279202e-05
   19 KSP Residual norm 5.512071401534e-05
   20 KSP Residual norm 5.358343883296e-05
   21 KSP Residual norm 5.010757822471e-05
   22 KSP Residual norm 4.467826573978e-05
   23 KSP Residual norm 3.689462107862e-05
   24 KSP Residual norm 3.042819913212e-05
   25 KSP Residual norm 2.770721844164e-05
   26 KSP Residual norm 2.560987357069e-05
   27 KSP Residual norm 2.383241083705e-05
   28 KSP Residual norm 2.130615728769e-05
   29 KSP Residual norm 1.864709534240e-05
   30 KSP Residual norm 1.691734844476e-05
   31 KSP Residual norm 1.663343086351e-05
   32 KSP Residual norm 1.384476692638e-05
   33 KSP Residual norm 1.096664875448e-05
   34 KSP Residual norm 9.041538100897e-06
   35 KSP Residual norm 8.035116378152e-06
   36 KSP Residual norm 7.487358771470e-06
   37 KSP Residual norm 6.922286567347e-06
   38 KSP Residual norm 6.683978271630e-06
   39 KSP Residual norm 6.571513786902e-06
   40 KSP Residual norm 6.392196001859e-06
   41 KSP Residual norm 5.885985199009e-06
   42 KSP Residual norm 5.342015656913e-06
   43 KSP Residual norm 4.498991783463e-06
   44 KSP Residual norm 3.932284705947e-06
   45 KSP Residual norm 3.573012327624e-06
   46 KSP Residual norm 2.812525717644e-06
   47 KSP Residual norm 2.357823053723e-06
   48 KSP Residual norm 2.321096234255e-06
   49 KSP Residual norm 2.254448087145e-06
   50 KSP Residual norm 1.900644375418e-06
   51 KSP Residual norm 1.687852279266e-06
   52 KSP Residual norm 1.548995817152e-06
   53 KSP Residual norm 1.295446188831e-06
   54 KSP Residual norm 1.042834938211e-06
   55 KSP Residual norm 8.481533694890e-07
   56 KSP Residual norm 6.756185007410e-07
   57 KSP Residual norm 5.746887988703e-07
   58 KSP Residual norm 5.526723766353e-07
   59 KSP Residual norm 5.008099478074e-07
   60 KSP Residual norm 4.465353560522e-07
   61 KSP Residual norm 3.927688485383e-07
   62 KSP Residual norm 3.420693756600e-07
   63 KSP Residual norm 2.673713349059e-07
   64 KSP Residual norm 2.400243253714e-07
   65 KSP Residual norm 2.165205347772e-07
   66 KSP Residual norm 1.886361334908e-07
   67 KSP Residual norm 1.600299088365e-07
   68 KSP Residual norm 1.230937818800e-07
   69 KSP Residual norm 9.728878010846e-08
   70 KSP Residual norm 7.739080437147e-08
   71 KSP Residual norm 6.400565474022e-08
   72 KSP Residual norm 5.774380293199e-08
   73 KSP Residual norm 5.262337181248e-08
   74 KSP Residual norm 4.380556816512e-08
 41 KSP preconditioned resid norm 2.105290133097e+04 true resid norm 7.939938805261e+16 ||r(i)||/||b|| 4.521608724809e+14
    0 KSP Residual norm 6.841749150660e-03
    1 KSP Residual norm 2.363150428293e-03
    2 KSP Residual norm 8.844816246439e-04
    3 KSP Residual norm 7.399280175224e-04
    4 KSP Residual norm 8.152875281328e-04
    5 KSP Residual norm 5.705714452426e-04
    6 KSP Residual norm 5.545991807728e-04
    7 KSP Residual norm 5.568312728534e-04
    8 KSP Residual norm 3.984359252430e-04
    9 KSP Residual norm 3.518179049850e-04
   10 KSP Residual norm 2.865683517061e-04
   11 KSP Residual norm 1.946304172583e-04
   12 KSP Residual norm 1.695859517312e-04
   13 KSP Residual norm 1.509675120733e-04
   14 KSP Residual norm 1.380468936414e-04
   15 KSP Residual norm 1.259986345381e-04
   16 KSP Residual norm 1.083130710512e-04
   17 KSP Residual norm 8.715524198467e-05
   18 KSP Residual norm 6.396011558164e-05
   19 KSP Residual norm 4.942927362900e-05
   20 KSP Residual norm 4.505356838945e-05
   21 KSP Residual norm 4.308999656278e-05
   22 KSP Residual norm 3.715629535318e-05
   23 KSP Residual norm 3.138894546386e-05
   24 KSP Residual norm 2.535823915175e-05
   25 KSP Residual norm 2.287812607685e-05
   26 KSP Residual norm 2.075648186285e-05
   27 KSP Residual norm 1.871789703307e-05
   28 KSP Residual norm 1.570953441385e-05
   29 KSP Residual norm 1.365960268182e-05
   30 KSP Residual norm 1.228732972138e-05
   31 KSP Residual norm 1.234470804237e-05
   32 KSP Residual norm 1.087278841960e-05
   33 KSP Residual norm 8.844936092204e-06
   34 KSP Residual norm 7.120485131028e-06
   35 KSP Residual norm 5.976178118320e-06
   36 KSP Residual norm 5.047847474608e-06
   37 KSP Residual norm 4.379867890795e-06
   38 KSP Residual norm 4.058224319163e-06
   39 KSP Residual norm 4.109843619958e-06
   40 KSP Residual norm 4.033356075586e-06
   41 KSP Residual norm 3.594404957626e-06
   42 KSP Residual norm 3.275464848295e-06
   43 KSP Residual norm 2.817569724154e-06
   44 KSP Residual norm 2.458220178731e-06
   45 KSP Residual norm 2.361313029935e-06
   46 KSP Residual norm 2.068544301005e-06
   47 KSP Residual norm 1.847217535112e-06
   48 KSP Residual norm 1.759979870877e-06
   49 KSP Residual norm 1.673099545886e-06
   50 KSP Residual norm 1.431318427249e-06
   51 KSP Residual norm 1.316592746098e-06
   52 KSP Residual norm 1.275241058966e-06
   53 KSP Residual norm 1.116010261181e-06
   54 KSP Residual norm 9.526046844932e-07
   55 KSP Residual norm 8.963645445155e-07
   56 KSP Residual norm 7.578147693963e-07
   57 KSP Residual norm 6.304157989137e-07
   58 KSP Residual norm 5.459278326444e-07
   59 KSP Residual norm 4.811425356981e-07
   60 KSP Residual norm 4.310702242542e-07
   61 KSP Residual norm 3.630664598016e-07
   62 KSP Residual norm 2.928688468898e-07
   63 KSP Residual norm 2.366372451740e-07
   64 KSP Residual norm 2.104069142208e-07
   65 KSP Residual norm 1.944937696921e-07
   66 KSP Residual norm 1.728402991375e-07
   67 KSP Residual norm 1.568978663183e-07
   68 KSP Residual norm 1.361617646301e-07
   69 KSP Residual norm 1.183901202293e-07
   70 KSP Residual norm 9.653275466982e-08
   71 KSP Residual norm 7.510865937253e-08
   72 KSP Residual norm 6.081414656161e-08
 42 KSP preconditioned resid norm 1.957509013646e+04 true resid norm 8.268430184905e+16 ||r(i)||/||b|| 4.708676852745e+14
    0 KSP Residual norm 7.649614691567e-03
    1 KSP Residual norm 2.655921634485e-03
    2 KSP Residual norm 1.025468401791e-03
    3 KSP Residual norm 8.333481282778e-04
    4 KSP Residual norm 8.830350770686e-04
    5 KSP Residual norm 6.147874518018e-04
    6 KSP Residual norm 5.650671931018e-04
    7 KSP Residual norm 5.486362169857e-04
    8 KSP Residual norm 4.135381544613e-04
    9 KSP Residual norm 3.714173034486e-04
   10 KSP Residual norm 2.941708580862e-04
   11 KSP Residual norm 2.027756832023e-04
   12 KSP Residual norm 1.889580376599e-04
   13 KSP Residual norm 1.601802062105e-04
   14 KSP Residual norm 1.301604007311e-04
   15 KSP Residual norm 1.126774027860e-04
   16 KSP Residual norm 9.488363031767e-05
   17 KSP Residual norm 7.834050311818e-05
   18 KSP Residual norm 6.275094909709e-05
   19 KSP Residual norm 5.555941215709e-05
