[petsc-users] How to use
Sharp Stone thronesf at gmail.com
Thu Oct 2 13:57:03 CDT 2014
Hi all,
I'm sorry I'm still confusing that if I have calculated the Jacobian
elements, how can I go ahead to solve the linear system with dof>1 at each
node? The example code ex19 solves the linear system with Guass-Seidel
method, and now I do want to use Jacobian matrix because I've found the
Jacobian elements. Any ideas? Many thanks!
On Thu, Oct 2, 2014 at 1:26 PM, Sharp Stone <thronesf at gmail.com> wrote:
> Hi Matt and Jed,
> Thank you very much for your replies. In source code ex19, the routine
> SNESSetNGS() is used, and no other options or Jacobi routines are used. How
> can we change the iteration method? The routine SNESSetFromOptions(snes)
> could do this for the user? If I understand correctly, petsc would use
> Gauss-Seidel or Jacobi method as designated with even the same source code?
> Thank you in advance!
> On Thu, Oct 2, 2014 at 1:12 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Sharp Stone <thronesf at gmail.com> writes:
>> > Matt,
>> > Thank you very much!
>> > The ex19 used the Gauss-Seidel method. But I'm a little bit wonder
>> whether
>> > we have any examples of Jacobi method to solve such linear systems
>> "(mat)A
>> > dot (vec)X = (vec)B" with dof>1? Thanks in advance!
>> ex19 does whatever you want: -pc_type jacobi and the like.
> Best regards,
> Feng
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/b927c21c/attachment-0001.html>
