[petsc-users] MatSolve in CG
De Groof, Vincent Frans Maria Vincent.De-Groof at uibk.ac.at
Mon Nov 10 10:57:55 CST 2014
Dear all,
I am writing a few variations on the PCG algorithm. Starting with my own PCG implementation, I noticed that my routine is quite a bit slower (~20%). I think I tracked it down to the MatSolve calls in PCApply. I am using BDDC as the preconditioner.
In the Petsc PCG function, each PCApply calls the MatSolve 3 times. It also calls MatSolve once somewhere between calling KSPSolve and KSPSolve_CG (KSP_SetUp has been called before). So MatSolve is called 1+3*(# iterations) per KSPSolve. In my own PCG variation, the initial MatSolve is not called. But MatSolve is called 4 times in each iteration, so in total 4*(# iterations).
Where does this MatSolve in between KSPSolve and KSPSolve_CG come from? And how can I make my function use less MatSolve's?
I hope that I explained the problem clearly, and maybe this is a very trivial question.
kind regards,
Vincent
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141110/fabc347d/attachment-0001.html>
