[petsc-users] hypre support
Fri May 16 12:56:49 CDT 2014
   Algebraic multigrid is not for everything.
On May 16, 2014, at 11:49 AM, Dario Isola <dario.isola at newmerical.com> wrote:
> Thanks a lot for your answers.
> I ran it with
> -ksp_type gmres -pc_type hypre -pc_hypre_type euclid
> and it worked very well. Thanks.
> I then tried to use boomeramg as a preconditioner coupled with Richardson but I was not successful, it failed to solve the system and returned nans.
> -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_relax_type_all SOR/Jacobi -pc_hypre_boomeramg_print_debug -ksp_view -ksp_monitor_true_residual
> and i got the following
>  ===== Proc = 0     Level = 0  =====
> Proc = 0    Coarsen 1st pass = 0.000000
> Proc = 0    Coarsen 2nd pass = 0.000000
> Proc = 0    Initialize CLJP phase = 0.000000
> Proc = 0  iter 1  comm. and subgraph update = 0.000000
> Proc = 0    CLJP phase = 0.000000 graph_size = 18308 nc_offd = 0
> Proc = 0  iter 2  comm. and subgraph update = 0.000000
> Proc = 0    CLJP phase = 0.000000 graph_size = 7 nc_offd = 0
>  ===== Proc = 0     Level = 1  =====
> Proc = 0    Coarsen 1st pass = 0.010000
> Proc = 0    CLJP phase = 0.000000 graph_size = 8725 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 16 nc_offd = 0
>  ===== Proc = 0     Level = 2  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 4721 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 13 nc_offd = 0
> Proc = 0  iter 3  comm. and subgraph update = 0.000000
> Proc = 0    CLJP phase = 0.000000 graph_size = 4 nc_offd = 0
>  ===== Proc = 0     Level = 3  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 2495 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 22 nc_offd = 0
>  ===== Proc = 0     Level = 4  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 1337 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 2 nc_offd = 0
>  ===== Proc = 0     Level = 5  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 695 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 3 nc_offd = 0
>  ===== Proc = 0     Level = 6  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 343 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 21 nc_offd = 0
>  ===== Proc = 0     Level = 7  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 174 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 15 nc_offd = 0
>  ===== Proc = 0     Level = 8  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 81 nc_offd = 0
>  ===== Proc = 0     Level = 9  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 37 nc_offd = 0
> Proc = 0    CLJP phase = 0.000000 graph_size = 6 nc_offd = 0
>  ===== Proc = 0     Level = 10  =====
> Proc = 0    CLJP phase = 0.000000 graph_size = 11 nc_offd = 0
>   0 KSP preconditioned resid norm 7.299769365830e+14 true resid norm 8.197927963033e-03 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 2.319459389445e+28 true resid norm 6.152576199945e+12 ||r(i)||/||b|| 7.505038136086e+14
> KSP Object: 1 MPI processes
>   type: richardson
>     Richardson: damping factor=1
>   maximum iterations=90, initial guess is zero
>   tolerances:  relative=0.1, absolute=1e-50, divergence=100000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: hypre
>     HYPRE BoomerAMG preconditioning
>     HYPRE BoomerAMG: Cycle type V
>     HYPRE BoomerAMG: Maximum number of levels 25
>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>     HYPRE BoomerAMG: Threshold for strong coupling 0.25
>     HYPRE BoomerAMG: Interpolation truncation factor 0
>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>     HYPRE BoomerAMG: Maximum row sums 0.9
>     HYPRE BoomerAMG: Sweeps down         1
>     HYPRE BoomerAMG: Sweeps up           1
>     HYPRE BoomerAMG: Sweeps on coarse    1
>     HYPRE BoomerAMG: Relax down          SOR/Jacobi
>     HYPRE BoomerAMG: Relax up            SOR/Jacobi
>     HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>     HYPRE BoomerAMG: Relax weight  (all)      1
>     HYPRE BoomerAMG: Outer relax weight (all) 1
>     HYPRE BoomerAMG: Using CF-relaxation
>     HYPRE BoomerAMG: Measure type        local
>     HYPRE BoomerAMG: Coarsen type        Falgout
>     HYPRE BoomerAMG: Interpolation type  classical
>   linear system matrix = precond matrix:
>   Matrix Object:   1 MPI processes
>     type: seqbaij
>     rows=22905, cols=22905, bs=5
>     total: nonzeros=785525, allocated nonzeros=785525
>     total number of mallocs used during MatSetValues calls =0
>         block size is 5
> Do you guys have any suggestion?  Is it possible that I am haven't initialized boomeramg properly? Or it is just my system equations that can not be solved by AMG?
> Sincerely,
> Dario
> On 05/16/2014 11:54 AM, Barry Smith wrote:
>> On May 16, 2014, at 10:46 AM, Dario Isola <dario.isola at newmerical.com>
>>  wrote:
>>> Dear all,
>>> I am investigating the use of hypre+petsc. I was able to successfully configure, install, compile petsc 3.3 with the external package for hypre.
>>> I tried to run it with the following options
>>> -pc_type hypre -pc_type_hypre pilut -ksp_type richardson
>>> and, although he did not complain, it does not solve the system either.
>>    Do you meaning it did not converge? At first always run with -ksp_view (or -snes_view if using snes or -ts_view if using ts) and -ksp_monitor_true_residual to see what is going on.
>> is wrong it is -pc_hypre_type pilut
>> Note that pilut will generally not work with Richardson you need a “real” Krylov method like GMRES.
>> Also the ilu type preconditioners don’t scale particularly well though occasionally they can be fine.
>>> To what extent is hypre supported by petsc? More specifically, what kind of matrices?
>>    If it cannot handle the matrix type it would give an error message.  Hypre uses a format like AIJ so you should use AIJ. Note that you can make the matrix type a runtime option so you don’t have to compile in that it is BAIJ.
>>> I am using a baij matrix.
>>> Thanks in advance,
>>> D
