[petsc-users] 3D multi-dof DMDA and Poisson equation
Jed Brown jed at jedbrown.org
Wed Oct 8 15:07:04 CDT 2014
Håkon Strandenes <haakon at hakostra.net> writes:
> Hi,
> I am making a new, simple incompressible CFD code. I have created a grid
> as a 3D DMDA, with ndof=4, one dof for each velocity component (u,v,w)
> and one for the pressure (p). Currently I am creating a forward Euler
> step, where the velocities are updated based on the velocities and
> pressure from the previous time step. That works great. Now I need to
> solve a Poisson equation for the pressure correction term, enforcing
> continuity onto my solution, and this is where I have a few questions
> for you:
> 1)
> How do I set up my equation system in the most efficient way? The
> vectors from the DMDA is not contiguous in a global sense, i.e. if I map
> the local (i,j,k) indices to a global index with
> globId = (info.mx*info.my)*k + (info-.mx)*j + i;
This is a "natural index", used in some cases for IO, but not for
computation.
> globId is not gontignous on any process. How do I create my coefficient
> matrix, r.h.s. vector and solution vector?
DMCreateGlobalVector()
it will use what is described in the Users Manual as "PETSc ordering".
Please read this section of the manual; I think it will answer your
questions.
> Is there some way I can make the local parts of the matrix and vectors
> mimic the decomposition from the DMDA? Or should I push all values
> into a different decomposition scheme, where each process holds one
> contigous slab of the equation system using the global ID's calculated
> above? Have I missed some really basic stuff here?
> 2)
> I know that my coefficient matrix from the Poisson equation is
> symmetric. Currently I am still creating and inserting values on both
> the upper and lower diagonal. Is this really necessary? Or is there a
> "smart" way I can save half the storage by only creating the upper or
> lower part?
-dm_mat_type sbaij
> 3)
> I solve a transient problem, but my coefficient matrix is the same for
> all time steps and I only recompute the r.h.s. vector for each time
> step. I have got the impression that KSPsolve "finds out" if the A
> matrix have changed since last invocation or not, recalculating the
> preconditioner as necessary.
If you just call KSPSolve, it will reuse everything.  Call
KSPSetOperators (assuming you are manually doing the time
discretization) if the matrix changes.
> But still I feel that I should utilize this property more. Do you have
> any tips in how I can use this in the most efficient way possible? For
> example really, really efficient, but expensive, preconditioners?
> Thanks in advance.
> Regards,
> Håkon Strandenes
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141008/61aed57d/attachment.pgp>
