[petsc-users] How to use
Jed Brown jed at jedbrown.org
Thu Oct 2 14:02:05 CDT 2014
Sharp Stone <thronesf at gmail.com> writes:
> Hi all,
> I'm sorry I'm still confusing that if I have calculated the Jacobian
> elements, how can I go ahead to solve the linear system with dof>1 at each
> node? The example code ex19 solves the linear system with Guass-Seidel
> method,
As we just said, the same code (ex19.c) can use many different methods.
The default method is Newton-Krylov with block Jacobi preconditioning.
Run with -snes_view to see details.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/2973ea04/attachment.pgp>
