[petsc-users] TaoSolve() not working for multiple processors
Justin Chang jychang48 at gmail.com
Tue Oct 14 21:34:50 CDT 2014
Attached is the source code and the makefile used to compile/run the code.
The source code is basically a dumbed down version of SNES ex12 plus
necessary TAO routines.
Thanks
On Tue, Oct 14, 2014 at 8:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 14, 2014 at 8:04 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Hi all,
>> So I am writing a non-negative diffusion equation using DMPlex's FEM and
>> Tao's SetVariableBounds functions. My code works really perfectly when I
>> run it with one processor. However, once I use 2 or more processors, I get
>> this error:
> It looks like the problem is in the TAO definition, but you can check by
> just solving your problem with, for instance, BJacobi-LU in parallel.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Nonconforming object sizes
>> [0]PETSC ERROR: Vector wrong size 89 for scatter 88 (scatter reverse and
>> vector to != ctx from size)
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Nonconforming object sizes
>> [1]PETSC ERROR: Vector wrong size 87 for scatter 88 (scatter reverse and
>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
>> Date: 2014-10-04 20:10:35 -0500
>> [1]PETSC ERROR: [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
>> [0]PETSC ERROR: ./bin/diff2D on a arch-linux2-c-debug named pacotaco by
>> justin Tue Oct 14 19:48:50 2014
>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-fblaslapack --download-mpich
>> --with-debugging=1 --download-metis --download-parmetis --download-triangle
>> --with-cmake=cmake --download-ctetgen --download-superlu
>> --download-scalapack --download-mumps --download-hdf5 --with-valgrind=1
>> -with-cmake=cmake
>> -with-cmake=cmake
>> [0]PETSC ERROR: #1 VecScatterBegin() line 1713 in
>> /home/justin/petsc-master/src/vec/vec/utils/vscat.c
>> [1]PETSC ERROR: [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010 in
>> /home/justin/petsc-master/src/mat/impls/aij/mpi/mpiaij.c
>> [1]PETSC ERROR: #3 MatMultTranspose() line 2242 in
>> /home/justin/petsc-master/src/mat/interface/matrix.c
>> [0]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>> /home/justin/petsc-master/src/tao/constrained/impls/ipm/ipm.c
>> [1]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>> [1]PETSC ERROR: [0]PETSC ERROR: #5 TaoSolve_IPM() line 50 in
>> [1]PETSC ERROR: #6 TaoSolve() line 190 in
>> /home/justin/petsc-master/src/tao/interface/taosolver.c
>> [0]PETSC ERROR: #7 main() line 341 in
>> /home/justin/Dropbox/Research_Topics/Petsc_Nonneg_diffusion/src/diff2D.c
>> [1]PETSC ERROR: #7 main() line 341 in
>> [1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
>> -------send entire error message to petsc-maint at mcs.anl.gov----------
>> ----------------End of Error Message -------send entire error message to
>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
>> [cli_1]: aborting job:
>> [cli_0]: aborting job:
>> I have no idea how or why I am getting this error. What does this mean?
> It looks like one dof is given to proc 0 which should live on proc 1. We
> have to look at the divisions
> made in the KKT solver. Can you send a small example?
>   Matt
>> My code is essentially built off of SNES ex12.c. The Jacobian matrix,
>> residual vector, and solution vector were created using DMPlex and the
>> built-in FEM functions within. The Hessian matrix and gradient vector were
>> created by simple matmult() functions of the jacobian and residual. The
>> lower bounds vector was created by duplicating the solution vector (initial
>> guess set to zero). My FormFunctionGradient() is basically the same thing
>> as in the maros.c example. can give more information if needed.
>> Thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/96952de7/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/96952de7/attachment.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/96952de7/attachment.obj>
