[petsc-users] MatSolve in CG
Jed Brown jed at jedbrown.org
Sat Nov 15 15:30:24 CST 2014
"De Groof, Vincent Frans Maria" <Vincent.De-Groof at uibk.ac.at> writes:
> Dear all,
> I am writing a few variations on the PCG algorithm. Starting with my own PCG implementation, I noticed that my routine is quite a bit slower (~20%). I think I tracked it down to the MatSolve calls in PCApply. I am using BDDC as the preconditioner.
> In the Petsc PCG function, each PCApply calls the MatSolve 3 times. It also calls MatSolve once somewhere between calling KSPSolve and KSPSolve_CG (KSP_SetUp has been called before). So MatSolve is called 1+3*(# iterations) per KSPSolve. In my own PCG variation, the initial MatSolve is not called. But MatSolve is called 4 times in each iteration, so in total 4*(# iterations).
> Where does this MatSolve in between KSPSolve and KSPSolve_CG come from? And how can I make my function use less MatSolve's?
I recommend running in a debugger to get the stack trace.  I don't know
what is different between your Krylov implementation and CG, but it
should be obvious when you compare.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141115/939a3d22/attachment.pgp>
