[petsc-users] 3D multi-dof DMDA and Poisson equation
Wed Oct 8 15:04:28 CDT 2014
On Wed, Oct 8, 2014 at 3:00 PM, Håkon Strandenes <haakon at hakostra.net>
wrote:
> Hi,
> I am making a new, simple incompressible CFD code. I have created a grid
> as a 3D DMDA, with ndof=4, one dof for each velocity component (u,v,w) and
> one for the pressure (p). Currently I am creating a forward Euler step,
> where the velocities are updated based on the velocities and pressure from
> the previous time step. That works great. Now I need to solve a Poisson
> equation for the pressure correction term, enforcing continuity onto my
> solution, and this is where I have a few questions for you:
> 1)
> How do I set up my equation system in the most efficient way? The vectors
> from the DMDA is not contiguous in a global sense, i.e. if I map the local
> (i,j,k) indices to a global index with
> globId = (info.mx*info.my)*k + (info-.mx)*j + i;
> globId is not gontignous on any process. How do I create my coefficient
> matrix, r.h.s. vector and solution vector? Is there some way I can make the
> local parts of the matrix and vectors mimic the decomposition from the
> DMDA? Or should I push all values into a different decomposition scheme,
> where each process holds one contigous slab of the equation system using
> the global ID's calculated above? Have I missed some really basic stuff
> here?
See SNES ex5 (which is Poisson when you throw away the extra e^u term).
Hopefully this will explain your question about numbering.
> 2)
> I know that my coefficient matrix from the Poisson equation is symmetric.
> Currently I am still creating and inserting values on both the upper and
> lower diagonal. Is this really necessary? Or is there a "smart" way I can
> save half the storage by only creating the upper or lower part?
You can save storage, but not work, so unless you are memory constrained,
this is not worth doing.
> 3)
> I solve a transient problem, but my coefficient matrix is the same for all
> time steps and I only recompute the r.h.s. vector for each time step. I
> have got the impression that KSPsolve "finds out" if the A matrix have
> changed since last invocation or not, recalculating the preconditioner as
> necessary. But still I feel that I should utilize this property more. Do
> you have any tips in how I can use this in the most efficient way possible?
> For example really, really efficient, but expensive, preconditioners?
We should figure this out automatically. Please report if this does not
happen for you. Also, we recommend using
TS for timestepping (at least eventually).
    Matt
> Thanks in advance.
> Regards,
> Håkon Strandenes
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141008/63c66531/attachment.html>