   20 KSP Residual norm 5.712672361791e-05
   21 KSP Residual norm 5.686853276368e-05
   22 KSP Residual norm 5.142459357070e-05
   23 KSP Residual norm 4.366557473552e-05
   24 KSP Residual norm 3.906910599964e-05
   25 KSP Residual norm 3.748264814786e-05
   26 KSP Residual norm 3.517382806903e-05
   27 KSP Residual norm 3.181529121120e-05
   28 KSP Residual norm 2.700856766821e-05
   29 KSP Residual norm 2.308954582075e-05
   30 KSP Residual norm 2.153599585848e-05
   31 KSP Residual norm 2.160546126970e-05
   32 KSP Residual norm 1.943580581710e-05
   33 KSP Residual norm 1.703535852862e-05
   34 KSP Residual norm 1.526636492585e-05
   35 KSP Residual norm 1.354904880899e-05
   36 KSP Residual norm 1.152431331920e-05
   37 KSP Residual norm 9.735247027132e-06
   38 KSP Residual norm 8.772392325721e-06
   39 KSP Residual norm 8.276278668864e-06
   40 KSP Residual norm 7.596661624973e-06
   41 KSP Residual norm 6.660893665535e-06
   42 KSP Residual norm 6.236759123373e-06
   43 KSP Residual norm 5.287754883860e-06
   44 KSP Residual norm 4.360171131362e-06
   45 KSP Residual norm 3.634321358329e-06
   46 KSP Residual norm 2.688742933622e-06
   47 KSP Residual norm 2.072035396840e-06
   48 KSP Residual norm 1.865985960310e-06
   49 KSP Residual norm 1.698149417692e-06
   50 KSP Residual norm 1.463358701737e-06
   51 KSP Residual norm 1.328707597483e-06
   52 KSP Residual norm 1.267224015116e-06
   53 KSP Residual norm 1.089330038047e-06
   54 KSP Residual norm 9.620801983557e-07
   55 KSP Residual norm 8.756610241621e-07
   56 KSP Residual norm 7.263046369919e-07
   57 KSP Residual norm 5.956130503293e-07
   58 KSP Residual norm 5.333969013251e-07
   59 KSP Residual norm 4.828929062570e-07
   60 KSP Residual norm 4.315887747104e-07
   61 KSP Residual norm 3.586215658232e-07
   62 KSP Residual norm 2.766908910091e-07
   63 KSP Residual norm 2.196647300234e-07
   64 KSP Residual norm 2.035240864530e-07
   65 KSP Residual norm 1.958604191608e-07
   66 KSP Residual norm 1.734196309683e-07
   67 KSP Residual norm 1.506753401343e-07
   68 KSP Residual norm 1.327210061708e-07
   69 KSP Residual norm 1.190025995448e-07
   70 KSP Residual norm 1.030255361311e-07
   71 KSP Residual norm 8.636906819522e-08
   72 KSP Residual norm 7.635632800147e-08
 43 KSP preconditioned resid norm 1.834656977901e+04 true resid norm 8.563281376977e+16 ||r(i)||/||b|| 4.876587683708e+14
    0 KSP Residual norm 7.945468330826e-03
    1 KSP Residual norm 2.743230503785e-03
    2 KSP Residual norm 1.025370266502e-03
    3 KSP Residual norm 8.421479310026e-04
    4 KSP Residual norm 9.064995869749e-04
    5 KSP Residual norm 6.059268893194e-04
    6 KSP Residual norm 5.842139628834e-04
    7 KSP Residual norm 5.970750243976e-04
    8 KSP Residual norm 4.435449958101e-04
    9 KSP Residual norm 3.848288393754e-04
   10 KSP Residual norm 3.022705887708e-04
   11 KSP Residual norm 1.938018447489e-04
   12 KSP Residual norm 1.628274811088e-04
   13 KSP Residual norm 1.340146358043e-04
   14 KSP Residual norm 1.138902061175e-04
   15 KSP Residual norm 1.028285126872e-04
   16 KSP Residual norm 8.995223394877e-05
   17 KSP Residual norm 7.744319971273e-05
   18 KSP Residual norm 6.248590678175e-05
   19 KSP Residual norm 5.304165616064e-05
   20 KSP Residual norm 5.345453716135e-05
   21 KSP Residual norm 5.465024666066e-05
   22 KSP Residual norm 5.092642329793e-05
   23 KSP Residual norm 4.479307896396e-05
   24 KSP Residual norm 3.862618956547e-05
   25 KSP Residual norm 3.597311506456e-05
   26 KSP Residual norm 3.297347388597e-05
   27 KSP Residual norm 2.997406922532e-05
   28 KSP Residual norm 2.584914519934e-05
   29 KSP Residual norm 2.232555319789e-05
   30 KSP Residual norm 1.898275402831e-05
   31 KSP Residual norm 1.872239444191e-05
   32 KSP Residual norm 1.716940343790e-05
   33 KSP Residual norm 1.529771178742e-05
   34 KSP Residual norm 1.312981904051e-05
   35 KSP Residual norm 1.156591472825e-05
   36 KSP Residual norm 1.016524168932e-05
   37 KSP Residual norm 9.444977752200e-06
   38 KSP Residual norm 9.046253105976e-06
   39 KSP Residual norm 9.017750862843e-06
   40 KSP Residual norm 8.504566358579e-06
   41 KSP Residual norm 7.028099112108e-06
   42 KSP Residual norm 6.129136112890e-06
   43 KSP Residual norm 5.015873754027e-06
   44 KSP Residual norm 4.118497518847e-06
   45 KSP Residual norm 3.543665125623e-06
   46 KSP Residual norm 2.750817019829e-06
   47 KSP Residual norm 2.160128157912e-06
   48 KSP Residual norm 1.861468667569e-06
   49 KSP Residual norm 1.571563674113e-06
   50 KSP Residual norm 1.292490587135e-06
   51 KSP Residual norm 1.228608305736e-06
   52 KSP Residual norm 1.218676155406e-06
   53 KSP Residual norm 1.061788333870e-06
   54 KSP Residual norm 8.963965528049e-07
   55 KSP Residual norm 8.563929561929e-07
   56 KSP Residual norm 7.194148267358e-07
   57 KSP Residual norm 5.726184076211e-07
   58 KSP Residual norm 4.938754885524e-07
   59 KSP Residual norm 4.551459893873e-07
   60 KSP Residual norm 4.497025569600e-07
   61 KSP Residual norm 4.008373575411e-07
   62 KSP Residual norm 3.247223498568e-07
   63 KSP Residual norm 2.512433938424e-07
   64 KSP Residual norm 2.039831245713e-07
   65 KSP Residual norm 1.751591580972e-07
   66 KSP Residual norm 1.539373591788e-07
   67 KSP Residual norm 1.328495597157e-07
   68 KSP Residual norm 1.105405388401e-07
   69 KSP Residual norm 9.843392816202e-08
   70 KSP Residual norm 8.652307832273e-08
   71 KSP Residual norm 6.939616605567e-08
 44 KSP preconditioned resid norm 1.673348104017e+04 true resid norm 8.997778410888e+16 ||r(i)||/||b|| 5.124023542803e+14
    0 KSP Residual norm 1.068940190048e-02
    1 KSP Residual norm 3.696226261142e-03
    2 KSP Residual norm 1.365499441580e-03
    3 KSP Residual norm 1.036803391587e-03
    4 KSP Residual norm 1.063043512076e-03
    5 KSP Residual norm 6.832245879458e-04
    6 KSP Residual norm 5.688343876472e-04
    7 KSP Residual norm 5.592497261418e-04
    8 KSP Residual norm 4.118306049072e-04
    9 KSP Residual norm 3.609255859944e-04
   10 KSP Residual norm 2.875765835321e-04
   11 KSP Residual norm 1.873537601536e-04
   12 KSP Residual norm 1.680585023560e-04
   13 KSP Residual norm 1.544529441896e-04
   14 KSP Residual norm 1.368378046171e-04
   15 KSP Residual norm 1.257726559882e-04
   16 KSP Residual norm 1.117857134263e-04
   17 KSP Residual norm 9.568960682874e-05
   18 KSP Residual norm 7.517130278619e-05
   19 KSP Residual norm 6.293296057179e-05
   20 KSP Residual norm 6.317854600704e-05
   21 KSP Residual norm 6.387343805195e-05
   22 KSP Residual norm 6.094869667116e-05
   23 KSP Residual norm 5.381497186561e-05
