[petsc-users] 3D multi-dof DMDA and Poisson equation
Håkon Strandenes haakon at hakostra.net
Wed Oct 8 15:00:24 CDT 2014
I am making a new, simple incompressible CFD code. I have created a grid
as a 3D DMDA, with ndof=4, one dof for each velocity component (u,v,w)
and one for the pressure (p). Currently I am creating a forward Euler
step, where the velocities are updated based on the velocities and
pressure from the previous time step. That works great. Now I need to
solve a Poisson equation for the pressure correction term, enforcing
continuity onto my solution, and this is where I have a few questions
for you:
1)
How do I set up my equation system in the most efficient way? The
vectors from the DMDA is not contiguous in a global sense, i.e. if I map
the local (i,j,k) indices to a global index with
globId = (info.mx*info.my)*k + (info-.mx)*j + i;
globId is not gontignous on any process. How do I create my coefficient
matrix, r.h.s. vector and solution vector? Is there some way I can make
the local parts of the matrix and vectors mimic the decomposition from
the DMDA? Or should I push all values into a different decomposition
scheme, where each process holds one contigous slab of the equation
system using the global ID's calculated above? Have I missed some really
basic stuff here?
2)
I know that my coefficient matrix from the Poisson equation is
symmetric. Currently I am still creating and inserting values on both
the upper and lower diagonal. Is this really necessary? Or is there a
"smart" way I can save half the storage by only creating the upper or
lower part?
3)
I solve a transient problem, but my coefficient matrix is the same for
all time steps and I only recompute the r.h.s. vector for each time
step. I have got the impression that KSPsolve "finds out" if the A
matrix have changed since last invocation or not, recalculating the
preconditioner as necessary. But still I feel that I should utilize this
property more. Do you have any tips in how I can use this in the most
efficient way possible? For example really, really efficient, but
expensive, preconditioners?
Thanks in advance.
Håkon Strandenes
