[petsc-users] How to use
Sharp Stone thronesf at gmail.com
Thu Oct 2 14:06:22 CDT 2014
Hi Jed,
Thank you very much!
On Thu, Oct 2, 2014 at 3:02 PM, Jed Brown <jed at jedbrown.org> wrote:
> Sharp Stone <thronesf at gmail.com> writes:
> > Hi all,
> > I'm sorry I'm still confusing that if I have calculated the Jacobian
> > elements, how can I go ahead to solve the linear system with dof>1 at
> each
> > node? The example code ex19 solves the linear system with Guass-Seidel
> > method,
> As we just said, the same code (ex19.c) can use many different methods.
> The default method is Newton-Krylov with block Jacobi preconditioning.
> Run with -snes_view to see details.
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/af95a48b/attachment.html>