   24 KSP Residual norm 4.668954303764e-05
   25 KSP Residual norm 4.364914362555e-05
   26 KSP Residual norm 4.026829236648e-05
   27 KSP Residual norm 3.642498195651e-05
   28 KSP Residual norm 3.218609574910e-05
   29 KSP Residual norm 2.946702341324e-05
   30 KSP Residual norm 2.738101831327e-05
   31 KSP Residual norm 2.670531030981e-05
   32 KSP Residual norm 2.284648832803e-05
   33 KSP Residual norm 1.864392868907e-05
   34 KSP Residual norm 1.559774662327e-05
   35 KSP Residual norm 1.345859036667e-05
   36 KSP Residual norm 1.132447688899e-05
   37 KSP Residual norm 9.485766681601e-06
   38 KSP Residual norm 9.022173096874e-06
   39 KSP Residual norm 8.682472839293e-06
   40 KSP Residual norm 7.847656785606e-06
   41 KSP Residual norm 6.427838531119e-06
   42 KSP Residual norm 5.410236913360e-06
   43 KSP Residual norm 4.364958921999e-06
   44 KSP Residual norm 3.794094458332e-06
   45 KSP Residual norm 3.583990867507e-06
   46 KSP Residual norm 3.037667233348e-06
   47 KSP Residual norm 2.491681748670e-06
   48 KSP Residual norm 2.142623860458e-06
   49 KSP Residual norm 1.680106972358e-06
   50 KSP Residual norm 1.294449947079e-06
   51 KSP Residual norm 1.141842217116e-06
   52 KSP Residual norm 1.057488908235e-06
   53 KSP Residual norm 9.243193715263e-07
   54 KSP Residual norm 8.768571106897e-07
   55 KSP Residual norm 9.093688602513e-07
   56 KSP Residual norm 8.082819565107e-07
   57 KSP Residual norm 6.406098166720e-07
   58 KSP Residual norm 5.443475292529e-07
   59 KSP Residual norm 4.941574695216e-07
   60 KSP Residual norm 4.717477106585e-07
   61 KSP Residual norm 4.354051278597e-07
   62 KSP Residual norm 3.757179860061e-07
   63 KSP Residual norm 3.085232616450e-07
   64 KSP Residual norm 2.636112561660e-07
   65 KSP Residual norm 2.326530352069e-07
   66 KSP Residual norm 1.972264881966e-07
   67 KSP Residual norm 1.743024090012e-07
   68 KSP Residual norm 1.628420778541e-07
   69 KSP Residual norm 1.552845988308e-07
   70 KSP Residual norm 1.438983865413e-07
   71 KSP Residual norm 1.198978899178e-07
   72 KSP Residual norm 1.059726521179e-07
 45 KSP preconditioned resid norm 1.566228445630e+04 true resid norm 9.320890532567e+16 ||r(i)||/||b|| 5.308028309629e+14
    0 KSP Residual norm 1.023035159946e-02
    1 KSP Residual norm 3.536441251213e-03
    2 KSP Residual norm 1.299726708917e-03
    3 KSP Residual norm 9.428501552426e-04
    4 KSP Residual norm 9.630344648589e-04
    5 KSP Residual norm 6.368977362211e-04
    6 KSP Residual norm 5.513053110152e-04
    7 KSP Residual norm 5.617556710062e-04
    8 KSP Residual norm 4.347941713256e-04
    9 KSP Residual norm 3.906150283847e-04
   10 KSP Residual norm 3.120084082186e-04
   11 KSP Residual norm 1.984641078560e-04
   12 KSP Residual norm 1.681185546211e-04
   13 KSP Residual norm 1.371417088701e-04
   14 KSP Residual norm 1.121381601931e-04
   15 KSP Residual norm 1.004023393828e-04
   16 KSP Residual norm 8.905858437048e-05
   17 KSP Residual norm 7.916812527319e-05
   18 KSP Residual norm 6.416002845146e-05
   19 KSP Residual norm 5.123151421311e-05
   20 KSP Residual norm 4.983864355666e-05
   21 KSP Residual norm 5.093238155446e-05
   22 KSP Residual norm 4.875813942182e-05
   23 KSP Residual norm 4.380301171124e-05
   24 KSP Residual norm 3.902866695035e-05
   25 KSP Residual norm 3.602001554898e-05
   26 KSP Residual norm 3.237738235880e-05
   27 KSP Residual norm 2.883863304348e-05
   28 KSP Residual norm 2.566135573405e-05
   29 KSP Residual norm 2.339711398578e-05
   30 KSP Residual norm 2.172070412002e-05
   31 KSP Residual norm 2.215652395288e-05
   32 KSP Residual norm 2.041810770762e-05
   33 KSP Residual norm 1.840317638983e-05
   34 KSP Residual norm 1.632981195663e-05
   35 KSP Residual norm 1.411967595011e-05
   36 KSP Residual norm 1.177600970864e-05
   37 KSP Residual norm 9.485871252377e-06
   38 KSP Residual norm 7.853507742643e-06
   39 KSP Residual norm 7.386855929668e-06
   40 KSP Residual norm 6.644163066161e-06
   41 KSP Residual norm 5.256380649064e-06
   42 KSP Residual norm 4.384025386803e-06
   43 KSP Residual norm 3.552475448562e-06
   44 KSP Residual norm 2.764945944119e-06
   45 KSP Residual norm 2.471277442834e-06
   46 KSP Residual norm 2.059282947255e-06
   47 KSP Residual norm 1.680435974468e-06
   48 KSP Residual norm 1.438952643236e-06
   49 KSP Residual norm 1.302221630097e-06
   50 KSP Residual norm 1.150403423476e-06
   51 KSP Residual norm 1.059786968767e-06
   52 KSP Residual norm 1.018262542155e-06
   53 KSP Residual norm 8.896479556252e-07
   54 KSP Residual norm 7.386690416481e-07
   55 KSP Residual norm 6.614686577572e-07
   56 KSP Residual norm 5.505979420336e-07
   57 KSP Residual norm 4.300348202747e-07
   58 KSP Residual norm 3.612676247250e-07
   59 KSP Residual norm 3.102019883359e-07
   60 KSP Residual norm 2.949675441403e-07
   61 KSP Residual norm 2.705807583346e-07
   62 KSP Residual norm 2.296994756951e-07
   63 KSP Residual norm 1.715661988897e-07
   64 KSP Residual norm 1.350853774156e-07
   65 KSP Residual norm 1.150777370489e-07
   66 KSP Residual norm 9.713973641981e-08
 46 KSP preconditioned resid norm 1.458094822686e+04 true resid norm 9.677010485817e+16 ||r(i)||/||b|| 5.510830261531e+14
    0 KSP Residual norm 1.165338459409e-02
    1 KSP Residual norm 4.021154451202e-03
    2 KSP Residual norm 1.428210877005e-03
    3 KSP Residual norm 9.534950746545e-04
    4 KSP Residual norm 9.336632914576e-04
    5 KSP Residual norm 5.542260730215e-04
    6 KSP Residual norm 4.285308139791e-04
    7 KSP Residual norm 4.169386015716e-04
    8 KSP Residual norm 3.236925930430e-04
    9 KSP Residual norm 2.956336777945e-04
   10 KSP Residual norm 2.548255791119e-04
   11 KSP Residual norm 1.709957602369e-04
   12 KSP Residual norm 1.444251024216e-04
   13 KSP Residual norm 1.271527953630e-04
   14 KSP Residual norm 1.109463616545e-04
   15 KSP Residual norm 1.026935813105e-04
   16 KSP Residual norm 9.036300059143e-05
   17 KSP Residual norm 7.974732054415e-05
   18 KSP Residual norm 6.246581512295e-05
   19 KSP Residual norm 4.815085281768e-05
   20 KSP Residual norm 4.508466254521e-05
   21 KSP Residual norm 4.605830327172e-05
   22 KSP Residual norm 4.480079189875e-05
   23 KSP Residual norm 4.226825723677e-05
   24 KSP Residual norm 3.886440867565e-05
   25 KSP Residual norm 3.714483739506e-05
   26 KSP Residual norm 3.466813048214e-05
   27 KSP Residual norm 3.157816438163e-05
   28 KSP Residual norm 2.734108066183e-05
   29 KSP Residual norm 2.289084423499e-05
   30 KSP Residual norm 1.868739824367e-05
   31 KSP Residual norm 1.703050999555e-05
   32 KSP Residual norm 1.488926580684e-05
   33 KSP Residual norm 1.316289040688e-05
