[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tue Oct 28 08:44:55 CDT 2014
On Tue, Oct 28, 2014 at 8:00 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Matt
> With MUMPS it is indeed the same but not faster. E.g., see 1.txt and 2.txt
There is a big problem here. This system is never actually being solved.
Look at 1.txt:
0 KSP preconditioned resid norm 9.320055451716e+05 true resid norm
1.755998647494e+02 ||r(i)||/||b|| 1.000000000000e+00
380 KSP preconditioned resid norm 9.034871458425e-05 true resid norm
3.118451181896e+09 ||r(i)||/||b|| 1.775884728811e+07
The preconditioned residual did drop 10 order of magnitude, but the true
residual (b - Ax) is still very very large.
This looks like the system is singular and the preconditioner is masking
this. This needs to be figured out first.
I would go back to a small serial problem, and make sure it is actually
being solved.
   Matt
> With GAMG, cg takes forever (see 4.txt). For reference GAMG with preonly
> is attached again (3.txt)
> All logs include -fieldsplit_0_ksp_monitor.
> Also, the true residual shows small oscillations. Is that normal?
> Tabrez
> On 10/28/2014 07:08 AM, Matthew Knepley wrote:
>  On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali <stali at geology.wisc.edu>
> wrote:
>>  Mark
>> When I replace "-fieldsplit_0_ksp_type preonly" with
>> "-fieldsplit_0_ksp_type cg" then it becomes very slow (had to kill it).
>  That means something in the setup is wrong. It should be about the same
> or faster. Run with -fieldsplit_0_ksp_monitor
> so we can see what is happening.
>     Matt
>>  With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
>> -fieldsplit_0_pc_factor_mat_solver_package mumps -fieldsplit_0_ksp_type
>> preonly' it works fine but takes more time, and will be an issue for larger
>> problems. The output for this run is attached.
>> I will work on passing rigid body modes (as Matt mentioned) but short of
>> that what is the best set of options for solving the following problem
>> (i.e., linear elasticity with constraints):
>> |K cG'| | u | = |F|
>> |G  0 | |l/c|   |d|
>> where c is a scaling factor (so that cG' terms are more or less of the
>> same order as K)? The constraints are used to impose slip between surfaces
>> and so on.
>> Tabrez
>> On 10/27/2014 01:17 PM, Mark Adams wrote:
>> The null space for GAMG is not critical but useful for elasticity.  If
>> you in fact have an indefinite operator (eg, not "pinned)  the you need to
>> use an iterative coarse grid solver.  You are using '-fieldsplit_0_pc_type
>> gamg -fieldsplit_0_ksp_type preonly'.  And you have a hard elasticity
>> problem.  You are going to want to start with a stronger solver. Use cg
>> instead of preonly.  As Matt said start with MUMPS, then go to CG/GAMG,
>> then you can see how far you can cut the _0_ solver down.
>> Mark
>> On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>>  On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali <stali at geology.wisc.edu>
>>> wrote:
>>>>  Matt
>>>> On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>>  On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>> wrote:
>>>>>  Matt
>>>>> Sorry about that (I always forget it). The output for the smallest
>>>>> problem is now attached (see log.txt). I am also attaching some results
>>>>> that compare results obtained using FS/LSC and the direct solver (MUMPS),
>>>>> again for the smallest problem. The difference, as you can see is
>>>>> insignificant O(1E-6).
>>>>  1) How do you use MUMPS if you have a saddle point
>>>> I simply used -pc_type lu -pc_factor_mat_solver_package mumps.
>>>>  2) You can see from the output that something is seriously wrong with
>>>> the preconditioner. It looks like it has a null space.
>>>>     Did you add the elastic null modes to GAMG? Without this, it is not
>>>> going to work. We have helper functions for this:
>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>>  you could just copy that code. And then use
>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>>  I don't see it in the output, so I think this is your problem.
>>>>  In order to test, I would first use MUMPS as the A00 solver and get
>>>> the Schur stuff worked out. Then I would
>>>> replace MUMPS with GAMG and tune it until I get back my original
>>>> convergence.
>>>> I will try this with MatNullSpaceCreateRigidBody. Btw does it matter if
>>>> some nodes are pinned?
>>>  No these are null modes of the operator, not of the particular problem.
>>>    Matt
>>>>  Tabrez
>>>>    Thanks,
>>>>      Matt
>>>>>  Also, I did pass 'upper' and 'full' to
>>>>> '-pc_fieldsplit_schur_factorization_type' but the iteration count doesn't
>>>>> improve (in fact, it increases slightly). The attached log is with 'upper'.
>>>>> Regards,
>>>>> Tabrez
>>>>> On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>>  On Thu, Oct 23, 2014 at 7:20 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>>> wrote:
>>>>>>  Hello
>>>>>> I am using the following options (below) for solving linear
>>>>>> elasticity/poroelasticity problems involving slip between two surfaces
>>>>>> involving non-trivial geometries, i.e., elements with high aspect ratios,
>>>>>> large contrasts in material properties etc. The constraints are imposed
>>>>>> using Lagrange Multipliers.
>>>>>> A picture (shows displacement magnitude) is attached. The boundary
>>>>>> nodes, i.e., the base and the four side are pinned.
>>>>>> The following options appear to work well for the saddle point
>>>>>> problem:
>>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>>> -pc_fieldsplit_detect_saddle_point -fieldsplit_0_pc_type gamg
>>>>>> -fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type lsc
>>>>>> -fieldsplit_1_ksp_type preonly -pc_fieldsplit_schur_fact_type lower
>>>>>> -ksp_monitor
>>>>>> However, the number of iterations keep on increasing with the
>>>>>> problems size (see attached plot), e.g.,
>>>>>> 120K Tets        *507* Iterations (KSP Residual norm
>>>>>> 8.827362494659e-05) in  17 secs on   3 cores
>>>>>> 1 Million Tets  *1374* Iterations (KSP Residual norm
>>>>>> 7.164704416296e-05) in 117 secs on  20 cores
>>>>>> 8 Million Tets  *2495* Iterations (KSP Residual norm
>>>>>> 9.101247550026e-05) in 225 secs on 160 cores
>>>>>> So what other options should I try to improve solver performance? Any
>>>>>> tips/insights would be appreciated as preconditioning is black magic to me.
>>>>>  For reports, always run with
>>>>>    -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>>>  so that we can see exactly what you used.
>>>>>  I believe the default is a diagonal factorization. Since your outer
>>>>> iterates are increasing, I would strengthen this
>>>>> to either upper or full
>>>>>    -pc_fieldsplit_schur_factorization_type <upper, full>
>>>>>    Thanks,
>>>>>        Matt
>>>>>>  Thanks in advance.
>>>>>> Tabrez
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/14074be3/attachment-0001.html>
