[petsc-users] TaoSolve() not working for multiple processors
Justin Chang jychang48 at gmail.com
Tue Oct 14 20:04:39 CDT 2014
Hi all,
So I am writing a non-negative diffusion equation using DMPlex's FEM and
Tao's SetVariableBounds functions. My code works really perfectly when I
run it with one processor. However, once I use 2 or more processors, I get
this error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: Vector wrong size 89 for scatter 88 (scatter reverse and
vector to != ctx from size)
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Nonconforming object sizes
[1]PETSC ERROR: Vector wrong size 87 for scatter 88 (scatter reverse and
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
Date: 2014-10-04 20:10:35 -0500
[1]PETSC ERROR: [0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-526-gfaecc80  GIT
[0]PETSC ERROR: ./bin/diff2D on a arch-linux2-c-debug named pacotaco by
justin Tue Oct 14 19:48:50 2014
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-fblaslapack --download-mpich
--with-debugging=1 --download-metis --download-parmetis --download-triangle
--with-cmake=cmake --download-ctetgen --download-superlu
--download-scalapack --download-mumps --download-hdf5 --with-valgrind=1
-with-cmake=cmake
-with-cmake=cmake
[0]PETSC ERROR: #1 VecScatterBegin() line 1713 in
/home/justin/petsc-master/src/vec/vec/utils/vscat.c
[1]PETSC ERROR: [0]PETSC ERROR: #2 MatMultTranspose_MPIAIJ() line 1010 in
/home/justin/petsc-master/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: #3 MatMultTranspose() line 2242 in
/home/justin/petsc-master/src/mat/interface/matrix.c
[0]PETSC ERROR: #4 IPMComputeKKT() line 616 in
/home/justin/petsc-master/src/tao/constrained/impls/ipm/ipm.c
[1]PETSC ERROR: #4 IPMComputeKKT() line 616 in
[1]PETSC ERROR: [0]PETSC ERROR: #5 TaoSolve_IPM() line 50 in
[1]PETSC ERROR: #6 TaoSolve() line 190 in
/home/justin/petsc-master/src/tao/interface/taosolver.c
[0]PETSC ERROR: #7 main() line 341 in
/home/justin/Dropbox/Research_Topics/Petsc_Nonneg_diffusion/src/diff2D.c
[1]PETSC ERROR: #7 main() line 341 in
[1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
-------send entire error message to petsc-maint at mcs.anl.gov----------
----------------End of Error Message -------send entire error message to
application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
[cli_1]: aborting job:
[cli_0]: aborting job:
I have no idea how or why I am getting this error. What does this mean?
My code is essentially built off of SNES ex12.c. The Jacobian matrix,
residual vector, and solution vector were created using DMPlex and the
built-in FEM functions within. The Hessian matrix and gradient vector were
created by simple matmult() functions of the jacobian and residual. The
lower bounds vector was created by duplicating the solution vector (initial
guess set to zero). My FormFunctionGradient() is basically the same thing
as in the maros.c example. can give more information if needed.
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141014/42f71263/attachment-0001.html>