   34 KSP Residual norm 1.176666274689e-05
   35 KSP Residual norm 1.067015554096e-05
   36 KSP Residual norm 9.683841885193e-06
   37 KSP Residual norm 8.289029385390e-06
   38 KSP Residual norm 7.639491477433e-06
   39 KSP Residual norm 7.531435789549e-06
   40 KSP Residual norm 7.097915007145e-06
   41 KSP Residual norm 5.932511395006e-06
   42 KSP Residual norm 5.082346006282e-06
   43 KSP Residual norm 4.127554478438e-06
   44 KSP Residual norm 3.308466758627e-06
   45 KSP Residual norm 3.080558700489e-06
   46 KSP Residual norm 2.614399158331e-06
   47 KSP Residual norm 2.134658529762e-06
   48 KSP Residual norm 1.867579067836e-06
   49 KSP Residual norm 1.676055453007e-06
   50 KSP Residual norm 1.467406593581e-06
   51 KSP Residual norm 1.384527346995e-06
   52 KSP Residual norm 1.332916986381e-06
   53 KSP Residual norm 1.153092883405e-06
   54 KSP Residual norm 9.480760410664e-07
   55 KSP Residual norm 8.687028794959e-07
   56 KSP Residual norm 6.933949456396e-07
   57 KSP Residual norm 5.186478760568e-07
   58 KSP Residual norm 4.365943019232e-07
   59 KSP Residual norm 3.798127739025e-07
   60 KSP Residual norm 3.436195382948e-07
   61 KSP Residual norm 3.027833517334e-07
   62 KSP Residual norm 2.441374170129e-07
   63 KSP Residual norm 1.686263620605e-07
   64 KSP Residual norm 1.223747277648e-07
   65 KSP Residual norm 9.678364258946e-08
 47 KSP preconditioned resid norm 1.324524139961e+04 true resid norm 1.020728786373e+17 ||r(i)||/||b|| 5.812810777672e+14
    0 KSP Residual norm 1.537737235992e-02
    1 KSP Residual norm 5.303141895115e-03
    2 KSP Residual norm 1.863822726293e-03
    3 KSP Residual norm 1.178842406727e-03
    4 KSP Residual norm 1.110742074982e-03
    5 KSP Residual norm 6.563003990071e-04
    6 KSP Residual norm 4.483556622294e-04
    7 KSP Residual norm 4.278233237450e-04
    8 KSP Residual norm 3.326725098230e-04
    9 KSP Residual norm 3.120271251636e-04
   10 KSP Residual norm 2.770975930024e-04
   11 KSP Residual norm 1.858335130086e-04
   12 KSP Residual norm 1.563279523640e-04
   13 KSP Residual norm 1.348893147587e-04
   14 KSP Residual norm 1.168594300982e-04
   15 KSP Residual norm 1.063801307429e-04
   16 KSP Residual norm 9.499221736723e-05
   17 KSP Residual norm 8.796818715069e-05
   18 KSP Residual norm 7.185287198326e-05
   19 KSP Residual norm 5.558252909753e-05
   20 KSP Residual norm 5.079665310198e-05
   21 KSP Residual norm 5.038704247280e-05
   22 KSP Residual norm 4.872418680346e-05
   23 KSP Residual norm 4.526028706568e-05
   24 KSP Residual norm 4.087094903599e-05
   25 KSP Residual norm 3.832350172879e-05
   26 KSP Residual norm 3.500901798843e-05
   27 KSP Residual norm 3.018377313734e-05
   28 KSP Residual norm 2.546885541859e-05
   29 KSP Residual norm 2.248558918461e-05
   30 KSP Residual norm 2.020541661036e-05
   31 KSP Residual norm 2.083469298231e-05
   32 KSP Residual norm 1.925807109951e-05
   33 KSP Residual norm 1.745158197653e-05
   34 KSP Residual norm 1.578755104637e-05
   35 KSP Residual norm 1.409002102669e-05
   36 KSP Residual norm 1.186049749594e-05
   37 KSP Residual norm 9.321894263541e-06
   38 KSP Residual norm 7.937422102674e-06
   39 KSP Residual norm 7.516031927365e-06
   40 KSP Residual norm 7.247292645578e-06
   41 KSP Residual norm 6.267071304596e-06
   42 KSP Residual norm 5.438391466313e-06
   43 KSP Residual norm 4.408785153766e-06
   44 KSP Residual norm 3.561595662088e-06
   45 KSP Residual norm 3.332953606826e-06
   46 KSP Residual norm 2.851848227886e-06
   47 KSP Residual norm 2.391843396566e-06
   48 KSP Residual norm 2.174700887059e-06
   49 KSP Residual norm 2.018935879442e-06
   50 KSP Residual norm 1.802401396384e-06
   51 KSP Residual norm 1.659281636257e-06
   52 KSP Residual norm 1.604130360363e-06
   53 KSP Residual norm 1.423234953733e-06
   54 KSP Residual norm 1.174340220542e-06
   55 KSP Residual norm 1.051131959718e-06
   56 KSP Residual norm 8.249639230385e-07
   57 KSP Residual norm 5.804529359420e-07
   58 KSP Residual norm 4.390716428111e-07
   59 KSP Residual norm 3.478998227942e-07
   60 KSP Residual norm 3.059031637501e-07
   61 KSP Residual norm 2.870663424107e-07
   62 KSP Residual norm 2.694912628313e-07
   63 KSP Residual norm 2.033324690014e-07
   64 KSP Residual norm 1.570231981101e-07
   65 KSP Residual norm 1.361584972948e-07
 48 KSP preconditioned resid norm 1.101180815503e+04 true resid norm 1.109424710055e+17 ||r(i)||/||b|| 6.317913237796e+14
    0 KSP Residual norm 2.529136856971e-02
    1 KSP Residual norm 8.720225705961e-03
    2 KSP Residual norm 3.028019961647e-03
    3 KSP Residual norm 1.805563664619e-03
    4 KSP Residual norm 1.671546733155e-03
    5 KSP Residual norm 9.600033404930e-04
    6 KSP Residual norm 5.897667072834e-04
    7 KSP Residual norm 5.263190838057e-04
    8 KSP Residual norm 4.138638419305e-04
    9 KSP Residual norm 3.765030082530e-04
   10 KSP Residual norm 3.586739527397e-04
   11 KSP Residual norm 2.573711674052e-04
   12 KSP Residual norm 2.161858824945e-04
   13 KSP Residual norm 1.882692548809e-04
   14 KSP Residual norm 1.682163508274e-04
   15 KSP Residual norm 1.582097462802e-04
   16 KSP Residual norm 1.467037090156e-04
   17 KSP Residual norm 1.437081284073e-04
   18 KSP Residual norm 1.225327698188e-04
   19 KSP Residual norm 9.266339101892e-05
   20 KSP Residual norm 8.298615331556e-05
   21 KSP Residual norm 8.096719774835e-05
   22 KSP Residual norm 7.677743588621e-05
   23 KSP Residual norm 7.125044954353e-05
   24 KSP Residual norm 6.440721127719e-05
   25 KSP Residual norm 5.967430005539e-05
   26 KSP Residual norm 5.339200488487e-05
   27 KSP Residual norm 4.622250973352e-05
   28 KSP Residual norm 3.864097511643e-05
   29 KSP Residual norm 3.276978268988e-05
   30 KSP Residual norm 2.736378460015e-05
   31 KSP Residual norm 2.683611762354e-05
   32 KSP Residual norm 2.602328357325e-05
   33 KSP Residual norm 2.551761795412e-05
   34 KSP Residual norm 2.432374830800e-05
   35 KSP Residual norm 2.279692777872e-05
   36 KSP Residual norm 1.935194015836e-05
   37 KSP Residual norm 1.462745596173e-05
   38 KSP Residual norm 1.145233584938e-05
   39 KSP Residual norm 9.969109032963e-06
   40 KSP Residual norm 9.283300264275e-06
   41 KSP Residual norm 8.432012598578e-06
   42 KSP Residual norm 7.724490979256e-06
   43 KSP Residual norm 6.641157282154e-06
   44 KSP Residual norm 5.498796121628e-06
   45 KSP Residual norm 5.151701677424e-06
   46 KSP Residual norm 4.436927309378e-06
   47 KSP Residual norm 3.735597158709e-06
   48 KSP Residual norm 3.473169996960e-06
   49 KSP Residual norm 3.199012134481e-06
   50 KSP Residual norm 2.675036782820e-06
