[petsc-users] TaoSolve() not working for multiple processors
Tue Oct 14 20:39:45 CDT 2014
On Tue, Oct 14, 2014 at 8:04 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi all,
> So I am writing a non-negative diffusion equation using DMPlex's FEM and
> Tao's SetVariableBounds functions. My code works really perfectly when I
> run it with one processor. However, once I use 2 or more processors, I get
> this error:
It looks like the problem is in the TAO definition, but you can check by
just solving your problem with, for instance, BJacobi-LU in parallel.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: Vector wrong size 89 for scatter 88 (scatter reverse and
> vector to != ctx from size)
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Nonconforming object sizes
> [1]PETSC ERROR: Vector wrong size 87 for scatter 88 (scatter reverse and
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
> Date: 2014-10-04 20:10:35 -0500
> [1]PETSC ERROR: [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
> [0]PETSC ERROR: ./bin/diff2D on a arch-linux2-c-debug named pacotaco by
> justin Tue Oct 14 19:48:50 2014
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich
> --with-debugging=1 --download-metis --download-parmetis --download-triangle
> --with-cmake=cmake --download-ctetgen --download-superlu
> --download-scalapack --download-mumps --download-hdf5 --with-valgrind=1
> -with-cmake=cmake
> -with-cmake=cmake
> [0]PETSC ERROR: #1 VecScatterBegin() line 1713 in
> /home/justin/petsc-master/src/vec/vec/utils/vscat.c
> [1]PETSC ERROR: [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010 in
> /home/justin/petsc-master/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: #3 MatMultTranspose() line 2242 in
> /home/justin/petsc-master/src/mat/interface/matrix.c
> [0]PETSC ERROR: #4 IPMComputeKKT() line 616 in
> /home/justin/petsc-master/src/tao/constrained/impls/ipm/ipm.c
> [1]PETSC ERROR: #4 IPMComputeKKT() line 616 in
> [1]PETSC ERROR: [0]PETSC ERROR: #5 TaoSolve_IPM() line 50 in
> [1]PETSC ERROR: #6 TaoSolve() line 190 in
> /home/justin/petsc-master/src/tao/interface/taosolver.c
> [0]PETSC ERROR: #7 main() line 341 in
> /home/justin/Dropbox/Research_Topics/Petsc_Nonneg_diffusion/src/diff2D.c
> [1]PETSC ERROR: #7 main() line 341 in
> [1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
> -------send entire error message to petsc-maint at mcs.anl.gov----------
> ----------------End of Error Message -------send entire error message to
> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
> [cli_1]: aborting job:
> [cli_0]: aborting job:
> I have no idea how or why I am getting this error. What does this mean?
It looks like one dof is given to proc 0 which should live on proc 1. We
have to look at the divisions
made in the KKT solver. Can you send a small example?
  Matt
> My code is essentially built off of SNES ex12.c. The Jacobian matrix,
> residual vector, and solution vector were created using DMPlex and the
> built-in FEM functions within. The Hessian matrix and gradient vector were
> created by simple matmult() functions of the jacobian and residual. The
> lower bounds vector was created by duplicating the solution vector (initial
> guess set to zero). My FormFunctionGradient() is basically the same thing
> as in the maros.c example. can give more information if needed.
> Thanks,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/adea4c59/attachment.html>
