[petsc-users] TaoSolve() not working for multiple processors
Jason Sarich jason.sarich at gmail.com
Tue Oct 14 22:12:54 CDT 2014
Hi Justin,
If  the only constraints you have are bounds on the variables, then you are
much better off using the TAO algorithms tron or blmvm. IPM builds its own
KKT matrix for a ksp solve that is undoubtably much less efficient than
what will be used in tron (blmvm avoids ksp solves all together).
That begin said, it looks like there's a bug in IPM and I'll try to track
it down, thanks for the report.
Jason
On Tue, Oct 14, 2014 at 9:34 PM, Justin Chang <jychang48 at gmail.com> wrote:
>   Attached is the source code and the makefile used to compile/run the
> code.
>  The source code is basically a dumbed down version of SNES ex12 plus
> necessary TAO routines.
>  Thanks
> On Tue, Oct 14, 2014 at 8:39 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>>  On Tue, Oct 14, 2014 at 8:04 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>>  Hi all,
>>>  So I am writing a non-negative diffusion equation using DMPlex's FEM
>>> and Tao's SetVariableBounds functions. My code works really perfectly when
>>> I run it with one processor. However, once I use 2 or more processors, I
>>> get this error:
>>  It looks like the problem is in the TAO definition, but you can check
>> by just solving your problem with, for instance, BJacobi-LU in parallel.
>>>  [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Nonconforming object sizes
>>> [0]PETSC ERROR: Vector wrong size 89 for scatter 88 (scatter reverse and
>>> vector to != ctx from size)
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Nonconforming object sizes
>>> [1]PETSC ERROR: Vector wrong size 87 for scatter 88 (scatter reverse and
>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
>>> Date: 2014-10-04 20:10:35 -0500
>>> [1]PETSC ERROR: [0]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
>>> [0]PETSC ERROR: ./bin/diff2D on a arch-linux2-c-debug named pacotaco by
>>> justin Tue Oct 14 19:48:50 2014
>>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>> --with-fc=gfortran --download-fblaslapack --download-mpich
>>> --with-debugging=1 --download-metis --download-parmetis --download-triangle
>>> --with-cmake=cmake --download-ctetgen --download-superlu
>>> --download-scalapack --download-mumps --download-hdf5 --with-valgrind=1
>>> -with-cmake=cmake
>>> -with-cmake=cmake
>>> [0]PETSC ERROR: #1 VecScatterBegin() line 1713 in
>>> /home/justin/petsc-master/src/vec/vec/utils/vscat.c
>>> [1]PETSC ERROR: [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010
>>> in /home/justin/petsc-master/src/mat/impls/aij/mpi/mpiaij.c
>>> [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010 in
>>> [1]PETSC ERROR: #3 MatMultTranspose() line 2242 in
>>> /home/justin/petsc-master/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>>> /home/justin/petsc-master/src/tao/constrained/impls/ipm/ipm.c
>>> [1]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>>> [1]PETSC ERROR: [0]PETSC ERROR: #5 TaoSolve_IPM() line 50 in
>>> [1]PETSC ERROR: #6 TaoSolve() line 190 in
>>> /home/justin/petsc-master/src/tao/interface/taosolver.c
>>> [0]PETSC ERROR: #7 main() line 341 in
>>> /home/justin/Dropbox/Research_Topics/Petsc_Nonneg_diffusion/src/diff2D.c
>>> [1]PETSC ERROR: #7 main() line 341 in
>>> [1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
>>> -------send entire error message to petsc-maint at mcs.anl.gov----------
>>> ----------------End of Error Message -------send entire error message to
>>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
>>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
>>> [cli_1]: aborting job:
>>> [cli_0]: aborting job:
>>>  I have no idea how or why I am getting this error. What does this mean?
>>   It looks like one dof is given to proc 0 which should live on proc 1.
>> We have to look at the divisions
>> made in the KKT solver. Can you send a small example?
>>    Matt
>>>  My code is essentially built off of SNES ex12.c. The Jacobian matrix,
>>> residual vector, and solution vector were created using DMPlex and the
>>> built-in FEM functions within. The Hessian matrix and gradient vector were
>>> created by simple matmult() functions of the jacobian and residual. The
>>> lower bounds vector was created by duplicating the solution vector (initial
>>> guess set to zero). My FormFunctionGradient() is basically the same thing
>>> as in the maros.c example. can give more information if needed.
>>> Thanks,
>>> Justin
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/140616ac/attachment-0001.html>