   51 KSP Residual norm 2.187995874784e-06
   52 KSP Residual norm 1.929616177918e-06
   53 KSP Residual norm 1.623796547579e-06
   54 KSP Residual norm 1.292046651603e-06
   55 KSP Residual norm 1.189419090537e-06
   56 KSP Residual norm 1.042996713745e-06
   57 KSP Residual norm 7.995361730562e-07
   58 KSP Residual norm 6.102546806294e-07
   59 KSP Residual norm 4.839025498701e-07
   60 KSP Residual norm 4.298002047011e-07
   61 KSP Residual norm 4.093053943545e-07
   62 KSP Residual norm 3.952050688298e-07
   63 KSP Residual norm 3.240418403540e-07
   64 KSP Residual norm 2.577727357944e-07
   65 KSP Residual norm 2.166886066207e-07
 49 KSP preconditioned resid norm 1.016098975847e+04 true resid norm 1.147543884061e+17 ||r(i)||/||b|| 6.534992983613e+14
    0 KSP Residual norm 2.014751730764e-02
    1 KSP Residual norm 6.965128967426e-03
    2 KSP Residual norm 2.458950705186e-03
    3 KSP Residual norm 1.436187370269e-03
    4 KSP Residual norm 1.355915832117e-03
    5 KSP Residual norm 8.244585228380e-04
    6 KSP Residual norm 5.857960158146e-04
    7 KSP Residual norm 5.529150413455e-04
    8 KSP Residual norm 4.163269483849e-04
    9 KSP Residual norm 3.820156321200e-04
   10 KSP Residual norm 3.374410716302e-04
   11 KSP Residual norm 2.222488901810e-04
   12 KSP Residual norm 1.757560361732e-04
   13 KSP Residual norm 1.439389488094e-04
   14 KSP Residual norm 1.139941586897e-04
   15 KSP Residual norm 9.756740483185e-05
   16 KSP Residual norm 8.321865352518e-05
   17 KSP Residual norm 7.746631438270e-05
   18 KSP Residual norm 6.158238212134e-05
   19 KSP Residual norm 4.509068143151e-05
   20 KSP Residual norm 3.655819397263e-05
   21 KSP Residual norm 3.355416133263e-05
   22 KSP Residual norm 3.213755535085e-05
   23 KSP Residual norm 3.083530032586e-05
   24 KSP Residual norm 2.801595650808e-05
   25 KSP Residual norm 2.515459514272e-05
   26 KSP Residual norm 2.236450847735e-05
   27 KSP Residual norm 1.922790666296e-05
   28 KSP Residual norm 1.525739031535e-05
   29 KSP Residual norm 1.264085919461e-05
   30 KSP Residual norm 1.036479736113e-05
   31 KSP Residual norm 9.535822218185e-06
   32 KSP Residual norm 8.530241395454e-06
   33 KSP Residual norm 7.184685480567e-06
   34 KSP Residual norm 6.349632644878e-06
   35 KSP Residual norm 5.961643760947e-06
   36 KSP Residual norm 5.479859104209e-06
   37 KSP Residual norm 4.340697217846e-06
   38 KSP Residual norm 3.448868263597e-06
   39 KSP Residual norm 3.210147815538e-06
   40 KSP Residual norm 3.160156370872e-06
   41 KSP Residual norm 2.909990886827e-06
   42 KSP Residual norm 2.696138777541e-06
   43 KSP Residual norm 2.348395859547e-06
   44 KSP Residual norm 1.966644147929e-06
   45 KSP Residual norm 1.869077764919e-06
   46 KSP Residual norm 1.669314521407e-06
   47 KSP Residual norm 1.427225330931e-06
   48 KSP Residual norm 1.269773342409e-06
   49 KSP Residual norm 1.151370695893e-06
   50 KSP Residual norm 1.038246251457e-06
   51 KSP Residual norm 9.715853220357e-07
   52 KSP Residual norm 9.694384981127e-07
   53 KSP Residual norm 9.028560327428e-07
   54 KSP Residual norm 8.108626112536e-07
   55 KSP Residual norm 7.974114946454e-07
   56 KSP Residual norm 7.140184536740e-07
   57 KSP Residual norm 5.594907194899e-07
   58 KSP Residual norm 4.357519314403e-07
   59 KSP Residual norm 3.539158008487e-07
   60 KSP Residual norm 3.233131067159e-07
   61 KSP Residual norm 3.114888799006e-07
   62 KSP Residual norm 3.043194243786e-07
   63 KSP Residual norm 2.407968266722e-07
   64 KSP Residual norm 1.903583628524e-07
 50 KSP preconditioned resid norm 9.426536560751e+03 true resid norm 1.191223652352e+17 ||r(i)||/||b|| 6.783739008296e+14
    0 KSP Residual norm 2.249841924119e-02
    1 KSP Residual norm 7.781664635687e-03
    2 KSP Residual norm 2.726547275219e-03
    3 KSP Residual norm 1.542887226069e-03
    4 KSP Residual norm 1.408720582229e-03
    5 KSP Residual norm 8.123388922393e-04
    6 KSP Residual norm 5.507207900451e-04
    7 KSP Residual norm 4.998200915810e-04
    8 KSP Residual norm 3.708927774712e-04
    9 KSP Residual norm 3.229767342502e-04
   10 KSP Residual norm 3.007584984555e-04
   11 KSP Residual norm 2.055581010868e-04
   12 KSP Residual norm 1.596103201953e-04
   13 KSP Residual norm 1.305743529813e-04
   14 KSP Residual norm 1.076132614924e-04
   15 KSP Residual norm 9.787201491072e-05
   16 KSP Residual norm 8.740312357648e-05
   17 KSP Residual norm 8.481258240273e-05
   18 KSP Residual norm 7.137120181873e-05
   19 KSP Residual norm 5.312239061753e-05
   20 KSP Residual norm 4.449250413237e-05
   21 KSP Residual norm 4.035542983360e-05
   22 KSP Residual norm 3.684508535649e-05
   23 KSP Residual norm 3.282088297511e-05
   24 KSP Residual norm 2.786661940131e-05
   25 KSP Residual norm 2.414164978471e-05
   26 KSP Residual norm 2.084937802557e-05
   27 KSP Residual norm 1.849171584439e-05
   28 KSP Residual norm 1.490210491450e-05
   29 KSP Residual norm 1.222357533759e-05
   30 KSP Residual norm 1.014570804217e-05
   31 KSP Residual norm 9.676284617596e-06
   32 KSP Residual norm 8.939032502326e-06
   33 KSP Residual norm 7.755974776723e-06
   34 KSP Residual norm 6.817504502032e-06
   35 KSP Residual norm 6.252582488409e-06
   36 KSP Residual norm 5.672989803458e-06
   37 KSP Residual norm 4.550319728838e-06
   38 KSP Residual norm 3.552445446494e-06
   39 KSP Residual norm 3.102724226900e-06
   40 KSP Residual norm 2.985390695811e-06
   41 KSP Residual norm 2.751827341512e-06
   42 KSP Residual norm 2.671934578975e-06
   43 KSP Residual norm 2.382593075155e-06
   44 KSP Residual norm 1.997153271735e-06
   45 KSP Residual norm 1.885446072722e-06
   46 KSP Residual norm 1.660379467724e-06
   47 KSP Residual norm 1.397007873130e-06
   48 KSP Residual norm 1.229646316961e-06
   49 KSP Residual norm 1.119330806309e-06
   50 KSP Residual norm 9.971479274286e-07
   51 KSP Residual norm 9.275441622520e-07
   52 KSP Residual norm 9.799288840118e-07
   53 KSP Residual norm 9.451732953376e-07
   54 KSP Residual norm 8.435198407802e-07
   55 KSP Residual norm 8.572036080193e-07
   56 KSP Residual norm 8.066579589692e-07
   57 KSP Residual norm 6.384472013951e-07
   58 KSP Residual norm 4.991355060566e-07
   59 KSP Residual norm 3.987833326552e-07
   60 KSP Residual norm 3.426524136347e-07
   61 KSP Residual norm 3.045644311966e-07
   62 KSP Residual norm 2.782838213557e-07
   63 KSP Residual norm 2.300840683363e-07
   64 KSP Residual norm 1.897317716222e-07
 51 KSP preconditioned resid norm 8.625804677687e+03 true resid norm 1.258184275912e+17 ||r(i)||/||b|| 7.165064037536e+14
    0 KSP Residual norm 2.896225439208e-02
    1 KSP Residual norm 1.000114132932e-02
