[petsc-users] Fieldsplit with LSC for constrained elasticity/poroelasticity?
Tue Oct 28 07:08:11 CDT 2014
On Tue, Oct 28, 2014 at 5:39 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Mark
> When I replace "-fieldsplit_0_ksp_type preonly" with
> "-fieldsplit_0_ksp_type cg" then it becomes very slow (had to kill it).
That means something in the setup is wrong. It should be about the same or
faster. Run with -fieldsplit_0_ksp_monitor
so we can see what is happening.
   Matt
> With MUMPS , i.e., with '-fieldsplit_0_pc_type lu
> -fieldsplit_0_pc_factor_mat_solver_package mumps -fieldsplit_0_ksp_type
> preonly' it works fine but takes more time, and will be an issue for larger
> problems. The output for this run is attached.
> I will work on passing rigid body modes (as Matt mentioned) but short of
> that what is the best set of options for solving the following problem
> (i.e., linear elasticity with constraints):
> |K cG'| | u | = |F|
> |G  0 | |l/c|   |d|
> where c is a scaling factor (so that cG' terms are more or less of the
> same order as K)? The constraints are used to impose slip between surfaces
> and so on.
> Tabrez
> On 10/27/2014 01:17 PM, Mark Adams wrote:
> The null space for GAMG is not critical but useful for elasticity.  If you
> in fact have an indefinite operator (eg, not "pinned)  the you need to use
> an iterative coarse grid solver.  You are using '-fieldsplit_0_pc_type gamg
> -fieldsplit_0_ksp_type preonly'.  And you have a hard elasticity problem.
> You are going to want to start with a stronger solver. Use cg instead of
> preonly.  As Matt said start with MUMPS, then go to CG/GAMG, then you can
> see how far you can cut the _0_ solver down.
> Mark
> On Thu, Oct 23, 2014 at 11:51 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>>  On Thu, Oct 23, 2014 at 10:48 AM, Tabrez Ali <stali at geology.wisc.edu>
>> wrote:
>>>  Matt
>>> On 10/23/2014 09:54 AM, Matthew Knepley wrote:
>>>  On Thu, Oct 23, 2014 at 9:27 AM, Tabrez Ali <stali at geology.wisc.edu>
>>> wrote:
>>>>  Matt
>>>> Sorry about that (I always forget it). The output for the smallest
>>>> problem is now attached (see log.txt). I am also attaching some results
>>>> that compare results obtained using FS/LSC and the direct solver (MUMPS),
>>>> again for the smallest problem. The difference, as you can see is
>>>> insignificant O(1E-6).
>>>  1) How do you use MUMPS if you have a saddle point
>>> I simply used -pc_type lu -pc_factor_mat_solver_package mumps.
>>>  2) You can see from the output that something is seriously wrong with
>>> the preconditioner. It looks like it has a null space.
>>>     Did you add the elastic null modes to GAMG? Without this, it is not
>>> going to work. We have helper functions for this:
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexCreateRigidBody.html
>>>  you could just copy that code. And then use
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetNearNullSpace.html
>>>  I don't see it in the output, so I think this is your problem.
>>>  In order to test, I would first use MUMPS as the A00 solver and get
>>> the Schur stuff worked out. Then I would
>>> replace MUMPS with GAMG and tune it until I get back my original
>>> convergence.
>>> I will try this with MatNullSpaceCreateRigidBody. Btw does it matter if
>>> some nodes are pinned?
>>  No these are null modes of the operator, not of the particular problem.
>>    Matt
>>>  Tabrez
>>>    Thanks,
>>>      Matt
>>>>  Also, I did pass 'upper' and 'full' to
>>>> '-pc_fieldsplit_schur_factorization_type' but the iteration count doesn't
>>>> improve (in fact, it increases slightly). The attached log is with 'upper'.
>>>> Regards,
>>>> Tabrez
>>>> On 10/23/2014 07:46 AM, Matthew Knepley wrote:
>>>>  On Thu, Oct 23, 2014 at 7:20 AM, Tabrez Ali <stali at geology.wisc.edu>
>>>> wrote:
>>>>>  Hello
>>>>> I am using the following options (below) for solving linear
>>>>> elasticity/poroelasticity problems involving slip between two surfaces
>>>>> involving non-trivial geometries, i.e., elements with high aspect ratios,
>>>>> large contrasts in material properties etc. The constraints are imposed
>>>>> using Lagrange Multipliers.
>>>>> A picture (shows displacement magnitude) is attached. The boundary
>>>>> nodes, i.e., the base and the four side are pinned.
>>>>> The following options appear to work well for the saddle point problem:
>>>>> -pc_type fieldsplit -pc_fieldsplit_type schur
>>>>> -pc_fieldsplit_detect_saddle_point -fieldsplit_0_pc_type gamg
>>>>> -fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type lsc
>>>>> -fieldsplit_1_ksp_type preonly -pc_fieldsplit_schur_fact_type lower
>>>>> -ksp_monitor
>>>>> However, the number of iterations keep on increasing with the problems
>>>>> size (see attached plot), e.g.,
>>>>> 120K Tets        *507* Iterations (KSP Residual norm
>>>>> 8.827362494659e-05) in  17 secs on   3 cores
>>>>> 1 Million Tets  *1374* Iterations (KSP Residual norm
>>>>> 7.164704416296e-05) in 117 secs on  20 cores
>>>>> 8 Million Tets  *2495* Iterations (KSP Residual norm
>>>>> 9.101247550026e-05) in 225 secs on 160 cores
>>>>> So what other options should I try to improve solver performance? Any
>>>>> tips/insights would be appreciated as preconditioning is black magic to me.
>>>>  For reports, always run with
>>>>    -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>>>>  so that we can see exactly what you used.
>>>>  I believe the default is a diagonal factorization. Since your outer
>>>> iterates are increasing, I would strengthen this
>>>> to either upper or full
>>>>    -pc_fieldsplit_schur_factorization_type <upper, full>
>>>>    Thanks,
>>>>        Matt
>>>>>  Thanks in advance.
>>>>> Tabrez
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141028/e41b1051/attachment-0001.html>
