[petsc-users] Multiple solves with PCMG fail
Filippo Leonardi filippo.leonardi at sam.math.ethz.ch
Mon Nov 10 08:18:40 CST 2014
Super late update, sorry.
Not sure
if I understood you correctly:
if(n) {
    PetscValidScalarPointer(r,3);
    ierr = PetscPrintf(PETSC_COMM_WORLD, " ---> n = %d nonzero if.\n",
n);CHKERRQ(ierr);
  } else {
    ierr = PetscPrintf(PETSC_COMM_WORLD, " ---> n = 0 else.\n");CHKERRQ(ierr);
I get (btw this is also the case with a single process):
./test1 -pc_type mg -pc_mg_levels 3
 ---> n = 0 else.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Pointer: Parameter # 4
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-925-g233c798  GIT Date:
2014-11-03 17:44:15 -0700
[0]PETSC ERROR: ./test1 on a arch-linux2-cxx-opt named Besikovitch-III by
filippo Mon Nov 10 15:15:47 2014
[0]PETSC ERROR: Configure options PETSC_ARCH=arch-linux2-cxx-opt
[0]PETSC ERROR: #1 KSPComputeEigenvalues() line 125 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #2 KSPChebyshevComputeExtremeEigenvalues_Private() line 328 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/impls/cheby/cheby.c
[0]PETSC ERROR: #3 KSPSolve_Chebyshev() line 373 in
[0]PETSC ERROR: #4 KSPSolve() line 465 in /home/filippo/Workspace/petsc-
[0]PETSC ERROR: #5 PCMGMCycle_Private() line 19 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #6 PCApply_MG() line 337 in /home/filippo/Workspace/petsc-
[0]PETSC ERROR: #7 PCApply() line 440 in /home/filippo/Workspace/petsc-
git/ksp-zero-eig/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #8 KSP_PCApply() line 230 in /home/filippo/Workspace/petsc-
git/ksp-zero-eig/include/petsc-private/kspimpl.h
[0]PETSC ERROR: #9 KSPInitialResidual() line 63 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/interface/itres.c
[0]PETSC ERROR: #10 KSPSolve_GMRES() line 234 in
/home/filippo/Workspace/petsc-git/ksp-zero-eig/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: #11 KSPSolve() line 465 in /home/filippo/Workspace/petsc-
[0]PETSC ERROR: #12 main() line 149 in
/home/filippo/Workspace/C++/MLMCTest/test1.cpp
[0]PETSC ERROR: ----------------End of Error Message -------send entire error
message to petsc-maint at mcs.anl.gov----------
On Thursday 06 November 2014 11.27:59 you wrote:
> if (n) PetscValidScalarPointer(r,3);
> and put a print statement.  n==0 in your case when it fails.
Name: Filippo Leonardi.vcf
Type: text/vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141110/fecfeef5/attachment.bin>