    2 KSP Residual norm 3.495186055002e-03
    3 KSP Residual norm 1.996484783996e-03
    4 KSP Residual norm 1.828327706984e-03
    5 KSP Residual norm 1.054374961256e-03
    6 KSP Residual norm 6.355563734858e-04
    7 KSP Residual norm 5.490374043826e-04
    8 KSP Residual norm 4.044195347461e-04
    9 KSP Residual norm 3.586864348861e-04
   10 KSP Residual norm 3.338818106887e-04
   11 KSP Residual norm 2.290409216084e-04
   12 KSP Residual norm 1.878410883568e-04
   13 KSP Residual norm 1.680414430761e-04
   14 KSP Residual norm 1.464149517926e-04
   15 KSP Residual norm 1.383934457305e-04
   16 KSP Residual norm 1.286312297590e-04
   17 KSP Residual norm 1.296675718557e-04
   18 KSP Residual norm 1.124701015547e-04
   19 KSP Residual norm 8.623514687789e-05
   20 KSP Residual norm 7.330970765560e-05
   21 KSP Residual norm 6.694552841670e-05
   22 KSP Residual norm 6.044529459289e-05
   23 KSP Residual norm 5.566730717127e-05
   24 KSP Residual norm 4.970944537541e-05
   25 KSP Residual norm 4.793832887048e-05
   26 KSP Residual norm 4.723039776080e-05
   27 KSP Residual norm 4.529586894585e-05
   28 KSP Residual norm 3.999420887683e-05
   29 KSP Residual norm 3.507093574033e-05
   30 KSP Residual norm 2.869940217284e-05
   31 KSP Residual norm 2.716055635395e-05
   32 KSP Residual norm 2.540820341108e-05
   33 KSP Residual norm 2.331954568011e-05
   34 KSP Residual norm 2.105868070728e-05
   35 KSP Residual norm 1.933715467956e-05
   36 KSP Residual norm 1.709696453273e-05
   37 KSP Residual norm 1.333517916126e-05
   38 KSP Residual norm 1.064257887776e-05
   39 KSP Residual norm 9.351185163763e-06
   40 KSP Residual norm 8.634942057860e-06
   41 KSP Residual norm 7.509476540536e-06
   42 KSP Residual norm 6.742035044856e-06
   43 KSP Residual norm 5.819701721514e-06
   44 KSP Residual norm 4.958336558898e-06
   45 KSP Residual norm 4.667553348271e-06
   46 KSP Residual norm 3.895071317867e-06
   47 KSP Residual norm 3.083836980055e-06
   48 KSP Residual norm 2.627159089299e-06
   49 KSP Residual norm 2.374917833700e-06
   50 KSP Residual norm 2.154811548644e-06
   51 KSP Residual norm 1.932602948388e-06
   52 KSP Residual norm 1.849071939491e-06
   53 KSP Residual norm 1.661532462426e-06
   54 KSP Residual norm 1.405369306770e-06
   55 KSP Residual norm 1.321654099292e-06
   56 KSP Residual norm 1.151407842631e-06
   57 KSP Residual norm 8.828233702174e-07
   58 KSP Residual norm 6.981318578454e-07
   59 KSP Residual norm 5.691179635192e-07
   60 KSP Residual norm 4.910801158627e-07
   61 KSP Residual norm 4.395115698343e-07
   62 KSP Residual norm 3.847207943129e-07
   63 KSP Residual norm 2.839765832047e-07
 52 KSP preconditioned resid norm 7.732139191549e+03 true resid norm 1.349578176487e+17 ||r(i)||/||b|| 7.685530842599e+14
    0 KSP Residual norm 3.787459797456e-02
    1 KSP Residual norm 1.306543726641e-02
    2 KSP Residual norm 4.552019316152e-03
    3 KSP Residual norm 2.673940737973e-03
    4 KSP Residual norm 2.455975780412e-03
    5 KSP Residual norm 1.396437062816e-03
    6 KSP Residual norm 8.271037518237e-04
    7 KSP Residual norm 6.872546481628e-04
    8 KSP Residual norm 5.251319056442e-04
    9 KSP Residual norm 4.828630648123e-04
   10 KSP Residual norm 4.575698097434e-04
   11 KSP Residual norm 3.205492493711e-04
   12 KSP Residual norm 2.764488252880e-04
   13 KSP Residual norm 2.608338461779e-04
   14 KSP Residual norm 2.455740551764e-04
   15 KSP Residual norm 2.460713809335e-04
   16 KSP Residual norm 2.412622649133e-04
   17 KSP Residual norm 2.465729413177e-04
   18 KSP Residual norm 2.148404270203e-04
   19 KSP Residual norm 1.574627594820e-04
   20 KSP Residual norm 1.320872666101e-04
   21 KSP Residual norm 1.195631830924e-04
   22 KSP Residual norm 1.085991333173e-04
   23 KSP Residual norm 9.816982180059e-05
   24 KSP Residual norm 8.941460303292e-05
   25 KSP Residual norm 8.881125578828e-05
   26 KSP Residual norm 8.742332111047e-05
   27 KSP Residual norm 8.299357351975e-05
   28 KSP Residual norm 7.334607914548e-05
   29 KSP Residual norm 6.136062744331e-05
   30 KSP Residual norm 4.821351366598e-05
   31 KSP Residual norm 4.279817364688e-05
   32 KSP Residual norm 3.838508511205e-05
   33 KSP Residual norm 3.502632131077e-05
   34 KSP Residual norm 3.095180135225e-05
   35 KSP Residual norm 2.758721576792e-05
   36 KSP Residual norm 2.359640371988e-05
   37 KSP Residual norm 1.838106081348e-05
   38 KSP Residual norm 1.463793449263e-05
   39 KSP Residual norm 1.319359280582e-05
   40 KSP Residual norm 1.258373653515e-05
   41 KSP Residual norm 1.136721262300e-05
   42 KSP Residual norm 1.057606660182e-05
   43 KSP Residual norm 9.178960772006e-06
   44 KSP Residual norm 7.577487185675e-06
   45 KSP Residual norm 6.793643591561e-06
   46 KSP Residual norm 5.517000969765e-06
   47 KSP Residual norm 4.310791162269e-06
   48 KSP Residual norm 3.801213837702e-06
   49 KSP Residual norm 3.520991737270e-06
   50 KSP Residual norm 3.168836007215e-06
   51 KSP Residual norm 2.917871088374e-06
   52 KSP Residual norm 2.788057311734e-06
   53 KSP Residual norm 2.428598525515e-06
   54 KSP Residual norm 1.976041504167e-06
   55 KSP Residual norm 1.863103404246e-06
   56 KSP Residual norm 1.603125510216e-06
   57 KSP Residual norm 1.152030559125e-06
   58 KSP Residual norm 7.945228000465e-07
   59 KSP Residual norm 5.793664702319e-07
   60 KSP Residual norm 4.825770010647e-07
   61 KSP Residual norm 4.213693415355e-07
   62 KSP Residual norm 3.790411982450e-07
   63 KSP Residual norm 3.186239009831e-07
 53 KSP preconditioned resid norm 6.615977705299e+03 true resid norm 1.479645949961e+17 ||r(i)||/||b|| 8.426236273432e+14
    0 KSP Residual norm 5.534299543885e-02
    1 KSP Residual norm 1.908845669056e-02
    2 KSP Residual norm 6.675424341165e-03
    3 KSP Residual norm 3.865402939741e-03
    4 KSP Residual norm 3.523146775089e-03
    5 KSP Residual norm 1.985996689575e-03
    6 KSP Residual norm 1.142253430123e-03
    7 KSP Residual norm 9.762937638121e-04
    8 KSP Residual norm 7.422361091932e-04
    9 KSP Residual norm 6.707384236066e-04
   10 KSP Residual norm 6.441654898371e-04
   11 KSP Residual norm 4.605729290877e-04
   12 KSP Residual norm 3.975308948994e-04
   13 KSP Residual norm 3.683314363720e-04
   14 KSP Residual norm 3.402185283451e-04
   15 KSP Residual norm 3.344095429710e-04
   16 KSP Residual norm 3.216162395950e-04
   17 KSP Residual norm 3.219828398117e-04
   18 KSP Residual norm 2.712905047165e-04
   19 KSP Residual norm 1.963628429018e-04
   20 KSP Residual norm 1.615188451505e-04
   21 KSP Residual norm 1.446186832760e-04
   22 KSP Residual norm 1.291746550311e-04
