[petsc-users] Multiple solves with PCMG fail
Mark Adams mfadams at lbl.gov
Thu Nov 6 10:27:59 CST 2014
Humm, not sure what the problem is. I used your test code to debug this
branch.
You might go to this line:
[1]PETSC ERROR: #1 KSPComputeEigenvalues() line 119 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/interface/itfunc.c
if (n) PetscValidScalarPointer(r,3);
and put a print statement.  n==0 in your case when it fails.
On Wed, Nov 5, 2014 at 2:37 AM, Filippo Leonardi <
filippo.leonardi at sam.math.ethz.ch> wrote:
> @ Jed
> Can't figure out what solver is causing the problem actually, I tried
> evrerything: mg_levels, mg_coarse and nothing.
> On Tuesday 04 November 2014 12.21:29 Mark Adams wrote:
> > On Tue, Nov 4, 2014 at 2:55 AM, Filippo Leonardi <
> > > Sorry for the late update.
> > > I tested the code with the branch:
> > > ksp-zero-eig
> > Did you make PETSc after the checking out the branch?
> Yes.
> > Please send us the
> > error message and run in debug mode if possible.
> See below.
> > > But the problem seems to still be there, also tried:
> > > -ksp_chebyshev_estimate_eigenvalues_random
> > > but does not change.
> > > Just tell me what test you need and I'll try to do them.
> > > Best,
> > > Filippo
> > > On Wednesday 29 October 2014 10.30:14 Mark Adams wrote:
> > > > > Yeah, that should work; an alternative is to defer the estimate
> until
> > > > > the next solve.
> > > > Sounds better.  As I said one of my users has a zero RHS on the first
> > > solve.
> ( Despite ARCH being arch-linux2-cxx-opt  it's compiled in debug mode )
> mpirun -np 4 ./test1 -mg_levels_ksp_chebyshev_estimate_eigenvalues_random -
> ksp_chebyshev_estimate_eigenvalues_random -pc_type mg -pc_mg_levels 5 -
> draw_pause -1 -ksp_view
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Null argument, when expecting valid pointer
> [1]PETSC ERROR: Null Pointer: Parameter # 3
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for
> trouble shooting.
> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.2-925-g233c798  GIT
> Date:
> 2014-11-03 17:44:15 -0700
> [1]PETSC ERROR: ./test1 on a arch-linux2-cxx-opt named Besikovitch-III by
> filippo Wed Nov  5 08:32:52 2014
> [1]PETSC ERROR: Configure options
> [1]PETSC ERROR: #2 KSPChebyshevComputeExtremeEigenvalues_Private() line
> 328 in
> /home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/impls/cheby/cheby.c
> [1]PETSC ERROR: #3 KSPSolve_Chebyshev() line 373 in
> [1]PETSC ERROR: #4 KSPSolve() line 460 in /home/filippo/Workspace/petsc-
> [1]PETSC ERROR: #5 PCMGMCycle_Private() line 19 in
> /home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/pc/impls/mg/mg.c
> [1]PETSC ERROR: #6 PCApply_MG() line 337 in /home/filippo/Workspace/petsc-
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141106/447f9d30/attachment.html>
