[petsc-users] How to use
Sharp Stone thronesf at gmail.com
Thu Oct 2 15:29:46 CDT 2014
Hi all,
In the ex19, specifically from Lines 581-587, about the "invert the system"
part,
581:             /* invert the system:582:              [ dfu / du
0        0        0    ][yu] = [fu]583:              [     0    dfv /
dv     0        0    ][yv]   [fv]584:              [ dfo / du dfo / dv
dfo / do     0    ][yo]   [fo]585:              [ dft / du dft / dv
 0    dft / dt ][yt]   [ft]586:              by simple
back-substitution587:            */
 I realized u and v are independent variables, but even so, the first two
rows should be both containing dfu/dv and dfv/du terms just like the 3rd
and 4th rows, do I miss some points?
Thank you in advance!
On Thu, Oct 2, 2014 at 3:02 PM, Jed Brown <jed at jedbrown.org> wrote:
> Sharp Stone <thronesf at gmail.com> writes:
> > Hi all,
> > I'm sorry I'm still confusing that if I have calculated the Jacobian
> > elements, how can I go ahead to solve the linear system with dof>1 at
> each
> > node? The example code ex19 solves the linear system with Guass-Seidel
> > method,
> As we just said, the same code (ex19.c) can use many different methods.
> The default method is Newton-Krylov with block Jacobi preconditioning.
> Run with -snes_view to see details.
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/cb6fb523/attachment.html>