   23 KSP Residual norm 1.175761622082e-04
   24 KSP Residual norm 1.090909997489e-04
   25 KSP Residual norm 1.121856284236e-04
   26 KSP Residual norm 1.126690856171e-04
   27 KSP Residual norm 1.076815099431e-04
   28 KSP Residual norm 9.539951594810e-05
   29 KSP Residual norm 8.161318611896e-05
   30 KSP Residual norm 6.202852712847e-05
   31 KSP Residual norm 5.468156361474e-05
   32 KSP Residual norm 4.875029542327e-05
   33 KSP Residual norm 4.468761814285e-05
   34 KSP Residual norm 4.095854702023e-05
   35 KSP Residual norm 3.877659589576e-05
   36 KSP Residual norm 3.496736295495e-05
   37 KSP Residual norm 2.778422143147e-05
   38 KSP Residual norm 2.228734290922e-05
   39 KSP Residual norm 1.987670987355e-05
   40 KSP Residual norm 1.865655677751e-05
   41 KSP Residual norm 1.658341661346e-05
   42 KSP Residual norm 1.501570195641e-05
   43 KSP Residual norm 1.277429215131e-05
   44 KSP Residual norm 1.066377559656e-05
   45 KSP Residual norm 1.001338999738e-05
   46 KSP Residual norm 8.603321916745e-06
   47 KSP Residual norm 7.168230995531e-06
   48 KSP Residual norm 6.577881405729e-06
   49 KSP Residual norm 6.182423765918e-06
   50 KSP Residual norm 5.388222545195e-06
   51 KSP Residual norm 4.376214086067e-06
   52 KSP Residual norm 3.821061360066e-06
   53 KSP Residual norm 3.242234396330e-06
   54 KSP Residual norm 2.657702673126e-06
   55 KSP Residual norm 2.490268249837e-06
   56 KSP Residual norm 2.215518093240e-06
   57 KSP Residual norm 1.673059323179e-06
   58 KSP Residual norm 1.218050121133e-06
   59 KSP Residual norm 9.118615192059e-07
   60 KSP Residual norm 7.554474239578e-07
   61 KSP Residual norm 6.760870134778e-07
   62 KSP Residual norm 6.128925428863e-07
   63 KSP Residual norm 4.872665529947e-07
 54 KSP preconditioned resid norm 5.588411829570e+03 true resid norm 1.606666312672e+17 ||r(i)||/||b|| 9.149587415484e+14
    0 KSP Residual norm 7.117524502481e-02
    1 KSP Residual norm 2.452091515298e-02
    2 KSP Residual norm 8.565659841127e-03
    3 KSP Residual norm 4.915899435939e-03
    4 KSP Residual norm 4.488899314170e-03
    5 KSP Residual norm 2.534088372379e-03
    6 KSP Residual norm 1.459261970655e-03
    7 KSP Residual norm 1.208628459326e-03
    8 KSP Residual norm 9.141846939026e-04
    9 KSP Residual norm 8.241150986565e-04
   10 KSP Residual norm 7.876633703423e-04
   11 KSP Residual norm 5.593527590639e-04
   12 KSP Residual norm 4.815295234214e-04
   13 KSP Residual norm 4.471015821100e-04
   14 KSP Residual norm 4.174339016644e-04
   15 KSP Residual norm 4.142527530944e-04
   16 KSP Residual norm 3.966636464920e-04
   17 KSP Residual norm 3.987710186403e-04
   18 KSP Residual norm 3.409946844508e-04
   19 KSP Residual norm 2.435692452505e-04
   20 KSP Residual norm 1.995643042580e-04
   21 KSP Residual norm 1.788208294162e-04
   22 KSP Residual norm 1.606543376267e-04
   23 KSP Residual norm 1.434276753393e-04
   24 KSP Residual norm 1.318874022217e-04
   25 KSP Residual norm 1.357640431484e-04
   26 KSP Residual norm 1.371426380330e-04
   27 KSP Residual norm 1.320730748297e-04
   28 KSP Residual norm 1.174040308615e-04
   29 KSP Residual norm 9.969159465049e-05
   30 KSP Residual norm 7.526918193918e-05
   31 KSP Residual norm 6.409408645616e-05
   32 KSP Residual norm 5.545743202136e-05
   33 KSP Residual norm 5.093333858239e-05
   34 KSP Residual norm 4.731292167660e-05
   35 KSP Residual norm 4.630335662995e-05
   36 KSP Residual norm 4.394877655871e-05
   37 KSP Residual norm 3.627167435510e-05
   38 KSP Residual norm 2.892500785312e-05
   39 KSP Residual norm 2.558467050303e-05
   40 KSP Residual norm 2.322979730074e-05
   41 KSP Residual norm 1.985998939806e-05
   42 KSP Residual norm 1.806209559269e-05
   43 KSP Residual norm 1.571481200276e-05
   44 KSP Residual norm 1.306026693550e-05
   45 KSP Residual norm 1.236227601277e-05
   46 KSP Residual norm 1.091785477771e-05
   47 KSP Residual norm 9.014979945176e-06
   48 KSP Residual norm 8.081703382362e-06
   49 KSP Residual norm 7.331529431001e-06
   50 KSP Residual norm 6.428883296168e-06
   51 KSP Residual norm 5.600272525901e-06
   52 KSP Residual norm 5.041587219015e-06
   53 KSP Residual norm 4.189151729950e-06
   54 KSP Residual norm 3.413833986449e-06
   55 KSP Residual norm 3.211983588033e-06
   56 KSP Residual norm 2.816520152414e-06
   57 KSP Residual norm 2.074732309036e-06
   58 KSP Residual norm 1.501228226841e-06
   59 KSP Residual norm 1.123841774593e-06
   60 KSP Residual norm 9.168761012380e-07
   61 KSP Residual norm 7.736451894018e-07
   62 KSP Residual norm 6.715326781752e-07
 55 KSP preconditioned resid norm 4.862818612284e+03 true resid norm 1.720548582098e+17 ||r(i)||/||b|| 9.798120201027e+14
    0 KSP Residual norm 8.097048986072e-02
    1 KSP Residual norm 2.785049534840e-02
    2 KSP Residual norm 9.684456395891e-03
    3 KSP Residual norm 5.650376247637e-03
    4 KSP Residual norm 5.199262421606e-03
    5 KSP Residual norm 2.966573500979e-03
    6 KSP Residual norm 1.692045148297e-03
    7 KSP Residual norm 1.387209750694e-03
    8 KSP Residual norm 1.050455468777e-03
    9 KSP Residual norm 9.497006304171e-04
   10 KSP Residual norm 8.961278488919e-04
   11 KSP Residual norm 6.291680836294e-04
   12 KSP Residual norm 5.504589413296e-04
   13 KSP Residual norm 5.281798966696e-04
   14 KSP Residual norm 5.053366004482e-04
   15 KSP Residual norm 5.080776569570e-04
   16 KSP Residual norm 5.051760021010e-04
   17 KSP Residual norm 5.265107423845e-04
   18 KSP Residual norm 4.652135565841e-04
   19 KSP Residual norm 3.399176827505e-04
   20 KSP Residual norm 2.834763365470e-04
   21 KSP Residual norm 2.549028565209e-04
   22 KSP Residual norm 2.277981488194e-04
   23 KSP Residual norm 2.051433406325e-04
   24 KSP Residual norm 1.894263801135e-04
   25 KSP Residual norm 1.940292985477e-04
   26 KSP Residual norm 1.916170631285e-04
   27 KSP Residual norm 1.807390612590e-04
   28 KSP Residual norm 1.561156995800e-04
   29 KSP Residual norm 1.257244859992e-04
   30 KSP Residual norm 8.808334349971e-05
   31 KSP Residual norm 6.983541834365e-05
   32 KSP Residual norm 5.802738647411e-05
   33 KSP Residual norm 5.228163110035e-05
   34 KSP Residual norm 4.906259915446e-05
   35 KSP Residual norm 4.913092591751e-05
   36 KSP Residual norm 4.775218606894e-05
   37 KSP Residual norm 3.885868942540e-05
   38 KSP Residual norm 2.948912342050e-05
   39 KSP Residual norm 2.356093479027e-05
   40 KSP Residual norm 1.970979939765e-05
   41 KSP Residual norm 1.608494721158e-05
   42 KSP Residual norm 1.403225031077e-05
   43 KSP Residual norm 1.234528305432e-05
   44 KSP Residual norm 1.088762436300e-05
