[petsc-users] TaoSolve() not working for multiple processors
Justin Chang jychang48 at gmail.com
Tue Oct 14 23:58:13 CDT 2014
Hi Jason,
Both of those algorithms resolved my problem. Thanks!
Justin
On Tue, Oct 14, 2014 at 10:12 PM, Jason Sarich <jason.sarich at gmail.com>
wrote:
> Hi Justin,
> If  the only constraints you have are bounds on the variables, then you
> are much better off using the TAO algorithms tron or blmvm. IPM builds its
> own KKT matrix for a ksp solve that is undoubtably much less efficient than
> what will be used in tron (blmvm avoids ksp solves all together).
> That begin said, it looks like there's a bug in IPM and I'll try to track
> it down, thanks for the report.
> Jason
> On Tue, Oct 14, 2014 at 9:34 PM, Justin Chang <jychang48 at gmail.com> wrote:
>>   Attached is the source code and the makefile used to compile/run the
>> code.
>>  The source code is basically a dumbed down version of SNES ex12 plus
>> necessary TAO routines.
>>  Thanks
>> On Tue, Oct 14, 2014 at 8:39 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>>  On Tue, Oct 14, 2014 at 8:04 PM, Justin Chang <jychang48 at gmail.com>
>>> wrote:
>>>>  Hi all,
>>>>  So I am writing a non-negative diffusion equation using DMPlex's FEM
>>>> and Tao's SetVariableBounds functions. My code works really perfectly when
>>>> I run it with one processor. However, once I use 2 or more processors, I
>>>> get this error:
>>>  It looks like the problem is in the TAO definition, but you can check
>>> by just solving your problem with, for instance, BJacobi-LU in parallel.
>>>>  [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Nonconforming object sizes
>>>> [0]PETSC ERROR: Vector wrong size 89 for scatter 88 (scatter reverse
>>>> and vector to != ctx from size)
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Nonconforming object sizes
>>>> [1]PETSC ERROR: Vector wrong size 87 for scatter 88 (scatter reverse
>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80
>>>> GIT Date: 2014-10-04 20:10:35 -0500
>>>> [1]PETSC ERROR: [0]PETSC ERROR: See
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80
>>>> [0]PETSC ERROR: ./bin/diff2D on a arch-linux2-c-debug named pacotaco by
>>>> justin Tue Oct 14 19:48:50 2014
>>>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>> --with-fc=gfortran --download-fblaslapack --download-mpich
>>>> --with-debugging=1 --download-metis --download-parmetis --download-triangle
>>>> --with-cmake=cmake --download-ctetgen --download-superlu
>>>> --download-scalapack --download-mumps --download-hdf5 --with-valgrind=1
>>>> -with-cmake=cmake
>>>> -with-cmake=cmake
>>>> [0]PETSC ERROR: #1 VecScatterBegin() line 1713 in
>>>> /home/justin/petsc-master/src/vec/vec/utils/vscat.c
>>>> [1]PETSC ERROR: [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010
>>>> in /home/justin/petsc-master/src/mat/impls/aij/mpi/mpiaij.c
>>>> [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010 in
>>>> [1]PETSC ERROR: #3 MatMultTranspose() line 2242 in
>>>> /home/justin/petsc-master/src/mat/interface/matrix.c
>>>> [0]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>>>> /home/justin/petsc-master/src/tao/constrained/impls/ipm/ipm.c
>>>> [1]PETSC ERROR: #4 IPMComputeKKT() line 616 in
>>>> [1]PETSC ERROR: [0]PETSC ERROR: #5 TaoSolve_IPM() line 50 in
>>>> [1]PETSC ERROR: #6 TaoSolve() line 190 in
>>>> /home/justin/petsc-master/src/tao/interface/taosolver.c
>>>> [0]PETSC ERROR: #7 main() line 341 in
>>>> /home/justin/Dropbox/Research_Topics/Petsc_Nonneg_diffusion/src/diff2D.c
>>>> [1]PETSC ERROR: #7 main() line 341 in
>>>> [1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
>>>> -------send entire error message to petsc-maint at mcs.anl.gov----------
>>>> ----------------End of Error Message -------send entire error message
>>>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
>>>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
>>>> [cli_1]: aborting job:
>>>> [cli_0]: aborting job:
>>>>  I have no idea how or why I am getting this error. What does this
>>>> mean?
>>>   It looks like one dof is given to proc 0 which should live on proc 1.
>>> We have to look at the divisions
>>> made in the KKT solver. Can you send a small example?
>>>    Matt
>>>>  My code is essentially built off of SNES ex12.c. The Jacobian matrix,
>>>> residual vector, and solution vector were created using DMPlex and the
>>>> built-in FEM functions within. The Hessian matrix and gradient vector were
>>>> created by simple matmult() functions of the jacobian and residual. The
>>>> lower bounds vector was created by duplicating the solution vector (initial
>>>> guess set to zero). My FormFunctionGradient() is basically the same thing
>>>> as in the maros.c example. can give more information if needed.
>>>> Thanks,
>>>> Justin
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/ce1d5306/attachment.html>
