[petsc-users] Memory corruption with two-dimensional array and PetscMemzero
Christophe Ortiz christophe.ortiz at ciemat.es
Wed May 21 08:18:06 CDT 2014
On Tue, May 20, 2014 at 4:25 PM, Jed Brown <jed at jedbrown.org> wrote:
> Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> > Would the following be ok ?
> > //Creation of vector X of size dof*dof:
> > VecCreateSeq(PETSC_COMM_SELF,dof*dof,&X);
> > // Using two-dimensional array style:
> > PetscScalar *x;
> This needs to be
>   PetscScalar **x;
> as you would have noticed if you tried to compile.
> > VecGetArray2d(X,dof,dof,0,0,&x);
> > x[i][j] = ...;
> Yes.
> > Is it ok ?
> > Then, what should be passed to MatSetValuesBlocked() ?
> Since the array starts are (0,0), you can just pass &x[0][0].
> Remember to call VecRestoreArray2d() and eventually VecDestroy().
I tried and it works. The advantage is that it avoids setting up and using
pointers.
However, I found out that it is significantly slower than using explicit
pointers of pointers **.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140521/e2792ac0/attachment.html>