   45 KSP Residual norm 1.071930332901e-05
   46 KSP Residual norm 9.560015373745e-06
   47 KSP Residual norm 7.729596621484e-06
   48 KSP Residual norm 6.694020308090e-06
   49 KSP Residual norm 6.080095146805e-06
   50 KSP Residual norm 5.340801611436e-06
   51 KSP Residual norm 4.570337941684e-06
   52 KSP Residual norm 4.216431725451e-06
   53 KSP Residual norm 3.671477390153e-06
   54 KSP Residual norm 2.960721494223e-06
   55 KSP Residual norm 2.801199472463e-06
   56 KSP Residual norm 2.593094018395e-06
   57 KSP Residual norm 2.041275135301e-06
   58 KSP Residual norm 1.489128390812e-06
   59 KSP Residual norm 1.086192246907e-06
   60 KSP Residual norm 8.784624368373e-07
   61 KSP Residual norm 7.598945731528e-07
 56 KSP preconditioned resid norm 4.266164340989e+03 true resid norm 1.836361597449e+17 ||r(i)||/||b|| 1.045764813128e+15
    0 KSP Residual norm 9.734111293474e-02
    1 KSP Residual norm 3.351236092044e-02
    2 KSP Residual norm 1.172250434111e-02
    3 KSP Residual norm 6.495880831233e-03
    4 KSP Residual norm 5.883235272948e-03
    5 KSP Residual norm 3.318964425320e-03
    6 KSP Residual norm 1.912855153202e-03
    7 KSP Residual norm 1.593440648588e-03
    8 KSP Residual norm 1.157658519626e-03
    9 KSP Residual norm 1.000884603435e-03
   10 KSP Residual norm 9.600579737453e-04
   11 KSP Residual norm 6.730787319291e-04
   12 KSP Residual norm 5.519402301365e-04
   13 KSP Residual norm 4.991750748235e-04
   14 KSP Residual norm 4.497907231049e-04
   15 KSP Residual norm 4.367545309703e-04
   16 KSP Residual norm 4.133743983384e-04
   17 KSP Residual norm 4.278837545250e-04
   18 KSP Residual norm 3.784761981932e-04
   19 KSP Residual norm 2.721189776360e-04
   20 KSP Residual norm 2.137712676530e-04
   21 KSP Residual norm 1.834616735391e-04
   22 KSP Residual norm 1.590450704979e-04
   23 KSP Residual norm 1.418151037482e-04
   24 KSP Residual norm 1.282077249439e-04
   25 KSP Residual norm 1.303003751437e-04
   26 KSP Residual norm 1.327957401822e-04
   27 KSP Residual norm 1.299175303303e-04
   28 KSP Residual norm 1.162352848207e-04
   29 KSP Residual norm 1.010247527231e-04
   30 KSP Residual norm 7.812742759124e-05
   31 KSP Residual norm 6.774559877373e-05
   32 KSP Residual norm 5.931013488744e-05
   33 KSP Residual norm 5.402446545501e-05
   34 KSP Residual norm 4.992005024758e-05
   35 KSP Residual norm 4.958704503613e-05
   36 KSP Residual norm 4.854802962807e-05
   37 KSP Residual norm 4.153167020452e-05
   38 KSP Residual norm 3.406039604803e-05
   39 KSP Residual norm 3.051357349430e-05
   40 KSP Residual norm 2.786768746962e-05
   41 KSP Residual norm 2.368381621025e-05
   42 KSP Residual norm 2.100606643935e-05
   43 KSP Residual norm 1.782726753663e-05
   44 KSP Residual norm 1.448786755593e-05
   45 KSP Residual norm 1.367238826875e-05
   46 KSP Residual norm 1.230515391224e-05
   47 KSP Residual norm 1.064571473618e-05
   48 KSP Residual norm 9.979454169078e-06
   49 KSP Residual norm 9.490434858101e-06
   50 KSP Residual norm 8.375194042996e-06
   51 KSP Residual norm 6.924545850403e-06
   52 KSP Residual norm 6.081694373014e-06
   53 KSP Residual norm 5.057411735333e-06
   54 KSP Residual norm 3.984780896761e-06
   55 KSP Residual norm 3.715181539819e-06
   56 KSP Residual norm 3.439471845442e-06
   57 KSP Residual norm 2.694381357429e-06
   58 KSP Residual norm 2.022736769713e-06
   59 KSP Residual norm 1.514617114149e-06
   60 KSP Residual norm 1.213176250354e-06
   61 KSP Residual norm 1.033439723532e-06
   62 KSP Residual norm 9.339196905519e-07
 57 KSP preconditioned resid norm 3.588300009114e+03 true resid norm 2.025168832433e+17 ||r(i)||/||b|| 1.153286100375e+15
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 1.438264043302e-01
    1 KSP Residual norm 4.949969620921e-02
    2 KSP Residual norm 1.722525991671e-02
    3 KSP Residual norm 1.003128270574e-02
    4 KSP Residual norm 9.136248811885e-03
    5 KSP Residual norm 5.154880279509e-03
    6 KSP Residual norm 2.959435490126e-03
    7 KSP Residual norm 2.469024976228e-03
    8 KSP Residual norm 1.872358716273e-03
    9 KSP Residual norm 1.703625757661e-03
   10 KSP Residual norm 1.646023298693e-03
   11 KSP Residual norm 1.180248093195e-03
   12 KSP Residual norm 1.027162664013e-03
   13 KSP Residual norm 9.645198407274e-04
   14 KSP Residual norm 8.991999559088e-04
   15 KSP Residual norm 8.854476916254e-04
   16 KSP Residual norm 8.520628731759e-04
   17 KSP Residual norm 8.594115514554e-04
   18 KSP Residual norm 7.296494206375e-04
   19 KSP Residual norm 5.194112854287e-04
   20 KSP Residual norm 4.247355731663e-04
   21 KSP Residual norm 3.806791627345e-04
   22 KSP Residual norm 3.431911915923e-04
   23 KSP Residual norm 3.141771958831e-04
   24 KSP Residual norm 2.949977399556e-04
   25 KSP Residual norm 3.063472948783e-04
   26 KSP Residual norm 3.093611083713e-04
   27 KSP Residual norm 2.945437149512e-04
   28 KSP Residual norm 2.570348340777e-04
   29 KSP Residual norm 2.119598600564e-04
   30 KSP Residual norm 1.538243415304e-04
   31 KSP Residual norm 1.290977588615e-04
   32 KSP Residual norm 1.132740495052e-04
   33 KSP Residual norm 1.065776006388e-04
   34 KSP Residual norm 1.012380201501e-04
   35 KSP Residual norm 1.005203450168e-04
   36 KSP Residual norm 9.550144740830e-05
   37 KSP Residual norm 7.663249899939e-05
   38 KSP Residual norm 5.843432016332e-05
   39 KSP Residual norm 4.856472448830e-05
   40 KSP Residual norm 4.246126578709e-05
   41 KSP Residual norm 3.612834309081e-05
   42 KSP Residual norm 3.312665767316e-05
   43 KSP Residual norm 2.975232974953e-05
   44 KSP Residual norm 2.578464738439e-05
   45 KSP Residual norm 2.497910656697e-05
   46 KSP Residual norm 2.185533006985e-05
   47 KSP Residual norm 1.773658919152e-05
   48 KSP Residual norm 1.568563766309e-05
   49 KSP Residual norm 1.430107230766e-05
   50 KSP Residual norm 1.241428021738e-05
   51 KSP Residual norm 1.038130970723e-05
   52 KSP Residual norm 9.204344254369e-06
   53 KSP Residual norm 7.670690020288e-06
   54 KSP Residual norm 6.070490800828e-06
   55 KSP Residual norm 5.693507146990e-06
   56 KSP Residual norm 5.220329757465e-06
   57 KSP Residual norm 4.048429857886e-06
   58 KSP Residual norm 2.991885369648e-06
   59 KSP Residual norm 2.202617597307e-06
   60 KSP Residual norm 1.727572505277e-06
[mpiexec at aci-service-1.chtc.wisc.edu] Sending Ctrl-C to processes as requested
[mpiexec at aci-service-1.chtc.wisc.edu] Press Ctrl-C again to force abort
0.03user 0.12system 1:26.53elapsed 0%CPU (0avgtext+0avgdata 17072maxresident)k
904inputs+0outputs (3major+1805minor)pagefaults 0swaps
salloc: Relinquishing job allocation 79007
