[petsc-users] Memory corruption with two-dimensional array and PetscMemzero
Jed Brown jed at jedbrown.org
Wed May 21 08:21:47 CDT 2014
Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> I tried and it works. The advantage is that it avoids setting up and
> using pointers.  However, I found out that it is significantly slower
> than using explicit pointers of pointers **.
Are you creating and destroying in an inner loop?  What gets set up is
the same, and it's fewer allocations than what you were doing with many
calls to malloc.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140521/1fea18d7/attachment.pgp>
